- OK another clutch discussion
- Clutch engaging itself
- What's the hot new clutch fix?
- How long did you stock clutch last?
- ls7clutch=noticeable change in revs?
- broken shift boot clip!
- 6spd problem (soft pedal)
- Next Step
- What oil to use?
- Clutch Slipping or Slave
- Transmission Mount I need the Stiffest mount made.
- Wot Issues Ls1 Joe / Textralia Guys
- Is the factory Z06 flywheel ductile?
- t56 broke-need input.
- Loud bang, and a wheel hop question
- popping out of 1st at low speeds
- LS7 clutch pedal play
- Z06 Clutch
- New 1LE mount and still problem
- Good compromise Clutch?
- Manual Transmission Broke?
- HELP....Installed new Spec 3 = Grinding
- How possible?
- bleeding clutch
- Low load vibration / 6th grear vibration
- Info For Anyone Getting A Centerforce Df
- what's everyone doing for the knobs??
- changing flywheel
- 3rd gear pop?
- stock clutch specs
- Soft pedal feel
- Textralia and reusing flywheel
- clutch problem
- is shifting suppose to be rough
- help me change out my slave cylinder PLEASE.
- ? on Mcleod Master rebuild and bench bleeding.
- Hard to go into 1st
- Clutch assembly
- lou short shift vs short throw
- Symtoms of a bent shift fork ? How about a seized pilot bushing ?
- Warranty on McLeod master?
- I Need A Slave!!!
- All 6speeds equal??
- 1st gear ratio change
- 3rd gear problem
- Tranny or Rear?
- Big clutch problems, big questions 2000 LS1 Pressure plates work in a 97 LT1?
- ls7 clutch kit
- teaching someone to drive
- shifting.....good at high rpm, bad at low
- Question about LS6 clutch kit
- question about damper springs
- T56 scatter shield
- Pro 5.0 road noise?
- What manual transmission in 2002 TA?
- Tranny problms
- Hurst Billet to Pro 5.0
- Please dont tell me I need a new Synchro!
- anyone haveing problems with the McLeod adj slave cylinder
- power shifting problem
- Fastest t56 Viper
- should I buy a new master cylinder?
- Textralia ExoSkel install pictures and early review
- where can I get this shifter knob?
- soft clutch pedel
- t56 install write up ????
- where can i pick up an 01-02 clutch master cylinder?
- Help wanted!! Manual Tranny question...
- How a dremel can prevent suicide
- What clutch is best?
- will a LS7 clutch work with the LS1 flywheel?
- what is the best slave?
- Correct dimension auto to M6
- new flywheel...old clutch
- LT1 Flyweel
- T 56 clutch hose
- T56 Install
- is gm color blind
- Clutch overheated at Road Atlanta - how to fix?
- Resurfacing Stock PP and Flywheel
- At what mileage do you change a trans mount?
- Stuck in Gears 3 or 4
- spec 3+ review.
- Just got my Textralia ExoSkel (Pics)
- How to work an manual tranny!!
- Clutch problem
- How important is the moisture guard?
- Best Place To Get A Input Shaft?
- LS7 Clutch and Flywheel question
- Help me pick out a clutch
- will this old school bellhousing fit on the ls1 5.7?
- OEM Clutch ok with 4.11's?
- 75K miles...should I change it? What fluid?
- Shifting weird when cold
- cylinder leak?
- Violently pops out of gear.... WTF?!
- UMI short stick installed
- RAM Dual Disk Street Review
- Clutch pedal stuck @ floor and now mushy... hydraulics or PP?
- McLeod single disc clutch users come here
- t56 rebuild
- slave cylinder mod
- Dumb clutch pedal question
- lightweight flywheel that will work with LS6 clutch?
- What stick is this??
- bleeding ? need help asap
- bellhousing blanket
- bellhousing torque?
- t56 dimensions/bellhousing height?
- Q about poly trans mount
- Bad pilot bearing?
- Help...
- Textralia Exo-Skel So Far So Good
- Clutch recommendations?
- clutch pedal / master cylinder question
- length of stock fbody clutch line
- RAM adjustable master cylinder
- Rattling shifter
- Life expectance out of textralia?
- Best Clutch for power
- which clutch should I use?
- Another case of grinding clutch....
- Will at T56 out of a 1993 fit my 1996?
- Clutch Material Thickness for Spec 3?
- DAMN Clutch!
- input shaft play
- adjustable clutch master cylinder
- clutch problems
- Pilot bushing and TB
- T56Rebuilds.com December/Christmas Special
- Where to find?
- Can not down shift into 2nd anymore?
- T56 retro fit
- trans help
- Changing synchros
- LS7 finally has 500 miles on it....
- T56 mounting
- LT1 clutch disc replacement?, will any 11" 26 spline disc work?
- T-56 crossmember queston
- what qualifies as a warranty repair?
- X-mas gift to myself. Mcleoud or Textralia....Few questionrs search didn't answer
- HP tuners how to convert to M6?
- Hurst Skip Shift Eliminator
- proshifted t56
- T56 Rebuilds
- Finished Exo-Skel and a few other mods...
- Only goes in reverse with the motor off...
- Which clutch???
- Clutch Info Needed Inside!!!
- will a t5 out of a third gen work in a 93 camaro
- ok.. what now
- Oops Broke a line...
- will the dealership be able to tell a tranny swap?!?
- G/F's Clutch is slipping...got a few questions
- bad master cylinder?
- well I ordered one
- clutch master pre bled?
- Textralia Exo-Skel launch vid
- Need info on TKO-600
- tranny help
- Spec Stage 3+ is holding up good so far
- Master cylinder hydraulic line different?
- what clutch for LS2 with a 2001 T56?
- tranny rebuilt now problom
- Clutch sticks to floor, wtf?
- Transmission/Clutch problems
- t56 swap
- Ever use both hands to get out of 4th?
- ram vds900 vs ls7
- My LS7 Clutch
- Possible BLOWN Transmission...?
- Bleeding problems
- ls1 vs ls6 clutch
- What the best way to flush the clutch.
- Auto to 6-speed How much work??
- Tranny update
- need help ASAP!! clutch install problems
- Help - T5 Trans Removal Question
- Having a serious tranny problem..HELP!
- clutch pedal . missing spring!?
- t56 limits?
- OK...should I go auto or manual???
- Got the Textralia OZ700 in the SS tonight
- Newbe Help!!! T56 not fuctioning
- T56 Problems
- What clutch should i get?
- Clutch pedal spring?
- A4 complete swap for your M6!!
- Parts store slave
- Stock Hurst shifter
- Drill Mod with Valvoline Synthetic Fluid
- Ok! Wtf!?
- Textralia
- Jegs CAGS help *PICS*
- I need to fix the trans (6spd). What else should I replace while it's out?
- Centerforce Clutch Noise ?
- Tranny issues
- Need Help ASAP! Weird clutch/tranny sound?
- Spec 3 slipping?
- Master cylinder bad?
- Am I too big to drive a M6?
- z06 short stick work on my 00 fbod?
- Shifter?
- Advice needed. RAM VDS install.
- Reverse?
- A4 to M6 conversion... 30mph speedo???
- Ram VDS
- what should i do to my trans to hold up to 500rwhp??? what clutch too?
- New Pilot bearing at 20k miles???
- LT1 style clutch/PP how many people have converted?
- What do I need to know about this?
- Spec Clutch Users What Master Cylinder?
- LS7 clutch
- GM Slave or Parts store Slave?
- clutch package
- centerforce Question
- Exo Skel installed.....brief review.
- Which textralia clutch should I get??
- thump noise
- Tranny mount going bad??
- Master Cylinder
- swap tranny gears around?
- Help: Rattling from shifter, and Squeeling or Howling when shifting....
- Odd question about big clutch driving style
- will my tranny clear my headers
- Spec 3+
- Part number for Shifter boot
- clutch is starting to slip
- Lt1 to Ls1 T56 swap in need of specifics.
- C.A.G.S question
- T56 just hanging out
- Help, need a new clutch!
- Textralia clutch install questions
- how difficult to fix t56 reverse gear at home?
- Picture's of LS7 vs. old LS6....
- Got my Textralia in from the Byunspeed GP
- t-56 behind sbc/bbc
- 5.0 vs factory ordered hurst
- Trans or clutch
- M6 Fluid Change
- mcleod single disk
- Clutch Fluid / Pedal
- Tranny Shop Screwing Me Please Help!!
- Slave Install Help!
- how much power can a stock clutch assembly hold before...
- Centerforce DF
- Heavy Duity T-56 trans.
- Help me identify this clutch and pressure plate
- t-56 rebuild help
