View Full Version : Manual Transmission
- Mobile 1 Synthetic Tranny fluild
- Mcleod m800 (new transmission)
- 1-2 Shifting issue on hard launch
- Spec 3 + feels good ..
- shifter rattles sometimes while driving
- Rear bushing...T56
- Trying to install my Tick MC. Is my feed line upside down?
- monster level 3 and 9 inch equals carnage
- chevy t56 to sbf
- Were is the speed sensor located?
- Help with tranny removal.
- Tick Master Adjustment Question (Pics)
- new cluch help
- Can you hear your clutch engage?
- Help!!!!
- M6 carnage with pics, need parts.....
- If you re-install an old clutch,does it need another break in?
- Anyone using Kevlar Pilot Bearing?
- Master cyl fitment ?
- Squeaky Clutch...
- Shift boot RING
- Just got my Tick MC - I'm pissed
- new tranny mounts
- My MN12 T56 Carnage and Happy Ending
- Huge RPM Transmission Sale + Free Shipping!
- Clutch bleeding trouble. Space issue.
- After Clutch Install Problems
- 1995 t/a
- Bad slave???
- Hurst billet/plus
- TR6060 what one? 2 part numbers
- Built t-56 (viper shaft) build sheet
- Which Clutch would be best?
- Fidanza twin vs Monster M5
- Information on Liberty 5 speed swap?
- are ls7 and ls2 slave the same throw out distance?
- Purchasing JUST a clutch disc?
- How can i tell if i have a hurst?
- Noise when releasing the clutch pedal
- 2nd and 4th are gone :(. Rebuild or buy new? How much to fix?
- is this the right ARP bolts to get?
- what to look for when buying a used t56
- HELP, were can I find hydraulic fittings?
- monster pedal feel?
- Some changes at Monster Clutch Co.
- Monster Clutch Co. Holiday Sale!!!
- Flywheel Recommendations
- Firewall mount Master Cyl. What size would U use?
- Bellhousing supplier
- Stock clutch?
- wont go into gear after tranny install
- I cant connect the master to the slave... :(
- Clutch stuck engaged...
- stupid Master Cylinder question?
- t56 for sale with 35k miles
- 4th gear syncro going? Symptoms?
- who makes the shortest throw shifter
- Clutch not disengaging after missed shift Updated w/pic!
- decision on shifters
- M6 Clutch Issues, At a Complete Loss.
- Flywheel
- is this the pilot bearing ill need?
- Nasty grinding while engaging clutch. Loose Flywheel?
- M6 Build or Replace?
- out of town and the clutch went...
- F1 Dual Friction clutch?
- Question about reverse.
- need some flywheel help
- t56 length
- T56 locked out of 2, 3, 4, 5 intermittent
- ? for you t56 builders
- clutch suggestions for a truck
- Morris Motorsports...TICK MC and Stock MC
- Is the mount on a F-body T56 offset?
- Going about rebuilding my trans with 105k miles on it...
- Question about dialing in Lakewood scattershield
- Need wiring pics for M6 to A4---searched stickies
- A Tip for Bleeding - Ghettoing w/o a wobble
- Grinding noise in 1rst gear ? // TRANS fix NIGHTMARE story
- stupid clutch questions
- few conversion questions...no dice on search
- T56 Sensor identification
- ????? how you guys doin it 10.s on moter?????
- Whats the purpose of stop screws - B&m ripper shifter?
- What makes clutch fluid dark?
- New clutch and hydraulics and clutch stuck
- need a T-56 rebuild in ala/tenn
- Shifter question
- High Rpm Shifting Problems....
- what flywheel??
- Rear seal and bushing question
- clutch problems cont....
- Please help! Clucth disengagement issues - weeks now!
- Clutch Recommendations
- Would My CSC be the same ?
- kevlar pilot bushing?
- Problems getting into gear and reverse
- help please .....
- pilot bearing or bushing...
- Preferred fluid for T56?
- Do I really need that shifter boot???
- Ram HD still getting it done. 1.43 best this year/ 10.66 cam only
- f body / gto
- "Clunk" When Shifting
- Pilot bearing removal
- Help, I need a whole new transmission!
- Clutch problem (sorry its a little long)
- LS7 Clutch install
- T56 downshift vibration and 1ST thru 4th
- Just installed Tick master constant bubbles at 14kpa with mity vac
- McLeod Soft Lok
- Hurst short shifters please come in. New short chrome stick installed.
- what shifter comes stock on a 99 z28?
- Just finished the rebuild
- After my Spec 3+ Install, Engages low and creeps forward
- New clutch recommendation ?
- How to bleed your clutch with a TICK SPEEDBLEEDER (mod, please sticky)
- Help, I need a transmission shop in the Buffalo, NY area!!!
- Ford t-56 on a ls1 motor?
- Need help with my speed bleeder
- How To Start M6 w/out Pushing Clutch In
- T56 rebuild Quote
- Tranny fluid and shifter?
- Gto belhousing with camaro starter
- Quick Pilot Bearing Q
- Im constantly having clutch problems? Anyone do the hole mod?
- T56 Nightmare
- Odd clutch slipping issue?
- 04 GTO T56 shifter question
- which monster?
- Hydraulic problem?
- What does the reverse light plug on a T56 go into?
- centerforce clutch on a 94 t56 wont disengage!!! HELP!
- Help! Before i go on a shooting rampage!
- Difference in ls1 and ls2 shifters
- traill blazer ss shifter handle
- How to remove throwout from slave?
- Clutch pedal return spring
- This is why you eliminate weak links in tranny (pics)..
- cluctch or transmission problem HELP!
- t56 wont go into some gears!
- Zoom kelvar pilot bushing; which way do you install it?
- Complete T56 Conversion $875
- faceplated t56
- clutch pedal not returning
- Quick question after ls7 clutch install
- Clutch bleeding with Tick Speed bleeder
- Ever had problems with your black clutch peddle switch?
- Tick Master cylinder
- Problem installing T-56, please help.
- My T-56 and Engine hate each other.
- Spec 3+ in 408 w/ 250 shot?
- Gears Grinding When Clutch is Down?
- t56 in ls1 GTO?
- Dropping T-56 got Question
- Anbody running Motul RBF600 and know where to get it.
- PICTURES of measuring for shim, and bench testing setups, good tech....
- parting out 2002 trans am
- New SPEC Stage 1 high rev stuck
- Noise coming from my T56...help...
- grinds going into gear
- Inspection plate is off - what do I look for?
- A bleeding issue?
- Good shop to have a T56 rebuilt near Northwest Arkansas
- checking clearances when installing a new clutch
- shift throw questions is it serious?
- Who Red powder coats their transmissions?
- Clutch engaging with clutch petal on the floor!
- T56 rebuild: shaft shimming not required?
- LS1/LT1 T56 tail housing
- AAAHHHHH! I'm yankin this tranny apart asap.. Help
- Problems getting in gear.. PLEASE HELP!
- Monster Clutch finally got our stickers!
- The LS7 clutch that never dies.
- T56 Input shaft bearing question
- not quite sure?
- 4l60e to T-56
- Monster gettin it done!
- T56 question
- Steve@MONSTER Clutch CO....
- t 56 swap
- SNL Performance and Monster Clutch Co.
- I Think Its Time For A New Clutch
- lightweight flywheel
- Shifter relocation on a F-body LS1 trans
- Monster Stage 2 in! Couple of issues...
- No Clutch Pressure???
- Trans Prob
- clutch problem
- Is a C5 clutch master compatible to Camaro LS1 slave?
- Did the rev test and need some answers.
- Tranny Rebuild Advice
- t56 build up question
- Not engaging
- T-56 transmission & the LL8 4.2 I6 compatability?
- couple questions after Ls7 clutch install
- t56 front plate ?
- Replace 5/6 sychro? pics within
- ls7 clutch issues
- T56 rattle on during right turns
- Is it in the shifter or transmission?
- Snap ring and lock ring replacement?
- One hell of a guy..
- Clutch Issues, Possible air in the system?
- Clutch pedal engages too quick and is too low
- What years t-56 will fit in a '00 Z-28?
- Flywheel shim vs slave shim
- Trans cooler on a manual?
- yes another lt-ls trans thread
- Clutch replacement opportunity.....
- centerforce DFX....opnions
- clutch choice for cam/spray/boltons
- short throw
- clutch choice ??????
- Noob Question
- Replacing master cly
- Bore Size On Stock F-Body M/C?
- Guys in need of a Level 2 Monster
- t56 faceplated
- Clutch engages right off the floor? hard to take off in 1st, need shim?
- Spec stage 3+ and stock flywheel????????
- Help, clutch dropped to the floor and hydrolic fluid leaking
- Help putting 6 spd setup into Auto body
- SPEC stage 4 pressure plate. Can it be resurfaced?
- t56 how strong?
- Clutch Bleeding Prob, T56 swap
- Spec 2+ Cluch -- Pressure plate not allowing block to mate with bellhousing
- Engine to Bellhousing Stud Kit?
- Need Hurst Billet/Plus Handle Part#
- What hydraulic fluid do you use?
- i want to chance from auto to stick
- Better off buying a built T-56 or rebuilding mine?
- GM Syncromesh in cold weather
- ran into an issue with the auto to manual swap, need input
- ?'s bout my 6sp car
- I really want a 4 speed!
- clutch for 1000rwhp?
- Dual Mass Clutch
- couple questions on transmission reinstall
- Monster stg 3 issues
- Has anyone gone faster than 8.69 with a manual??
- What is wrong with this?
- Transmission shop in NY?
- T56 wont go in or stay in reverse?
- Problem at the track w/my T-56
- 5th gear/reverse grinding on M12
- Monster level 3 chatter
- trouble installing t 56
- Need T56 input shaft end play/preload setting.
- Clutch not disengauging!
