View Full Version : Manual Transmission
- lt1 t56 to a ls engine
- i need help guys
- t-56 swap
- Skip Shift Delete
- Did any here use parts store slave or master cylinder?
- strange noise only when cold
- replacing clutch....
- LS1Speed Flywheels
- slave ?
- spec clutch question
- need help chosing gears in my99 ss m6 150k 4.10s???
- eBay shifters
- Pressure Plate and Flywheel Bolts - Replace?
- Never ending clutch problem
- Help with a clutch...
- trouble bleeding slave(I have read sticky)
- centerforce LM clutch
- POLL:Mcleod or Quick Time Bell Housing
- i just ordered...
- HOW much does a 4l60e generally cost??
- T56 question
- Where is the writeup...
- What is wrong with my LS1 Please help
- Clutch Bleeding Question
- HELP! squeeking/ grinding sound when I push in the cutch.
- Deal on Spec3t clutch
- best slave and master cylinder??
- WOT Shifting issues, clutch engage on floor *SOLVED*
- new clutch drinking fluid help
- anyone with B&M ripper shifter..need info!!
- T56 Bearing Races?????
- well i just ordered my monster :)
- Are the Master Cylinder and Slave really needed when doing a clutch?
- dex/mer ATF
- aluminum flywheel????
- lt1 t56 shaking when engaging clutch at low speeds
- flywheel question
- clutch pedal engagment high
- cant bleed system help
- Need help with 2 step
- Just ordered Stage III Monster
- Fresh t56- No Reverse-skip shift stuck?
- t56 question
- Please tell me my clutch isnt bad!
- who's missed 4th and went back to 2nd??
- When things dont go as planned doing a clutch job
- 1998 z28 tranny problem please read
- fully built t56 looking for t400
- Good way to launch a 6 speed?
- Clutch time?
- the ls7 clutch has been a good, inexpesnive clutch for us to use. what about these??
- T-56 i.d
- dont know if im blind, but need some help here
- Fried C5 Spec 3+, Tick Master?
- clutch recomendations
- hard to get into gear after everythng fixed/replaced
- balancing
- Proform Short throw Shifter!
- 1993 m28 and m29 t56 vs 94+
- Please help.... Problems with drill mod
- Where can i find a *LS7 Clutch*
- Concerning re-finishing stock flywheels...
- rear main leak need new clutch disc???
- clutch slip
- clutchy time!
- Any reasons to not use alum flywheel?
- Clutch install priblem need help asap
- 01 M6 SS Camaro Spec clutch problem
- t56 tranny question.?
- Tick Master Cylinder Help
- Looking for a reputable performance shop in Miami
- M6 fluid
- Pull clutch to CSC?
- Stock Ls1 clutch
- Max RPM for syncros
- what is the solution for a sticky clutch pedal on a vette?
- T56 spline count and Moser Pinion
- m6 torque arm bracket bolt sizes??
- ACT Twin Disc Review
- lt1 hydraulic line
- Monster Clutch- Stage 3 or 4???
- New OEM Clutch question
- spec clutches?
- Places that sell T-56 conversion kits?
- i ordered a monster clutch today
- Second Gear Question
- Valeo clutches?
- Good T-56 Upgrade company?
- Wat does it mean when it says skip shift?
- Help! Going Cable to Electric VSS signal!?!? muncie M21
- Anyone have a Tick Master Cylinder Install write up?
- Normal driveshaft spin?
- Stock Clutch Question.
- shifter is rattling BAD!!!
- t 56 question
- Hurst 3915065 GTO Shifter in a 69 Camaro
- What transmission parts are rotating when...
- Clutch question...pics inside
- is this a good set up?
- grinding full throttle on big motor
- New slave?
- One wheel spin???
- Need some help on what to get please...
- m6/m5 top center console!
- wanted lt1 bellhousing
- Squeaking clutch pedal?
- Need a custom clutch plate to >
- Review - Tick MC in my 403" SS
- Monster Clutch Drivability
- Short Throw Shifter Question
- Another T-56 question!
- T56 swap to T5... any one done it?? please respond
- Ls7 clutch swap problem 06 gto
- Blow Proof Bell Housing-Quicktime or Mcleod???
- Stupid vent tube
- Grinding when clutch is depressed
- spec 3 train
- parts for ls7 clutch
- Tranny mount?
- Need a new clutch
- Can't get trans. to go in gear. Help?
- Just installed spec clutch, couple of suggestions.
- MGW Shifter Installed
- Diameter of front bearing in c5 tt
- input shaft
- Tick is awesome
- If anyone can help me find a taller shifter, please direct me...
- Need some help hydro problems
- T56 Grinding noise...
- F1 Racing chromoly flywheel any good?
- Mcleod RXT Street Twin
- ram VDS issue
- Oil on my clutch....
- T56 Hydraulic Throwout Bearing problem (?)
- Popping out of reverse leading to not being able to put it in gear?
- Help with Pt# Please
- ls7 clutch for stock 01 ss?
- no 6th gear
- LS7 vs. Centerforce Dual Friction.
- M6 Blankets..SCATER SHIELD
- The Tick Performance F-Body Adjustable Master Cylinder Bracket Swap-Out Program
- Just installed Tick Master
- where to get LT1 stock flywheel?
- Another Textralia Thread
- rev matching??? pls respnd...
- Anyone here use a centerforce
- If you need to remove a pilot bearing...
- m6 swap problems
- Which Textralia Do I need?
- ARP torque
- F-body & CTS T56 differences
- Changing fluid
- HELP! ls1 to T101 adaptor????
- Tranny/Clutch issues
- C5 corvette manual transmission guys???
- What is this??
- LS7 clutch questions???
- Diagnosing T56 Clutch/Slave problem
- overtorqed pp bolts
- t56 on a v6
- HELP me ID this???????
- hardened output shaft?
- Wiring questions A4 to M6 Swap
- Tuet 1260 to LS!
- clutch issue.....
- New Master now very short pedal travel
- easy t56 question
- Pilot bearing chewed up the input shaft... HELP!!
- A4 to Saginaw 3 speed
- wheres the front torque arm mount bolt
- shift rail parts
- Parts needed for my new clutch?
- Can i usu stock fly with new clutch?
- Hey guys please help..
- any pics on bleeding the clutch???
- T-56 an cold weather ?
- Easy question
- transfer case/bell housing leak.
- I Need a clutch!
- help me ASAP mcleod master cylinder
- Pro 5.0 shifter Issue
- clutch problem, bad clutch slave cylinder ?
- Drill Mod And Now More Problems
- blowing fluid through rear seal. Driveshaft issue?
- help? bad slave cylindar?
- hurst billet plus bolt size?
- what does shift skip means??
- Clutch Question???
- Check out these lines on my new LS7 clutch
- Grinding issue....
- Need a smooth, streetable clutch for 500+HP
- Difference in flywheel weights... and "seat of the pants"
- tranny/clutch help
- getting ready to rebuild my t56 myself
- Drill Mod = Failure Need Help
- help with a throw out bearing
- down shifting... pls respond. thx
- centerforce clutches?
- Spec Super Twin pics
- Clutch Flywheel combo only?
- So, is there any possible scenario where my T56 gets stuck in gear...
- Looking @ a C5 with M6.. question?
- Viper T56 input shaft VS. LSx input shaft
- Throw out bearing
- transmission mount ?
- how much rwhp can the LS7 clutch handle
- help I am in over my head
- LS1/LS6 Slave part number?
- Fidanza Flywheel question
- LS3 + TKO500 = What clutch and flywheel??
- Clutch Pedal Return Spring?
- my clutch blew a brand new slave cilinder
- T-56 tools
- Pilot bearing Puller Help!
- Spec clutch, worth it?
- switch on the clutch pedal?
- possible to get pro 5.0 shifter base gto setup?
- lt1 BRAND NEW slave leaking to bellhousing
- Is my clutch done???
- Trani Fluid
- automatic to 6-speed conversion
- B&M Ripper shifter new style & old style differences?
- G-force T-56 gears
- Mcleod Street Twin Horrible Chatter
- Is LTx flywheel same as SBC?
- Clutch Bleeding help!!!
- Please help. Clutch not fully engaging
- Adjusting "adjustable" Master Cylinder
- What speed/rpm for 6th gear???
- M6 Problem
- Midplate question cable clutch
- Wich throw out bearing for t-56
- not another clutch bleeding question!!
- what do u think Mcleod clutches
- Tranny Noises
- t-5 ??
- duel disk clutch install question
- pedal to the floor, not going in gear
- Clutch line question
- Grinds going into 4th after rebuild - only when shifting fast.
- T56 Clutch problem: Randomly pedal stiffens up and clutch starts to slip. Need help
- t56 questions
- Any reason not to do the drill mod?
- Throw Out Bearing
- Who has broken their C5 MM6/M12 transmission output shaft?
- Shifting issue still not solved...
- Too much weight bad for trans???
- slave cyclinder done?
- 16oz through the hydraulics, now what?
- rust on flywheel question..
