View Full Version : Manual Transmission
- who's got the best price on a steel flywheel?
- How can i tell ...
- yet another weird clutch issue...
- Corvette Trans
- Possibly a Dumb Q about slippage
- IS this normal ?
- shifter pix
- I Need Help!!!
- Tranny Removal Questions...
- Spec Stage 3+ w/ stock flywheel? pushing 508rwhp and 548tq??
- Best clutch to buy that will allow me to ride out the whole.
- t56 question? plz help
- where, and how much............
- Clutch change questions
- 4an clutch line were to purchase
- which clutch???
- Exeedy clutch owners...??
- quick zf speed question..
- questons on bleeding.
- Need help with clutch everyone!
- just installed textralia, possible blown slave cylinder, have ????
- Interesting T56 info
- My tachometer / shiftlight dilemma
- Tranny fluid low..does this sound right?
- Dowels on flywheel
- What is the newest 6 spd. I can use with an old style motor?
- Need a flywheel please help
- Spec stage 2???
- tranny help?
- Mcleod Street twin clutches
- Time for new components?
- is the ls7 clutch worth the $$$
- Boy I hate feeling like a Idiot
- best site for selection of clutches?
- Stock tranny limits?
- Whiny Chattery Clutch On Engagement
- 100k mile OEM clutch {pix}
- RAM Powergrip disk ripped apart!
- Borg warner or Tremec
- Ram Clutches vs. exedy
- what thread size are the trans mount bolts?
- how long should the clutch fluid leak out of the bellhousing?
- Thread for a noobie- Needing advice for "upgrading" my clutch
- What clutch recommended?
- 98 Camaro A4, 99+ T56....any surprises?
- Wierd vibration from M6 tranny
- intermitent low clutch pedal engagment
- T56 (M10) SSR yoke info
- assembly
- Clutch not disengaging
- slipping clutch
- HELP - Connecting Manual speedometer to T-56???
- Ls6 vs Ls1 flywheel
- shifting trouble, urgent help needed
- SPEC Clutches: Post your Success/Failure Stories
- T56 in a blown/cammed LQ9 4wd Silverado ECSB?
- ebay shifters
- Best Value / Quality Single Plate clutch and cover?
- Textralia clutch
- how to tell hydraulic leak?
- Slow Shifting M6?
- t56 by G Force???
- Shifter just a' rattles
- T56 replacement parts
- HELP PLEASE! Clutch Pedal Stuck To The Floor Today
- Fly Wheel Dowel Pins?
- question on what clutch to go with
- free play at top of clutch pedal
- clutch pedal going soft??
- M6 Problems.......
- Keeping Our Cars SAFE From Clutch Explosions
- Is it possible to run a LS7 clutch on a LT1?
- Any Aluminum flywheel for the ls7 clutch?
- Textralia clutch
- Cheapest place for SPEC Stage III
- Could I use my Aluminum Flywheel with a LS7 clutch
- Pos Spec 3
- installing a pilot bearing, help
- What could cause popping out of 2nd and 4th?
- pro 5.0
- I'm new to all this so be gentle!
- Centerforce 1 engages low, hard to shift.
- New tranny a few questions
- what not to do when breaking a clutch in?
- Joe at www.t56rebuilds.com
- ls7 clutch catch point question
- when to stop drilling
- Clutch (Z06) Break-in???
- Just exploded my pressure plate. Catastrophic
- Hurst vs Stock
- Which 6 speed do I have?
- B&M Ripper or Pro 5.0?
- Which fluid and how much?
- Cruising RPM
- Write up on clutch install?
- What clutch?
- TO Bearing
- Clutch Disc Size questions
- Clutch Questions
- Clutch hydrolics
- Honda ATF in a M6?
- Update on " Help Please"
- Weird clicking noise from tranny
- How many A4's have gone south after bolt ons?
- Steel or Aluminum Flywheel?
- Clutch problems
- Grinding... need help!
- spec 5 clutches???
- spec 3 poll
- I miss my 4.10s
- Centerforce after 50k miles Lots of pics
- C4 transmision hp potential
- Which shifter?
- Tranny guys, lost order of spacers, help??
- Got a ZOOM clutch, have a few ?'s
- Liberty Pro shifted guys come in
- Did I ruin my clutch?
- How many miles on your Centerforce?
- High HP Clutch Poll!
- Help with tranny rebuild
- C5 M12 to Hybrid Interchange
- LT1 vs LS1 T56, do they interchange?
- Revving car...RPM slow to bleed off. Could it be my Textralia clutch?
- tq specs?
- what flywheel for 600+ rwhp t56'd fcar?
- What gear?
- spec 5 clutch over spec 3
- spec 3???? maybe
- Hole in the Bell Housing!
- clutch and syncros
- What does a stock LS7 flywheel weigh?
- Correct LS7 Clutch Part Number???
- Hurst Knob and Pro 5.0?
- Pro 5.0
- I want a line lock......a little help here?
- clutch plate damaged
- Mcleod and clutch release resistance?
- what clutch???
- Hard to move the shifter through the gears at all times ?
- Drill mod
- Tranny NOTCHINESS?
- stripped threads
- Help Please!!
- what would cause a rattle sound at idle?
- RAM powergrip HD? comments??
- Pretty sure my clutch is gone!
- Centerforce
- anyone running a spec st3+ clutch yet?
- Vibrations - New ZO6 clutch and all new hydraulics
- cold start?
- Slipping
- Whoooooo!!!!!!!!1
- Will it hold
- when does it engage
- bleed valve
- Changed Tranny fluid to Mobil 1
- Help.....what went wrong?.......
- Best way to install an M6?
- Necessary to replace slave?
- By far the best way to bleed your clutch hydralic system
- some stupid t-56 questions from a 4l60e guy
- How long did it take you to do a clutch swap?
- My Transmission Help
- Anyone running the Mcleod Bellhousing....inside please!
- Clutch sticking to the floor after running it kinda hard
- Car stuck in reverse, now fixed. Carnage report
- 6th gear swap is there such a thing?
- Shifting Problems
- Strange Noise from area of Tranny HELP!!!
- can LS1 bolts be used for LS7 clutch install?
- Flywheel bolts
- Any way we could have a sticky on LS7 clutch install?
- T5 upgraded rebuilds
- Trans rebuild
- possible problem with trans?
- Clutch return spring & clutch master cylinder
- what MPG change from stock gear to 4.11?
- LS1/LS7 flywheel
- How many people are running an LS7 clutch RIGHT NOW?
- Torque Arm mounting brackets all the same for T56's?(93-02)
- gears grindin
- Best place to buy Mobil 1 Synth. ATF
- SPEC 5 opinions???
- Leather T56 shift knob
- do i have the correct part numbers?
- question about stock slave shim?
- Pro 5.0 out of an LT1
- Emergency!!!
- Need T56 help-bleedin clutch
- Diff in Speed
- Ls7 clutch????'s
- Where to buy LS7 clutch?
- Is traction with Nitto 555r's worth the risk of a dead 10-bolt?
- Car is stuck in reverse!! HELP!
- Please Help, Afraid To Drive!!!
- Different LS7 clutch numbers
- Exedy single disk questions
- I just changed by M6 trans oil, and now I have noise
- LS7 Clutch
- Need Diagnoses on my T56 problem pease!
- Quick slave cyl question
- Should I beef up the tranny before..
- grinding going into 3rd
- master cylinder
- Spec 3????
- I have a problem please help.
- Help with possible tranny issue
- Brand tex clutch, brand new master and slave clutch stopped disengaging
- T56 Rebuilders
- Help with clutch pedal
- Cartek fbod clutch kit
- tranny problems
- SLP Shifter
- wtf?
- GOOD clutch needed for Bolt-on Camaro SS!!!
- 2002 LS6 Clutch Kit vs 2002 LS1 clutch Kit
- McCleod Master help
- No Ethics lesson, quick help about scam.
- Help learning to drive manual.
- almost time to replace stock clutch
- 2002 master drill mod?
- Anyone Use Redline Products
- Anyone use the steeda tri-ax shifter?
- Why change shifters?
- Questions on Ripper Shifter
- Here's One For The Experts?
- Changing Reluctors to Compensate for Gears?
- what CLUTCH???
- A "click" going into fifth
- M6 and 12 bolt =No No?
- RPS Clutch? or Carteck clutch?
- Textralia Tri Grip Clutch???
- Funny sound
- bad synchro's
- Weight difference: t56 and th350
- what stock is the stock shifter?
- Difference? Slave vs Throw out bearing?
- 01 SS stock flywheel... mechanic says can't be ballanced
- Best way to get an OEM Flywheel?
- New Ram HD, free reving or slipping on freeway
- ls7 clutch too much for fairly stock ls1
- Textrailia Website?
- No top gears
- which short stick to go with my 5.0?
- opinions on Textralia slave cyl.
- My Clutch v. pghd pos
- My ls7 clutch pics
- How much horsepower can a C5 driveline take?
