PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 [82] 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Hydraulic or trany problem?
  2. Thinking about a LS7 clutch
  3. Master cylinder to Slave cylinder braided hose part number request
  4. Where are Pro 5.0 shifters made?
  5. whirlling sound
  6. Built T56 with a 2 Step?'s
  7. pics of my toasted clutch..sorry 56k
  8. t56 problem
  9. Questions on stock clutch
  10. Clutch Slipping Horribly/Vibration
  11. leaking bleeder valve, what to use ?
  12. Shifting problems
  13. Luk Clutch Kits
  14. Automatic computer in a 6-spd car?
  15. 5th gear
  16. Ram vds System
  17. Thread an f-body shifter to take Vette knob?
  18. Bleeding clutch
  19. Textralia rebuild?
  20. 3-4 gear
  21. Which Clutch for my application
  22. B&M Ripper, hard push over to REVERSE!
  23. Need Advice :)
  24. LS2/7 Flywheels Are Here!
  25. master cylinder
  26. Old-school looking Hurst shifter on T56?
  27. steeda shifter
  28. ls2 fly/ls7 clutch/pressure part#
  29. Is this clutch ok?
  30. replaceing clutch does flyweel need to be resurfaced?
  31. has anyone ever had this problem
  32. What the hell is going on?...NE ideas?
  33. T56 rebuilders in here please, aligning shift rails!
  34. Does your Exo-skel make noise (ring/rattle) when pedal is down?
  35. Need trans help asap!
  36. Quick T56 Tranny Question
  37. powergrip hd with stock flywheel?
  38. Question on removing transmission
  39. 2000 M6 Trans Fluid
  40. Funky Tranny on Drag day...
  41. where should a clutch start engaging?
  42. Problem removing master cylinder
  43. Researching clutch setups
  44. LS 7 clutch problems post here
  45. C5:grinds into gear, can clutch assy be in backwards?
  46. grinding into 3rd gear
  47. Thanks Byunspeed, textralia rules...
  48. Spec Clutch Owners In Here......
  49. McLeod SFI bellhousing worth it?
  50. Pro 5.0 shifter rebuild kit.... where to get one?
  51. Ram Powergrip Hd?????
  52. Help identify this sound!
  53. C6 LS7 clutch shifting probs...pilot bearing?
  54. A4 - M6 Conv. Noob. ?
  55. 1995 T56 flywheel question
  56. LS7 clutch and aluminum flywheel
  57. Pro 5.0 clicking?
  58. stupid newb question
  59. Quick Question - Vent Tube
  60. Wtf Man!?!?
  61. 98 hydraulic question
  62. Transmission harness
  63. Those of you who have REBUILT YOUR OWN T56 come in!
  64. how can i test the slave when its out?
  65. Spec 2+ first impressions and issues
  66. To power shift or not 2.
  67. Whats my T56/clutch/flywheel worth
  68. t56 not slideing in all the way
  69. headers?
  70. Bellhousing to Block Bolt size?
  71. slave cylinder?
  72. clutch cable?
  73. McLeoud Adjustable Master Cylinder
  74. Pilot Bearing vs Pilot Bushing
  75. ram powergrip hd help
  76. Final clutch question... i promise
  77. Reverse lock out plug?
  78. Need some input for reinstalling the driveline on my Z06
  79. Hard To Get Into Certain Gears
  80. 02 camaro slave upgrade
  81. Centerforce Stage 3?
  82. Drill Mod question....?
  83. LT1 T56 in a 1st gen camaro.....
  84. transmission noise
  85. V6 M5 to T56 swap
  86. spec 3 or ram?
  87. help real quick!
  88. Stock Reverse Non-Rebuild Question
  89. A4-M6 conversion question
  90. Cartek Clutch Users sill around?
  91. leaving it in a gear to park?
  92. Reverse????
  93. New RAM clutch and lost pedal??
  94. Shift light fuse
  95. ram clutch help--ASAP
  96. What are the chances of my clutch still being good?
  97. I need new OD gears, where to buy.
  98. clutch for ~750 wheel tq.?
  99. Which RAM and flywheel (is there difference between makes)? Drivability?
  100. Anyone notice harder shifting after Mobil1 trans fluid?
  101. Aluminum flywheel/LS7 question
  102. M6 clutch problem. Please help!
  103. Ram -> LS7 - Any thing extra i will need?
  104. Mcleod street twin question
  105. T56 torque rating?
  106. T56 rebuild: do I need the 1/2 outer cones?
  107. LT1 t56 Hydraulic issues?
  108. Transmission break in...
  109. OUCH! grinded
  110. Cant decide drill mod or not?
  111. Need a new Clutch! What one should I get?
  112. Air? Bad Slave? I'm puzzled.
  113. what size line?
  114. clutchless shifting: ruin the tranny?
  115. GM master cyclinder or Mcleod adjustable?
  116. what is the 6spd drill mod
  117. transmission noises any help plz!!!!!
  118. opinions on spec stage 3+ for LT1?
  119. Questions on Spec Clutches?
  120. A4 to M6 conversion
  121. Why is it so hard.....?
  122. why wont this work
  123. Couple clutch hydraulic questions (new master, new line...)
  124. what would it take to run a Tremec TKO600 behind a 6.0L?
  125. why doesn't my shiftball fit?
  126. Buying an 02 f-body M6 with 60k miles, what kind of maintenance?
  127. Mighty Vac clutch bleeder
  128. auto to manual quick question
  129. Middle of tranny rebuild, got some questions
  130. Just had Ls7 clutch installed!
  131. Assembly Grease
  132. t-56 Transmission Cooler ?
  133. Spec slave cylinder shim
  134. question on shift shaft assembly
  135. Proper way to break in clutch...
  136. anyone looking to do a tranny conversion?
  137. Please help diagnose Problem
  138. clutch pedal squeaks
  139. Any complete overhaul kits available?
  140. B&M SHORT Throw INSTALL >>>NEED HELP!!!!
  141. Heaver chatter with Tex OZ700
  142. Problem with 5-6 gearchange in a Cadillac CTS-V
  143. Circuit questions
  144. Clutch return spring.
  145. Clutch engagement high or low, which is better?
  146. Clutch Chatter - Ram Powergrip H.D.
  147. clutch problems!
  148. Where to get LS7 clutch hydrualic spacer?
  149. Master cylinder help
  150. Slave cylinder question
  151. Part number for Z28 black leather shifter ball?
  152. Bleeding Q
  153. Shifter goes in gear, but makes a sound right before going in??
  154. Slipping Clutch
  155. can't shift at high RPMS
  156. napa clutch
  157. rust on clutch reusable?
  158. heat wrapping clutch line my personal review
  159. Torque Specs for Exo-Skell Clutch??
  160. remote mount T/a
  161. Current master cylinder no restriction in line???
  162. Auto to Manual
  163. quick question on throwout bearing
  164. Anyone Ever Had a Textralia OZ700 Clutch Balanced?
  165. body shops own me
  166. anyway to tell?
  167. rebuilding my trans..
  168. Has anyone tried this way of bleeding your clutch system?
  169. Where to get not so common T56 parts?
  170. T-56 Rebuild time, NOOB questions!!! PLEASE HELP
  171. Pops out of 3rd and vibration
  172. t-56 in A4 LS1 camaro
  173. t-56 in A4 LS1 camaro
  174. HELP! need T-56 identification!
  175. Plug-ins on the Tranny?
  176. Clutch is shot
  177. trouble getting into 3rd
  178. DFX capacity?
  179. guys, i cant shift
  180. stage 4(+) t-56 ?s
  181. Can u daily drive a Exo-Skel?
  182. no 5th gear??
  183. Just replaced fluid in M6 now its notchy
  184. What's wrong?
  185. Spec Stage 1?? Anyone Running it?
  186. Finding an LS7 clutch kit???????????????????
  187. Trany and clutch master?
  188. sleeve cylinder on LT1
  189. Air in slave cylinder??????????
  190. Can you machine pressure plate? RAM clutch ??
  191. automatic to 6 speed
  192. Transmission mount help
  193. 2nd and 4th problems?
  194. trans bolts....torque specs?
  195. Tranny Issues
  196. Master Cylinder question
  197. Clutch pedal stays on the ground...
  198. Where do you guys shift at?
  199. Stupid f'ing Clutch Master Cylinder!!!
  200. ram clutch powergrip set any opinions on this clutch?
  201. which tranny
  202. 01-02 hydraulics require drill mod too, right?
  203. Now that my T-56 is almost done..
  204. T-56: what years to stay away from? know problems?
  205. What should i expect from Spec 3+?
  206. ls7 or ls2 flywheel?
  207. Stiff Reverse
  208. wiring harness question
  209. reverse lock out solenoid
  210. new clutch Breakin?
  211. Slight clutch slip on occasion?
  212. need clutch maybe???
  213. Down shifting to 2nd
  214. T56 Production Numbers
  215. clutch slipping
  216. T56 MAX hp/tq
  217. Shift knob
  218. So I acquired a borg-warner rebuild tool kit. . .
  219. ugly hoping.
  220. machining the flywheel
  221. Want to buy Centerforce clutch with Aluminum Flywheel??
  222. clutch problems...i think
  223. Clutch, Master, Slave? Need Help?
  224. Hard to get into gear at WOT
  225. Hard Gears
  226. This tranny is driving me nuts!
  227. Clutch recomendations for my 2nd gen ls1 Rx7
  228. front plate?
  229. mity-vac clutch bleed...in reverse
  230. Starting a m6 (how far do you push the clutch in)
  231. LS7 Clutch Break In Complete!!
  232. help pick parts. .
  233. Sticky Clutch pedal travel.
  234. slave or master?
  235. Favor... measure shift boot for me????
  236. Bad Bearing? T56Rebuilds/6SpeedInc help please!
  237. Replacing the master SUCKS!!
  238. m6?? whats better than stock
  239. whats the point of a dax number???
  240. does anyone have a slave cylinder spacer? i need one!!!
  241. Clutch Advice
  242. Who has the best deal on a Centerforce DF w Al Flywheel?
  243. What to do about my clutch
  244. bleeding clutch problem
  245. Pilot Bearing Issue!! NEED HELP FAST!!!
  246. Need Help Fast!
  247. ls7 clutch
  248. Possibly rebuilding myself, some questions
  249. Stock flywheel weight
  250. Shifting problem cured! Come in SPEC
