PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 [123] 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Clutch or tranny broke?
  2. T40 bolts on tranny
  3. Newbie To Clutches..please Help Me!!!
  4. texh artical on trans removal(anyone have one or a place to fine one)
  5. How could this be true
  6. Help clutch or trans problem
  7. Trans rebuild help
  8. Need help now please!
  9. Found a sweet/ lightweight sheild.
  10. Mcloed Clutch
  11. Grind when in gear????
  12. Problems shifting???taking to much time
  13. T56 is slipping in high gear at low rpms???
  14. 1ST and 2ND "rattle can" noise?? When engauged, please help
  15. Transmission won't disengage (need input on hydraulic failure)
  16. Help with possible tranny damage
  17. Speaking of strange noises....
  18. dry tranny
  19. Help with bleeding and the drill mod...
  20. Spec 3 Break-In
  21. Can my clutch be adjusted?
  22. T56 rear cone bolt pattern?
  23. Is there such thing as a manual trans cooler ?
  24. M6 to A4 and A4 to M6 Conversion info requested
  25. Mcleod Clutch
  26. Can some1 make a sticky?
  27. What is that frickin' noise!!!?
  28. Where to Go for Stout T-56 Rebiuld?
  29. No pedeal?
  30. Rebuilt T56 and still shifting problems Master bad?
  31. McLeod Twin Disk Torque Specs and Clearances
  32. which shifter do you like.
  33. Bleeding or Bad Master Cylinder
  34. Centerforce Slave, Anyone using?
  35. A4 to M6 wiring - PLEASE HELP
  36. 96-98 SLP Hurst shifter work for an 02?
  37. 2 small (hopefully) problems...
  38. What's causing this. Clutch noise(not chatter)
  39. clutch master cylinder install/questions
  40. Which Flywheel
  41. Spacer that comes with Spec clutch?
  42. stock hurst and short stick
  43. FYI - a new slave cylinder solved my shifting problems
  44. Shifter or Tranny?
  45. Shifter or Tranny?
  46. 2 Tranys blown for no reason????
  47. Help w/ Squeeling Sound
  48. No presure
  49. Best Clutch for the buck
  50. Those with Pro 5.0 chime in please
  51. Probs with my Tranny
  52. Bleed By Friday Night
  53. RAM 980 Slipping After 1000 Miles
  54. Skip Shift Eliminator?
  55. Shifter won't go into gear?
  56. McLeod is here!! Question
  57. Whats in the new 03 / 04 cobras and will it fit ??
  58. why not cartek?
  59. "Help" New ram clutch and wont go into gear
  60. thinking of upgrading to a spec stg 3, do i need a new flywheel?
  61. Ram 910/402 PP and Resurfaced Flywheel
  62. clutch wont disengage help
  63. Ram 600 series and G5X3
  64. Shifter Rattles
  65. Anyone use this Place?
  66. What just fell out of my Tranny?
  67. Clutch is GONE
  68. ram stage 4 910 sucks on street / get better?
  69. m6 shifter wont go in reverse....HELP!!!!
  70. Pilot bearing upller tool from autozone...
  71. Clutch Blown. where to get another cheap
  72. What's it take to fix the clutch problem?
  73. How the hell did you take off the bellhousing??
  74. Bad Throwout Bearing???
  75. What is the part # for GM syncromesh?
  76. is it my trans or my rear?
  77. Pics of RAM 910 VDS
  78. quick drill mod question
  79. clutch recommendations
  80. Spec and McLeod and RAM oh my!
  81. clutch went to the floor?
  82. Second T-56 blown
  83. Cost of rebuilt T56?
  84. Pilot bearing needed for clutch install?
  85. pedal feel after drill mod
  86. aluminum Flywheel?
  87. Upgrading to aftermkt clutch for 1st time - What other parts do I need?
  88. I'm considering piecing together a Ram clutch system and have a couple of questions
  89. Need Clutch Help
  90. CAGS and fuel economy
  91. bigger reservoir tank?
  92. Clutch Sticking
  93. help. noise in 1st and 2nd under light acceleration
  94. Good IL Trans Guys
  95. Performed drill mod, did I drill far enough?
  96. Will stock driveline parts hold if...
  97. Balance issues - whoever's clutch you use
  98. Best place to buildup T56
  99. What Stage Spec is this clutch? (pic inside)
  100. Anyone ever use D & D?
  101. The never-ending clutch dilemma
  102. Flywheel Clutch Dilemma
  103. Pedal Height VS: Engagement Point
  104. M6 Swap...Quick Wiring Question
  105. putting a iron block that was in a auto truck in my M6 SS?
  106. clutch pedal sticks to the floor
  107. warrenty info on spec?
  108. Lenco or Liberty
  109. Sanity Check my clutch decision, please.
  110. bleeding new slave/ blew out seal???
  111. Which LSS model to get?
  112. How much use have you got out of your LS6 clutch setup?
  113. What's the weak link?
  114. HELP: Drivetrain vibration.
  115. clutch wanted
  116. How to tell which master!?
  117. 3rd and 4th gear grinding...(THE ANSWER TO HOW AND WHY)
  118. Clutch Install Costs?
  119. I need a budget clutch...
  120. broke my spec III?
  121. Help find me a thread/link on clutch install please
  122. rebuilt m6 stiff to go into gear after racing?
  123. What Are Signs of Crappy-Bled Clutch Hydraulics?
  124. All Aftermarket clutch owners come in
  125. T56 Master cylinder vs Slave cylinder info
  126. What slave cylinder do I need to get?
  127. What kind of clutch is this ?
  128. Is this the right one?
  129. using a Viper T-56 in our cars?
  130. GM part number for LS6 clutch kit?
  131. looking to buy a camaro.. what to watch out for in the t-56?
  132. Do I really need to get a new flywheel?
  133. RAM 980 Chattering
  134. question about 1/4 times
  135. Do I need anything else?
  136. Bit the bullet and ordred a Mc Leod twin disk
  137. Tranny question answers please
  138. Spec 3 Owners please...come inside
  139. Dropping the Transmission, How HARD is it??
  140. Feelin' stoopid but...
  141. Final word, whats the fix for a mushy pedal?
  142. slave cylinder bad?
  143. gto knob on stock shifter???
  144. About to order clutch, should I get kevlar or carbon?
  145. 3rd gear grinding, 3rd & 4th gear rattling noise
  146. how much did you cut off the pro 5.0 shifter?
  147. Mcleod Bellhousing???
  148. gm part # for slave cylinder
  149. Hurst black 6 speed pattern shift knob pic
  150. Need a TailShaft housing
  151. Slave / Master Problem????
  152. Just ordered Lou's short stick!
  153. sticking in reverse.??
  154. clutch problems
  155. Spec 3 = better 60ft. times?
  156. What kinda 60ft times???
  157. T56. help
  158. which short throw shifter is better?
  159. Couple easy questions pertaining to replacing the clutch and slave cylinder
  160. Spec Stage 2 Problem; Slipping After 2000 Miles
  161. Broken output shaft
  162. Rebuild 6 speed 2k C5 - Do it myself?
  163. actualy travel length of rod on master???
  164. which way do i turn my adj master
  165. replacing clutch...Is there anyone that recommends the Spec Stage III
  166. Shift Point?
  167. What Kind of clutch to get???
  168. The replacement!
  169. What possible causes for a changing engagment point?
  170. Opinions on the best clutch/shifter setup!!
  171. Bleeding Spec 3.
  172. Bleeding my Clutch? Spec 3
  173. Need a place to get a built mn6!
  174. Rear-end gearing?
  175. Syncro application ? All t-56's the same ?
  176. Decel noise just started yesterday..
  177. what is the best shifter?
  178. HELP! tranny mount....
  179. Could my trany handle 425hp?
  180. rebuild tranny
  181. spacers or shims, do they help
  182. T56 Swap for a Cleveland.
  183. Help...
  184. Spec Clutch sliping.
  185. T56 rebuild
  186. ls1 noob with trans problems
  187. What do I need?
  188. Should i M6 it?
  189. How Much HP will the T-56 Handle?
  190. LS1 T56 jumping out of reverse! HELP!
  191. Cluthc engagement points changing
  192. making M6 Solid?
  193. Spec clutch chatter
  194. Will a RAM powergrip require an adj master or shims?
  195. 95 Camaro LS1 retrofit
  196. how to remove master cyl in vette?
  197. New Clutch+Flywheel- Balance??
  198. Ram VDS in LT1
  199. opinions from those who have ran BOTH 3.73's and 4.10's.
  200. slave cylinder
  201. Grinding in first gear.
  202. Tranny ?
  203. Tranny Question??
  204. got new clutch in,but now need help with trans.
  205. Attn San Antonio area guys clutch prob
  206. Details on A4-->M6 conversion
  207. G force T56
  208. "Clutch needed" post, again..
  209. CTS-V Drill mod? fluid?
  210. how to remove line for DRILL MOD
  211. ram stage 4 910 need adj. master?
  212. Slave Cylinder Warranty work ? Or not?
  213. DTC 0704 - Any Advice?
  214. 7,000 rpm shifts...shift light, or tach w/ light?
  215. Mcleod Lt Dual Disc Clutch For Sale!!
  216. Shifter installation problem! Help!
  217. Clutch Pedal not coming up all the time
  218. jss from factory z28 shifter
  219. SPEC St 3 on ebay????
  220. Anyone in IL looking to help with Tranny
  221. instaling a new bearing in the front of the input shaft on a t 56
  222. master cylinder rod and retainer clip ?
  223. Need help finding a stupid little part
  224. wasn't the shift fork...
  225. how to bleed clutch/ new slave
  226. Buschman clutch bleeding procedure
  227. clutch wants to grab WAY to soon.. need help
  228. Dumb problem and i'm tired of it!
  229. Rock Crusher 4-speed In A 4th Gen?
  230. 3rd gear grind?
  231. Confused on gears and trans.
  232. Clunking sound?
  233. need help with clutch!!! stuck...
  234. Nasty Grind!
  235. has the cartech clutch been forgotten?
  236. question
  237. RAM 980 Impressions
  238. Who makes billet slider keys?
  239. Clutch Problem Help
  240. Do I need a rebuild?
  241. need a clutch!!
  242. Auto to a 6 speed? anyone want to trade ;)
  243. Car STICKS at certain RPMs?
  244. Still have problem after bleeding clutch
  245. Clutch Bleeding and Dirty Fluid!?!?
  246. Another clutch question??
  247. Spec 3 In; Shifting Problems
  248. Raidiator Question
  249. Clutch Inhibit Switch and RAM 402/980
  250. 5th gear question... 6th seems fine
