View Full Version : Manual Transmission
- Gear stick problem
- Safety interlock on trans mount?
- LS2clutch LS7 Flywheel
- Tranny mount
- T56 trouble.
- ive havent seen aything about the mcleod single disk
- LS2 + G-Force T-5?
- ls1/lt1 6 speed differences?
- Clutch fluid low, why?
- Tranny Fluid(T56)
- BAD! Violent shuddering and shaking with new clutch HELP!
- slipping spec stage 3
- wat fluid to put in the t56?
- t56? need help
- need a steel flywheel-what kind?
- Which Slave to get?
- Need distance: Release bearing to P. Plate
- Problem with Good clutch spinning
- Vin number on t56?
- trouble with 3rd gear
- how hard to replace clutch master cylinder?
- T-56 Tranny GURUS in here!!!
- Having trouble w/ Standstill burnout
- MASSIVE t56 install problems trans wont slide in all the way
- How do you know when the master is bad?
- Pro 5.0 + Hurst Return Springs?
- need a good clutch
- please help keep blowing slave cylinders
- Anyone know a shop in Joliet, Il?
- Bad master seals ?
- Slave Cylinder Grenaded!
- Part# Help For new clutch!
- Clutch Master Cylinder I.D.
- ws6 store short stick
- Heat related???
- T56 Gear Grind Issue
- Rear main leaking... do I need to replaced my new clutch because of it???
- Clutch: Ram vs. Ram HD ????
- Done with clutch install one problem shifting into second
- Pilot bearing vs. bronze bushing
- Where to get flywheel resurfaced?
- Wont go into first above 30
- Unsure of Problem
- $200 clutch and 13lb chromoly FW are in
- sometimes not going into gear???
- what do i need?
- Feel of LS6 clutch.....
- 2nd instead of 4th?
- Simple Question:
- What are the symptoms of a loose flywheel?
- swapping to m6
- Very Notchy T-56-Sounds like wooden blocks colliding, time to go for a fresh rebuild?
- clucth
- should i use shim on new clutch?
- which clutch for my turbo? (annoying question, i know)
- hyd. clutch problem
- Shift Point/Shift Light Question
- Installed the Pro 5.0
- t56 tranny/cags problem
- ls2/ls7 clutch part numbers
- Set or remove stops?
- Anyone Know Where I Can Get A Good Clutch For A Good Price
- T56Rebuilds.com Special
- what the f$$k is up w/ ram hd
- M6: Did you balance your FW+PP?
- I didn't disconnect the hydraulics... need to bleed?
- Fastest clutch swap
- Oil on my flywheel bolts
- Clutch help
- just breaking in? or f'd up???
- clutch peddle
- clutch parts
- 4th gear problems
- HELP! Will all my new parts work together??
- Who makes the best clutch set up for
- McLeod Question
- Clutch not disengaging all the way at WOT
- Take a Guess...
- shift knob dilema
- Picking up a used clutch and pressure plate, what else do I need?
- Tail Shaft Bushing Part Number?
- Problems with reverse
- Getting my First F-Body T56 Clutch
- T56 problems 4the getting stuck.
- out with the old, in with the new (Clutchmaster)
- Ram clutch...use their flywheel or stocker
- pressure plate torque?
- What's the definition of the LS2 Clutch?
- LS2 Clutch/Flywheel **I NEED THE PRO'S!** (oh yeah..SPEC 3 SUCKS!!!)
- 1LE mount?
- Can I start my engine without the trans. in?
- 5.0 Pro shifter on a Viper trans
- just needing a little help for a friend
- Clutch ?
- Mechanics school??
- Need Customer Photos
- GM tranny mount
- Flywheel holes dont align need input...
- Will I need more parts for my rebuild?
- Help!!
- Resurface the flywheel or not....
- Do I Need A New Clutch And What Kind
- Transmission Jack suggestions, PLS
- Ok
- can i start my car with no tranny in?
- going with a ls7 clutch kit! 2 questions
- Clutch?
- please tell me WHAT THE HELL IS A 2 STEP?
- question about mcleod clutch please help
- 2001 SS vs. 2002 WS6
- Can't get mity vac to work. Followed doc
- Anyone use this ......
- Hows my RAM Look? Pics (56k suk it)
- Stuck clutch pedal.
- clutch for 600rwhp
- t56rebuilds?
- Hurst Shifter has play in it...
- Spec 4 clutch is in - The question now is...
- Tranny Mount Question....
- How Much Is A Gm Master Cylinder?
- Low on fluid?
- weird problem
- approved bell housing?
- Crossmember Question
- looking for weights of different clutch setups
- RAM vds900 series
- why does this dick harrell prototype use a zo6 clutch?
- Slave cylinder... stay stock or get aftermarket?
- problem
- Stickey Tires = Smoked Clutch
- double clutching?
- Does my clutch look ok??
- Trans install question
- Correct position of clutch pedal?
- How bad is this clutch (SPEC Pics)
- reverse lights
- is there a master cylinder and slave cylinder i can use with spec besides $$$ mcleod?
- Effort During Shifts?
- high hp clutch?????
- LS7 clutch with coni-seal slave cylinder?
- LS6 clutch kit
- clutch master and hose part #
- trans?
- Shifter
- clutch seems to slip after bleeding it
- My clutch is slipping...
- Shifter popping outta gear..help
- Clutch kit suggestions, pros/cons
- Anyone using a mcleod single disc on lt1? Come in
- Centerforce DFX
- help removing the piolit bearing please
- Bell housing still ok to use?
- clutch gone?
- Which clutch should I buy?
- How long for break in --spec 4
- Can't Shift after Mcleod/LT4PP & Trans swamp!! PLEASE HELP
- Spec Stage 1
- what do u need for a new clutch?
- Clutch gone! what and where to buy?
- Ram Powergrip is slipping
- Is this my hydraulics shortcomings or clutch.
- shifting at higher RPM
- intense vibration while in gear
- clutch bleed
- Who makes SPEC's flywheels?
- AAAGGGHHH!!! t.o. bearing not mounted on slave
- go stick or stay auto?
- Ls7 grabs anything i throw at it!!!!
- What gear ratio
- T-56 shifter bolt thread size
- 02 t-56 vs 06 t-56
- Tranny for a 454?
- Reverse locked out-Searched
- Automatic To Manual
- T56 Input Shaft Length
- Installing pilot bearing please help
- Just got my new tranny back in.
- Synthetic Trans Fluid.........
- t-56 rebuild help
- driven gear TSB?
- Clutch Problems
- T-56 for 800whp tops, viper trans or build it?
- Aluminum Flywheel
- Any feedback on spec s5 clutch?
- Where to buy a Lou's short throw shifter?
- Strongest T56
- Viper Internals
- Need Help Quick!!
- Difference between 01 and 02 shifters?
- T-56 Measurement Request
- Strange problem, all advice appreciated
- tranny problems
- What are torque specs on PP bolts for Textralia clutch
- Tight fit on crank bearing.
- Possible Tranny Problem
- WS6 Store Short Stick
- What is a Good clutch for a reasonable price for a 98 trans am with 400 HP
- Bad SPEC pressure plate? Doesn't fit Flywheel...
- Need help fast.
- B & M Shifter Replacement Ideas?...
- T56 Questions
- skip shift solenoid
- Clutch disc question
- Black fluid/sludge coming from inside bellhousing, HELP!!!
- McLeod twin disk anything bad?
- More power--Harder to shift?
- Pro 5.0 Shifter
- Anybody going to NvsS 6speed
- wont go into 3rd at WOT, cant tell if tranny issue or hydrolic issue
- Are LT1 T56 Pedal Assemblies the same as the LS1 car assemblies
- Dual Disk + Billet or Aluminum Flywheel?
- Very tough to get into reverse
- Textralia installed(corvette)
- Squeeking sound while going into gears
- 1st gear stick??
- LS7 clutch upgrade - throwout bearing?
- Possible to install C6 Z06 transmission to a C5?
- ls7 clutch
- Stuck in 5th
- Guys with 500whp+ w/ T56 come on in
- Clutch slip @ 2500 miles (Rear Main or Crankshaft plug??)
- RAM VDS 900 or SPEC 3+ ?
- Air in the system?
- Bump stops on a pro 5.0
- Should I shorten my B&M Ripper even more? (no 56k)
- Opinions of SLP clutch kit
- downshift problem 94 T56
- Clutch questions.
- Viper 30 spline conversion
- New Clutch, 250 Miles, Shifted, POP, Petal on Floor...
- Spec 3+ Install Complete
- Best adj. master?
- What Shift Knob Do You Have?
- WHat does it take to use a Viper t56
- Does tranny fluid go in here?
- Where can I find Shifter bolts?
- ripped teeth off input shaft gear... oops
- Light flywheel easier on clutch?
- 12" Centerforce DF...
- Anything special about Ram slave and adj MC?
- scatter shield
- textralia clutch for LT1?
- Who has BEAT on an LS7 clutch, details please
- Replace input shaft bearing?
- Most streetable clutch BESIDES Textralia?
- will a 2001 z06 clutch fit my 1998 trans am????????
- stock transmission
- Tranny/Clutch Problems.
- Trans/Clutch problem diag. Need help.
- Anyone with a Textralia please respond
