PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. output shaft seal
  2. upgraded slave T56 ?
  3. Shifter Bolts?
  4. Remove braised metal covered wire???
  5. SPEC Twin Disk Clutch Assembly
  6. Removing the tranny from an LT1 t56 car
  7. Clutch bleeding techniques
  8. cheapest tranny rebuild kit?
  9. 4th gear not cooperating? Shift fork maybe?
  10. Ls7???
  11. pedal problem
  12. bUSHING OR BEARING
  13. Silly Clutch install Question
  14. anyone had problems with spec 3+?
  15. wont start...clutch lockout?
  16. What do you think this is? ( video of noise )
  17. Look what Byun and Fedex gave me
  18. pro 5.0 with ws6 short stick
  19. Clutch Chirp
  20. car wont shift into gear...
  21. dont know
  22. ws6 store short stick vs ebay
  23. aftermarket clutch master
  24. 550-600rwhp... RPS -or- Textralia -or- ?
  25. RAM powergrip, steel billet fly wheel + more came in (pics)
  26. Parts store FLYWHEEL
  27. Powershifting, speed shifting, etc
  28. New m6 driver..need help
  29. Clutch sticks to floor
  30. installed spec 3+
  31. Labor Hours Needed for a clutch install
  32. Poly Tranny mount ?
  33. why do pedal stick to the floor at high rpm's
  34. Help me buy parts for my tranny
  35. Totally stock transmission problems
  36. Plastic slave?
  37. Transmission Hard to shift into reverse?
  38. SPEC stage 2+ Q's
  39. converting 2000z28 from A4 to M6
  40. transmission oil?
  41. corvette slave fit f body T56 ?
  42. slave or master cylinder, ways to trouble shoot which one!!
  43. help picking short throw shifter
  44. Pedal just lays on floor, whats going on???
  45. Just had LS7 clutch installed...
  46. Does your master cyl. leak air and cause a bad pedal???
  47. New master with clutch install?
  48. brand new spec 3+....
  49. Need input on slave cylinder part number
  50. T56 Differences?
  51. Need some tranny help?
  52. Got my Ram Powergrip HD Installed!
  53. 3.8 -> LS1 can I keep the M5?
  54. RAM HD and 5000rpm dumps?
  55. Energy Suspension Trans Mount..
  56. WTF now i cant connect my hydraulic line!!!
  57. bleeding with the mighty vac
  58. Pops out of reverse
  59. new clutch how to install throwout bearing???
  60. New clutch install, then racing
  61. M6 to TH350, do I have everything?
  62. Wow i messed up T56 guys inside!
  63. Pro 5.0 Shifter & boot install
  64. Corvette vs. F-Body T56.
  65. will a ls7 clutch/flywheel be a direct bolt in
  66. Mcleod or Ram Adjustable master?????
  67. Could you tell me what is wrong with my car?
  68. What needs replaced with the clutch
  69. HELP!! should I go witht the spec2+ or LS7
  70. stripped out tranny cross member bolts
  71. clutch hydraulics!! im about to go CRAZY!!!
  72. Z06 clutch kit?
  73. 5 speed to 6 spd conversion, peddals?
  74. flywheel
  75. do you loose any power going to a ls7 clutch and ls2 flywheel?
  76. HELP!!! trans or throwout bearing???
  77. If you havent done the drill mod.....DO IT!!!
  78. C5-m6 grinds and a thud into gears after motor swap
  79. Clutch package shopping
  80. Interesting shifting fix
  81. Hurst Billet Plus Questions
  82. stock clutch master cyl.
  83. How streetable is faceplating?
  84. cracks in bellhousing
  85. Soft/sticking pedal after WOT thru 4th...clutch not hydraulics, right?
  86. pedal sticking with new master and slave
  87. Fragged Blocker Ring?
  88. Slave is spewing fluid...
  89. Clutch Problem
  90. Transmission Blanket
  91. grinding 6th, no speedo, no reverse solinoid, fresh build
  92. 6-Speed 350 in 3rd gen questions....
  93. so i got the 6" stick, and..
  94. grinds going into 5th when cold! HELP!
  95. Flywheels
  96. no fluid in hydrolic resivore?
  97. Making stock Master adjustable?
  98. Clutch pedal gets soft...
  99. Where do you get the "ring"
  100. t 56 rebuild
  101. how many different manual trans are there?
  102. hard to shift
  103. i know everyone asks but wich clutch please help
  104. Clutch Question
  105. installing 1 - 2 slider
  106. slave cyl.pic
  107. getting a clutch what else
  108. Surface finish for SPEC flywheel
  109. Sticky On Wot Issues
  110. T56 tailhousing swap?
  111. Clutch master cylinder *CONFIRMATION*
  112. Spec Stage 2 In 6.0 Slipping
  113. B&M Ripper shifter??
  114. clutch master clutch kit
  115. Master Cylinder Question
  116. best place to get an ls7 clutch
  117. going from auto to stick...
  118. Tranny squeal
  119. Voodoo shift forks?
  120. Clutch "POPS" up after 3/4 disengagement
  121. Tranny whine?
  122. Where do i get all bolts for my t-56 install!!!
  123. Exoskel after 1200 DD miles
  124. Where can I get the braided line for tha master cyl at??
  125. Manual vs Powerglide
  126. what bolts for the bellhousing
  127. Shifterboot retention ring?
  128. Need Help Quick!!! Drill Mod
  129. Spec questions
  130. Question about parking brake cables
  131. Six Speeds Inc. Monthly Special **Free Shipping is Back**
  132. Whats this noise??
  133. tailshaft seal
  134. Where to find McLeod Street Twin
  135. Textralia Clutch Problem
  136. spec3 +
  137. Wow. Just got off the phone with T56Rebuilds/SixSpeedsInc
  138. 05 GTO T56 + Stock clutch on 98 LS1
  139. Bad blocker rings? Or clutch problem?
  140. H/C Combo with approx. 400-420 RWHP Do I replace the stock LS6 Clutch?
  141. Clutch install writeup
  142. Powershifting..Or not
  143. T56 corvette question
  144. again with the noises!!!
  145. LS7 clutch installed!!!
  146. Pilot bearing?
  147. what clutch to go with for 700 rwhp
  148. when drivin hard i cant get into 3rd?!
  149. Ram VDS
  150. Pulling tranny Help ASAP
  151. Finally ordered a new clutch
  152. where do i Get this bushing?
  153. Help Please!!
  154. Do what joe tells you too
  155. t56 rebuild
  156. T56 5th and reverse troubles (grinds when you let the clutch out)
  157. Be honest, how many upgrades do I really need for my rebuild.
  158. What are the HP limits on the stock T56?
  159. used t56 tranny price
  160. Anyone replace JUST the 93-97 Slave cylinder?
  161. Funny clutch disenguagement?
  162. bleeding
  163. LT1 Clutch options
  164. grinding fifth ?!?!
  165. how the F did u get your shift knob off?
  166. Lost 2nd gear T56
  167. 11" Centerforce DF Question?
  168. Put in an exo skel, now I have some funny noise, please give your comments
  169. No Clue what this could be?
  170. Grind on me...
  171. Clutch slip...
  172. LT1 short shifter/short stick to LS1 Tranny?
  173. Spec Stage 3+
  174. Hydraulic Clutch Problem?
  175. Best Dual Disk Clutch Setup
  176. T56Rebuilds.com new website www.sixpeedsinc.com launching
  177. Cartek clutch guys inside please
  178. Alignment tool for ls7 clutch?
  179. cluch sticking
  180. T56 Tranny Swap
  181. 6" or 6.5" short stick
  182. Another WOT shifting problem, but not the same...
  183. Scoggin Dickey's New Look On The Web!
  184. LS6 Disk replacement??? Need some info quick
  185. Lt1 Vs. Ls1 T56
  186. M6 Vs A4 w/Stall ????
  187. Whats difference between 98-00 & 01-02 Slave cylinders?
  188. compatibility w/ ls7 clutch & flywheel
  189. How long did your aftermarket clutch last?????
  190. cobra t-56 clutch ?
  191. my McLeod SFI bellhousing install
  192. 13,000 on the odo and having a clutch issue
  193. ls7 clutch torque spec
  194. centerforce DFX clutch kit god or bad anyone know
  195. pilot bearing question
  196. T56 r and r
  197. Squeaking Fylwheel
  198. New AC Delco master cylinder+slave cylinder
  199. Torque specs?
  200. McLeod SFI Bellhousing
  201. Clutch master cylinder question?
  202. Clutch bleeding help?!?
  203. Anyone overhaul their own T-56?
  204. New whine started this week.
  205. pops out of 4th
  206. Taking it to the dealer
  207. Major clutch or hydraulic problems
  208. Clutch install writeup
  209. Retaining clip
  210. need help t56
  211. LS1Tech Search Fails me
  212. Trouble getting into 2nd?
  213. T-56 upgrades?
  214. Witch is the best fluid for my clutch.
  215. ls7 clutch what do i need install?
  216. has anyone ever heard of this
  217. Part Number
  218. simple easy question about trans oil
  219. Spec 3+ issues
  220. Clutch engagement issues
  221. Bellhousing Help!!!
  222. master hydraulic line
  223. 1st gear grinding?
  224. I believe I need a new clutch?
  225. RPM Transmissions prices at Exotic Performance Plus
  226. Wich slave cylinder to buy.
  227. Why are people having LS7 clutch problems?
  228. Weird Noise
  229. which adj master cylinder.
  230. What slave cylinder do I have?
  231. Clutch decision
  232. need clutch spec help!
  233. LS7 Out Finally
  234. Type of clutch?
  235. how the hell do I stop bucking from a large cam
  236. what manual bellhousings will bolt to an ls1?
  237. 1st time clutch bleeder needs some serious help
  238. Rebuilding my tranny to make it stronger, need help
  239. Loose slave bolt?
  240. problems with t56 rebuilds
  241. Sticking clutch pedal owners step inside. Interesting development..
  242. vibration
  243. QUESTION! Car won't shift smoothly into 2nd....
  244. bleeding clutch
  245. New T56 installed.... 56K beware!
  246. Drill Mod: Removing exhaust tube make it easier?
  247. LS6 bell housing
  248. WOT = trouble
  249. 3rd to 2nd grinding?
  250. Need help, slave?
