View Full Version : Manual Transmission
- Heard of Texas drive train performance for t56?
- Clutch pedal problem
- pro 5.0 question
- speed bleeder
- new clutch install a4 to m6 swap
- Sponsors who sell MGW
- Rebuilding a Faceplated T56
- Short shifter problem?
- T56 grinds wont go into reverse?
- Best T-56 Trans Fluid ?
- Another Hydraulic Issue
- New clutch only dis-engages 7/8 of the way out
- Flex Plate
- Just finished my first clutch install, hats off to monster
- Does Your 6 Speed Sound Like This?
- Moody Clutch
- Which clutch for lq4 and nv4500
- C6 t56 to tr6060 swap. What to do with cooler lines ?
- I'm and idiot laugh then maybe help?
- Help I'm ready to go insane with this clutch
- my speed bleeder and MC lines are touching my headers
- LS7 clutch install
- broken t56 what would you do ?
- Does this Mantic 9000 look ready to install?
- Finally removed the trans for the clutch swap..
- Shifting problems!!!
- T56 Output shaft question
- T56 not engaging properly
- ID this clutch, quick disconnect question, suggs
- Low mile Monster clutch/flywheel has hotspots-what happened?
- Rockland standard gear??
- 2000 Camaro Cluch Master Cylinder
- Just finished my first clutch install !!
- t56 rebuild
- t56 parts supplier
- Several t56 questions
- T56 roulette
- Stock Clutch or Upgrade?
- LS1 Clutch with LS3/T56 Swap
- Tranny Removed, now some troubleshooting help
- Slightly aggravated, tranny removal, tips appreciated
- Hard to shift after road trip
- New Monster Stage 2 Billet Twin disc - shakeS?
- LS6 clutch install questions.
- Need suggestions/opinions on a clutch setup...
- Tick master cylinder adjustment
- Installing and Adjusting a Tick master
- Tick master adjustment
- Tick master install
- T56 Wont go into gear with car off-
- clutch time
- T56 Front cover questions
- tick remote bleeder was worth every bit of $50 or I did something wrong
- T5 problems.
- Is my master cylinder bad?
- spec stage 3 clutch concerns
- Worn t56 bushing?
- LS1 T56 vss hookup
- manual trans fluid t56
- Clutch install gone wrong?
- Has anyone traded a 4L60E to get their T56??
- Bolt in T56 Magnum for 4th Gen F-Bodies Now available
- RXT help
- will a factory ls9 clutch fit 4th gen with t56?
- 1st gen ls swap guys with t56 ?
- Recommend a T-56 Transmission for an A4 swap
- replacement clutch for '05 light mods
- diamond clutch stage 2 reviews
- I need some opinions please
- steady clutch pressure, not going in to gear
- Need Help, Aftermarket speedomoter wiring
- T56 wont engage in 1st or 2nd help!!!
- T56 HELP NEEDED, LINKAGE STUCK IN 4th
- Tick remote bleeder question
- t56 5th gear problems
- T56 Mag/ TR6060 in LT Fbody
- T56 issues!!!
- ZF 6 spd in a LS3
- Monster Twin Installed!!
- clutch for stock 09 vette
- Transmission clunk (Video)
- Which roller pilot bearing?
- Is this for real!?!?!
- transmission fluid... what to go with
- Luk LS7 vs Luk LS1 Replacement Clutch
- T56 vette tail housing
- Digital Shift Knob
- LS2/LS7 flywheel on LS1 T56
- Anybody ever use a ZF6 or a NV4500
- Need help ID'ing clutch brand
- where can I get viper input shaft?
- Cadillac t56 in ls1 rx7?
- Differences in Slave Cylinders
- new t56 wrong front cover?
- Slave cylinder out. Decided to do m6 to a4 swap
- pressure comes and goes
- pros and cons of twin clutches
- Which master/slave to use?
- Tick master keeps disconnecting from slave
- Tr6060 new type shifter ?
- Can I use LS7 Slave on my 1998 T56?
- About to do my clutch..
- Looking for Tick adjustable master.
- tranny options
- Need help selecting gear ratios please!
- Clutch diagnostic advice needed
- Fidanza Short Shifter????
- Clutch Suggestions, Sponsors chime in?
- Won't go in reverse, occasional grinds, clutch pedal feels wrong
- Shifter ball doesnt thread....
- t56 2.66 or 2.97 gear set??
- Long time
- McLeod Twin Disc Clutch from SBC/T56 to LS1???
- big power 6spd guys, what brand ring & pinion
- just bought a t/a have trans questions
- clunk shifting into 3rd when cold
- Will an 08 C6 tr6060 bolt into my 06 Z51
- Tick Master Install - Line Won't Go Back into Transmission
- ls1-ls7 clutch/flywheel
- did i over pay ?
- New Monster clutch slipped and pedal stuck to the floor
- broke T-56 transmission, options?
- Having problems taking driveshaft off and putting back on tailshaft
- T56 Rattle
- SFI Bell housing
- WTB T56 Fbody Offset Lever
- clutch woes
- Transmission crossmember sizes
- T56 Bellhousings
- Short throw shifter
- Time for a rebuild (T56)
- Slave Cylinder??????
- Clutch pedal stays on the ground
- Take a Listen to this
- Hot spots on used flywheel and pressure plate
- Swap my auto for manual. 45k miles
- Monster clutch
- t56 parts availability
- What parts needed for auto to t56?
- T56 reverse is locked out
- Clutch recomendations
- Something NOT a T56 for less than 400rwhp
- M6 or Kilduff Machine Lightning Rods w/4l60E
- Noisy Transmission!!
- T56 Magnum ratio help???????
- Transmission decisions
- Tranny issues
- Newest LS7 clutch part number?
- newb needs advice on his t56
- How to tell which shifter I have? T56 02 camaro
- Ripper shifter handle options
- Clutch Upgrade. What Am I Missing?
- Lingenfelter TC1 For No-Lift Shift?
- Ls2 cts T56 trans in ls1 camaro?
- flywheel ??
- Best clutch for 450whp/450tq under $450 ?
- Weird noise t56.
- whats the best clutch kit for a 2002 z06 under $1,200?need for 700rwhp
- Grinding/slipping at high revs?
- 94 m6 clutch doesnt fully engauge until the lest inch
- Dreaded clutch issues 1999 FRC
- 2007 T56 in a 99 Fbody ????
- 2nd gear issues out of 6 speed?
- What's my t56 magnum missing
- Wanna see something cool?
- T56 leak?
- LS1-T-56 Air Gap - How to increase it?
- ticking noise
- Won't shift into 1,3,5 or reverse
- Fidanza Aluminum Flywheel
- 2000 T-56 issues
- Question related to T56 slaves
- Best Ls1 Clutch
- TickPerf or Bog-warner rebuild kit?
- T56 no engagement issue
- need help with clutch choices
- 4th gear grind only when going into gear HELP
- Jeff @ Textralia ???
- clutch
- can i change 4th gear in T56
- tr 6060 spray/cooler?
- Clutch Anticipate Switch after A4 to M5 Conversion
- Tick Speed Bleeder
- Hydraulic line popped off slave?
- Where can I get a flywheel? Cheap
- WTB GTO T56 Offset Lever
- Royal Purple synchro max ?
- LS1 T-56 problem, car won't move in any gear
- No clutch
- Wound out in 4th...grinds if I try to hit 5th quickly. Normal for T56?
- best stock clutch for 97 trans am
- Multiple T-56 Problems. Need advice on the proper parts to buy
- serious T56 clutch problems
- ls1 t56 problems after clutch install
- Pro 5.0 shifter with tall stick?
- SFI bell housing guys get in here!
- All gears grinding and pedal grinding
- TR6060 Rattle (CTS-V)
- stall ??????,
- T56 rebuild extra washer
- Shift rail problem on assembly
- Keisler files Chapter 7 Bankruptcy
- GTO ls1/ firebird t56?
- Brand new clutch not engaging, slips like all hell...
- What do you guys shift your built transmissions at?
- Reverse lockout solenoid through the shifter
- clutch slipping
- Modifying B&M RipShifter
- Adapting TR6060 to LQ4
- Manual Transmission Swap Question
- Tick Performance Master Cylinder
- high HP cars... who all is running radials?
- o-ring on quick disconnect fitting at slave cylinder
- clutch for stock flywheel
- T56 jolting
- Clutch Selection????
- After market trans cross member.
- t56 bearing name plz help
- MGW Shifter... Longer Shaft Available?
- Help deciding a clutch
- Tick speed bleeder.
- t56..magnum..6060.. questions
- Best Slave cylinder-T56????
- T56 Cable speedometer drive mod with viper output shaft
- Should I buy a used clutch?
- new clutch what year z06 for 02 camaro SS?!
- clutch pedal stuck to the floor
- For those who have done an A4 -> M6 swap
- Help t56 was rebuilt 5th not going in sometimes
- Radnom Clutch Pedal Engagement Point. HELP!
- fbody offset lever
- I'm new to manual driving, and I don't know what's wrong...
- tranny problem with 5th and 6th
- not another ls7 vs monster 2 clutch..
- Corvette T56 transaxle dimension
- C5 tail housing swap
- different LSx to T56 bell housings(SSR vs Fbody)
- LT1 to LS1 T56 strength and cost questions
- Pedal still feels a bit mushy
- Auto or 6 spd big power
- LSX 8 bolt Aluminum Flywheel.
- how do my syncros look?
- Is there a real difference in corvette and F body shifters?
- What is the purpose/function of the T56 Transmission Bumper?
- Searched high and low. Shimming question.
- tr 6060...
- T56 Mainshaft roll out spec.
- LTx T56 clutch problems...
- A4 to T56 conversion template?
