PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 [130] 131 132 133 134 135 136 137
  1. skip shift eliminator
  2. HP limits of t-56?
  3. Convert Hydraulics to Cable Clutch
  4. Mcloed adj master problems help PLEASE!!!
  5. Stock hurst shifter vs. 5.0 Pro? Oppinions Please
  6. new clutch..any suggestions
  7. 600+ rwhp + stock driveshaft = ?
  8. SPEC pressure plate failure??? what broke off my clutch?
  9. Hurst Billet with LSS to Pro 5.0 with LSS
  10. Should I use McLeod adjustable master cylinder?
  11. Hurst short throw shifter, was it a GM or SLP option?
  12. replacing clutch
  13. bleeding the clutch hyd.
  14. notchy shifter?
  15. Can you do the drill mod on 02 cars?
  16. ZO6 Clutch limitations
  17. clicking noise in clutch
  18. Tranny mounts the same from 93-02 for 6 speed?
  19. smoked my driveshaft and tq-arm today
  20. Cannot line up tranny to bolt on bell housing... M6
  21. can't seem to line up tranny to re install
  22. clutch gurus please help
  23. Clutch Problem?
  24. Insatlling new tranny in the morning!
  25. M6 Woes Again...
  26. Anyone ever replaced the springs in their shifter?
  27. Short Shifter
  28. Has anyone MIS-SHIFTED with Lous Short Stick (LSS) ???
  29. Which clutch for my setup?
  30. Richmond Transmission
  31. Clutch feels funny, is this normal?
  32. Whats the real story on bench bleeding???
  33. GF grinding gears
  34. Do I need to have my stock flywheel counterbored?
  35. 99+ Silverado transfer case behind T56?
  36. Problems going into second
  37. T-56 stuck in 4th problems ....not from bent 3/4th fork
  38. clutch super hard
  39. Question about clutch alignment tool...
  40. 98 and newer t56 master cylinder
  41. Spec stage 3 clutch is squealing still!!! Help!!!!
  42. Who has a D&D T56 ? got a question....
  43. Help finish my parts list for T-56 conversion
  44. New Clutch Adj master, cant switch gears :)
  45. Updated 01+ Clutch Master or McLeod Adjustable?
  46. V6 master cylinder vs. V8 master cylinder
  47. Differance between T56 and A4 tranny mount??
  48. 93-97 T-56 are good 98-02 T-56 are junk
  49. Questions Concerning Rebuild
  50. Pro-Shifted
  51. Shit for 60' times
  52. Is my clutch bad?
  53. M6 swap speedo question....need HELP
  54. How to make stock master adjustable
  55. crappy burnout? weak clutch possible?
  56. sorry guys, know this doesn't go here, but i need HELP
  57. how to tell difference in a LT1 T56 and an LS1 T56
  58. slave question
  59. How much is a stock T-56 worth?
  60. Pro Shifted T56
  61. Have Pre Bled Master. 01 car, do I need to bleed slave?
  62. STOCK Z28: optimum shift points?
  63. What is the T56 worth?
  64. Who has good Instructions for Spec Stage III Install?
  65. Which Part # is the latest slave?
  66. Clutch Problem...need help
  67. Manual or Automatic?
  68. power loss? clutch slipage possible?
  69. Won't Shift into 2nd Sometimes
  70. t5 to a t56 in a 2000 4.8 sierra?
  71. Pro 5.0 or B&M short shifter
  72. 430RWHP, Spec stg3, Do I need new hydraulics?
  73. clutch for pretty much bolt on car, no more than 380 rwhp
  74. adjusting my stock clutch??!?!
  75. Car does not go into 3rd sometimes??
  76. how to swap to a manual????
  77. Ever blow out a slave cylinder?
  78. Opinions on Clutches!!!!!!
  79. Stroker guys: How long has your T-56 held up for?
  80. mcleod master problem
  81. Hurting clutch?
  82. 3rd gear problem - kind of weird.
  83. Bleeding CM with Mityvac,Constant Air bubbles,notchy Shiftin
  84. clutch fork, tranny fork ?
  85. Anyone here use the Yank crossmember?
  86. ok... Why won't my car go into reverse??? Thanks
  87. OK, what did I break?
  88. After market slave.
  89. Clutch Break-in procedure SPEC Stage III ??
  90. Problem w/ new Pro 5.0
  91. transmission gearing??
  92. what kind of shifter do i have???????
  93. Star spec stage 3: Carbon fiber Vs. Kevlar Vs. Ceramic ?????
  94. Rattling after fluid change M6 Dexron 3
  95. Bad Mcleod Master Cylinder?
  96. LS6 & Richmond ROD (6 Speed)
  97. Gotta problem with my stage 4
  98. how muck HP will a 2001 6M trans take?
  99. Car still doesn't shift at high RPM's....After MC bled...
  100. hard clutch pedal after a run *DELETED*
  101. sort sift tranny noise ???
  102. Thank You TSP!
  103. M6 Gurus please help!
  104. What does this means?
  105. Twin disk with new hydraulics In but heard noises on startup
  106. Slipping a nasty clutch in stop+go traffic == really bad?
  107. tri-ax shifter for mustang t-56
  108. Tranny makes grinding noise in gear under accel
  109. Z06 Clutch/Flywheel install
  110. newbie question: what exactly is clutch chatter?
  111. hydraulics question
  112. Guys with 2001 + raptor shift lights,I need ur need help .
  113. Anyone have problems with MTI Skip Shift Eliminator
  114. High horsepower / streetable clutch needed.
  115. Powershifting
  116. where is the best place to buy a spec stage 3 clutch
  117. trans wont shift when hot?
  118. Does this sound like a hydraulics problem?
  119. Any special tools needed fot T-56 rebuild?
  120. Lou's Short Stick
  121. do i really need the adj. master ? or ...
  122. Clutch problem (long)
  123. Hurst Shifters...Questions
  124. Original Clutch?
  125. Which clutch should I use for my setup?
  126. anybody want to trade A4 for M6 setup?
  127. What Clutch does not need special shimming (want a bolt in)
  128. New flywheel question
  129. Huge Problem, need help!
  130. Broke my second trans last night (experts please chime in)
  131. McLeod Clutch??
  132. NEED HELP FAST!! anybody know how to wire b/u lamps?
  133. HELP! Is my trans dead or is something else messed up?!
  134. Flywheels, Resurface or New one? Getting Spec Stage 3!
  135. Syncros from D&D Performance
  136. Anyone ever used ARP flywheel bolts? got a question...
  137. What is the drill mod?
  138. Flywheel Bolt Torque?
  139. New to a stick, is this normal?
  140. shifting problems after 9'' install
  141. Problems with new clutch
  142. Any f-bod shifter equal to Breathless vette shifter, or..
  143. M6 knocking sound when clutch is out......
  144. Come on M6 guys...
  145. McCleod Clutch Master Cyl
  146. Slave Cylinder
  147. Drill size for slave cylinder?
  148. Wiring for M6 conversion
  149. automatic to manual
  150. clutch problem, fluid maybe?
  151. installing a fidanza alum. flywheel {i have a question}
  152. clutch for bolt on car?
  153. Pro 5.0, B&M Ripper????
  154. Grinding 5th....
  155. Pops out of reverse
  156. McLeod Clutch??
  157. True or False: Aluminum flywheel is bad for drag racing.
  158. Do I need an adjustable Master Cylinder?
  159. Clutch pedal question
  160. Can't get hydrolic master line in slave.
  161. Questions on synchros. Input needed!!
  162. Clutch won't come back up...
  163. Clutch is acting wierd
  164. Skip Shift Eliminator Install???
  165. how do you gravity bleed a clutch???
  166. Is your M6 hard to shift at high rpms? Come in for the fix!!
  167. What clutch to go with?
  168. Anybody know a "how to" on bench bleed the MC ?
  169. Will a new T56 bolt up to an older small block?
  170. please answer a stupid ? for a M6 newbie....
  171. Researching RAM VDS (Stick only, in here please)
  172. Yet another question - any idea how to adjust Cartek's MC?
  173. Steel or Aluminum Flywheel w/ SPEC 3 clutch?
  174. need clutch help guys please.
  175. Chatter VS gearing
  176. Ram VDS pedal pressure?
  177. Pops out of 3rd Gear
  178. PLEASE help.
  179. POS Cartek clutch, need opinions on 2 choices for a new one
  180. Anyone using GM Syncromesh?
  181. How to cut the bell housing to cool the clutch?
  182. Which is the rright slave PN?
  183. New Master Needed for Z06 Clutch?
  184. has anyone converted an automatic to a 6 speed transmission?
  185. Clutch bleeding problems
  186. Hooking the slave up
  187. t56 skip shift disable
  188. Need a Cheap Clutch
  189. I hate my car
  190. What's the record for a RAM 402/6130/stock flywheel combo?
  191. MAC's burninate my hydro line ... need part number (please)
  192. Strange Noise!!!!!!
  193. Bolt size?
  194. I need a clutch
  195. Help me decide on an aluminum flywheel...
  196. has anyone ever rebuilt a mcleod master?
  197. Best Place to Purchase Pro-5.0 Shifter
  198. SPEC clutch
  199. trany wont go back in
  200. 425+ RWHP guys, what clutch are you using....
  201. looking for info on swap anybody got and idea.
  202. clutch question help
  203. Strange Noise
  204. Spec S2, M/C & S/C ordered. Question inside.
  205. Clutch
  206. B&M Ripper question?
  207. Hydrolics problem??
  208. will a b&m ripper on a '97 ws.6 fit/work in an '01 ws.6?
  209. i need a t56 for a ls1 and all the stuff to change from a4
  210. Nut size for master cylinder?
  211. pilot bearing
  212. How do I check my tranny fluid???? 99 M6 (pics)
  213. want A4 to M6 trade around Texas area
  214. What are diffs. in steel, kevlar, etc for flywheels?
  215. Changing Tranny Fluid and a bit nervous
  216. Rebuilding Tranny & New Clutch
  217. slight grinding into second at high rpm's
  218. output seal
  219. Need New Clutch. Which one?
  220. B&M Ripper, help save synchros? How about 3-2 misshift?
  221. bellhousing
  222. Slave Cylinder
  223. t-56 question, may need to rebuit
  224. Guys PLEASE help!
  225. short stick...where to buy?
  226. What is the advantage of a billet flywheel vs stock?
  227. Rebuild or New
  228. flyweheel
  229. Stuck in fourth? HELP!?!?
  230. clutch noise
  231. Average cost for clutch and 12 bolt installs?
  232. help
  233. Return Spring
  234. what clutch?
  235. looking to get a t56 either trade or find one forsale
  236. Transmission Grinding very bad
  237. flywheel
  238. Spec stage 3 ceramic what else do i need?
  239. Bulletproof T56? Anyone make them
  240. can someone help me
  241. RAM Clutches tech notes - VDS and 980 discs
  242. All right, I'm an idiot, how do I install a Hurst shift KNOB
  243. Can't get master line off of tranny? Help!
  244. clutch problem or not?
  245. How to save the T56.
  246. How much to rebuild a t-56???
  247. Need help reassembling Mcleod adjustable master....PLEASE!
  248. OH NO MY CLUTCH!!!!!!
  249. My clutch smells?? Does that mean...
  250. NEED ANYTHING ELSE FOR A STAGE 3 CLUTCH
