PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Want LS7 clutch, what do I need:
  2. Maybe a dumb Q but i was curious...
  3. Tranny Problem
  4. Spec Stage 3 is CRAP!!!
  5. Am I geting a line of BS here?
  6. McLeod bell housing ?/help
  7. Is this synchro assembly still OK?
  8. t56 m12 question
  9. Soft pedal info (found it searchin..figure i'd post)
  10. corvette t56
  11. need new clutch help please
  12. whats my clutch worth-for sale after price determined
  13. lou's short stick?
  14. clutch decision
  15. Stupid question, using a mityvac to bleed clutch
  16. new clutch....
  17. Where is syncromesh?
  18. LS7 Slave cylinder
  19. What is my problem?
  20. HELP!! Grinding Noise with Wierd Symptoms!
  21. Ram Clutch and fidanza flywheel question
  22. Thanks Six Speeds Inc
  23. Where do i find it??
  24. URGENT:tranny mount bolt size
  25. This sound like a loose flywheel??!!
  26. differences in 93 and 94-02 tranny?need a builder also
  27. transmission grinding..
  28. two man bleeding
  29. GM Vs. Ram Master/Slaves
  30. need help: bleeding clutch
  31. Need a new clutch, any suggestions?
  32. 1st gen LSX/Viper T56 conversion - What VSS do I need?
  33. % loss thru drivetrain?
  34. Is my clutch bad or could it just be the slave cylinder?
  35. Need a new clutch, any suggestions?
  36. need a t56....anyone got one for sale?
  37. Ram HDX review....
  38. New Clutch
  39. whats wrong?
  40. not sure where to put this
  41. uh-oh...tranny problems
  42. Master Cylinder ?
  43. clutch line
  44. trouble with clutch, help me out.
  45. security & radio lock on clutch swap???
  46. Just installed new clutch
  47. T56 Problem?
  48. ws6store short stick = good
  49. WTF am I doing wrong-pilot bearing removal
  50. Why an M6 is better than an A4
  51. Got my Formula back after the new ls7 and slave,and drill mod
  52. syncromesh??
  53. What clutch for my mods?
  54. skip shift
  55. Breaking in LS7 Clutch
  56. Six Speeds Inc. leaving for LSX event
  57. Question about a loose Pro 5.0
  58. 1-2 shift... HELP
  59. Clutch break in
  60. issue with reverse
  61. Reverse doesn't engage
  62. anyone running the McLeod RXT Street Twin
  63. blew my clutch which clutch be better
  64. New ls7 clutch, slave, pilot bearing, drill mod
  65. anyone ever broke a rearend and trans at the same time?
  66. car pulls a little with clutch pedal pushed in at 5k
  67. Ls7 clutch or Different Clutch Setup?
  68. ls1 to lt1
  69. Performance Transmission shop in NJ, PA or NY
  70. Drill mod different on new Master Cylinder models?
  71. Who is using RAM clutches?
  72. T-56 Reverse Solenoid??
  73. Need some help & advice...
  74. LS7 - A bad decision?
  75. Wieghted Shift Knob?
  76. clutch swap
  77. Hurst shifter does not fit
  78. **Shifter Vibration Problem....PLEASE help**
  79. anyone got the Spec Stage 3+
  80. my experience with G FORCE Transmission parts
  81. advice on clutch iMS nstall
  82. t56 rebuild
  83. Need ur help on this weird vibration issue !!
  84. Main shaft tail thread size?
  85. T56 performance rebuilder
  86. Launching an M6 LS1 TA
  87. Power Shifting
  88. T56 Leak What could it be?
  89. o ring on master
  90. Six Speeds Inc. 925fwhp @ 9600rpms Naturally Aspirated!!!!
  91. t56 manual trans?
  92. Transmission fluid, how much do you use?
  93. Pro 5.0 ?
  94. MN12 Is Installed : D
  95. What am I doing wrong, transmission won't go back in
  96. Whats are signs of clutch giving up?
  97. ls7 break-in question
  98. Come in if you've rebuilt your T56 yourself
  99. Clutch Experts, Help!!!
  100. drill mod
  101. 1LE mount?
  102. Any sponsors sell a hardened main shaft for a T-56?
  103. Is this part availabe ?
  104. New M12 Tranny On the Way
  105. McLeod clutch help?!?!
  106. Ram Twin Disk?
  107. LS2 Flywheels Confused?
  108. Auto to 6spd.
  109. cant seem to get it to grab. help please?
  110. Hydraulic Issues
  111. stupid tranny
  112. New LS7 clutch + hydrolics 650 miles then sudden change in pedal feel?
  113. m12 needs rebuild
  114. mcleod adj master rebuild ?
  115. Clutch job Q's
  116. T56, oil getting chucked out breather tube
  117. Clutch swap on a 03 cobra T56
  118. Is the drill mod worth it on a LS1/T56?
  119. T56 CORE for sale
  120. t56 setup for sale
  121. Shifty clutch issues.
  122. T-56 Issues HELP PLEASE
  123. Shifter Rattle
  124. The Best Clutch for 500bhp under $500???
  125. Help with clutch problem!
  126. Help with a Textralia OZ700.
  127. T56 slave cylinder
  128. LS7 clutch problems?
  129. question about hydraulics
  130. Where to buy ls7 clutch-pressure plate, disc, flywheel
  131. T56 carnage! (PICS)
  132. Stock Clutch Launch RPM???
  133. Getting my Clutch and Hydraulics done, Check it out
  134. LSX Event Update and SPECIALS involving Six Speeds Inc.
  135. Six Speeds Inc. New Shipping Method
  136. street n strip clutch
  137. How to change a slave cylinder?
  138. manual swap problem
  139. What Clutch And stage # should i use
  140. t56 swap
  141. Do Twin Disc Clutches Last Longer?
  142. machining a shorter stick from scratch!!
  143. not your average clutch sticking question
  144. bell housing bolts
  145. new clutch and tuning on dyno?
  146. dRILL MOD OR NEW LINE?
  147. Clutch Recommendation Help
  148. Replacing all Hydraulics and clutch $?
  149. leaking MS...
  150. HELP!! Is my Textralia salvagable? Huge detailed pics inside!
  151. TKO 600 & L92. What bell housing & hyd clutch
  152. can this be the clutch
  153. driveline vibration help!!!
  154. Please help - Noise from Tranny???
  155. Stock clutch on a H/C swap
  156. Need to understand T56 fluid level
  157. how strong is stock flywheel?
  158. Bizzar NEED!!!!!! some help guys.
  159. Wow. Got my new LS-6 clutch in today with updated hydraulics
  160. Spec 3+ clutch or tranny noise and shake
  161. What clutch do I need?
  162. Whats needed: LS1 T-56 behind BBC??
  163. How many miles for LS7 break in?
  164. Where to set shift light?
  165. Anyone had starter problems after putting a new clutch in??
  166. Vibrating shifter. whats wrong?
  167. Switch flywheel without changing clutch
  168. t56 clutch and pedal
  169. where to buy?
  170. Any benefit to Ram Adj. MC over the stock upgraded GM one?
  171. rant: slave cylinder is shot
  172. Clutch vs Dyno
  173. t-5 rebuild
  174. who has used what billet flywheel from EBAY?
  175. Tranny Whine On Deceleration Please Help
  176. another ls7 clutch q
  177. Any Roadrace/Auto X Guys? Shifter Preference?
  178. Bad Driveline Vibration
  179. Honda ATF put in
  180. No more flat or sticking clutch pedal...
  181. Clutch Fluid
  182. Transmission is Binding
  183. tranny cooler?
  184. Installed LS7 & Fidanza flywheel
  185. What tool do i need for master to slave line?
  186. Rear Main Seal question....?
  187. How long should a factory clutch last?
  188. Best clutch for the PRICE
  189. tranny or gears??
  190. M6 here I come
  191. 1999 Trans Am not wanting to shift into gear.
  192. LS7 Clutch guys, in here
  193. Gen-Trans T56 Dog Engagement Race Gear Set
  194. lack of shifter cup bushing cause grinding?
  195. Drive Shaft length?
  196. spec stage 2
  197. spec stage 3, release point?
  198. Best place
  199. How do you tell If Clutch Bad?
  200. Normal Wear for Textralia / Life remaining?
  201. Reverse lock-out and Skip shift
  202. T56 whine in 5th and 6th under load.
  203. Modified T56 Lockout?
  204. Pro 5.0 problem ???
  205. aluminum flywheel worth keeping?
  206. viper t56
  207. T56 repair help
  208. Do I have upgraded Hydraulics or not?? (2001 +)
  209. Textralia- whats the est fly wheel to run with it?
  210. reverse on my T56 feels weird
  211. little problem
  212. High rpm clutch slippage
  213. help me choose a clutch
  214. Need Advice/help Asap
  215. flywheel weights
  216. Help!! Clutch slips badley with drag radials
  217. t56 horsepower record/max horsepower?
  218. T56 rebuilders... Is this1-2 synchronizer usable?
  219. How bad does this look? (PICS)
  220. ls7 cltuch+ls1 flywheel???
  221. Is my clutch smoked?
  222. check out this toasty ol' spec clutch
  223. black2002ws6 Remote bleeder.
  224. Tranny pops out of 5th
  225. ls7 clutch question
  226. Toasted Clutch?
  227. tranny grinding in all gears..plz help!!!
  228. t56 rebuilders- help :).
  229. about ot install ls7/ls2 any tips?
  230. Chirping noise after Ls7 install
  231. bolts that connect to crank
  232. how do i get the slave cylinder off?
  233. Looking for best place to find tranny parts/gears
  234. How much to have a Mcleod twin rebuilt?
  235. short stick
  236. Spec 3 clutch grenaded (springs)
  237. that clutch return spring!!!
  238. please tell me my clutch is going!
  239. What clutch is this?
  240. Hurst shift knob rattles, solutions ??
  241. T56 rebuild
  242. Bolt size
  243. Tranny Problem?
  244. Looking for a t5.
  245. lt1 t56, how can i put it behind my ls1???
  246. Ram Adj Or Mcleod For Spec 2
  247. Clutch Instalation Question
  248. Clutch Return Spring - How to install?
  249. IS a GTO T56 and bellhousing the same as an F-body T56 and bellhousing?
  250. Frequently Asked Questions
