PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 [91] 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Reverse... Fuckin t56's haha
  2. Louis's short shifter problem
  3. WTB LS1 T56 Front cover
  4. 02 Slave Cylinder Spec's
  5. lt1 to ls1 t56
  6. anyone running a ram street dual?
  7. centerforce dual friction??
  8. Fall Special Stars October 12th- 31st
  9. Unkown tranny problem?????? HELP HELP
  10. What Type of Clutch to Run With
  11. Suggested Shift RPM Above Peak HP
  12. Do a Steel or Aluminum flywheel?? ls1 Fbody
  13. Lets answer this once and for all: Which clutch for 600rwhp?
  14. What Clutch do you guys recommend???? 550rwhp
  15. Any one have the SPEC 3+ in there ls1 fbody?
  16. Clutch and Hydraulics...
  17. Noob with clutch question
  18. T56 Rebuild Q's
  19. Another RAM or the Ls7
  20. Price guesstimate??
  21. Aftermarket master/slave setup
  22. clutch master issues (possibly)
  23. GM's, Viper's and Ford's T-56 ?s.
  24. help! driveshaft won't go in....
  25. T56 no 5th/6th or downshift after "rebuild"
  26. 402 and a M6
  27. RPM transmissions has anyone tried these?
  28. is the cartek clutch strong enough for 450-550 to the ground
  29. shifter squeek!
  30. Ls7 Clutch
  31. clutch help wont disengage
  32. Need Info
  33. Spec Warranty?
  34. Cant go into Second Need Help
  35. New Clutch Question
  36. Clutch Problem
  37. CLUELESS ... please help ... clutch problems...
  38. clutch slipping
  39. may sound like a stupid questions but....
  40. Friend wants to use a T56 with a 500+ci BBC... I have ?s
  41. T-56 questons
  42. if a car is tough to get in 1st from a stop...
  43. What's the difference between an Adjustable Master and a Clutch Pedal Stop?
  44. spec5 install ???'s
  45. How do spec clutches feel?
  46. Fall Special- Need Input from everyone!
  47. New Centerforce DFX Clutch???
  48. question about shifters
  49. 6 speed trans problem help!
  50. Clutch is sticking!
  51. spec stage 3+
  52. replacing master
  53. How long will my stock ls6 clutch last with a 150 wet shot?
  54. Clutch Pedal is bleeding off pressure... WTF?
  55. clutch squeaking!!!!
  56. stock tranny with spec 4 question
  57. Tranny fluid
  58. paper/carbon fiber syncros?
  59. Having Clutch Problems
  60. Clutch? Tranny? or a combo of both?
  61. LS7 Clutch Install Questions
  62. Clutch/Trans Problems 98-00
  63. Fresh rebuild Car jumps out of 6th gear
  64. Changing tranny fluid
  65. Transmission/Clutch Know-it-Alls. HELP! lol
  66. how much hp/tq can the stock ls6 clutch handle?
  67. lightweight flywheels and heavy duty clutches
  68. Spec Stage 3 Install few questions
  69. Which clutch to get?
  70. Output shaft seal question!!!!!!!!!!
  71. T56 Gurus get in here !
  72. possible GP on LS2 aluminum flywheels
  73. shifter clunk-clunk?
  74. Exedy twin slips on a 150 shot - rebuild time?
  75. Sloppy clutch pedal...
  76. Need some advice... Is it my driving? Or the clutch setup???? LS7 time?
  77. M6 question?
  78. Another clutch engagement
  79. Textralia Clutches
  80. whats the drill mod??
  81. Line Up Tool Help!!!
  82. Grinding going into 3rd after clutch install
  83. Throw out Bearing
  84. clutch wont bleed!!
  85. Trans??
  86. shifting problem
  87. Manuel Swap
  88. Centerforce Q's
  89. master cylinder or shim?
  90. Rebuilding tranny and have a question.
  91. T56 to '84 SBC??
  92. Rebuilding the T-56
  93. LS7 vs LS1 Clutches
  94. stock tranny question?
  95. mn12 tranny
  96. just installed rebuilt tranny have ????
  97. I just have the clutch disk!
  98. ls7 from byunspeed
  99. clutch is slipping time for a new
  100. WRU Byunspeed Website???
  101. WOT grinding issue
  102. Whats the best clutch for me?
  103. Tranny Problem
  104. Master cylinder
  105. B&M Short Throw
  106. Cores Needed
  107. 3rd Gear Vibration -- Worn Clutch or Transmission Problem?
  108. stuck in 4th!!
  109. New slave, break in???
  110. Shifter for 01 SS
  111. Spec Stage 3+ questions
  112. Help! Clutch won't disengage!I think!
  113. Camaro SS shift knob
  114. napa clutches
  115. ls7 STILLL isnt here yet!
  116. Driving Schools?
  117. 2 Wks Left on Special
  118. Pressure (Power) Bleeding PSI
  119. Clutch recommendation for mods listed
  120. Looking for a good forum to discuss the T-56....
  121. Which Poly Trans Mount?
  122. T5 on an ls2? what does it take?
  123. Need HELP fast!! pulling tranny STUCK!!
  124. To use textralia or not?
  125. Stock Flywheel Bolts or Crank stronger??
  126. [b]slave Shim And Drill Mod[/b]
  127. Bad Slave
  128. clutch issues
  129. Very hard to get into reverse.........any ideas???
  130. Anyone Running a SPEC 1?
  131. My toasted Spec III clutch, PICS inside.
  132. what clutch do I need
  133. Is there a special flywheel to put a T56 on a 6.0? Stock one won't work...
  134. Whats a better short throw Pro 5.0 or B&M Ripper??
  135. the best t56 rebuild parts
  136. T56 Problems.
  137. kinda puzzled
  138. stright cut gears?
  139. Calculating Gear Ratios
  140. Tough shifting M6..I learned something
  141. transmission problems
  142. how hard the install on shift forks and slider keys??
  143. whine coming from trans?
  144. My Mcleod Adujustable experience...
  145. I think my spec bit the dust
  146. Clutch ???'s
  147. Reverse gear locked permanently.
  148. clutch engages/disengages on floor board? pedal is fine.
  149. Spec 3+ due to be installed, do I really need a new Master Cyl?
  150. Ripper shifter works, then doesnt work WTF??
  151. T5 5th and Reverse are inop
  152. Ram HD with a stock flywheel??
  153. A4 to M6 swap need help
  154. Ram clutch question
  155. Blown Transmisson?
  156. slave cylinder over exstending, how to fix
  157. Need help diagnosing my clutch problem.
  158. High rev clutch slip
  159. Stronger transmission
  160. Different Slave T56?
  161. Where can I get this shifter knob???
  162. M6 to A4 conversion question's
  163. Master Cylinder
  164. LS7 clutch/LS2 Flywheel
  165. Clutch slipping after 4000 miles (WTF)
  166. tranny swap - general question
  167. What clutch will handle 600rwhp?
  168. Bad Slave clylinder?
  169. clutch burning out?
  170. [97 C5] What does a clutch anticipate switch do?
  171. Light Fly for LS6 clutch?
  172. Broken Tranny Mount?
  173. Anyone have the T56 Isolator cup part#?
  174. Clutch went out this morning. Extent of damage?
  175. Clutch on Floor Under Hard Acceleration
  176. billet flywheel
  177. Clutch is Rock hard
  178. LS7 Clutch and Flywheel.
  179. shifter vibrating in 3rd
  180. Will an adjustable master create more seperation? Need Help! Cars down for a month!
  181. Clutch Won't work!!! HELP!!!!
  182. Pulling transmission how hard??
  183. Tex. vs. RAM
  184. thoughts on the pro 5.0
  185. Fallin outta fifth gear
  186. Flywheel?
  187. What happens if you don't bleed the system after a new clutch is installed?
  188. automatic transmission shifter button
  189. clutch
  190. HELP PLEASE Ram VDS 910 Clutch problems AGAIN
  191. LS7 Clutch install help
  192. Fair price to have a clutch installed??
  193. New clutch install is nothing but problems help!
  194. Missing 2nd gear
  195. New spec 3plus reviews
  196. need help guys
  197. Question about t56 rebuild
  198. Drill Mod Question (Already read the article)
  199. Can you diagnose this?: clutch hydraulics
  200. clutch return spring
  201. still a little confused...
  202. 2nd gear got me >:o
  203. Car shudders violently after clutch install
  204. whats the best slave cylinder
  205. Bleedin brand new ls7 clutch, new slave, new master
  206. power bled my clutch. great results
  207. transmission problems/ PS problem-
  208. who has the best deals on Spec clutches?
  209. focking slave cylinder
  210. Plzzz someone identify my B&M shifter.
  211. Just got transmission back from T56 rebuilds a couple questions...
  212. New clutch install complete, weird problem LOOK.
  213. LS7 clutch is taking the abuse
  214. T-56 Rebuilds
  215. I have a hole in my bell housing!!
  216. Help Me Pick A Great Clutch
  217. rebuilt tranny, now can't shift 2nd to 3rd worth shit
  218. T-5 convertion kit
  219. Car is at a stop, push in the clutch, put it in first and car wants to roll forward?
  220. Do I need a master?? Please help answer some LS7 questions.
  221. Tranny issue
  222. What clutch should I go with?
  223. Shifter problems
  224. New Ls7 Clutch..Pedal sticking down under hard accel
  225. Bendix master cylinders.......
  226. Need Help With Throwout Bearing/clutch Install
  227. whining sound starting to get louder (ls1joe rebuilt it)
  228. I bet no one can figure this out.
  229. VSS inductor wheels the same on F-Body's & vette's?
  230. Whining noise......
  231. Anyone running the RAM Dual Clutch?
  232. Need a new transmission
  233. sporadic noise when going from a stop...
  234. Noise coming from clutch... what could it be?
  235. Textralia after 16 months
  236. quick help please....
  237. tranny swap
  238. Ls6 clutch
  239. improper flywheel resurfacing?
  240. Understanding gears.. a newb's quest.
  241. LS1 Flywheel anyone?
  242. LT1 t-56 to BBC
  243. Anyone have a F-body AND a C5 with Aftermarket Shifters?
  244. boiling clutch fluid?
  245. GM Master & Slave Part#'s Please????
  246. How long do I have left?
  247. Found my groaning noise!
  248. gto t56
  249. Stock shifter assembly?
  250. 4th gear grind
