PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Ok more recent textralia feedback please
  2. trany wont go back in?...help!!!
  3. Used Parts - Where to Buy?
  4. No lube = T56 MELTDOWN! Pics...
  5. 01-02 slave part number?
  6. car in neutral=rising rpms?
  7. quick shifter question
  8. McLeod Single Disk Problems Help!!
  9. Return Spring *PIC*
  10. Cobra T56 in LS1???
  11. 6" or a 6.5"?
  12. does a vert use a different crossmember than hardtop/t-tops?
  13. T56 Questions Plz Help!
  14. Clutch death question ....
  15. grinding noise when coasting to stop
  16. SPEC sucks!
  17. How far can tail be lowered when removing trans?
  18. RAM clutches?
  19. What is McLeod contact info?
  20. hard clutch pedal stickin low!!!
  21. About to upgrade clutch, what else should I change while I'm in there?
  22. Ls7 clutch beatdown !
  23. What do you use??
  24. 01 Dodge Ram 3/4ton NV3500 Clutch issue, I need some input!!
  25. Clutch riding debate
  26. Any Members Looking To Do M6-A4 Swap?
  27. LS6 Master Cylinder? *PIC*
  28. WARNING SPEC parts and customer service...
  29. My Mcleod SFI bellhousing does not line up
  30. RAM Street Dual disc
  31. do i need the mcleod adj master with there clutch?
  32. T56 Turbo truck clutch poll
  33. NEW T-56 rebuild and new CM clutch... wont go into gear.
  34. Thunk/pop on hard decel & when reversing up an incline - Drivshaft/tranny
  35. What clutch do i have?
  36. shudder problems?
  37. Clutch Problems
  38. LS7 Clutch guys, come in!
  39. SPEC 3 in a '99, No Flywheel and Upgraded Hydraulics
  40. Slipping/Shuddering Clutch
  41. Stuck in 5th T56 Tranny Please Help
  42. Flywheel????
  43. Will the C6 shift knob fit a Lou's Short Stick?
  44. HELP!!!!!!!! Drivetrain angle confusion:trans to rear parallel angles necessary?
  45. Reverse Lights...
  46. Resurfacing flywheel
  47. Harlan shift light question
  48. Good (firm) pedal but clutch won't completely disengage
  49. Slave cylinder loose?
  50. Just how good is the factory Hurst shifter?
  51. LT1 hydraulics vs LS1 hydraulics
  52. Hurst shifter?
  53. I think I killed my clutch
  54. And I forgot to order some stuff...
  55. Some nasty noises!
  56. Where to get new disks for my street twin?
  57. Ram HD gets its 1st test!!!
  58. slave cylinder issues
  59. 402+N20 Clutch
  60. Spec stage 3 is gone...... need some pointers on picking out a new clutch
  61. Guys with pressure plate bolt loosening, may have a partial explanation
  62. changing the clutch fluid?
  63. Synchronizer
  64. Clutch Problem... Need Help
  65. My slave that came with Textralia clutch - is it correct one??
  66. TEXtralia OZ700 options questons
  67. whos got the ls7 clutch?
  68. Do Not Buy Ram Clutches
  69. Quick disconnect + Air in Clutch line ??
  70. I think I need a new tranny!!
  71. Shifter shaking violently... Loud knocking...
  72. trans repair cheap
  73. Clutch/Slave/Master Cylinder question
  74. feels like clutch is slipping
  75. Spec Stage 2...With this combo?
  76. Clutch in but ?
  77. transmission problems (m6)
  78. needa quick answer
  79. Could wrong fluid cause a grinding when power shifting?
  80. Some stupid questions for an idea I have...
  81. GM 1LE Tranny Mounts
  82. your thoughts on spec stage 1 clutch
  83. !cags
  84. T-56 just rebuilt..... stiff as a board? Break-in time?
  85. I downshifted to 3rd on the interstate....
  86. Which clutch???
  87. Transmission Gear Grind
  88. Flywheel Question HELP!!
  89. What the hell happend
  90. mcleod and shim?
  91. Please explain/describe clutch "chatter"
  92. Center Force DF question???
  93. Hurst Billet Plus Shifter./ FASTENAL
  94. Tranny Swap!!
  95. Finished New Clutch INstall Need Help
  96. Hydrolics ???
  97. Clutch install question.
  98. winding when in gear
  99. What happened????
  100. What is a (never used) NOS 93 T56 Worth?
  101. Need Help to solve clutch problem....
  102. M6 and M5 tranny issues that are similar
  103. Clutch for T56 and 800+ WHP?
  104. I just cant figure out my problem
  105. forged t56 internals?
  106. Polyeurathane tranny mount question
  107. What manual transmissions will bolt to 4.8?
  108. looked threw the sponsors BUT reco on Trany?
  109. Is 93-97 T56 the same as the 98-02 T56
  110. Clutch question?
  111. slave cylinder problem
  112. My 93 04 LS1 mustang, mating MN12 ?s.
  113. How many of you are using the ls6 clutch
  114. My Nearly New Pro 5.0 Not Returning to Center
  115. New clutch cost...
  116. what throwout bearing??
  117. Tranny install question
  118. McLeod twin disk arrived
  119. ws6 store short shifter
  120. LS7 clutch installed this weekend
  121. Ram dual disk initial review.
  122. torque specs!
  123. Is an E-Clip OK for MC Push Rod?
  124. need 6 speed answer quick
  125. Another Clutch Thread
  126. Technical Question - Experts Needed
  127. Hurst Billet Plus Shifter
  128. Spec stage 4 clutch
  129. What are u guys trapping with 500rwhp..what clutch?
  130. Got my tranny back
  131. FS: 2001 C5 T56Rebuilds.com Transmission with 1 year warranty
  132. Ls7 Clutch and Ls6 clutch side by side pics
  133. new transmision installed .now clutch trouble help me
  134. mcleod clutch spacers.....
  135. What Clutch Now?
  136. Drove My First M6 Car Today
  137. Another SPEC piece of junk
  138. Reverse Lock Out!
  139. shifter bolt hole is striped what to use to fix it?
  140. silicone gasket maker for shifter install?
  141. clutch life-span?
  142. Clutch Circuit SES code!?
  143. My LS7 clutch problems.
  144. mcleod adjust master!! look inside--problem
  145. AutoMeter Temp guage on a 6spd???
  146. Stage 4 Spec --- Ceramic disk only????
  147. Anybody Ever Use One Of These Shifters Off Ebay??
  148. adding fluid in shifter location?
  149. Clutch bleed gone wrong
  150. Cruise Control.
  151. Help Me Pick A Clutch
  152. Need the flywheel original specs on it's thickness, b4 I resurface...
  153. 93 clutch slave cylinder+"drill mod"
  154. what master and slave should i upgrade to?
  155. sucessful drill mod?
  156. Long/B&B style clutch
  157. master cylinder install issue Help
  158. Car jumps out of third gear
  159. Quick Question - input shaft length?
  160. Clutch fluid replaced
  161. Textralia x grip?
  162. clutch break in?
  163. Please Help iam a idot
  164. What is my weak point now?
  165. Centerforce DFX
  166. smoother shifts question
  167. rk sport billet flywheel friction surface
  168. Textralia broke after 4,000 miles!!???!!
  169. Which fluid will give smoother shifts?
  170. Yet another LS7 Installed!
  171. t56 transmission bearings?
  172. HELP Spec clutch install
  173. Difference between V6 and V8 Master Cylinders
  174. Need part # for rubber boot on the shifter.
  175. DOH! new clutch time??
  176. HELP please...Stange problem
  177. HELP!!! Stock Hurst Knob Removal
  178. Mcleod clutch pedal pressure extremely hard
  179. car had motor swap, Skip shift on when car starts?
  180. How long did your SPEC 3 last?
  181. T56Rebuilds.com Limited Time Special
  182. Will An A4-M6 Conversion Be Worth It?
  183. New Clutch Installed!
  184. I stumped the Transmission guy, need help.
  185. hydraulics?
  186. clutch pedal changing pressure!!
  187. Tranny banging
  188. Hurst Billet Short Shifter
  189. So I think I blew third....
  190. Drill Mod?
  191. what would cause.....
  192. 98-00 and 01-02 slave...
  193. clutch pedal springs
  194. need some tips!
  195. output shaft seal leak!!
  196. Dot 4
  197. Pilot bearing
  198. Reverse problems
  199. spec flywheel, RAM CLUTCH help!
  200. hydraulics issue
  201. Spacer in SPEC 4 kit
  202. Clutch Install...questions
  203. clutch and shifter???
  204. you use a ls1 slave for a ls7 clutch install right???
  205. New Hose Design = New Drill Mod?
  206. gear ratio change? t-56
  207. sloppy knob
  208. What ARP bolt kit for a Textralia clutch??
  209. ls6 fiywheel question
  210. Momo shift knob/short shift?
  211. having a t-56 problem
  212. Question with Ram Powergrip Clutch
  213. Partial T56 Rebuild?
  214. Help! Fidanza flywheel botls?
  215. What the Heck is That Skip Shift For?
  216. is it dead?spec 3
  217. Broken clutch return spring?
  218. clutch not broke in yet!?!?!?!?!
  219. Best price on a new Slave cylinder?
  220. Problems Shifting in upper Rpm's
  221. CF 12" DF held GREAT!!!!
  222. LS7 clutch - shim?
  223. T-56 fluid fill
  224. Time for a new clutch?
  225. which mcleoud? where to buy?
  226. Problems with M6 and shifting..
  227. What is the part number for the flywheel for installation of the ls7 clutch in a ls1
  228. 5th Gear Craziness
  229. Shifting problem
  230. Whining on T-56
  231. manual transmission shift points?
  232. USED Ls2 Corvette flywheel for ls7 clutch??
  233. lost clutch!!!!!slave or master cyl?????
  234. Clutch Line Install Problem
  235. Help! Need Torque Arm Mounting Bracket ASAP!
  236. LT1 vs. LS1 T56
  237. so i think i blew up my new ram hd
  238. Common T-56 Problems?
  239. just bought new clutch, what else do i need?
  240. New to the T56
  241. clutchmasters with lightweight flywheel
  242. M6 to 4l60e conversion
  243. T56 shift points
  244. v6 Tranny
  245. Any on runin a dr evil t-56 trans?
  246. slp skip shift eliminator?
  247. clutch return spring?
  248. Why upgrade the slave & master cylinder
  249. Can you guys help me out?
  250. 9" question for high hp Manual cars
