View Full Version : Manual Transmission
- Clutch Pedal problem?
- Clutch Install Woes
- spe clutch stage II or III
- Anyone make a shorter shifter shaft for the Pro 5.0?
- Do I need a new throw out bearing?
- Flywheel and Tranny Bolts
- Clutch
- whos better ripper or pro 5.0
- Can someone explain to me what my clutch is doing?
- RIPPER or PRO-5.0 ???
- What do you think the ideal shift point is?
- Thumbs up to McLeod
- T-56 question
- Mcleod Twin Disc.....
- Is this a good price for a clutch?
- problem with t-56!!
- Opinions on M6 vs A4?
- T56 Tools
- How much HP on a SPEC stage II clutch? Whos got one?
- What clutch flywheel??
- mcleod rev lok II or ram vds 980
- Can Ram clutch hold with 450 rwhp car ??
- clutch pedal problem
- Should I install my own clutch???
- RAM clutch...users
- anyone had d&d rebuild their M6
- Those who have shortened their B&M Rippers come on in (Please)!!!
- ram clutch disk help
- Clutch swap question... How do I stop the flywheel from spinning???
- T-56 Strenght
- T56 Rebuild
- Bleeding the clutch components - help please???
- Which DOT brake fluid to use in the hydraulic clutch system?
- CLUTCH SWAP!!! HELP
- clutch sticking to floor board
- Clutch Hydraulic Leak. Please Help me find it????
- Clutch question Please Help
- squeaky clutch petal
- Any McLeod REV-LOK II users?
- Grinding problems??
- CLutch Install problems.
- Throwout bearing
- Clutch Opinions with MY setup...
- Which Flywheel (urgent, ordering tonight)
- mcloud clutch users inside please.
- WHICH CLUTCH DO YOU RECCOMEND?
- Need part numbers for throwout & pilot bearings
- How difficult to change clutch?
- m6 groans
- Grinding / Vibration
- Need Ram installing tips and typical clutch questions
- What's the final answer on clutch balance?
- Ram clutch disc options....
- Need clutch installation directions...
- Mcleod master cyl. --> Slow leak inside car.
- What is the part # for Z06 clutch? slave?
- soft clutch pedal
- Squeaking clutch pedal
- M6 Bearings
- Grab your clutch pedal!!
- 99Z switching to Z06 clutch set up- any other alternatives?
- M6 trans fluid?
- Clutch/Tranny Issues
- M6 Cars: Top speed in 5th with 3.23s, 3.42s, 3.73s, & 4.10s?
- Ripper shifter or Lou's short stick
- Clutch pedal noise
- LT1 twin plate clutch?
- ripper or pro 5.0 shifter
- CENTERFORCE CLUTCH ??????????
- Clutch Pedal Pressure
- Grinding on fast shifts
- T-56 Replacement
- Dave With Cartek Please Answer My E-mails!!
- Aluminum flywheel with LS6 clutch, will it work?
- 01' vs. 02' Z06 clutch for F-body? &other clutch questions.
- Clutch ???
- Clutch problems
- Did the clutch line drill mod and still have problem. What is it?
- Unhooking clutch cylinder?
- clutch ?
- 3rd gear synchro gone again...
- How do I know when my clutch is done?
- Mike at ram clutches rocks!
- clutch question
- Performance difference in SLP clutch kit and ZO6 clutch kit?
- hardly any clutch pressure...
- Just bought a Mcleod Twin.. Questions
- clutch stuck to the floor
- Twin plate clutch & sfi flywheel?
- Clutch problems solved
- Stock flywheel resurfacing?
- T-56 Parts? Where to find?
- Any Ideas why my T-56 Grinds or Pops out in 4th gear
- stock clutch and rearend longevity w/ nittos?
- Advice on pulling T-56
- T56 Won't go into gear...
- TSB number for T-56 woes?????
- NEED A T-56 INCASE!!!!!
- clutch slipping
- Billet fly wheel on a bolt on car ??
- T-56 fluid, anyone ever use this?
- tranny crapping out ; synchro's fried?
- T56 reverse engagement... increasingly difficult?
- Clutch pedal on floor,...what happened?
- Cartek Clutch need help
- Clutch Experts... Help Me Out!!! Please!!!
- one question on my t56
- Swappin from an M6 to a th350, what are my th350 choices?
- How can I upgrade my T56?
- Simple answer needed - 3.42 to 4.10s with M6 - results?
- buying a used clutch - good or bad idea?
- Clutch pedal just doesn't feel right
- Ram Clutch, is this all I need?
- Clutch or tranny
- Do I need new master and slave for Ram Clutch?
- Quick start with my M6
- What clutch should I buy?
- Clutch Pedal Stays On Floor - HELP!!
- clutch pedal not fully re-tracting
- Whos got The Best Clutch Prices?
- ram clutch users,need help choosing what ram to use.
- Forward clutch not releasing?
- Opinions needed asap on clutch...
- Should i install new clutch before or after i dyno my car?
- Should i put in my new clutch in before i dyno my car or should i wait till after.
- Replacing 3rd gear in T56 under warranty have a couple questions
- Spec clutch flywheel
- Opinions on your aftermarket clutch...
- Clutch return spring broke, This happen to anyone else??
- How difficult is it to change clutch slave cylinder?
- Why only T-56??
- M6 guys with 4:10's
- Clutch choice
- Worth it to switch from Hurst BP to Pro 5.0?
- 6 speed stuck in 4th in ss camaro
- Clutch Problem on '02 with 500 miles
- Clutch engage / disengage adjustment?
- HELP! 2002 T-56 Problems
- Gravity Bled Clutch now there isn't any pressure!!
- How do you know when your clutch needs to be replaced?
- Opinions on the Spec Stage 3 carbon fiber clutch?
- TH350/T56 Weight Difference?
- On a Pro 5.0 shifter for a T-56, where do you set the shift stops at?
- McLeod Clutch Experiences Needed
- How do you bleed the clutch?
- Can a stock flywheel be used with the mcleod twin disk setup?
- lingenfelter clutch
- Drill mod on M6
- m6?
- did mcleod finally come out w/ sfi bellhousing?
- Question for all the M6 guys!
- is there anybody having goodluck with star clutch with over 500hp at wheels?
- LS1 clutches and balance issues...
- NEW! RAM Aluminum Flywheel
- How much for all the parts to rebuild a t-56???
- Intrest in Stronger T-56 Components?
- Master cylinder shaft broke "again".... I have Cartek Clutch + 01 GM master.. Read
- Am I hurting my synchros?
- 10.49 with and 1.47 60ft with RAM clutch system
- Another clutch question?
- Does anyone have a write-up on changing the fluid in a t-56
- Cartek Clutch Fluid Replacement?
- ZO6 clutch?
- Clutch Problems
- Spec stage 3, mcleod master cylinder, gm 02 slave cylinder
- HELP 3 T-56 trannies in 9000 miles
- Ram, McLeod, or Star Stage3???
- Resurfaced flywheel (.035") + SPEC Stg3
- t-56 failure:dealer ship voids warranty help fast
- Lockup clutch going bad,How can u tell?
- Clutch change
- what clutch?
- Clutch help!!!
- Spec carbon fiber clutch and aluminum flywheel glazed with 100 miles??
- T56 rebuild...
- T56 Rebuild, Synchro Still grinds
- how do yha feel about the Zo6 clutch? Let me know
- Cartek clutch problem
- clutch problem
- clutch fluid
- Anyone that has had their master cylinder off on their Clutch, I need help!!
- Anyone that has had their master cylinder off on their clutch, I need help!!
- stock LS-1 flywheel question
- New clutch - Cartek or Spec, help me decide *L*
- Clutch experts: Question on installing used Twin Disk setup?
- Some rookie clutch ?'s. Please help!
- At what power level is an aftermarket clutch needed?
- Is double-clutching "really" needed with LS1's?
- Spec Clutch Which Material?????
- Ram Clutch
- What's up with my clutch?
- How the heck does the clutch return spring go in?
- Lightened Flywheel or No?
- Help ASAP! Issue with CARTEK master cylinder (pics)
- Couple of RAM Clutch???
- 3.73's worth the $ in an M6?
- Flywheel Question
- SLP Shifter or PR0 5.0 or Ripper
- Best clutch ??
- 4.56 in an M6
- Is the Whole Forward Clutch assm
- flywheel recomendation
- Clutch break in period--- possible shudder??
- What is wrong with this SPEC clutch?
- MY MCLEOD MASTER WORKS!!!
- Email address for SPEC clutches?
- All users for SPEC clutch
- Light weight flywheel?
- Mcleod Master cylinder Theory.
- Cartek clutch with resurfacing the stock flywheel?
- Shifter comparison.. Pro 5.0 vs B&M ripper.. etc
- t-56 ?
- Some important T-56 questions...
- 4L60E clutches and bands
- Hays clutch vs LS6 clutch !!
- T56 question
- bulletproof t56 parts?????
- I need a new clutch ASAP
- Tranny opinion?
- clutch which one?????????????
- T-56 Leaks fluid from tail, with driveshaft out??
- Drill mod necessary for LT1 M6?
- Resurfacing the stock flywheel?
- Mcleod Master sux!
- Clutch squeal - normal?
- clutch????????????????
- Cartek Clutch Issues. Need Help Please
- Clutch Bleeding Made Easy - 1/4" Breaker
- Ls1-M6 Clutch Questions?
- Flywheel Shields for M6
- Cartek or Mcleod
- Which clutch should I get?
- M6 learning difficulty?
- t-56 rebuild pics
- T56 durability?
- Is it my clutch, hydraulics, or tranny ?
- CLUTCH STICKS to the FLOOR
- McLeod twin disk and >7k rpms???
- Anyone grease/lube splines during clutch install?
- Drill Mod on 98 Clutch MC?
- About to buy an M6
- Mcleod Rev-Loc II Exploded (W/Pics This time I promise)
- Clutch Noise... Pressure Plate? Plz Confirm..
- best clutch for my setup?
- Aluminum Flywheel Worthwhile???
- m6 woes
- Need advice on "clutch pedal play" - biggie or no biggie?
