PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Slave cylinder?
  2. prob w/ putting 5.3 in 5spd truck
  3. bm ripper question
  4. Master Cylinder Problem Again.
  5. Bleeding LT1 Master...
  6. Need 2 buy clutch and have some Q's
  7. Should I replace the cutch?
  8. hurst pistol grip knob!!!!
  9. c5-Gears grind now, no air in hydr. what can be wrong/damaged?
  10. Clutch prob?
  11. hard getting in reverse (Lt1 ) where is the fuse
  12. shift light tutorial
  13. Textralia OZ700 is in.
  14. i need t-56 parts!
  15. Bleeding the clutch, what fluid do I need?
  16. Clutch problems, (master/slave related)
  17. How do you know its time for a clutch??
  18. 600rwhp Daily Driver Needs a new clutch?
  19. Spec Stage 3+
  20. If you need a braided clutch line....
  21. New clutch for me : (
  22. First gear
  23. Factory Warranty and Transmissions
  24. Changing out the clutch. What else should be changed?
  25. t56 viper yoke part number?
  26. 97 camaro clutch bleed closed system
  27. Wiring short. Looking for wiring schematics.
  28. Pilot bearing or pilot bushing
  29. T-56 Question
  30. clutch fluid vs brake fluid
  31. clutch
  32. fly wheels
  33. Mcleod part numbers?
  34. Any difference between the factory Hurst and Hurst Billet Plus shifters?
  35. I have a couple important Lt1 t56 questions please help
  36. T56 Rebuild Manual
  37. crazy noises from the transmission?
  38. whats the difference between the Ram and the Mccloud adjustable Master Cylinder
  39. Teach me how to speed shift.....
  40. McLeod Single owners........ Inside...
  41. exo-skel help
  42. kinda feel like a dumba$$
  43. Cheapest place to get ls7 clutch ls2 flywheel?
  44. Popping out of Second Gear?
  45. Need clutch info...
  46. I need some parts, help!
  47. Help, I don't know what to do... Problem out of fucking nowhere for the lose.
  48. Attention!!spec I Got The Pics
  49. any tips or advice??
  50. SPEC 3+ concern/question??
  51. Remote Clutch Bleeder
  52. Mity Vac bleeding
  53. Best adjustable master cylinder????
  54. what is strong Ls1 t56 or LT1 borg warner
  55. Spec 4 or Spec 3+
  56. more clutch problems... slave/master?
  57. Oh no...
  58. t56, spun input shaft bearing race
  59. Transmission or Clutch??
  60. Question about burning a clutch
  61. Problems shifting to 2nd
  62. Clutch plate worn enough to replace?? (Pics)
  63. Best clutch kit >$400 for stock vehicle?
  64. clutch work...some basic questions
  65. strong 5 speed for cheap?
  66. Air in line?
  67. t56 oil
  68. am i getting ripped off?
  69. Leftover part?
  70. Help me diagnose my T56 problem
  71. centerforce TO bearing...
  72. which clutch bleeder?
  73. Mcloud Master Cylinder Q
  74. hydrolic line broke...fluid all over the clutch
  75. Help! Mushy and low clutch pedal AFTER races!
  76. Slave Cylinder Bleeder Thread
  77. Grinding, Ticking, Always missing 3rd gear, B&M
  78. stock clutch Hp rating?
  79. Worn Blocker Rings
  80. 4th and 5th gear slip?
  81. Slave cylinder line wont connect
  82. Pics of the carnage that was once my t56
  83. Part # for Factory round shift knob?
  84. Which shim is which?
  85. Question about ls7 clutch??
  86. Clutch releasing way to high
  87. ZO6 Slave work on an Fbody?
  88. 2001 Trans Am Clutch Hydrolic Q
  89. Ram Powergrip HD in C5 Z06
  90. Opinions on RAM Street Dual
  91. Exo Skel
  92. How much fluid to flush master cyl?
  93. clutch choice
  94. Somethings wrong!!
  95. are all slaves created equal?
  96. Clutch Leak
  97. break-in LS7
  98. someone please help
  99. A4 to M6
  100. What next?
  101. Skip shift prob???SpeedO??
  102. clutch problem
  103. Launching decent....
  104. Grinds Going into 6th
  105. Clutch bleeding problem.
  106. will t56 cags eliminator fit 93' viper's t56??
  107. new clutch
  108. Has anyone tried a M6 out of a LT1 car swap into an M6 in a LS1 car?
  109. 3rd Gear Problem?
  110. Whats wrong with tranny and clutch?
  111. 2nd puller
  112. 1-2 shift grind question...
  113. push clutch
  114. Problems with Spec???
  115. Do you think my clutch is slipping?
  116. lt1 vette clutch master cylinder ?
  117. Are gears the best way to improve low end
  118. NAPA Slave ?
  119. Xtd???
  120. HELP...with bleeding hydra tranny 91 C1500
  121. ExoSkel's back in stock @ SDPC!
  122. Need help/advice on clutch problem.
  123. Throwout bearing, and Pilot bearing
  124. Soft Pedal with McCleod
  125. Blue loctite whats the deal?
  126. T56 into C3 Corvette Hydraulic clutch help,
  127. pulled the clutch and found.....
  128. Diagnosing the clutch slave with engine out
  129. what flywheel for textralia clutch?
  130. Hard to get into gear on nitrous?
  131. Shifter rattle?
  132. LQ4 Engine in 99 TA
  133. Road racing manuals that don't break
  134. Hydraulics
  135. NEW Trans problems
  136. T56 converson questions into a 1986 IROC
  137. Clutch fluid boil, causing air in lines, and funny pedal feel?
  138. Napa clutch master cylinders
  139. Spec Stage 3 Clutch Prob
  140. Who sells the cheapest LS6 clutch?
  141. Still grinding going into 3rd
  142. Broke the tranny again
  143. Weird Noise
  144. TO bearing noise normal?
  145. clutch sticking to floor
  146. Help with no clutch pressure.
  147. a4 to m6 conversion
  148. ls7 clutch kit
  149. Anyone running the Spec 2+?
  150. lock up in 3rd
  151. Bellhousing
  152. DOT 3 or DOT 4 for clutch hydraulics?
  153. wich shifter
  154. Which brake fluid for the clutch??
  155. Diagnose My Clutch Failure - Pics
  156. did i install defective master?
  157. NEED HELP!! Clutch wont bleed fully, what can I do???
  158. Need Help Trans Hard To Shift Into All Gears
  159. lt1 clutch decision
  160. Mcleod
  161. Another grinding sound thread...
  162. whats all parts are needed for a conversion a4 to t56
  163. T56 troubles
  164. Thinkin about buying M6 car
  165. Torque Arm bolt into trans!! HELP !!
  166. Drill mod question...
  167. 2006z clutch woes
  168. clutch decision
  169. How does your exo skel engage on the street
  170. Slipping clutch
  171. what kind of fluid to use
  172. transmission question
  173. LS7 clutch gm part #
  174. T56 temperature while racing..
  175. Clutch chatter.
  176. spec 3 vs spec 4
  177. Clutch gets soft and wont go into gear....
  178. input shaft won't go into the Pilot bearing
  179. lost 2nd gear
  180. would a ws6 store shifter work on a b&m shifter?
  181. Help!! Reverse Grind :(
  182. hare to get out of gear what could it be?
  183. Do T need the Drill mod on a 01 TA
  184. New spec 3+ question grind (vette)
  185. hp rating for ls2 clutch
  186. Textralia
  187. Q: Fittings to convert quick disc. to an style
  188. VERY frustrated AGAIN
  189. Spec 3 slipping only 6k on it?
  190. linkage question
  191. Which master cylinder to upgrade to?
  192. NEWER LS1 clutch master cylinder
  193. problem with hurst shifter
  194. 2nd gear grind!!
  195. T56 clutch fork hitting Pressure Plate
  196. remote bleeder
  197. Replace tranny seal - driveshaft
  198. what kind of fluid?
  199. grinding without shifting?
  200. Need a Transmission Jack
  201. t56
  202. Clutch sticking to floor, wont go into gear..?
  203. Issues with shifting, please help....
  204. What is the purpose of slider keys?
  205. sharing my excitement...
  206. 1st to 2nd Gear Shift Grinding....?
  207. Need some help please guys.
  208. what clutch for 500-550 rwhp... ?
  209. Not enough tranny fluid?
  210. Problem with t56
  211. Where's the bleeder? '99 LS1 T56
  212. RSG Rockland Standard Gear T56 1200hp????
  213. Ls1 T-56 Behind BBC
  214. putting in spec 3+ but have to dyno next week, will I hurt my clutch
  215. New clutch BUT grinding in 1st Gear!
  216. Transmission Whine
  217. Rough Shifts T56
  218. Best way to bleed clutch
  219. Another Reverse Lockout issue
  220. Exo-skel anyone??
  221. tranny install trouble
  222. At a total loss......
  223. Clutch for my 95 LT1
  224. how does the reverse hook up on a T56?
  225. i need help with shifter in 96 trans am
  226. problems
  227. clutch pedal stop?
  228. i believe i found a good deal for a t56 setup!!!!
  229. drill mod
  230. What are the limits of the stock T56? [Tried to search, but it's not working]
  231. Any tips on quieting my Pro 5.0?
  232. My clutch just went out, flywheel question
  233. Car wont crank at all, seems clutch is stuck. any ideas??
  234. I made the switch from a4 to T56
  235. Missed 3rd... now this???
  236. stop bolts on 5.0?
  237. Clutch Noise
  238. CAGS skip shift eliminator
  239. Am I the only one whos tranny rattles like a little ***** in neutral?
  240. throw out bearing?
  241. Hard to get into gear.
  242. What is a high mileage t56 worth $$$ ?
  243. T56 Differences
  244. drill mod sucks
  245. Shifting Weirdness
  246. part numbers........ls7/ls2 pkg,slave,pilot
  247. Clutch and Flywheel
  248. Major Problem!
  249. what causes a clutch to not disengage??
  250. Just had LS7 clutch installed...and theres a smell?
