PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Reccomend me a clutch!
  2. Bench Bleed new Slave?
  3. My slave cylinder came with little o ring???
  4. T56 Rebuild
  5. Can I Use an LS7 Clutch and Spec ALUM Flywheel???
  6. Reaaaally bad vibration when clutched in and revved.
  7. the Zoom D2 Series Twin Disc Clutch Kits
  8. flywheel bolts
  9. Six Speeds Inc. New Shipping Policy
  10. Textralia Exo-Skel Triple Pics...
  11. cruise control not working!
  12. Pressure Plate -- Is This Normal?? (PIC)
  13. Clutch opinions
  14. Fidanza Flywheel Wear Issues?
  15. clutch?, drivetrain problem?
  16. Where the heck can i get a VSS??
  17. BIG problem
  18. New Slave Cylinder...can it be bleed first?
  19. torque specs on flywheel?
  20. LS7 Clutch
  21. Sponsers: LS7 clutch & flywheel
  22. Where can i buy a replacement ram throwout bearing?
  23. Found out my problem
  24. Spec 2+ not shifting at high RPMs
  25. How much for clutch and flywheel install?
  26. Engine in Bind after Clutch Install
  27. Good Daily Driver Clutch for (500-700rwtq)
  28. clutch problems....
  29. tranny going...
  30. Sloppy shifter??
  31. adjustable rod for t56
  32. Bad Master Cylinder question
  33. T56 Clutch Install Need Help Quick!!!!!!
  34. Clutch install problems
  35. where can i buy a t-56 polyurathane mount?
  36. going inside a 6 speed
  37. Im Lost. Ls7 CLutch Kit vs. My Combo Now
  38. Centerforce Dual Friction
  39. New clutch... Do I need a new ...
  40. why the hell does my car keep popping outtta 3rd gear
  41. how does the clutch suppose to feel
  42. advice on pulling t56
  43. issues with my 02ta
  44. What Is ls7 Clutch Kit Part Number on SDPC?
  45. Jam up going into 3rd gear?
  46. t56
  47. buy a flywheel or resurface?
  48. Spec 4 owners, please come in
  49. A4 to T56 swap advice needed
  50. anyone sell a complete rebuild kit?
  51. Burnt Spots On Flywheel? Clutch Slipping
  52. Vibration from alluminum flywheel?
  53. Spec Stage 3+ or Textilla oz700
  54. Cartech dead at like 3000 miles questions and stuff.
  55. Help asap textralia twin no instructions..
  56. ls7 clutch?????????????
  57. flywheel ?
  58. Diagnosis needed...
  59. Need a transmission rebuild for my GTO... recomendations?
  60. ARP Flywheel bolts - Who has disassembled after using Red Loctite?
  61. 6 speed to 6.0L
  62. Where/who should I buy a Centerforce clutch from?
  63. Clutch pedal sticks to the floor.Help!
  64. What clutch do I need!?
  65. Clutch Install Question
  66. tranny help??
  67. ls6 clutch
  68. pilot bearing too loose in crank, ideas?
  69. help! problem with 3rd gear
  70. Putting it to the ground: A Spec clutch review
  71. Anyone use Findanza flywheel with Centerforce Dual Friction?
  72. Trans stuck in 3rd
  73. tranny problem.Please help
  74. Will it work?
  75. Question about a Pro 5.0
  76. A T56 where it's never been before, a few Q's...
  77. T56 removal
  78. Reverse fork shift pad
  79. Burnt clutch fluid
  80. Textralia 0Z700 engagement before/after break in
  81. What clutch holds 1200rwhp in a C5?
  82. LT1 t56 in a LS1?
  83. Please look: LT1 t56 questions reverse-skip shift sensors
  84. Anyone know where to get a t56 conversion kit
  85. Won't go into any gear!
  86. Cost for a NEW T56?
  87. LS7 clutch hold 450 RWHP + Nitorus?
  88. Got my new tex twin disc no instructions ..questions..?
  89. New Clutch?
  90. clutch/trannie vibration?
  91. Please help... (I have searched)
  92. Bleeding clutch for a 95' style T-56
  93. weird T56 problem!
  94. Centerforce clutch problem? No pedal pressure?
  95. High pitched whining 1st-3rd...quiet in 4th???
  96. tailshaft bushing ?
  97. Viper T56
  98. Best clutch fluid?
  99. Where to buy reverse lockout assembly?
  100. T-56 gearing and drag shift points...
  101. need to buy clutch disk only
  102. Newbie Question
  103. Problems with my Spec Stg 3
  104. Clutch Hydraulics
  105. clutch just went to shit
  106. pedal sticking to floor@ high rpm
  107. spec 3 clutch and flywheel install
  108. where can i order an ls7 clutch kit???????
  109. My pedal died...
  110. spec 2 question
  111. Six Speed inc. 5A???
  112. Tranny Help Guys...PLEASE LOOK
  113. Tranny fluid?
  114. Spec 5
  115. Output shaft broke
  116. ram powergrip issues
  117. My ls7 Clutch Setup is GARBAGE!
  118. Shifter!
  119. T-56 vehicle speedo sensor problem
  120. LS7 clutch review
  121. Ram clutch life question
  122. VSS Plug
  123. making wierd noises
  124. T-56 Question
  125. Losing 2nd
  126. Is this related to tranny or clutch?
  127. Bellhousing broke. Shifting Problems
  128. Trying to remove the clutch MC
  129. Hard to shfit
  130. Clutch Install Problems
  131. Exo skel slipping at the track
  132. Racheting sound now clutch pedal high
  133. Pedal feel
  134. Strange Clutch Problem, Need Help
  135. UMI Short Stick dimensions
  136. Good news/ Bad news
  137. age old clutch question
  138. Stuck in 4th
  139. 5th Gear f***** up??
  140. pro 5.0 or b&m ripper
  141. Drill Mod Review: Just Done!
  142. SPEC 3, 3+, 4, or RAM Powergrip HD?
  143. LS1 t56 and LS2 t56
  144. Anyone have the part number for a LS6 flywheel?
  145. clutch ?'s ZO6 vs LS7
  146. Getting t-56 rebuilt by Hanlon, what have I missed...
  147. M6 pops out of 3rd?
  148. Spec stage 2 vs LS6 clutch
  149. ok, i bleed and bleed the master and it is still sticking at high rpms
  150. Car starting without clutch pedal pressed!?
  151. Manual Trans Fluid Change - Is there a filter?
  152. T56 Installation
  153. shifting issues
  154. P0704 help!
  155. Clutch ?'s
  156. Slick Shifted T56
  157. cold starts, banging of 5th and 6th
  158. Vibration in 6th when decelerating?
  159. New Clutch, Shifting Problems NEED HELP!!!!!
  160. Tranny Parts
  161. whats wrong with 2nd?
  162. What do you guys think of this LS6 clutch and PP?
  163. tough/slow shifting?
  164. save me part2
  165. Will this work with an LS7 clutch and Pressure Plate?
  166. Ram HD with resurfaced flywheel
  167. Fidanza Short Shifter?
  168. Can't powershift 2nd
  169. How to hold flywheel during removal/installation
  170. cutting the shifter shorter
  171. I found the cause of my leak...
  172. Need new slave and master- which ones?
  173. Vibration
  174. Caddy CTS-V trans fit f-body LS1?
  175. CAGS Solenoid removal
  176. where to find high perf. T56
  177. RCI transmission blanket
  178. power bleeding question
  179. 3rd gear hesitation
  180. Spec 3 problems/slipping/vibrating
  181. high pitched squeal on 1st clutch release of the day (only in forward)
  182. t56 problems
  183. trouble getting into 1st and 4th
  184. Transmission popping out of gear on turns
  185. Name this shifter!
  186. Leaking Fluid...
  187. Terrible grinding noise coming from my clutch...
  188. trans problems
  189. Anyone sell ls6 clutch without flywheel?
  190. is their a big difference
  191. Have you run Honda ATF? (T56)
  192. Difference in ls1 and ls2 flywheels?
  193. Clutch Questions
  194. master and slave cylinder
  195. What is the best shifter???
  196. ls7 clutch long term update
  197. what all is needed?
  198. LT1 T-56 to 6.0 Truck motor questions
  199. Covering the clutch line
  200. Richmond 5-speed in 3rd gen. ?????
  201. The bleeding stops here
  202. Textralia Aluminum Slave
  203. Do I have everything I need for my Clutch swap?
  204. a4 to m6
  205. Can an LS7 hold my power?
  206. Whats going out! Tranny or Clutch
  207. Textralia Fastener/Balance Questions
  208. What is the best way to remove roll pin?
  209. NEED HELP BLEEDING HYDRAULICS!!!!..please
  210. Adjustable Master Cylinder?
  211. Flywheel Bolts
  212. I hate hydraulic clutches!!!
  213. Gears Grinding, please help!!!
  214. Vibration after clutch install???
  215. 1le Lt1 T56?
  216. rebuild, or buy a new tranny?
  217. Clutch Wont Disengauge ?????
  218. Textralia Exo Skel install...may have blew it.
  219. can i mix...?
  220. HELP!!! new clutch problems..
  221. new wagner master???? to short? ...nothing
  222. Remote Clutch Bleeder NEW SPONSOR
  223. Mechanical Speedo adaptor?
  224. Odd RPM behavior in neutral
  225. Cheap front slip yoke when changing driveshafts
  226. ls7 clutch install
  227. Mechanical Speedo adaptor?
  228. ok, bad synchros or do i need a new clutch?
  229. Ls2 flywheel
  230. Replacing master cyclinder?
  231. Clutch master cylinder rod clip?
  232. Ram powergrip HD clutch?
  233. Ram clutch install problems
  234. Clutch question
  235. ls2=ls7 flywheel?
  236. T56 Trashed!
  237. LT1 Bellhousing question?
  238. need a clutch
  239. Textralia OZ700 after 10k miles
  240. A4 To T56
  241. Advice on a Clutch Kit..
  242. How long does this take?
  243. New LS7 Clutch/PP/FW setup going onto LQ9 need balancing?
  244. Problems
  245. I drove my Z28 today!!
  246. 2 broken T56's. what can i do?
  247. Bad Tranny Shop!!!!!
  248. Help with master cylinder questing/issues. Swap car...PICS
  249. Tranny wont go into first...
  250. Changing fluid in the T56
