View Full Version : Manual Transmission
- Clutch Return Spring
- Clutch robbing power???
- t56 Lightened flywheel question.
- Trans Am Nationals ruined my transmission...
- Weird Noise
- Exedy or Spec's clutch
- Tranny or Clutch?
- Rockland Standard Gear...Anyone use them?
- PHC Clutch - - - Need help PLEASE
- Slave cylinder swap done; car won't shift right
- T56 Slave cylinder problem.
- Need Help with reverse lockout
- Spec Stg 2 creaks when slipped
- A4 ==>M6
- GM says Tranny Problem Normal
- Leaks after installing Spec stage lll
- Newbie six speed question???? everyone in
- Hands down best M6
- Clutch will not disengage when the engine is running
- Spec 2 or 3???
- Do I Have M6 Mount Broke?
- Where to find a tranny mount???
- What cluch is best!!
- Breaking in Spec 3
- Adjustable Master Help??
- Is this possible.
- Pro 5.0 Urgent please read
- Clutch bleeding problems?
- Misaligned pilot shaft?
- bye bye spec stage 2
- resistance before gear
- Z06 clutch kit w/ 99 master cyl
- shifting w/o clutch
- will drill mod help shifting
- Any and all lookin' to sell their...
- Anyone have the FLP t-56.
- Who sells T-56 parts?
- How long should it take ...
- Clutch Problem HELP!!!!
- Hurst?
- Gauging interest of trading A4 for M6
- Tool for setting transmission bearings
- a couple A4 to M6 questions (truck)
- H E L P !!!!!!!!!!!
- billet flywheel reuseable?
- Another ? about shifters.. help
- Z06 & LS6 - Are they the same?
- clutch pedal pressure, notchiness shifting
- Toasted the stock clutch
- i have some 6 speed stuff for sale
- Transmission grinds in every gear
- decisions, decisions
- McLoad clutch
- Is this the same T-56 as the F bodies?
- Master Cylinder Questions
- spec III clutch pads
- Question about the Pro 5.0 now that I have it...
- Aluminum or Billet steel flywheel?
- B&M Ripper Shifter v.s. Pro 5.0
- Flywheel Differences
- how to make master clyinder adjustable???
- Whats a good break in time for a RAM clutch?
- Clutch stopped working
- Changine the clutch... do I need to change the fluid too?
- problems shifting from 2nd to 3rd
- lovin the pro 5.0
- Exedy Hyper Single Clutch ( '04 Z06 440 rwhp-402 lbs torque )...
- LT1 LS1 T56 question
- Equipment needed to use remote clutch bleeder
- update on Spec S4i
- Clutch Chatter?
- Trans or clutch problem?
- RAM clutch question
- Shifter Questions
- Pro 5.0 Question
- Clutch Install Help
- Need M6 Parts!
- trouble power shifting spec3i---HELP
- Clutch swap....
- libertys trans in f-body
- Lou's Short Stick
- Tranny Won't Shift! Please Help!!!
- 01 Trans Am needs a new clutch...another Z06?
- anyone want to trade for an A4/with high stall converter plus cash
- Flywheel Q?
- clutch break in time?
- New Clutch install this weekend
- Best Shifter ??
- HELP: Ram clutch slipping
- Master cylinder Question
- Anyone spraying a H&C on sticky tires and running a SPEC Stage III?
- What do you guys think about the 10 bolt rearend covers?
- Clutch master ????
- Clutch Failures - Why?????
- Well I need a new clutch
- Higher 5/6 Gears
- Freshly rebuilt trans sticks in 4th
- Uh oh stuck in 4th
- which one
- Which shifter?
- Where Can I Buy a Built T-56
- SFI bellhousing or blanket?
- Will this clutch work for my Camaro?
- Exedy Hiper Single !!
- '94 Corvette 6 speed clutch fluid LEAK??
- No clutch pressure after bleeding?
- Clutch Chatter...when turning?
- anyone purchased speed inc..new upgrd.t-56?
- spec S4i update and master adjustment
- Is there a GTO shifter out there?
- will a centerforce hold 700ft lb tq?
- Life Expectancy...
- Slave cylinder install question
- not pressure on clutch at all. please help did search
- Well dont I feel like a tard... PLEASE HELP!
- centerforce max hp rating?
- Clutch won't come up
- How about a 93' 6-speed in my notchback?
- K New Clutch Time..Need Opinions
- something is wrong with my 5th gear
- Pilot bearing/bushing when going A4 to M6???
- anyone wanting to trade.
- adjusting the mcleod adjustable master and Spec update
- Clutch Break in..
- Pic of B&M Ripper Shifter
- SPEC 3i problems
- How do you get the pilot bearing out??
- Why does it seem most of the McLoud Master "fail"?
- WHO SELL ls6 clutch with a good price
- c5 transaxle directly to ls1 block for midengine project car
- Clutch install ? Need help quick.
- where to install clutch?
- Getting to the Bottom of the McLeod MC
- How to break in a Spec clutch?
- Luk pro gold ..anyone using one.
- Need help with Notchy when shifting
- Grinding
- Installed Spec 3 w/Billet Flywheel
- Power to the pavment...
- Need Help New Trans am owner
- Shaking with a stage 2 clutch and Al flywheel
- How much will it cost to have my a4 computer flashed for an m6?
- Pro 5.0 and LSS Installed
- Post your clutch swap setup and prices
- Fly wheel options?
- Corvette C6 tranny?
- who in here has made the conversion swap a4 to m6?
- Help Please! I Need To Rid My Car Of The Check Engine Light!
- Clutch Drill Mod required for a 2001????
- grind when coasting into 1st??
- what did i break?
- Clutch Pedal Sticking At High Rpm?
- Spec 3i came apart
- HELP: installed a clutch and updated hydraulics today and...
- How can I tell?
- Trans line fittings
- clutch pedal stuck
- Will the Clutch hold?
- B&M Ripper Vs. Pro 5.0, Not what you think...
- How Difficult to...
- spec 3, 3i, xpad..please explain...
- Help!! Broke hose inlet going to slave cylinder
- short throw shifters
- Spec stage 3
- need a new clutch.
- Clutch Problems
- Viper internals????
- PRT transmission?
- Aluminum flywheels and bigger cams...any idle issues??
- Hey guys Can I get a little help?
- Me not too bright...
- Whining in 5th and 6th gear....
- Pressure plate compatible with a Spec 3 Clutch?
- Should I get WS6 w/ A4 or M6
- 1-2 Grind
- Resurfacing a pressure plate????
- MityVac
- Harlan Two Step...
- Mushy Clutch Problems
- Exedy hyper Single
- do u have to get one????
- torque arm poly mount
- need T-56 rebuild HELP!!
- Pilot bearing, solid brass or roller? whats better
- My Bulletproof Drivetrain setup
- Looking for Stock Torque arm mount for a manuel transmission
- Manual trans fluid- too go synthetic or not
- bellhousing looks cracked!!
- So, how clunky is too clunky?
- Corvette Short Stick
- Anyone know the part #'s off hand for master/slave cylinders?
- What exactly grinds when gears grind?
- Indicators of clutch slippage at track
- WOT Grind in 2nd and 3rd
- Transmission taking a dump... where to buy?
- car will not go into gear...help!
- Ordered Spec Stage 4I with billet steel flyhweel
- 3rd And 4th Gear Grinding After New Clutch?
- Has anybody ever seen this?
- What will an Exedy Hyper Single handle??
- Help...Disaster...Can't get into gear...!!!!
- What shifter knob do you guys like?
- Question, possible problem, please read.
- Installed LSS on my Pro 5.0
- Do we have a blowproof bellhousing yet?
- Got my G-force T56 installed
- SPEC Stage 2 (or 3) users?
- pro 5.0 help!
- Mcleod master ,cartech clutch..high pedal pressure
- Clutch load rating listing?
- Where to get clutch
- Problem with Clutch hydralic line disconect
- Who sells Exedy clutches?
- How much hp will stock clutch take?
- help, ASP!!!
- How much it cost to get the computer flashed when converting a4 to m6?
- what did i break??
- Change master cylinder every time?
- Bye Bye Clutch...
- M6 rebuild....how much?
- Stock Adjustable Master Writeup
- Ram 510 adjustable master cylinder
- Problem leak (mods help)
- How high should the clutch pedal be relative to the brake pedal?
- What clutch are you using?
- the ls6 clutch kit
- clutch install write up
- Factory Shift Fork for M6
- hydraulics problem
- T56 & clutch break in ??
- SPEC 3i Puck design
- spec stg 3 vs stg 3i, difference?
- I have two part numbers for the 02 slave cylinder whats the correct one?
- Please Help!!!!!!
- Clutch installation instructions?
- Dropping the t56???
- 3.73 or 4.10
- short stick for my pro 5.0???
- 3rd gear problems...
- clutch question, for spec 3
- Bores size for clutch MC?
- What shifter?
- Will a New Clutch and Hydraulics Cure Notchiness
- Who has the Z06 clutch?
- Car hard to shift in to reverse. HELP!
- which line lock to get?
- Clutch install problems...
- Clutch Pedal Dead?
- What should I do about my Spec Stage 3
- can my 6spd be made to work on dads olds SBC
