View Full Version : Manual Transmission
- New Trans Mount, New Noise?
- clicking sounds after clutch swap
- Poly trans mont???
- A4 considering M6
- what clutch to go with
- Have you seen this?
- Quick disconnect? not for me
- Clutch pedal issue...
- need help finding $0.50 part GM wants $70 for!
- Clutch for serious bolton car
- Ahhhh pops out of 3rd!!!
- I must have 1200 horsepower
- That's odd. 5-6 driven gear question.
- Shimming the Slave?
- Ram clutch
- Has anyone tried Pioneer 622817 trans mount?
- Pulled my t-56 tail housing off and found...
- Slave busted with only 1600 miles
- Is this the Master Cylinder or something else?
- Raptor shift lights? got issues.
- Trabsnission Squealing
- T-56 interchange
- 6 speed (manual) fluid change advise needed
- 5th-6th gear puller...anyone made their own?
- Won't Let Me Shift Quickly
- Spec 3X, Did you use the shim?
- Can I use synthetic gear oil in my T56?
- B&M Ripper install
- Wierd Vibration after new clutch
- D&D Tranny, acting up
- internal bumpstops HELP ASAP
- A4 to M6 conversion
- T56 gear ratios
- Can u buy the Z06 clutch minus the flywheel???
- which RAM clutch?
- anyone use RP Syncromax
- Why won't my clutch come back up?
- another Mcleod master cylinder question
- Clutch Madness
- Jerico questions, anyone do a swap???
- Blew the clutch?
- McLoed master cylinder users ...
- Master Cylinder part #s?
- m6 junkies..please help me bleed!
- Shifting Problem
- Master Cylinder???
- anyone had their pro 5.0 rebuilt?
- Just installed Spec Stage 3...First Impressions
- Am i paying too much to get my clutch done?
- grinding going into third?
- 600+ rwhp + cartek clutch = ?
- re-build your own t-56
- I've got 3 broken M6 trannies...going to make one good one out of them
- Spec 3 lightweight Pressure Plate, Help?
- Spec Stage III - Daily Driver - Master question
- RAM VDS users inside
- Vibration after clutch install?
- Go m6 or stay with my big stall A4
- How to determine bad slave?
- What the heck!?
- Crazy chattering after Pro 5.0 install
- M6 Short Throw
- Pro-shifting the T56
- Ever try and drive in 6th gear at 35mph?
- Flywheel ?
- Z06 Clutch vs Spec Stage II
- tranny 'scratch'?
- La-la-land between 3rd and 5th gear..
- Why so many flywheels?
- what clutch and shifters are best and whats the differnce?
- vibrations
- what is the Drill mod?
- T-56 shift forks
- WOT grinding, drill mod?
- people with pro 5.0, please read...
- info for rebuilding the mcleod master
- poly tranny mount backwards?
- shifting into reverse problems
- 98-00 to 01-02 slave cylinder difference
- How to shorten?
- Shifter Thread Size
- If you could would you switch from A4 to manual tranny if you had a 427 C5R LS6 motor
- Need Help with Drive line noise
- Did I mention @#$@% Centerforce?! More problems..
- Pulling motor out, how do i take off of tranny?
- NO more clutch pedal sticking to the floor!
- Hole in M6 Bellhousing
- Tranny Fluid: The "Why"
- Hard shifting issues
- Adjustable Master Help
- Opinions on Clutch and Flywheel
- Change rear main seal while clutch is out?
- Master Cylinder install question (in the process)
- Is it that important to balance?
- Just installed spec III
- Gear ratios for 6 sp ?
- 6sp. fluid
- Bolt size for pressure plate?
- Tranny gone bad?
- What kind of 5 speed transmission on a 97 S-10
- Star clutch from Speed Inc.
- About the recent spec clutch upgrade. (spec clutch owners come in).
- 500+ RWHP guys, which clutch?
- Can't shift from 6th to 5th
- HELP broke clutch
- Resurfacing the flywheel
- Telling the difference between old slave cyl and new?
- Flywheel question
- HELP-updated slave
- Tranny swap
- RAM clutch question
- Ways to quiet down shifter noise?
- F-body A4 to M6 swap
- How do i get rid of skip shift ????
- Thump while hard shifting
- Clutch Question
- ZO6 clutch price
- How to stop T56 from hitting tunnel.
- pro 5.0 question
- Throw out bearing
- What is Needed to Upgrade to Z06 Clutch?
- RAM 980 Disc is Awesome
- Broke something in my new RAM Clutch. Help...
- Are the uprgaded hydraulics prebled?
- Clutch engage/disengagment
- tranny leaking?
- GM Part# for Clutch Assembly
- New Clutch Need Instructions!
- GM made better trannies in July 02! Tell me if this is true.
- T56 grinds going into second
- Slave quick disconnect
- Explain T-56 to me? Im new
- pre 01' hydraulics
- Mcleod master helped a bunch..
- Anyone send a McLeod clutch back 2 McLeod for new disks?
- T56 Hard Shifting
- free beer!
- Car not going into gear
- Slave connector wont go back in.. Why??
- Many Problems after Dealer installed new clutch
- Syncro's
- getting really mad
- HELP me prevent 2-3 mis-shifts! Tranny came down 3 times!!!
- LPE has new Corvette hardened T56 main shafts in stock
- Directions for the Mityvac bleeding method?
- Reverse lock out ? got a question?
- slave cylender
- Anyone try or know about Luk gold series clutches?Feedback?
- Tranny goes into gear, but doesn't do anything...
- Lets say i put new clutch disk in backwards?
- Spec Stage III clutch Install - slave bleed?
- In the middle of A spec clutch install Quick Question
- Transmission Swap
- FOR SALE: 6-speed
- Very hard to put car in Reverse
- Spec 3 users
- RAM clutch vibration :(
- McCleod Clutch with stock slave AND master?
- clutch pedal hanging???PLEASE HELP
- jumps out of 3rd
- Help, slave quick connect is leaking fluid!
- ARP flywheel bolts?
- Help me pick a clutch
- Car won't go into gear at high rpm's
- Mcleod Master/Drill mod complete!
- Cartek any good?
- Add shims to slave cylinder?
- need some opinions..which is best for RACING?
- using the evil skipshift for good???
- Clutch Recommendmeants?
- quick ? on current install of master?
- What is the highest rpm the LS1 can handle?
- corvette flywheel
- Stupid Piece Of Shit Centerforce!! Problems inside..
- which master do you recommend?
- Got my clutch replaced under warranty
- tranny problem help
- Ahh!! Trany Fluid
- Do you need to purchase a new flywheel?
- Grinding 4th gear??? WTF? read this.
- Multiple Problems After Clutch Install.....
- WOuld you buys a used clutch?
- GM Clutch Part#
- Street twin install tips?
- what tag # should i be looking for on my t56 swap
- NE1 Drive a Jerico On The Street?
- Is it possible to buy a McLeod clutch by itself? No package?
- Which tranny M6 or M12 for Corvette drag racing.
- trani
- what exactly do I need for a new clutch
- Best price for Clutch/Pressure plate?
- Does a fried clutch disc negatively affect dyno numbers?
- Drill Mod Problem
- Third Gear Problems.. Help
- Organic Clutch and Nitrous ... Durable?
- drill mod - how does it affect driveability?
- HIgh RPM shifting...
- This all I need to put a ZO6 clutch in a 2000 car(part#'s)?
- SFI?? Yup...
- Fresh rebuilt trans didnt work - found out why..
- Bleeding Slave
- Clutch Tottally Screwed up or what?
- JSS on stock hurst......WOW!
- Clacking noise from tranny when shifting...
- Where to go for T56 internal parts?
- HELP PLEASE!!
- shift boot
- Diagnose my tranny problems please.
- SPEC III, stock rear end, tires, ANYONE?
- question about the skip shift!
- Be Honest. Whats Better? Stock Hurst with LSS or B&M Ripper?
- Anyone ever use LUK gold series clutch's
- lowdown on short throws and Pro 5.0s?
- T-56 pull....
- Change Tranny Fluid in a M6
- Hurst Blllet plus shifter
- Can you mix/match a clutch?
- Leaking Slave Cylinder ... Is Clutch still good?
- Throw out bearing
- about new tranny mount
- I've tried everything.. Car still won't shift...
- Tried Search but answers on this one. SDK or TDK
- Spec 3 ... few Qs?
- Clutch pedal spring broke?
- pedal on the floor
- Cant shift over 5K rpms
- Syncro?
- clutch problem i think !!!!!!
- Would this be my clutch slipping?? (Long post)
- Which tranny?
- Has anyone tried both the McLeod Single and the RAM 980?
- McLeod Single Disk slipping on high rpm shifts, is it toast?
- Gears or Rear end?
- spec 3 pressure plate torque spec
- Do I need to readjust my adjustable master cylinder??????
- Left leg can press 500,000 lbs
- Intermittent vibration through clutch pedal - non-LS1
- going from tremec to borg werner
- Clucth Strength
- Shifter thread
- slipping clutch on the bottle
- clutch install? how do...
- clutch is acting strange...
- ok how do you get this off
- Car Starts without Pushing Clutch down??
- Clutch wont re-engage at high RPM's???
- skip shift eliminator HELP!!!
- Ram 980 install; use the ram shims?
- mcloed vs spec?
- Just installed poly tranny mount, not what I expected
