View Full Version : Manual Transmission
- Broke a synchro
- grinding clutch...HELP plz.
- Which Six Speed?
- Problem??
- what kinda of tranny fluid?
- Viper T56
- Is this a stock clutch disk?
- Do Carbon Fiber Synrchos have a "break in period" ???? Please help!
- Tranny Getting HOT?
- Clutch Noise
- quick disconnect broken
- T56 with 9" 5.11 gears, what to expect??
- where to bt a clutch line O Ring
- where to find shiftball?
- Steel vs. Aluminum vs. Billet Steel flywheels
- Clutch Question????
- t 56 question
- Atf Poll
- Hydraulic Throw Out Bearing..
- Spec 3+ slipping
- 3rd gear grind
- LS7 clutch Installed
- ignition cut out?
- t56 behind older sbc
- Spec 3+ or Mcleod RST for a nitrous car need help ASAP?
- New Clutch Company.Trying Something Diff.
- Want to go auto--how much is my Level 2 M6 worth???
- Loose Shifter?
- Clutch adjustment help
- t56 mount part #??
- Imput bearing Issues?
- What clutch for 800+rwhp
- how much slower did the ls7 clutch make your car?
- UMI Adjustable Torque Arm Installed... Strange Noises!
- Single disc clutch setups...
- OEM Tranny mount
- spec mini twin
- Mcleod Master Cylinder??
- New MGW F-body short shifter
- diagnosis; neutral tire move
- Experts - How Much Shim?
- oz700 ?
- Torque specs- crossmember
- floor jacks ?
- clutch disc..
- stick with the t5
- torque method
- RPS to Textrilia?
- Need help - 2nd gear? Synchros? Something else?
- LS7 clutch install????
- Hydraulic clutch assembly
- Spec Stage 3+ with Stock Resurfaced Flywheel 0.20
- Slave spacer
- T 5 swap ... clutch line promblems
- Need a Slave Cylinder ASAP
- T-56 build?
- t56-questions
- Built T56 needed (sponsers)
- Reverse sleeve
- my clutch swap w/ pics, feel free to come in and give advice!
- question regarding dropping tranny
- drill mod question
- problem removing clutch master cl
- Need some clutch suggestions...
- Identify this part....
- spec 3+ clutch
- Clutch Pedal Pressure - Post Clutch Install
- Textralia Z Grip Is In
- Newb M6 questions
- new clutch choices
- T56 wont budge (LT1) please help
- where to buy Spec 3+?
- hard into reverse after road course
- Shifters
- Spec 3+ and Fidanza Flywheel ok?
- Textralia new install possiable trouble
- Did I ruin my Spec stg. 3?
- Posting from side of the road... what did I break this time!? lol
- t56 interchangable clutches?
- bench bleeding?
- will spec 3+ work w/ RAM billet steel flywheel?
- is it worth it to change your stock hurst shifter in a SS Camaro?
- GTO Stainless Clutch Lines?
- car surging or bucking = something broke
- Swapping clutches for 1st time
- Who has the new MGW shifter?
- Help
- Is it my tranny, clutch, or bearing going bad?
- What to consider before installing a Spec 3+ Clutch
- Clutch slipping...AGAIN.....HELP!
- Spec twin disc
- RPS Clutches?
- T-5 Won't go into gear sometimes. Clutch or Trans
- Clutch switch wiring confusion
- 3.73 rearend ZO6 trans gear combo ???
- spec mini twin disc?
- Six Speeds Inc. will be closed week of June 30-July 4th
- 2.66 1st 1.78 2nd, why??
- Spec Super Twin
- What did I do?
- GTO 2nd Gear Issue?
- Hydraulic leak??
- Help me identify this clutch.. spec?
- Power shifting T-56
- ram powergrip hd driveability
- someone please help T-5 clutch line and fitting problem I NEED HELP
- auto help
- Stock pressure plate weight?
- Throwout bearing popped off slave, Reinstalled-- Am I ok?
- clutch letting itself out.....slave prob? leak? help!!!!
- best street clutch/flywheel with minor mods done to car
- I thought the pro 5.0 was suppose to help with the 2-3 shift?
- Will not shift to second at high RPM's
- t56 bellhousing
- are 93-97 pedals the same as 98-02?
- are there any write ups on how to remove tranny
- Joe@SixSpeedsInc.com
- how much money from a4 to M6
- slave cylinder
- flywheel m6
- Clutch wouldn't release
- Who makes those metal shifter boot clips?
- Mcleod RST clutch?
- Ram Vds
- shortest throw shifter
- LS2/7 flywheel - lighten or billet steel replacement?
- Clutch Overkill
- Trans removal virgin
- Anyone used the new RAM produced slave?
- trans removal today
- drill mod m6
- new m6 clutch!!!
- putting m6 back together
- I need a GOOD clutch
- Rebuild T56 ..Do I need this ?
- How to make sure I never miss 3rd
- whats up with textralia's ordering process?
- More clutch issues - New Slave and now slipping
- Tranny help
- cts-v t56
- Tex oz-700 dragging update.
- New shifter
- Textralia or Spec Stage 3+
- Noob With A Spec
- Tranny Mount
- C5 T56 in a Camaro?
- No more cooked clutch fluid from header to hyd. line contact!!!
- IM looking for a 6spd setup for a performabuilt trans and yank 3600
- blackhawk clutches??
- 4th gear going out?
- New clutch issues
- Pilot bushing just slips out
- hurst billet guys come inside!
- Trouble w/ 2nd and 4th gear
- Is this the correct pilot bushing?
- Quick Clutch Bleeding Question?
- HELP! i need some advice on my tex exo skel
- throwout bearing size?
- Theoretically speaking....another LT1 t56 thread, help me out
- Shift Boot plastic retention ring
- dropping trans.. getting a new clutch what else?
- how is my transmission
- bearing vs. bushing
- what to do about inside wiring for an m6 to a4 swap
- is this normal?
- Clutch or hydraulics or tranny?
- Problems with pro 5.0
- Pedal Prob
- How to bench bleed your M/C?
- Aluminum Flywheel
- Need help with T56 trans
- 2004 gto shifter
- Need help deciding on a clutch
- Clutch Slave Install Question...
- Clutch bleeding problems?
- reinstall tranny, now issues
- Do I NEED a new bellhousing?
- Master Cylinder seals
- Mcleod Adjustable Master release date?
- Six speed in 2002 trans am
- car won't move
- Anyone ever seen a failure like this?
- newbe needs help with centerforce
- Clutch pedal pressure (Very stiff)
- WTF am I doing wrong?
- is this a good shifter?
- Clutch?
- Clutch grabbing off floor... I've tried everything
- Centerforce DFX
- What Clutch?
- Spec Clutch Spacer
- input shaft
- Hydraulic LT1 Clutch Line
- T56 Question
- Peddle sticks to floor, AKA shitty GM clutch system design
- Tailshaft Thread?
- MT newb question
- installing a bulit t-5 into an ls1 f-body
- Clutch not disengaging?
- ZOOM clutch ????
- Pistol grip shiftknob
- 411 gears what gear to hit from a 45mph roll
- Mcleod Bell housing.
- wat clutch w/450rwhp & and sprayin a 150hp shot?
- Chatter when I floor it.
- Trouble going into gear when stopped
- Spec Wtf!!!
- i need a t56 rebuild. 3rd grinds all to hell
- 96' ws6 seems to studder?
- Improving pedals for Heel/Toe?
- do i got a clutch problem or a trans mount problem?
- Best Of The Best
- constant 5th gear grinding
- T-56 viper upgrade.
- twin disk help
- need clutch help
- poping out of 3rd
- undecided between ls7 clutch or ram????
- why does rpm affect the hydraulics of the clutch
- Is this an lt1 or ls1 t56? (link)
- Power loss with 12bolt
- I think I ordered the wrong shifter
- INSTANT REBATES on SPEC Clutches at Tick Performance!
- clutch disc installation
- Centerforce clutch shot?
- Step by step on flushing/bleeding clutch fluid?
- 1-2 billet key install problem with pic
- '01 T/A Diff Noise
- Jarrod Short Stick Question
- Filling transmission fluid quick question.
- Trans, Clutch and God Knows What Else Issues
- No 6th
- silicone DOT 5 in clutch system???
- Clutch Issue- What causes Pedal to get HARD at high RPM?
- Six Speeds Inc Face Plated Trans
- what is this sound
- HELP Clutch Job Done NO REVERSE!!!
- O-Ring Question
- Output shaft problem/maybe?
- Shifting Problems @ High RPM - Done Drill Mod + New Parts, Bad MC?
- How to replace slave cylinder?
- SPEC stage 3? or stage 3+?
- Two thumbs up for my OZ700 clutch
- problem with 4 gear
- tranny problems
- Tex Exoskel.. stock master, or mc leod.
- new master cylinder problems
- Spec or Fidanza for LS7 clutch
- Bad Slave Cylinder???? I'm Feeling Nauseous!!
