View Full Version : Manual Transmission
- questions for those of you with a Tick
- looking for 3/8 bellhousing sapcer or contact info to summit racing
- Might be a really dumb question but....?
- SPEC Stage 2 Clutch Issue
- Monster clutches no longer making clutches??
- Clutch engage/disengage location issues please help.
- Clutch sticking to the floor
- Input shaft Help Please!!!
- t-5 and a 5.3 need help.
- New slave + Tick, no bench bleed. Trouble?
- Clutch/master help.
- how to remove reverse gear and vehicle speed sensor and install
- Clutch hydraulic problem?
- Diff. between 98-00 and 01-02 master cyl?
- 6speed Question
- Clunk when shifting 1-2?
- viper conversion output shaft question? *pics*
- Cant find Dexron III anywhere???!! What do I use?
- Clutch Recommendation For 600rwhp....
- Slave problem?
- Finally shortened my B&M ripper shifter if anyone wants to know how!!! Pretty simple
- Third gen fbody a4 to m5(6?) Swap?
- Parts worth?
- Need help identifying this part
- quick pilot bearing question
- Launching at the track
- Need Advice
- Monster Stage 4: DD ??'s
- Shifter getting hot with tranny fluid smell..
- Help with a part number please
- shaft rail assmebly
- Who likes their lightweight flywheel? I need opinions
- Help selecting a trans
- 6 speed rebuild
- best 6speed ls1 clutch for h/c
- Which trans mount... poly or rubber?
- Will a older style 11" clutch/pressure plate work on a new LS1 flywheel?
- Much Needed Clutch Replacement Advice for a Newbie
- T56 hard to shift into all gears, <5K miles on clutch
- What cars got a T5 5 speed in them?
- Fidanza flywheel has loose outer ring
- broken shift rail bolt!
- Hawks Third Gen T-56 Swap Kit
- Looking for clutch recommendations for my setup?
- C5 corvette torque tube input shaft run out.
- broken driveshaft
- Did I blow my Clutch Or Tranny?
- T56 differences
- High mileage T-56...
- trans and trans fluid
- monster level 3 squeal again and again and again
- Tailshaft housing leak questions
- New to Chevys Mopar man here
- weird squeaking noise
- t-56 experts please help
- transmisn fluid?
- Pro 50 junk Leaking trans atf
- New bell housing, now won't go into gear....
- where can i get a flywheel inspection cover?
- HELP!!! Throw out bearing or pilot bearing maybe?
- Tick Master Cylinder bad for daily driving??
- Anyone ever shortend a B&M Ripper shifter shaft?
- Strange grinding noise
- T56 problems
- Thinking about a Monster stage 3
- Transmission pulsing
- t56 bearing race removal?
- School Me Flywheel - Aluminum vs Steel
- LOL stock clutch vs cammed LS1.
- clutch and hydrualic replacement, won't go into gear, wtf!?
- Bench bleed?
- mn12 cup
- Common leaks on T5?
- Oil coming out of bellhousing?
- Someone tell me what happened here. PICS
- mn12 identify ?s
- question on t56
- Trouble getting tranny back in, need some tips please
- Clutch issues! HELP!
- Mc Leod flywheel problem
- Tick MC worth $300? what about pressure?
- 2 step
- Need a new clutch for 525+ rw
- differences in t56?
- *Update* "Pics Added" Lost clutch pedal totally after a hard pull??
- With monster?
- Master cylinder seal....
- Just installed monster stage 3
- high pitched whining when I shift gears...
- Reinstalling old clutch, resurface pressure plate?
- Where to buy ls1 t56 input shaft?
- Does not want to go into reverse
- Monster Level 4?
- almost finished need help!!!
- t56 rebuild
- question on monster clutch
- where to buy ls7 clutch flywheel kits
- Master quick disconnect wont go back in slave
- T56 Rebuilds starting at $680 for Stage 2
- GM pressure plate bolts
- 6th gear vibrations
- ls3 + t56 + ls7 clutch?
- Props off to Fidenza for there, no not flywheel but...
- LS7 clutch doesn't work with LS2 flywheel?
- tick remote bleeder for my new clutch, worth it?
- New Clutch, New Problems.
- Next clutch after LS7...
- Tried clutch swap, I failed! Whats wrong?
- Tick master remote blessed?
- time for new clutch...
- Good,Bad,No biggie?
- Help! T56 rebuild
- Stuck in 4th and grinding
- t56 clutch disengagement
- Bought my first LS1 with a t56
- Liberty Faceplatted T56 No first gear! help?
- Clutch Pedal Sticking.. Clutch Master Cylinder the cause?
- lost all clutch pedal while bleeding system?
- Firewall fracture after A4 to M6 swap. Pics.
- what did i break t56
- McLeod Master Cylinder Rebuild Kit
- is this a normal slave cly ?
- Textralia / QuickTime Bellhousing Install Pics
- T56 clutch failure please help!
- Master Cylinder Install - U-Bolt Problems
- Tick master w. Mcleod RXT twin ??
- anyone use RAM racing master cylinder??
- t56 wont shift into gears.
- sticking pedal problems
- Finally got a M6 swap ((( PICS)))
- Master-shift electronic bump shifter?
- M6, Tranny Problems :(
- bleeding clutch....i think im screwed
- Sounds like firecrackers in my transmission!
- witch clutch should i get??
- Had to have my ws6 towed last night.
- What you think I broke?
- clutch chatter ?'s need help please!!!
- Vibration in 6th on decel
- crazy clutch slip problem.....
- Who here rebuilds t56's?
- DFX cluch pedal feel?
- Slave Cylinder?
- brass shifter cup question
- how to convert t56 to sequential shift pattern?
- T56 Shifter
- T/O bearing again?
- Anyone got any feedback on the tick stage 2 trans package for t56
- T-5/5.3 combo.
- Reverse Lockout
- How do masters go bad...
- 2000 standard transmission issues
- zoom d2 clutch
- Monte SS T56 Question
- Reverse Poping out of gear
- Doing a t56 swap from 4l60e, couple of questions
- symptoms of low fluid???
- Spec clutches??
- Why is my digital shift lights rpms different then stock tachometer?
- Frustrated with snl/monster clutch co.
- mcleod rst twin disk or monster stage 5
- T56 vent tube....what's the white thing on the end/top?
- DD What Clutch
- strange noise and i cant push the clutch in
- ticking noise in trans, can hear near shifter
- What does everyone think?
- Differences in transmissions????
- Pilot Bearing
- Spec twin disk owners
- my shifter seems to vibrate really really hard
- T-56 Can't shift into 3rd
- Spec Stage 3+ shaking the hell out of the Car
- pulling the tires
- Transmission Chattering
- Corvette TR6060 VS T56 internals
- f1 racing clutch?
- Clutch pedal position sensor
- Think my trans is hurt
- Replacement Clutch opinons
- Mcleod RXT Twin Disk.. How is yours?
- Clutch Master Cylinder
- need help with t56 !!
- ARP LS1 Bellhousing Stud Kit
- centerforce dual friction
- Driveable but grinds all gears??
- Spec 2+ opinions
- Third gear grind unless i double clutch????
- Need a disc and pressure plate for my stock flywheel on a LT1 T56
- Master problems?
- B&m shifter ??
- t56 price help
- car wont start after blowing my trans
- t56 mt drag radial burn out
- Soft Clutch Pedal with Monster Stg 4?
- Grind while down shifting.
- T-56 oil?
- Bolts that hold on the slave cyl size???????????
- SBC vs LS1 clutch compatibility
- Please Help
- How much can these trannys hold?
- Question...
- Grinding 5th
- clutch pedal is to easy!!! help
- Should I fear for my output shaft?
- Clutch grinding from dead stop (tech info)
- t56 help
- rebuild my t56
- Which flywheel?
- Trans rebuilt, now harder to shift
- Clutch/rain issue???
- Tick Master Leaking
- no reverse
- Need some clutch help..
- Quicktime bellhousing owners inside
- Expert opinions needed
- clutch pressure problems
- Monster Level 3 Chatter
- Still having problems with Reverse - New Symptoms
- Replaced master & slave
- t56 yoke length
- LS7 Clutch setup won't bleed
- Leaking at clutch quick connect
- What brand T-56?
- Monster update!!!
- t56 build up
- LT1 vs LS1 internals
- Royal Purple Synchromax
- T56 lost 2nd gear??
- Oil in clutch
- car wont go into gear at high rpms
- Gto slave or f-body
- *HELP* Grinds in all gears PICS INSIDE
- clutches?
- help with bad clutch work
- 94 camaro slave cyl?
- Need a T56 transmission..
- C5 Z06 clutch is good for how much power?
- Spec stg 3 disk 11'', stock LS6 disk 11 3/4''?
- What Clutch to buy?
- Where to get a new slave
- Replaced some parts still hear a noise???
- 01' WS6 LS7 clutch launch issue after 13k miles
- Clutch Engagement Point With Tick Master
- Quick Time Bellhousing ?
- Skip shift Cylinod
- Mcleod clutch
- Need Help-Is it possible to overpush the TO bearing on a T56
- new clutch still shifting problems
