PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 [118] 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Hurst shifter
  2. PLEASE HELP!!! Please I need to put my car back together!
  3. Grinding 3rd and 4th
  4. How do I get my fly wheel off balanced to match my flexplate?
  5. Spec clutch lightweight option?
  6. Quick connect wont connect
  7. LS1 Stock flywheel..
  8. My motor is out and need to trailer my car with the tranny still in???
  9. Pro 5.0 Shifter Install Question
  10. rubber shifter boot
  11. Not all master cylinders are created equal!
  12. Flywheel Resurface or not?
  13. Why Does My Clutch Stick To The Ground When I....
  14. new shifter
  15. Do I need one??????
  16. Converter bolts
  17. 01+ MC work on '94 lt1
  18. Pics of my cracked bellhousing
  19. weird leak of clutch fluid below bleeder screw?
  20. Clutch advise needed!!!
  21. Trans is in! almost ready to go once again!!
  22. Dowel pin in end of crank
  23. What shudder????
  24. 450hp and stock flywheel??
  25. F-bod T56 & C5 T56
  26. M6 mods, repairs
  27. bumping vibration
  28. Help with change out..
  29. Labor costs
  30. clutch adjustment????????
  31. need help on upgrading hydros
  32. Need shop in Houston A4 > M6 conversion
  33. Drag racing with T56
  34. c6 shift nob...
  35. New to LS1
  36. Used Spec III
  37. I need help! looking for a complete t56 swap kit for A4
  38. What Clutch?
  39. T 56 problems
  40. Complete Rebuild, NEED HELP
  41. What is the drill mod ?
  42. Differences between 98-00 and 01-02 T-56 - a few other questions
  43. Trans shifting questions
  44. M6 for 1000+rwhp and 1200+rwtq
  45. RAM Clutch users inside, 900 series
  46. Is my clutch trashed?
  47. A4 to M6 swap
  48. anyone ever use a speed bleeder to bleed the clutch line?
  49. MY first spec3 lasted 8 months.. This one is on it's 2nd month 2k miles and junk.
  50. T-56
  51. clutch choices turning out to be like my cam choice
  52. How do I make my clutch pedal stiffer?
  53. Need Help With T56
  54. Smoother shifter than the 5.0?
  55. 2nd gear burnout hard on clutch???
  56. Installed McLeod. What is the break-in procedure?
  57. Any upgrades or mods for hydrolics for 97 T56?
  58. Clunking noise 3-4
  59. clutch this season...
  60. clutch is acting funny?!?!
  61. new 01+ master, does it come bled?
  62. problems@track with new clutch
  63. I damaged clutch m. cyl. quick connect
  64. harlen shift light
  65. Clutch master cylinder retainer clip
  66. T56 service manual, Anyone, help!
  67. Spec Stage 3 makes loud groaning noise on engagement
  68. Thowout bearing leak
  69. FINALLY, a clutch that works!!!
  70. the 6-speeds represented last night
  71. bellhousing...
  72. Can i use this Flywheel with the SPEC 4F?
  73. Are T-56's supposed to be so hard to get into gear?
  74. new clutch!!!
  75. which ratio do I have
  76. Clutch Stuck Read Easy Fix
  77. Ultimate M6?
  78. Sfi 6.1 Bellhousing Question
  79. T-56 shifter re-allocation
  80. auto or 6 spd?
  81. which clutch to buy?
  82. Clutch pedal going to floor not coming back up...
  83. Who's running the RAM Power Grip HD?
  84. LS7 Clutch
  85. M6 Issue
  86. shift knob
  87. Clutch Help Please...
  88. SFI Bellhousing question
  89. Do i need a new master cylinder???
  90. Spec3F or 4F for daily driven 408ci ?
  91. Z06 T56 to 98 Z28
  92. Richmond 6 + LS1?
  93. McLeod SFI bellhousing question
  94. 4.8L 5spd skipshift?
  95. Quick question...
  96. T-56 flywheel balance. LT1 vs. LS1
  97. Clutch Pedal Return Spring
  98. (ram clutch) need help!
  99. spec 3 guys please..
  100. T56 Rebuild in Southern California???
  101. Want to rebuild my t56
  102. tranny rebuilds in va beach area
  103. Clutch Scatter Shield!!!
  104. Please HELP!!! Car won't drive at all!
  105. ? about the stock hurst shifter
  106. problem going from 2nd to 3rd
  107. planning a spec stg4 install, what else should i install/replace?
  108. Problem...is it the pro5.0 or POS tranny
  109. Prothane Mount Installed
  110. Does your M6 make you cringe?!?!
  111. Shifter Question
  112. new master - old slave?
  113. Help W/ SPEC3&BilletSteel
  114. balancing a flywheel
  115. Shifting and Fast and Furious Question
  116. Clutch Grabbing in Different Places???
  117. master cyl. braided line
  118. Shifter
  119. clutch pedel acting weird.
  120. McLeod Clutch Installed
  121. Major tranny problem
  122. wtf is going on with my transmission??
  123. Adjustable Master Cylinder Question
  124. is this a spec stage4 for lt1 ?
  125. need help fast ASAP
  126. arp flywheel bolts and pressure plate bolts
  127. Pedal releasing low
  128. LUK Progold ?
  129. skip shift
  130. thinking of switching to auto
  131. Is my clutch slipping
  132. How much HP can a spec 2 handle?
  133. Like I shifted into reverse...
  134. 1996 z28, putting in spec stage 3 clutch what else
  135. Slippage in 5th right after trans reinstall
  136. what do i need to do to make ls1 t56 to a lt1 t56
  137. [Q]how to remove clutch master-cyl hose
  138. Noise coming from bellhousing when clutch peddal is depressed.
  139. I am normally an auto guy, but considering getting a t56 car...
  140. clutch smells AWFUL at WOT!
  141. mcleod clutch for ls1 opinions please!!
  142. Clutch torque specs
  143. how long will it take to swap to m6 with a lift
  144. Tranny hissing
  145. Vert .vs Coupe chassis difference (pics) - Does your coupe have these?
  146. What would it cost?
  147. How Much For A Stock T56 Rebuild?
  148. need new clutch, im not gonna make more than 400rwhp, zo6 kit ok?
  149. Spec stage 2 Disk with stock pressure plate?
  150. Is g-force the only way to go for 1000+ rwhp?
  151. gm slave or ram slave
  152. how much should I bleed clutch?
  153. Who all use a harlan 2 step with M6 ?
  154. LS6 clutch still chattering after 1500 miles
  155. 5th is weak is that normal??
  156. 800 Horsepower 8000rpm Manual Tranny Needed
  157. pulled trans last night
  158. PN Throwout bearing connection
  159. Drill Mod / Adjustable OEM Master
  160. PN for LS6 throwout bearing and pilot bushing?
  161. T56 Rebuild
  162. Mcloed =P O S
  163. Tranny issues when cold..
  164. OK< HERES THE "CLUTCH" PROBLEM
  165. need help bad.
  166. T56 connection
  167. is the mm6 and t56 transmission the same transmission
  168. Clutch help
  169. T56 swap hard?
  170. buddys 6 speed ..
  171. No, my slave was not leaking!!!
  172. Master Or Slave?
  173. will aftermarket shifter reduce et in the 1/4?
  174. 408 Stroker, trans????
  175. Dynamat for shifter vibrations (Install Pics)
  176. Vibration problem
  177. stock knob fitment on short stick.
  178. Source for core T-56's? I need a good rebuilder
  179. TKO 600 to LS6 for TVR
  180. Pull M6 tranny out, what's the procedure?
  181. Slave cylinder connection
  182. Help!
  183. Stock Z06 Clutch
  184. Did my slave cylinder die?
  185. Rebuilt Transmission
  186. rear pinion seal not on??
  187. broken trans??
  188. T56 reverse lockout
  189. Anyone have a pic of the ram master?
  190. Shim with SPEC clutches...where does it go
  191. what is weong with my tranny this time!
  192. clutch time!!!! help
  193. installing Spec 3 what else to change
  194. Can you change the stick on a Ripper?
  195. Resizing the length of Ripper shifter shaft
  196. Stock Clutch w/ heads/cam: how will it hold?
  197. Black mud, time to change Master Cyl fluid?
  198. shifters?
  199. bleed the slave cyl?
  200. Recommended RAM pn's
  201. 4l60E to 6 SPEED
  202. anyone know the dry weight of the t56 and the dimensions
  203. Stuck in gear, then popped out?
  204. Help beef up my tranny!
  205. Clutch? Worn out?
  206. with mcleod twin disk is new TO bearing needed?
  207. LS1/LT1 T56 Difference
  208. 6 Speed shifters Which One?
  209. Automatic -> Manual... whats involved?
  210. Does anyone have pics of the inside of a T56?
  211. Spec Stage 4, need some help
  212. should i buy this clutch?
  213. What's the deal with 6th gear??
  214. trouble with clutch?
  215. T56 rebuild question
  216. Easy way to bleed clutch lines w/out removal?
  217. New 06 Z06 clutch??
  218. anyone know gear ratios for f-body T56?
  219. Multiple problems
  220. stock 2001 clutch
  221. Your opinions on the best clutch for....
  222. Shifter ID
  223. Need best price advice
  224. McLeod master leaking
  225. Damaged Clutch Disc?
  226. Spec 3 Enough For H/C + Spray?
  227. Hurst shiffter better or worse??
  228. "Drill Mod" good or bad ??
  229. M6 Conversion
  230. Which clutch do you recommend?
  231. Spec billet steel flywheel, lighter than stock?
  232. Spec Aluminum Pressure Plate??
  233. *Sale* TTP Stage 3 A-K Built T56 Trans Ends 1/31
  234. replaced my stock hurst shifter with a hurst probillet i have some coments and ques
  235. Is my slave leaking??
  236. Was the factory Hurst shifter avail in the 98 T/A's?
  237. Ferrari style gate shifter
  238. Clutch Engagement Point.
  239. whats the difference in materials?
  240. What's Wrong With This Car?
  241. speedo is wrong how do i fix?
  242. Max holding power for t56
  243. more tranny mount woes
  244. Use thread lock on the bolts for aftermarket shifter sticks!
  245. question
  246. Shifting at Low RPM, found CAGS?
  247. missing a shift..
  248. Best Place to order Spec Stage 1 ???
  249. shifter install
  250. how does a dual disc clutch work
