PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Just purchased a SPEC 1 clutch
  2. Will Not Go Into 2nd Gear At WOT..?
  3. please help
  4. Sensor HELP
  5. *HELP!!* New clutch, wont go into gear
  6. help with wat i think is the rong trane cros brase link to its a 96 m6 car
  7. RAM HD clutch slippage !?!?!?
  8. Where can i find torque specs?
  9. Tranny fluid coming out of bellhousing
  10. Salve To Master Line ??'s
  11. Zoom twin disc clutch(stage 2), any thoughts?
  12. Everyone who uses mcleod clutch come in please..
  13. Salve cylinder throw out bearing
  14. Upgrade clutch or wait..
  15. LS7 Clutch Where to buy?
  16. T56 help
  17. Spec Twin Disc Clutch USERS COME IN!!!
  18. Clutch won't release after install.
  19. Spec stage 3+ clutch issues under spray !
  20. clutch noise ?
  21. T56 Builders
  22. Might be a stupid question
  23. which slave cylinder??
  24. think i broke a tranny mount?
  25. anyone run this flywheel?
  26. LS1 T56 parts?
  27. Will Stock Slave Work With Ls7 Clutch?
  28. New Clutch Suggestions
  29. Clutch or something else...
  30. Silicone in Clutch Master Cylinder???
  31. LS7 clutch install advice - FWIW
  32. Need clutch help... hydraulics aren't releasing the clutch at high rpms...
  33. Grinding with letting OFF the clutch...
  34. Quicktime bellhousing
  35. t5 swap FLYWHEEL QUESTIONS
  36. T56 carnage from the dyno...what happened?
  37. Can the "updated 01-02" slave cylinde be visually identified??
  38. filling tans up
  39. pilot bearing ???
  40. Track / clutch question
  41. Corvette LS1 and F-body T56
  42. clutch or throw out bearing????
  43. Wow look at my flywheel!
  44. 3rd gear pop out + 4th gear sticking... damn it
  45. Valeo LT4 PP and Misc Disk? Flywheel?
  46. will my trans be blowing apart?
  47. Spec pressure plate + ram disc
  48. T56 6spd output shaft oil seal
  49. who else has this issue with a stage 2 clutch??
  50. Putting in new clutch
  51. reverse lockout part number
  52. Lookin for a short shifter...
  53. WTB T-56 FOR 01 z28
  54. clutch slipping??
  55. Street Legal TV's Article is out! Quickest and Fastest M6 Article
  56. Why is 3rd and 4th vibrating?
  57. pedal question
  58. best trans fluid to get
  59. ls7 clutch install problem?
  60. Clutch Not Acting Right!!!! HELP!!!
  61. what gear is 1:1 ratio
  62. I Need Help!
  63. Clutch grabbing high, pedal adjustment without master cylinder adjustment
  64. Is this an O-Ring for the Slave?
  65. Reverse problem...
  66. My T56 Swap *Pics* 56k Warning
  67. This shouldn't happen should it???
  68. Looks like i need a clutch few q's first tho
  69. trans top hat replacement
  70. Clutch hydraulics
  71. May Special "April Special's Extended"
  72. Clutch Problem, Plz Help!!!!!!!
  73. Part # For Hydrolic Hose
  74. REAL feedback needed - T-56, Twin disc clutch, peddle effort
  75. Want a new transmission mount, have some questions
  76. Dual disk clutch, flywheel and floater clean up?
  77. Now there is another problem with my M/C
  78. How Much Brake Fluid?
  79. Transmission Mount Help M6
  80. T56 help...
  81. quick drill mod question
  82. Maddog stage 3 clutch kit ?
  83. Centerforce clutch
  84. T56 problem after swap!
  85. finally starting tearing down the T56 today, pics inside! (warning 56k)
  86. Hydraulic adapters?
  87. Trans builders please come in, check out these pics
  88. Thank God for Adjustable Master Cylinders
  89. 4 Gen M6 pedal????
  90. Problem w/ Reverse T56
  91. Do I need a bellhousing?
  92. New clutch: Pedal Wont move
  93. Torque arm ideas?
  94. which clutch?
  95. time for a new clutch
  96. T5 inquiries
  97. Congrats Amber and Joe (SixSpeedsInc) on the new addition!!!
  98. torque arm came loose while driving ???
  99. Does LS7 Clutch,Flywheel,Pressure Plate come Balanced
  100. Going for 10's N/A and 9's on spray, Stay T56 or go TH400/Transbrake?
  101. do i have to cut the floor to fit the t56 on the 67?
  102. Clutch engagement problem???
  103. wiring help needed for swap
  104. clutch pedal?
  105. Still no 5th,6th or rev
  106. Hmmm Clutchs Clutchs Clutchs
  107. LS7 Clutch
  108. Drag Clutch Death Illustrated
  109. So this cant be normal.
  110. Having Problems.....
  111. Only Users Please Vds Vs Tex
  112. '69 Camaro 4-speed - wanting to go T56
  113. need help ??????
  114. ExoSkel trashed before 3k
  115. drill hole
  116. Whats the difference between early and newer T56 ?
  117. clutch and pressure plate
  118. My M6 swap saga.
  119. Throwout bearing clearence
  120. Slave Fluid change ruined my hydrolics
  121. Help Please!!!
  122. T56 vs. M4
  123. ? on B&M ripper
  124. Any of the Sponsors Rebuild Ford Trannys?
  125. slave cylinder help needed!
  126. Clutch Test: A must do!!
  127. Pulling 6th?
  128. clutch line and DRiveshaft?
  129. high whine sound from tranny??
  130. M6 Swap Underway
  131. clutch issues
  132. LUK gold clutch and flywheel junk?
  133. Losing Clutch Fluid
  134. Trying to install T56 to 99 LQ4 Motor
  135. Whining noise between gears
  136. Help, grinding noise when I push in the clutch
  137. Launching on a new LS7/LS2 combo
  138. ATTN: Spec Stage 1 users and ex-users
  139. wierd grinding noise at low speeds
  140. Anyone else wish their T56 ratios were better spread?
  141. Got my transmisson back form GEARBOX.ORG
  142. Pedals install
  143. Dust Cover Screws??
  144. Launching on a new LS7/LS2 combo
  145. Another SPEC prob. Maybe??!!
  146. Have A Look At My Clutch
  147. drill mod
  148. Anyone broke a Tex OZ700 clutch?
  149. Cheapest LS7 clutch kit?
  150. HEHE... my Spec Twin :)
  151. bad clutch or bad slave?
  152. Another bleed thread advice please.
  153. need help with drive shaft
  154. CRAZY rattle sound when I first start to move.
  155. I cut down my hurst shifter.. nice mod
  156. Your choice for clutches
  157. clutch dragging
  158. t5 clutch
  159. torque arm mount
  160. Pro 5.0 question
  161. Output shaft bushing??
  162. Pressure bleeding or vacuum bleeding clutch questions
  163. Clutch Fluid Questions
  164. need help
  165. Ls7clutch + No2 = ?
  166. t-56 oil
  167. LS7 clutch grabs low?
  168. Need Help !! Wierd Thump Noise Coming From The Tranny Area , Help.
  169. Clutch question?
  170. Couple t56 removal/installation questions
  171. Dark clutch fluid...
  172. blowproof bellhousing?
  173. Need help ASAP with hydraulic issue Please!!!!
  174. How do you tell what slave you have?
  175. Free Play on Clutch Petal
  176. what trannsmission
  177. What NOT to do with a T56
  178. Textralia Disk
  179. LT1 T56 Bbody problem
  180. Shifter Not Centering
  181. How does this clutch look
  182. Clutch options for turbo setup
  183. Shift Lights
  184. $1500 to spend
  185. Best Short Stick?
  186. Please, God, help me with this vibration
  187. m6-a4
  188. Clutch question
  189. Need C Clips for 95 Pedal assembly
  190. Will LT1 6-speed tranny fit LS1
  191. So What clutch do I get for my car?
  192. Symptoms of a bad master?
  193. all dexron/mercon III the same?
  194. Change clutch now or when it goes out?
  195. Lookin for best T56 Clutch under $500
  196. What do U Guys think of Spec 3 Clutch.
  197. Reverse lockout solenoid circuit questions
  198. t-56 starter
  199. Which clutch?
  200. fenco clutches- Any good?
  201. How many of you have....
  202. Centerforce clutches suck for my LS1
  203. do rebuilt trans. come with trans. fluid
  204. T56 fill question
  205. tranny install question
  206. 93' T56 Tag #'s ????
  207. T 56 pedals
  208. looking for a T-56 that can handle over 800 rwhp
  209. lt1 t56 bellhouisng
  210. SPEC 3 Hop after 500+
  211. Textralia OZ 700 Z SFI spec?
  212. Strange noise coming from trans under decel, any ideas?
  213. averege cost for cluth and flywheel install!
  214. Anyone know where to find a clutch hydraulic hose
  215. exoskel pp bolts
  216. who has the best deal on mcleod
  217. My Official Textralia OZ700 Z-grip Review
  218. giving it another try today..
  219. Lazy Pedal
  220. OK, to clear up some LS7 clutch and Flywheel ???'s
  221. replacing shifter top hat
  222. LS7 clutch and Fidanza FW
  223. New GM Twin Disc Clutch???
  224. Clutch Care..Yes I Read Sticky!!
  225. Have an Idea for a 3rd to 2nd gear lockout when Drag Racing
  226. Resurfacing Billet Steel Spec Flywheel
  227. how much hp can the stock 01 clutch handle?
  228. Spec Twin Disk
  229. LS7 Clutch Chattering
  230. The line from the master cylinder to the slave cylinder
  231. Who is running the Hurst shifter?
  232. ls7 clutch part number?
  233. pulling tranny with solid motor mounts
  234. LS7 Clutch installed.... need input!
  235. Stock clutch grabs high
  236. performance clutch
  237. 2nd gear grinds sometimes
  238. T 56 bolts
  239. Surface Pressure Plate
  240. T56 assembly question
  241. T56 problem with reverse and 6th
  242. Plastic Shields??
  243. Textrilia: What color is the X Grip and what color is the Z grip
  244. Is the Ls7 clutch for me?
  245. Any way to lockout 2nd gear over "X" mph?
  246. shifter springs
  247. quick clutch alignment tool question
  248. People who can shift FAST step in please.
  249. Any Insight?
  250. Just wanted to confirm LS2 Bellhousing?
