PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Did i get lucky bench bleeding?
  2. Parts to replace during rebuild?
  3. Mity or Mighty?
  4. What Flywheel to use for old style 350 & T56?
  5. issues putting my T56 into Gear, need help
  6. Having an issue with a new LS7 clutch kit...
  7. #6 boot , wher can I get one
  8. Transmission ratios
  9. tranny whines like a rear end....
  10. i want a stick shift
  11. How rounded can syncro teeth be?
  12. To GM Synchromesh It or Not?
  13. Rebuilding -- what's necessary?
  14. Poly mount the same for A4 as M6?
  15. new clutch no work
  16. Trans issue
  17. How hard is it to install the Tick Master Cyl?
  18. looking for a bullet proof t-56
  19. Need help removing line from slave
  20. leaking/ boiling? wtf? 01 t56
  21. small pieace
  22. 4-5th goes into REVERSE ALOT! HELP
  23. New clutch problems
  24. what would you do? grind into 2nd
  25. where does this attach on the tranny?
  26. disk Q -will this work?
  27. Sell me a remote bleeder
  28. Clutch went out....?
  29. What clutch/flywheel for very light TA H/C
  30. advice/opinion failing parts
  31. Help identify possible problem...
  32. Transmission Crack Plz help
  33. f-body crossmember work on gto
  34. NOW OFFERING Tick Performance & TICKshift.com T-Shirts!
  35. transmission swap
  36. 850hp DD lt1
  37. LS7 clutch without Slave/Master
  38. New Clutch install and no Reverse still
  39. Help
  40. filling/ bleeding after clutch, master, bleeder install?
  41. bellhousing bolts
  42. anyone here try an acdelco clutch?
  43. T56 in a 99 v6 camaro
  44. Will this shift knob fit??
  45. help crazy noise!
  46. B&M short shifter install problems
  47. T-56 discussion GTO or LS1, stock or?
  48. Clutch pedal stuck to floor?
  49. Rebuilding T56 need input
  50. A little birdy told me that Monster Level 2 Clutches...
  51. Lvl 5 Monster in motion
  52. may have problem with street twin
  53. Happy Tick Customer
  54. crank freeze plug
  55. Weird Clutch Problem...HELP!!!
  56. very light clutch pedel
  57. spec stage 5?
  58. Z06 T-56 into F-body?
  59. Tick master cylinder install (track review)
  60. t-5 to sbc
  61. Torque specs for Tex PP bolts?
  62. Odd tranny problem
  63. LT1 to LS1 clutch hydraulic swap?
  64. hydraulic problems
  65. Monster Clutch 500 + mile update:
  66. What Twin?
  67. Please Help!!! Bad vibration.....
  68. Hooray for the stock 85,000 mile clutch!
  69. T 56 Removal Question??
  70. breaking in procedure
  71. How to tell if I have Hurst Shifter?
  72. lifespan or tex oz700
  73. Pressure Plate Bolts
  74. rattling sound during shifting
  75. tranny moving?
  76. slave cylinder not disengaging?
  77. 455 pontiac to t5?
  78. Clutch Fluid
  79. Cobra Shift Knob On Camaro
  80. GTO Clunky Shifting
  81. need help
  82. pilot bearing ????
  83. Intalled new clutch today, wont disengage?
  84. where can I buy a T-56 shift rail?
  85. B&M Ripper Shifter not short enough
  86. Monster Clutch needs your feedback!
  87. Six Speed INC Help
  88. starts moving at 5k
  89. C5 Reverse Issue
  90. 4th Gear issue
  91. Best way to bleed all new clutch hydraulics?
  92. Fluid Question
  93. Possible tranny noise??
  94. Spec 3+ before shim too low with shim too high
  95. Monster clutch
  96. M12, or T56 for my set up?
  97. Tick Master Cylinder
  98. Broke faceplate in T56
  99. MGW vs. Pro 5.0
  100. How Often Does a Slave Cylinder Need to be Changed?
  101. Thank You TDP - Jason Bailey
  102. Wont Go Into Reverse???
  103. Textralia FKE Grade 12.9 socket head bolt
  104. Clutch Pedal Spring
  105. Found something weird doing my clutch swap!
  106. What causes this to happen to a practically new spec twin disc
  107. clutch problems
  108. How Much Power/Torque will the LS7 Clutch Pkg Hold?
  109. t56 with bolt on transfer case? awd
  110. amount of "play" in transmission HELP
  111. T56 wiring help!
  112. will this happen?
  113. Shifting into the wrong gear stories
  114. Reverse Problem
  115. Bought used T56 questions concerns inside w/pics and video
  116. pilot bushing install help
  117. Won't go out of gear
  118. TICK master w/ LS7 clutch???
  119. A4 to m6 need help
  120. Few ?'s
  121. Do I Need to Turn My Drive Shaft 180 Degrees? ? ..... Help me out!
  122. LS7 clutch kit backordered?
  123. torque specs please :)
  124. help
  125. How Do I Adjust Tick Master
  126. TO bearing noise
  127. Factory slave shim
  128. Can't decide, Spec Stage 3 or Monster Level 3
  129. which clutch?
  130. Where to find the braided master to slave line?
  131. textralia owners chime in
  132. clutch swap question
  133. Crank freeze Plug ?
  134. LT1 T56 Mcleod Scatter Shield PICS!
  135. Bad Slave??
  136. Torque Specs?
  137. Install of tick bleeder line
  138. Help with Exedy Twin Disk, Pics Inside
  139. monster clutch: half stages?
  140. help with Spec 3
  141. T56/9 in
  142. Did the slave measurement, NO GAP... now what?
  143. how many quarts to fill a t56
  144. Need clutch
  145. Way To Go TICK!!!
  146. Bleeding With Remot Bleeder??
  147. Spec Stg 3+ .. HEAVY AS HECK?!?
  148. help me diagnose my tranny problem...
  149. Anyone know where to get those "roselock" bolts?
  150. T56 Tailshaft Part Number
  151. Transmission Carnage (pics inside)
  152. Monster Clutch Co.
  153. M6 behind a '99 LQ4 will it work?
  154. Can anyone identify this Adjustable Master Cylinder?
  155. clutch acting up. how would i adjust freeplay?
  156. cllutch slip question
  157. Still can't get my clutch to work...
  158. t56 questions ..
  159. A4 to t56 swap?
  160. advice? slave and master changed
  161. Clutch bleed question
  162. LS7 clutch the latest GM clutch which mates to LS1 F-bodies?
  163. Tick Adjustable Master is the way to go. My thoughts.
  164. Are you local to Baton Rouge, LA?
  165. Scatter sheild?
  166. LS1 clutch discs. (where to get just discs)
  167. adjustable master?
  168. LS1 bell housing?
  169. New Flywheel?
  170. SES light during high RPM shifts-->
  171. Another Monster stage III install thread...
  172. What adj master cyl to buy???
  173. Texas Speed Now a Distributor for Monster Clutches!
  174. why is it?
  175. Question about 6 speed at the track
  176. Whining in 1-4 from T56,Take a look at these input/counter shaft gears
  177. HELP! anyone have this part?
  178. 99camaro t56 fit in a 98 corvette
  179. Installed my Tick Master cyl 2day
  180. clutch question
  181. cold shifting problem?
  182. Source for T56 used parts?
  183. Where does your clutch engage?
  184. How bad to solid motor mounts make a clutch swap?
  185. Clutch pedal pressure with and w/o master cyl cap???
  186. Attn: Transmission & clutch gurus
  187. Clutch & Flywheel differences??
  188. Tranny going out?
  189. happy with pro 5.0 shifter length?
  190. No mees, no fuss bleeder line, no wrench needed
  191. Clutch issue need input!!!
  192. Master cylinder reservior replacement???
  193. wont shift at hi rpm?
  194. Strange grinding noise from T56 LT1
  195. Quick ?-Clutch Fluid
  196. Luk Stg. 2 clutch
  197. Can't shift on WOT RUNS! HELP
  198. M6 conversion question
  199. Tick Speedbleeder leaking not into slave
  200. Trans Locked Up???
  201. T56 rebuild ?'s
  202. Need some input on swapping from auto to stick.
  203. Torque numbers????PLEASE!!!
  204. Stick sizes; smaller than 6"(WS6 store)
  205. reverse lockout issue after tailshaft housing removal
  206. popped out of gear. Clutch?
  207. I need synchronizers for 02 T/A
  208. Skip Shift Eliminator...
  209. Countershaft??
  210. will pro 50 shifter from a mustang t-5 work with a t-56?
  211. Can't get all air out of the clutch master...
  212. 6 spd upgrades
  213. slave and master cylinder question?
  214. WTF..plastic?!?!?
  215. Shifting into 4th/rear end rattle issues
  216. No movement after t56 conversion
  217. Another bleeder valve question
  218. GTO MN12 in my F-Body : Problems, Help
  219. anyone tried Autozone slave or master cyls?
  220. 5th/6th gear puller?
  221. MGW shifter Installed
  222. Best/cheapest Master???
  223. Poll clutch master or new slave
  224. ls1 and lt1 bellhousing the same?
  225. REVIEW: Textralia and Tick MC *PICS*
  226. Traction Control on 98's?
  227. Need your thoughts!
  228. who builds a good T56 these day?
  229. T-56 Rebuild Companies
  230. 5th gear just grinds in gear
  231. Clutch Dis-Engagement issues
  232. any reviews for tick master's
  233. Rockland Tailshaft bushing
  234. factory shifter question
  235. MGW Shifter vibration
  236. New Clutch
  237. clutch change write ups anyone!??
  238. Short throw Shifter
  239. Need Tranny parts
  240. Gasket to quiet down the pro 5.0
  241. gto and fbody slave cylinder
  242. fidanza kevlar twin disk clutches?
  243. Tick bleed line: Where to mount
  244. anyone ever rebuild a Mcleod master cylinder
  245. Question on what is this shifter and t -56 transmission is from
  246. b&m shifter???
  247. tranny swap price?
  248. Check out my new Centerforce clutch
  249. Help...GTO swap guys step in
  250. Needing T-56 parts....
