View Full Version : Manual Transmission
- Clutch disc?
- What's fair price?
- Fairly new clutch help!
- 1999 camaro trans help
- Will an '03 C5 T56 fit in an '01 SS?
- clutch or master cylinder issue?
- its rough
- Odd T56 problem (03 Z06)
- Shifter rubbing center console.
- Tick Master leaking by firewall
- T56 Hurst Shifter Question?
- Like RPM Transmissions on Facebook!
- Throw out bearing differences
- tick master, clutch travel when warm
- Clutch Disengage Issue..Please Help
- Hydraulic line to master cylinder fitting?
- Need help - Clutch / Hydraulics issue
- Popping out of gear..... Need help.
- rod from pedal to master snapped
- Ls7 clutch
- Tick master rod loose?
- rusted clutch
- Clutch Smoked lastnight!
- forks gone bad?
- clutch questions and bolt sizes????
- Difference between some T56 trannys -need to know before I buy
- Aftermarket Bellhousing?
- Why you should upgrade your clutch
- 18,000 miles on a faceplated daily driver T-56
- Clutch Starter Switch Issues
- Squeaky clutch when pressed
- ls7 clutch help!!!!! c5 z06
- Tired of babying my car, help me find a clutch
- Problems after reinstalling my built T-56
- Oppinions on Hurst Billet/Plus shifter
- Tick Master, New Slave, Remote Bleed, New Clutch still not holding
- Trans mounts?
- Possible to lighten clutch pedal pressure?
- Pics of my new Hurst white ball shifter
- Texas Drivetrain Performance Reviews Wanted
- Viper tail housing bushing?
- Bellhousing bolt problem
- B&M Shifter Boot
- monster stage 3 clutch kit
- First gear grind. What could it be?
- Won't Go Into Reverse
- Shorter 1st Gear?
- looking to trade for a white ss ball shifter
- Hurst Plus Shifter?
- t56 borg warner pricing??
- Where can I finde a transmission mount
- 96 lt1 clutchless
- Another What clutch to buy
- Clutch and lighter flywheel
- Faceplated + Cryo treatment...
- Clutch and pressure plate
- Affordable way to get 1pc Countershaft?
- 2010 Camaro trans issue
- Used T56 w/ unknown history, into a turbo truck = rebuild first?
- Weird clutch issue? Need help
- CANNOT get trans out - will move 1-2 inches back then stop
- Vibration issue!!.....Ready to sell car..HELP!
- Huge decision to make please help!
- Unsprung clutch disks in street cars (newer twin disks)
- DIY faceplates?
- ~Dilemma! No pedal pressure...New Install~
- Some LS7 clutch questions
- t56 problem
- unknown oil
- Tick master & Pedal Travel
- Clutch Upgrade
- T-56 Transmission Mount Swap: A How-To
- Manual Transmission Fluid Change
- Spec Stage III clutch/throughout bearing shimming
- Pro 5.0 replacement bolts
- Issues after TICK Adjustable Master
- ID this shifter
- Can clutch from TR6060 work with T56?
- Anybody having problems with QT #8020
- raptor shift light (red wire??)
- Mcleod or Quicktime bellhousing (LT1)
- T56 life span, normal abuse?
- New clutch and flywheel
- lt1 t-56 on a lq4
- Re-use Pressure Plate w. 5k miles?
- C5 shifter alignment issue ;(
- Best slave for t56
- Best prices near Houston for T56 stage 2 outright?
- Master & Slave need replacing...what brand?
- GTO T56 help
- lucas transmission fluid?
- How to prolong the life of your clutch
- Shifters
- Too much clutch for my application?
- Haven't installed my pro 5.0 yet
- Is it my clutch, MC, or T56 that is shot?
- Finished swap, clutch won't disengage
- Name that flywheel!
- Pontiac engine to T56 trans
- clutch disconnect tool
- stock LS2 flywheel thickness
- Lt1 Clutch wont disengage
- Clutchless
- T56 GM oil problem
- clutch pedal bushing, see pic
- I bleed and bleed and still don't have a good pedal :(
- a4 to m6 conversion ses light comes on
- t56 problem when decellerating
- Anybody worked on a T5 before?
- Monsterclutchoutlet.com any good?
- wont shift into gear when running
- What to use to clean clutch with?
- LT1 T56 replacement flywheel mark
- Clutch help
- About to smash my tick master with a hammer. Help!
- Clutch Pedal Sticks To Floor??
- Clutch Adjustment
- In need of a cluster gear bearing
- 2001 lm7 + t56
- Clutch life span?
- Really dumb pedal question
- Pretty sure my Spec 3+ disintegrated last night. Had to tow. Seeking words of wisdom.
- 95 T56 - Trans Mount Bolt Size?
- Best shift points for stock LS1
- looking to swap my a4 for ur m6
- Rebuilt T56 or buy a T56 Magnum
- Hard shifts now gears grind
- Cant say enough good things about Monster
- New tick master same old problem...
- SPEC clutch questions
- PLEASE HELP ME!!! VIDEO INSIDE!!! Slave cylinder question.
- tick master install and adjustment
- Clutch feedback
- t56 input shaft broken.
- Anyone know if zoom rebuilds clutches.
- Anyone ever painted there T56?
- Need a measurement off stock clutch master cylinder
- I'm lost
- Input shafts for T65
- Clutch upgrade for LT1.
- Anyone know where to get a flywheel resurfaced in socal
- 3rd popping out is pissing me off.. HELPPP PLEASEE!
- T56 ????
- ok, what did i break? Reverse is a PITA!
- Clutch engages with the pedal close to the floor
- 2000 SS 6 speed VSS??
- 2000 SS 6 speed speed sensor fix?
- Tick Master factory slave line no releasing
- Where are you guys finding T56's for cheap?
- 01 camaro 6speed swap questions
- trans fluid
- Will it wear out the clutch if I hold the clutch at stop lights?
- Tranny install PITA any suggestions?
- Tr6060 conversion help
- Having a hard time shifting after spec twin disc clutch install "sc66pt"
- Help 98' Firebird 5 speed V6 pops out of 1st gear
- What clutch is needed to use LT1 T56 on LS1 motor?
- How much was your A4 to M6 swap?
- Another satisfied Tick Master Cylinder customer.
- Tick M/C and DOT5?
- crap! was told i need a Clutch kit...which one?
- HELP me collect some date - Take a look at this...
- Noisy Clutch/Ticking or like a Chattering gear noise
- What could it be my transmission or my bearings?
- Protecting clutch fluid line from heat
- t-56 rebuild, so many options need help!
- Clutch Pedal Engagement?
- This Hurst shift handle doesn't fit right!
- Newbie Spirited driving question
- Just bought an 02 Z28 M6 - Questions about the clutch
- Needing a T56!
- Sorry for asking, m6 filter?
- Someone explain this to me......
- Spec clutch Yes or No?
- High power LT1 clutch options
- No Reverse After Rebuild: 2004 GTO T56
- which clutch...did search...need some input-
- Pedal sticking.... >:[
- Hurst Short Shifter
- Tick master ordered
- Rebuilding my own T56
- pedal pressure issue! HELP
- lookin at the mgw shifter-opnions?
- t56 Problems
- Muncie 4 speed and 4.10 gears
- sinking clutch pedal
- T56 Rebuild/Upgrade parts from where?
- ebay flywheel?
- Stinking clutch
- missing bellhousing dowel
- Check my clutch setup
- Clutch advice
- Flywheel Runout...?
- '99 Firebird Hydraulic Clutch hose
- Please Help, Tick MC adjustment issues!!!!
- In stalling 6speed(stock) need some help.
- ls1 tranny question's
- How to install a B&M shifter?
- 6 puck or 3 puck clutch?
- New SPEC clutch new slave, having peddle problems
- Hydraulic leak from Master to Slave
- Bad slave?
- having trouble choosing what to do (clutch)
- T-56 Transmission confersion
- Transmission Faceplating?
- Tick Master Cylinder Install and product review
- Should I be concerner????
- now what? humming noise and rat.tat.tat
- quick clutch question
- t56 guys making big power...COME IN!!
- At shop, need to locate bleeder screw
- ahhh i need a clutch for the bird!
- Is my clutch MC working?
- T56 in 70 Camaro
- trouble going into gear. hydaulic issue?
- Serviced my T-56
- LS7 clutch manufacturer?
- built 4l60e swap for a t56 swap
- WTT my complete BUILT t56 setup for your BUILT 4l80e setup! Austin, Tx
- New T56, What fluid to run???
- McLeod rst break in
- Clutch Pedal Pressure and Ticking Sound???
- Looking To Faceplate My pig...... but I have some?????'SSSSS
- best deal to buy parts for mn6
- Tick Master Question
- Getting Serious about this A4 to m6 swap... final questions
- T56 Sensor/Switch ID help. See photo
- hydraulic clutch help
- why isn't the 6 speed fastest list not updated?
- New ls7 clutch problems
- Calling all T56 Rebuild Companies!
- Tick Master Did It Again!!!!! One Qustion Though???
- Anyone out there offer LT1 t56 rebuilds? Stage 1/2/3? HELP
- slave cylinder shim with LS7?
- shift knob removal/install question
- Ls1/t56 rx7 clutch issues
- RXT after half the year street/track. Pics
- t-56 not going into third gear
- T5 questions
- TR6060 rebuild help
- LS7 Clutch sale $425
- Slave cylinder problem
- Buying clutch this weekend, sponsors come in!
- stock oem hurst shifter stick
- Monster/Tick. Does this sound like air trapped in my M/C?
- Checking my T56
- wtf does my revers grind when i put it into gear
- pigtails needed?
- 5th and 6th are Phhhucked up
