View Full Version : Manual Transmission
- GM master w/ stainless cable?
- Anyone need a scattershield?
- Clutch Slipping?
- T56 Trans Bracket Torque
- Ssr T56
- master help
- What RPM to launch?
- How much can a LT1 T56 handle?
- no sixth gear
- Textralia disc behind an LT1
- new clutch from TDP works nice ;)
- spec stage 3 sucks
- Clutch Problems pleasseee help :(
- time for tranny/clutch work..need help!!!
- Pedal is sticky
- Need help with finding right part for clutch
- spring feeling to clutch after it engages
- Information for the Do It Yourselfer
- Tick Performance T56 Rebuild Special!
- Oz700 vs LS7
- Weird problem after clutch install HELP!
- Question about different T56s
- is this a good shifter
- raptor shift light install
- Factory Hurst Shifter GM PART NUMBER ?
- Tex Exo-skel
- new torque arm, tailshaft bushing wiped?
- Which of These Tranny Mounts?
- Spec stage 5 clutch cracking?
- Rear Main Seal Leak Destroy Clutch??
- Need a 6 speed
- Loctite Questions
- clutch slippin....sucks
- Textralia Exo-Skel Installation Questions
- m6 to a4 swap and vice versa
- Where is my reverse switch?
- Spec 3
- T56 ????
- BIG power w/T56 guys step inside
- Just swapped A4 --> M6
- Parts List for swap??? Help!
- Getting stuck in gear HELPPPP
- Tranny Rebuild, Clutch and Flywheel Recommendations
- I have a big problem i need help fixin! please read asap.
- Stock shifter (not hurst) with ws6store ss
- Spec flywheel w/ McLeod Twin Disc?
- Quick clutch install ?(LS7/Fidanza)
- What clutch?
- T56 rebuilder in Illinois
- 04 gto wont engage into gear
- Shifter popping out of 2nd gear....
- Clutch sticking what's that mean?
- hard shifting 6th gear
- Slave Leaking after clutch install! need help fast!
- some help ..
- iroc clutch issues
- slave cylinder keeps breaking!!!!!!
- Question about T56 tranny
- T-56 Transmission Question
- will 96 corvette clutch kit work in 95 trans am? throwout bearing is square!?!?
- how to remove shift know
- Fastest Six Speed list
- LT1 flywheel balacing dot??? what if it didnt come with one?
- Stockest feeling clutch that can withstand +700hp
- Problem with Mity Vac - Help!
- clutch line
- How much do corvette transmissions cost?
- tranzilla 6spd..
- tranny install
- Mcleod single o/k or tex oz700
- is it bad to use 5th gear at the track?
- what do u think is the problem? Slave or master cylinder?
- 3rd gear keeps poppin out
- clutch slipping
- Trans wont come out of 6th?
- Twin disc clutch on STOCK engine LS1
- tranny cooler
- Transmission being ...Stubborn
- Problem Getting Worse!!!!
- Need a new slave cylinder line
- Duralast LT1 pressure plate not made by Valeo???
- trany problems(t56) ugh!
- Picked up my macdaddy clutch slave today.
- LS1 clutch master cyl
- oz700 is sweeeet
- To Locktite or Not???
- Clutch problems
- is it bad when
- how hard is clutch install on a 2000 c5 vette?
- My tex twin disk experience
- Harlan 2 step
- Need help
- transmission is really messed up HELP!....
- Stainless clutch line
- Flywheel shim between crank and flywheel? what is the depth measurement for flywheel?
- ls7 clutch for H/C/I car?
- Bore size of master cylinder?
- Ls2 flywheel a must?
- Slave not bleeding!
- Shifter Gate Grease
- grinding in 3rd
- Anyone know A Affordable Shop in So. Cal
- Life of a stock clutch and how much power it can handle?
- Someone finally explain "powershifting" to me...
- Best 60' with Exo skel clutch( Tex Twin)
- Adjustible master for clutch?
- tranny wiring identification...help?
- Need New Clutch?
- problems with 3-4 shift
- How can I find out what clutch to use?
- What is it worth?
- Who else hates 1st gear in a Fbody?
- New MN12 GTO Tranny Review (in Fbody)
- Changed clutch, wont go into gear... help!
- LS7+Nitrous?
- Clutch Question?
- won't go in gear!
- GRINDING IN 5TH!!!!! T56 swap
- Need Help!!!!!!!!!!!!
- shifter for a t56 from a gto
- Found the LS7 Clutch Limit
- LuK Clutches... Anyone familiar with them?
- Article in Super Chevy Magazine
- ok pissed off!!!!!
- bought a spec stage 3+ got a stage 3 nothing?
- Who's everyone using for built T56's and HD clutches these days?
- T56 rebuild questions
- how much power will the tex, exo clutch hold???
- Clutch pedal goes limp under hard acceleration
- HELP! anyone have a used counter shaft? & used 2nd gear
- replacing clutch disc
- clutch issues, sparks from bellhousing, vid inside
- Installing throw out bearing question
- flywheel
- What type of Tranny Fluid?
- What years will be an exact replacement for a 2002 T-56?
- Bolt size
- what is the strongest clutch out there???
- clutch pedal just went to the floor
- Driveshaft balance???
- Do any one else's pedal squeak??
- Clutch help....
- Help......
- Exedy Twin Disc Users COME IN!!!
- HELP :: What would you do?
- In 3rd boost poured in boom!
- car wont go into any gears..whats the deal?
- This can't be right, please help a hydraulic clutch newb
- More than enough power, Help.. ow to Burnout M6
- Spec 3 clutch issues...
- installing the oz700 this weekend
- clutch master help
- new clutch opinions
- Reverse funky after new clutch???
- g-force stuff really that bad???
- Possible clutch engagement issue on Textralia?
- Cost to get a new tremec T56?
- Tranny Swap, Need Input
- Clutch swap issue! Need Help!
- t56 rebuild parts question....
- spec stage 3
- Do i need a slave shim
- touble getting into reverse: fuse or rebuild?
- Mcleod 600 series- quick Q
- Where to get Fidanza LS2 Alum flywheel for LS7 clutch?
- please i need help !
- Clutch Bleeding Help!
- LS7 Clutch/LS7 Flywheel
- Another magazine article with sixspeedsinc..
- T-56 with a torque converter?
- reverse wont 'take'
- Bellhousing & Flywheel PN's
- Spec Stage 2+
- Where is my clutch fluid going?
- SHOULD I BUY A PRO 50 or HURST BILLET SHIFTER?
- Rotational Noise ???
- Lightening LS2 flywheel??
- Help Diagnose please - Powergrip HD
- why is this in my T56
- Corvette Torque Tube
- LT1 T-56 clutch fork pivot assembly question
- Need a new 6 Speed
- Spec 3 with Fidanza Aluminum CRAZY NOISE?
- Purchased LS7 clutch...
- Manual Transmission Step by Step Rebuild Information
- Banging/Clunking Noise
- Who has a SPEC stage 3+
- Persistent Shifting Issue
- trans doesn't want to go into reverse
- Suitable Clutch For Drifting?
- Spec 3+ or Textraila
- slave cylinder leak please helppppp
- Do I need to shim my slave?
- 2006 GTO Clutch Opinions
- Hey Amber, Now what have I done???
- Resurface a Fidanza Steel Flywheel?
- Scatter Shield or not?
- Another noise question
- Stock clutch damaged... why?
- clutch line *pics* HELP!
- Slider (syncro) question
- ZOOM MU/ big clutch ?? what ya think?
- Soft Clutch Pedal
- Clutch bleeding issuse....HELP
- Grind when putting it into reverse...
- Leaking slave?
- pilot bearing removal?
- First LS7 Clutch Install
- Anyone order a Mcleod MC rebuilt kit lately?
- "A clutch of a 1000 dumps"
- Vibration at tailshaft. Need Help please.
- T 56 Output Bushing Installation Problem
- Not a normal bleeding question...
- Car wont go into 2nd gear
- Need bellhousing for LT1
- Clutch resevoir fluid color?
- How long should a aftermarket clutch last?
- Clutch Question
- T56 fluids
- Speed Sensor?
- Pics: What would cause the FW/PP surfaces to look like this?
- Hey LS1 Techies Clutch question
- Tranny rebuild "Kit":
- Master Cylinder Question
- Stupid, But Thought Id ask
- shortest throw?
- Hell Yeah!!!
- Did my rear end break my trans when it broke?
- What is wrong with my car? please help
- Kevlar pilot bushing...Worth it or not?
- Pressure Plate Question
- nice t56 check the vid
- how much would you pay? T56
- Shifter and Clutch
- Clutch Install Errors
- I Need Help Picking A Clutch!
- Adj Master Cyl benefits?
- slave maybe?
- Clutch Won't Fully Disengage (Spec 3+)
- My thoughts on Textralia...
- How much for a clutch?
- Ram Master cylinder?
- Help please, T56 problem in '98 TA
- What Do I Really Need?
- HELP needed from those who know there stuff.. What the **** are these pieces?!?!
- clutch.....
- Stock Hurst Shifter
- 98 ta ?
- clutch pedal exorcism
