PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 [102] 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. powershifting into second?
  2. Viper input shaft????
  3. LS7 with T-56 from SSR?
  4. rough day at the track, shifting is stiffer, why?
  5. stock clutch hp limit??
  6. Can the pressureplate hold the weight of the tranny?
  7. Mcleod twin disk install instructions???
  8. slave cylinder for c5
  9. Master cylinder
  10. is much power lost with a heavy clutch?
  11. Pilot bearing issue
  12. Wut Flywheels 2 Buy?
  13. Clutch Sticking at 4th gear
  14. PLease explain why?
  15. Flywheel Help!
  16. Clutch help
  17. mcleod hydraulic line?
  18. Can you bolt an LT1 flywheel/clutch setup to an ls1 car? (no im not gonna do it)
  19. tranny mount
  20. Drill Mod?
  21. RAM billet flywheel
  22. How many miles did your stock clutch last?
  23. Any ideas...?
  24. How long will a stock clutch/trans last?
  25. Official LS6/LS7 clutch ratings?
  26. what is this and where does it go
  27. Quick Question - Stock Clutch HP
  28. Clutch not engaging?
  29. do you have to break in the clutch?
  30. Uh ohh
  31. please help me diagnose this problem
  32. Clutch Pedal feels soft in the Morning!!!
  33. Breaking in a clutch
  34. Economy shifting
  35. Any Downsides to Textralia???
  36. Has Anyone Thought of This?
  37. 98 master - New one or reuse stock?
  38. McLeod slave bleeder extension?
  39. Which flywheel to go with?
  40. Lou's short stick on a B&M?
  41. Drill Mod and still have High RPM pressure loss
  42. So i took out my stock clutch today
  43. launching with m6 and et streets
  44. loss of power? give me your thoughts
  45. bleed question
  46. replaced master car is still wont go in gear.
  47. Need advice on adjustable master cyl. ASAP!
  48. can i hook a t56 tranny up to a lt1 with a auto wireing harness
  49. Lookin at ZO700AB Aluminum Flywheel Set..Opinions
  50. 3rd gear pop out
  51. Slip Yoke leak.... TQ arm caused??
  52. New SPEC 5 squealing but for how long?
  53. The problems i have with my car!
  54. a4 to m6
  55. gto-camaro: tranny's interchangable?
  56. Need Opinions
  57. Need Help ASAP!!!
  58. How to tell if the clutch is going?
  59. How much should a rebuild cost?
  60. New Clutch issues
  61. defective pressure plate??
  62. Need Help W/t56 Rebuild
  63. 1LE tranny mount ?
  64. Nosiey Clutch
  65. LS7 clutch/LS2 flywheel w/ D1SC Procharger
  66. Brand New Spec Clutch and Flywheel for sale
  67. What stick to get for a B&M?
  68. SPEC Clutch
  69. emergency- stuck in 3RD
  70. Bolt Sizes
  71. Shift Knob affecting shifting.
  72. 4th and 6th gear problems?!!!
  73. i need a clutch
  74. WTF! Tranny/Clutch Problems.(Long story)
  75. Oh god
  76. How much can it take?
  77. Where'd the 3.73s come from?
  78. Gm high carbon billet steel flywheel?
  79. smoother shifting
  80. Another ? on the fidanza flywheel?
  81. Clutch installation with headers?
  82. does anyone no what the stock thickness??
  83. only 5k on it and it failed
  84. Clutch is acting up- whats the diagnosis?
  85. Anyone here have g-forcebuilt t-56
  86. grinding
  87. How do I know I have a Hurst Shifter?
  88. Do V6 Fbodies have the same manual trans as the V8 models?
  89. How much should i pay for a ram 910/vds
  90. Slave cylinder travel
  91. would i need a clutch spacer???
  92. What kills a clutch?
  93. Who has had a clutch or pressure plate come apart?
  94. Textralia annouces our new double and triple disc clutch
  95. Just swapped out shifters...
  96. Anyone know where to buy puller?
  97. Input shaft chewed up?
  98. gears?
  99. What master and slave setup to use.
  100. T-56 Rebuild/New Clutch
  101. I think its time for a rebuild!
  102. rev limiter?
  103. Mcleod Street Twin rebuild..anyone?
  104. Stock flywheel weight...
  105. T56 build?
  106. Lou's short stick
  107. How much power can a stock M6 C5 tranny handle???
  108. Help, tranny wont go in gear!
  109. Can you resurface a presure plate?
  110. Should I teach my GF how to drive stick in my T/A??
  111. Cut the stock stick?
  112. clutch probs with a lt1
  113. sfi app. housing
  114. synthetic tranny fluid for rebuilt t-56
  115. What would worn master/slave sound like?
  116. can't get bolt off
  117. Burnouts with M6?
  118. grinding noise
  119. pressure bleed
  120. Stock master and Mcleod twin disk?
  121. T-56 trouble
  122. Step by step LS1 clutch replacement?
  123. t56 trans
  124. what should i buy
  125. Hydraulic line into Mcleoud master...
  126. Fidanza or Spec Flywheel?
  127. Upgrading clutch, need some help ASAP
  128. M6 Transmission Fluid Question
  129. LS6 clutch ok in Cammed C5?
  130. Need Help Started Car For First Time
  131. shifting at high rpms
  132. Which one...
  133. Bleeding the Clutch?
  134. shifters
  135. Which clutch?
  136. wheels wont spin
  137. Quick question on my purchasing choice!
  138. Will I need a new fly wheel???
  139. Gf-5r?
  140. Phucen Clutches. 422 Delema
  141. Master/Slave
  142. Burning the Clutch
  143. Remote Slave Cylinder Bleeder available for FBodies
  144. Clutch Replacement ?'s
  145. sequential?
  146. Whats trans fluid do you have in your T56?
  147. If there was a manual clutch setup available for LS1's would you buy it?
  148. How many people have gone "pro-shifted" with T-56?
  149. Weird Problem
  150. t-56 and 454 will it fit
  151. insulate clutch hydro line?
  152. Grinding while shifting gears.
  153. New clutch?
  154. T-56 or even a 5 speed that'll take 1000 rwtq?
  155. Grinding into 5th gear
  156. new clutch, slave and master
  157. Raptor Shift LIght Install Q's
  158. Is it impossible to get a very track reliable clutch that is streetable?
  159. Centerforce DF 12" Clutch??
  160. What to do with old clutch?
  161. Need minor help with LS6 clutch in LS1...
  162. What is Happening...........
  163. problem with hydraulics
  164. Possible Trans or Clutch Problems
  165. T-56 3rd gear trouble need help!!
  166. Do I need to bleed if I did this... Also Adjustable Master ?'s
  167. Ticking Noise Of Death!!!!!!!!!!!!!!!!!!!
  168. Serious Clutch Diagnosis Problem. Help!!
  169. Eveyone With A T56Rebuilds.com Tranny! We Need your Photos for our Website!
  170. When are ARP bolts needed / suggested?
  171. UMI short stick vs WS6store short stick
  172. does anyone know what is causing this?
  173. i think i found out the grinding noise
  174. Master and slave problem
  175. Fundamental question...
  176. Oh no...there the clutch goes.
  177. OEM Hurst Question
  178. Slave and Master Cynlinder
  179. about to pull the trigger.... last minute question
  180. clutches
  181. big problem
  182. fedup, pissed off, frustrated!
  183. Help with starting / clutch!
  184. bronze fork pad feedback
  185. Skip Shift light 98 Z-28 SS M6
  186. Normal rattling at 100,000 miles?
  187. clutch question
  188. "ideal" clutch pedel pressure????
  189. Long lasting, stong holding clutch.
  190. BIG POWER TURBO GUYS WITH M6's
  191. Just Got Ls7 Clutch Kit ????
  192. Just Got Ls7 Clutch Kit ????
  193. Need your help guys
  194. rebuildable hurst shifter
  195. Lost Reverse, 5th and 6th!!!! Need Help!!!!!
  196. T56 Problems inside....
  197. Dumb Question is a T56 a T56?
  198. What short stick should I get?
  199. Flameball shift knobs.
  200. Changing transmision fluid in a 6 speed?
  201. clutch problem maybe?
  202. Spec 4 Clutch who here is running it????
  203. Redline for MM6 trans?
  204. 3rd gear grinding .... help!
  205. WS6 Store Short Stick on PRO 5.0
  206. Downshifting
  207. car won't go into gear
  208. Shift light install
  209. Refacing flywheel
  210. Help Quick Clutch engaging really low
  211. Who sales Fidanza Friction Disk ?
  212. 6-speed set up...whats it worth??$$$??
  213. Does the Fidanza aluminum flywheel need balanced?
  214. Does the Fidanza aluminum flywheel need to be balanced?
  215. Looks like I’m a drill mod candidate
  216. tremmec TKO-600 ls2 69 camaro
  217. What i paid for my ls7 clutch
  218. Liberty Face Plating
  219. ctsv flywheel
  220. feedback on Hurst pistol grip??
  221. come in and give me some feedback!
  222. pics of hurst shifter
  223. Ls2 Clutch
  224. clutch problem with mcleod twin
  225. strange noises=not good!!!
  226. TEXtralia owners please chime in
  227. Spec vs. Ram
  228. Purpose of shimming a clutch
  229. where can i find a LS7 clutch kit?
  230. LS7 clutch install - shim slave? Quick answer please.
  231. clutch chatter?
  232. loose qd clutch line fitting on slave
  233. Clutch problems.. please help!
  234. SPEC 3, aftermarket flywheel...balance?
  235. Looking for Street/Strip Clutch
  236. HELP......Clutch install
  237. Know Squat about clutchs Help!!!!
  238. Will an ls7 clutch fit my needs
  239. clutch fluid hydro line?
  240. clicking noise coming from tranny/clutch
  241. trans making wierd noise
  242. McLeod?
  243. Mcleod twin disc owners inside please.....important
  244. Stock T56 hp limits?
  245. Cheapest place for LS7 clutch package?
  246. slave cylinder question
  247. 1st - 2nd....problem...
  248. reverse problem
  249. problem with my 3rd
  250. how long did it take you to rebuild your first t-56
