PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 [135] 136 137
  1. Can I use my stock throwout bearing with....
  2. Who is using the star stage 4 clutch?
  3. M6 Popping out of reverse.
  4. grinding going into 3rd and 4th after missed shift- syncros??
  5. 02 SS M6 missing from 1st to 2nd????
  6. McLeod Organic/Kevlar clutch installed!!
  7. RAM clutch... VDS or non-VDS?
  8. Ram clutch pedal pressure?
  9. Where to get T-56 built?
  10. Anyone have trouble with the new models of spec clutch
  11. I WANT THE BEST CLUTCH ????
  12. Got my B&M Pro 5.0...
  13. Did you guys modify your B&M Pro 5.0 ??
  14. Heads up for M6 guys.
  15. Is the M6 the weak point?
  16. Clutch recommendation for stock LS1 with 4.10's & DR's
  17. Oil leak and Clutch problem
  18. Grinding at WOT and upshift problem
  19. grinding rear end
  20. What flywheel for 500+ hp
  21. Clutch pedal adjustment?
  22. Just finished my first T56 rebuild.
  23. What clutch for et streets
  24. M6..... 3.73 OR 4.10'S????????
  25. Anyone using spec's S3 carbon clutch on a high HP ap?
  26. grind 2nd?
  27. Cartek clutch creaking sound...
  28. Anyone out there using an aluminum flywheel on a cammed M6 ?
  29. Synthetic clutch fluid???
  30. Best Clutch Kit??
  31. Clutch part numbers - which ones?
  32. Soft Clutch
  33. 3rd gear grinding?????
  34. NEED HELP WITH CLUTCH
  35. Question about SPEC Stage 3 Clutch
  36. How long...M6+5500RPM dumps?
  37. I need a picture of a McLeod Street Twin....
  38. Problem: clutch master, slave or both?
  39. Clutch Experts I need some help
  40. How many quarts for T56?
  41. Who else rebuilds our t-56s other then D&D Performance?
  42. Stock Clutch
  43. Grinding noises?
  44. Billet Steel Flywheel resurfacing
  45. how firm should the clutch pedal be after cartek clutch install??
  46. Interest in a billet output shaft for T-56's?
  47. Delayed engage with Mcleod and new slave... HELP!!!
  48. Would you recomend the RAM Clutch and these other options?
  49. M6 Tranny leaking about a quart a day!
  50. Adjusting Clutch Engagement Points
  51. RAM clutch people and installers Help Please
  52. Fair market price to replace synchros?
  53. Got huge problem with Z06 clutch I installed, please help
  54. RAM 402/6180 w/McLeod adj M/C in!
  55. Ping/Bang Cartek won't disengage anymore 3500miles
  56. Can't get tranny in gear - Clutch melted to flywheel??
  57. burned clutch
  58. Mcloed clutch install problem
  59. having some clutch problems, anyone help?
  60. ZO6 vs. T56?!?!?!
  61. 6th grinding going into gear
  62. Are the T56 in a LT1 and LS1 the same?
  63. Clutch fluid getting dirty? -> Turning dark.
  64. Has anyone found a way to change the first gear ratio in the T-56 to the Z06?
  65. Another T56 bites the dust
  66. Ram Clutch 1550/910/402 Install & Observations
  67. Mcleod masters..serious questions..
  68. Ram clutch peddle feel?
  69. T-56 Blues
  70. Cartek Clutch=good. Cartek Hydraulics=bad
  71. New M6 : having hard time getting in gear
  72. opinion: PRO 5.0 or B&M RIPPER ?
  73. Grinding the Calipers for 15x10 Pro-Stars
  74. How can you tell what type of SPEC clutch you got
  75. Difference between T-56s
  76. Pro 5.0 this
  77. need help please - slave/clutch failure ???
  78. Clutch or Tranny problem?
  79. Question about the contents of part number 12570281 (LS6 Clutch)
  80. Cartek Clutch?
  81. Spare tire jack makes a great M6 tranny lift
  82. Rebuild the T56 or time for a new one?
  83. Stock Clutch on 2001 Firehawk
  84. Clutch situation fixed!
  85. There's a lot of pieces in this T56 :)
  86. 3.73's or 4.10's with a M6
  87. Z06 transmission and 00 T56
  88. stock clutch longest&shortest lifetime?
  89. What aftermarket parts are avaliable for the T-56 (gears,syncro,shifting forks etc.)
  90. Wierd clutch feeling
  91. Just installed Ram clutch..a few questions/problems...
  92. pro 5.0
  93. Aluminum or Billet-Steel Flywheel??
  94. SPEC or Cartek Clutch????????
  95. Need Help Fast on McLeod MC
  96. grinding noises
  97. throwing a code after clutch install
  98. throw out bearing question
  99. So.....Which clutches are working the best?
  100. T56 problem, 5th gear pops out.
  101. Slipping Clutch Symptoms???
  102. M6 guys with a mushy pedal after a run
  103. McLeod Rev-Lok II questions
  104. M6 Aluminum DS
  105. I just got my McLeod ajd m/c for my C5, have a question....
  106. Z06 clutch
  107. What does the tube on the T56 go to?
  108. Prototype Mcleod Rev-Lok clutch --> Results and Impressions
  109. How to strengthen a T-56?
  110. do i need to shim a ram clutch???
  111. 413rwhp & 554rwtq putting clutch to early grave...
  112. Most effective way to "break" a T56??
  113. PLEASE HELP ME WITH MY CLUTCH!!!
  114. which clutch can take the most rwtq before slipping???
  115. Installing LS6 clutch tomorrow. Do I need new flywheel bolts?
  116. Clutch pedal gets stiff about 2 inches from floor??
  117. Looking for a great clutch? Look inside....
  118. ANOTHER CLUTCH QUESTION
  119. Calling Cartek....I have a gear question.
  120. Clutch break-in period?
  121. Clutch Question..... (pic)
  122. 3.42's to 3.23's in an M6?
  123. Pro 5.0 people....in here.....
  124. Advantages in steel -vs- aluminum flywheels??
  125. Guys major clutch/hydraulics problems....
  126. Just got a Pro 5.0 shifter!
  127. Is it true GM clutch slaves come pre-bled?
  128. Nice shift knobs for T-56's
  129. Stock Flywheel
  130. SFI Bellhousing for M6?
  131. Where is the best place to get billet steel flywheels?
  132. clutch died on me tonight! towed car home!!
  133. spec clutch tips
  134. RAM 910 disk & aluminum flywheel....
  135. How do you order a GM flywheel by itself???
  136. Clutch options....
  137. Adding friction modifier necessary when using Honda ATF with M6?
  138. Problems with McLeod adjustable pedal feel
  139. Need Clutch Advise
  140. SPEC Clutches
  141. ram-910 with stock flywheel
  142. When to shift? M6
  143. Are the 2002 Z-06 clutches different from the 2001s?
  144. Attn: Adj McLeod M/C people, not the usual question(Long)..
  145. McLeod adjustable master cylinder - Fbody/C5
  146. Anyone shift without the clutch??
  147. How long to R&R T56?
  148. How does the stock/Z06 clutch hold up to AutoX and Road racing 420RWHP?
  149. clutch install problem
  150. best way to bleed clutch hydraulics
  151. M6 Breakage Question
  152. clutch fluid
  153. Warranty info on clutch needed.
  154. T56 died on me this morning
  155. Z06 clutches
  156. What RPM's are you turning with 4.56's in a M6 in the 1/4
  157. best price on pro 5.0 shifter?
  158. ?'s about resurfacing the stock flywheel
  159. C5 M6 POPPING OUT OF 6TH
  160. what are the shims for a mcleod master
  161. What fluid to use in M6
  162. 4.10's in a M6 practical?
  163. T56 repair in DFW area
  164. RAM clutch is squeaking when I let it out
  165. Double Clutching?
  166. Dual Disk Clutch
  167. Dealer is giving me a new T56 under warranty.... Anything I could request??
  168. New Clutch Not Disengaging
  169. Viper T-56
  170. LS-6 Clutch part #'s
  171. T56 Parts
  172. Post your Dealer experiences w/ the POS factory clutch.
  173. Which Clutch?
  174. need help with clutch decision
  175. transmission problems (T56)
  176. New Clutch Break-in...help!
  177. T56 rebuild
  178. Has anyone had any problem with a SPEC stage3 clutch?
  179. CarTek Clutch and Bad Vibration
  180. drill out mod on mcleod adj. master...
  181. ?'s before ordering RAM clutch
  182. Won't shift into 3rd over 6000rpm? (M6)
  183. Drill mod ,do I have to rebleed clutch after..??
  184. streetable clutch for high hp ls1?
  185. Adjusting CarTek Clutch?
  186. Difference between pro 5.0 and lues SS
  187. write-ups for clutch install
  188. Pro 5.0 noise
  189. Likes/Dislikes about McLeod's Rev Lock II clutch
  190. What year did tremec start making the T-56
  191. Does anybody else's T56 grind when cold?
  192. installed cartek clutch this weekend and....
  193. T-56 pops out of 3rd under load from standing start WTF???
  194. Clutch pedal suddenly stiffer
  195. T-56 Makeing noises when getiing on it? How much to fix?
  196. Ram VDS clutch system gonzo after 1 day at the track...
  197. Done the drill mod on my Cartek....
  198. Need help quick- clutch related......
  199. How are those aftermarket clutches holding up?
  200. Street Clutch Recomendation
  201. What is wrong with my clutch?
  202. clutch position sensor
  203. Power limits of each clutch disk maker?
  204. drill mod with cartek?
  205. Soft Clutch
  206. Noise while rolling w/M6
  207. Rebalancing Flywheel Question?
  208. Please help.. Clutch saga woes wont go away!!
  209. clutch or transmission blown-- disagreement w/shop
  210. ram clutch
  211. Is it possible to change over to a mechanical clutch?
  212. CLUTCH HELP PLEASE
  213. goin to order a new clutch....
  214. Mcleod master w/o removing the shim?
  215. Lingenfelter HD Clutch...Anyone have one?
  216. M6 Shifting Forks
  217. WTF: Star Kevlar stage III clutch
  218. Do i need the Ram shoulder bolts for my clutch??
  219. Why is it so hard to change gears after clutch install???
  220. How much can hp can Mcleod handle
  221. Pro 5.0 question; are your boots getting in the way of the stops??
  222. dang PRO 5.0!
  223. Does any one have STAR "spec" (clutches) phone #??????
  224. Slipping clutch at 9000mi ?
  225. Best clutch for the $
  226. Flywheel resurfacing question
  227. Cartek owners in here ----->
  228. m6 Tranny getting stuck in any gear
  229. Weird Ram Clutch slipping problems
  230. who wants a T56 manual in .pdf format?
  231. HELP! getting new clutch mcleod twin or Ram 910???
  232. clutch slave or master cause clutch to slip???
  233. question on switching from M6 to auto !
  234. Will A Lightweight Flywheel work with Stage2 Spec?
  235. New clutch is slipping....please help
  236. Best clutch!!!
  237. Who's upgrade to the z06 clutch?
  238. Clutch Break In!!!
  239. What's the bulletproof M6 driveline setup?
  240. Almost have to force it into 2nd--Synchro's?
  241. high pitch squeal with clutch install
  242. mcleod rev lock II, v.s. cartek, v.s. RAM
  243. Question after clutch install ??
  244. Clutch slipping problem at only 8400 miles!!
  245. CLUTCH PEDAL PRESSURE
  246. Urgent Clutch help
  247. T56 problems
  248. fluid reservoir for LS1 M6 is black
  249. Trouble with McLeod clutch...w/i please...
  250. STAR Clutches
