View Full Version : Manual Transmission
- What am I doing wrong tex owners???
- what did I break??
- Tons of chatter after Spec stage one install?
- Need Help, Hard to shift into reverse after dropping engine/trans
- Need shifter removal help: sealant removal
- Ram Twin Disk Clutch System
- new t56 from D&D good idea?
- bleeding the clutch master cylinder?
- Installing the Master Clyinder
- No A/C HVAC after A4 to M6 swap
- whats the best M6 for a 3.73 rearend?
- real quick where is the bleeder valve
- Not shifting after slight load...
- Clutch installs Who is doing them
- Will an LS7 Clutch hold for me?
- Sudden soft clutch pedal?
- clutch release higher??
- Textralia Break In??
- clutch bleeding problem. (surprise) :/
- Clutch shopping, questions
- Clutch pedal to the floor, at an intersection
- M6 noise. Please help.
- NMCA 1 time only Race Special that is insane!!!!!!!
- Grinding Gears
- Wont go into reverse! need your hlep!
- could this be clutch slipping
- How much clutch is too much clutch?
- Can an LS style T56 be used behind another motor?
- Spec 3 slipping, weird
- shift boot clip
- High rpm shifts
- clutch problems--still have them after drill mod
- How much power will I be leaving on the table with my stock clutch?
- How much clutch throw is too much? Adj. master question...
- >>ALUMINUM FLYWHEEL OR BILLET STELL FLYWHEEL????????
- How to tell when clutch is failing?
- Transmission code
- Looking for a clutch
- After clutch install, I keep getting code 0704,Why?
- 4.10 Gears for my M6 Daily Driver
- A4 to M6
- Stick Question
- grinds goin into 2nd whats up
- LS7 Clutch/LS2 Flywheel Installed
- ***ATTN: SPEC*** Pics of my Stage 3
- Steel Shift Fork Question
- Who has actual experience with the spec 3+ clutch
- lt1 t56 to ls1 help now please
- Help With Whining Noise
- Slave and master suggestions
- need 01-02 slave cylinder...
- T-56 trans cooler interest?
- Installing 95 Chevy 5spd Help!!!
- spec....search is worthless today
- slave not disengaging clutch HELP!!!
- first gear grinding
- T56 Won't go into Reverse
- slave cylinder problem...
- quick stupid question be 4 i buy it!!!
- m6 problem help
- T56 Extension Housing gasket??
- m6 problem
- How do you bleed your clutch hydraulics?
- Flushing clutch hydraulics question
- Shifter bushings/spring?
- Pro 5.0 & Factory Hurst Short Stick
- Help me ID my left over T56 rebuild parts (PIC)
- less abrupt clutch???
- T56 locked me out of all gears???
- strongest T56 on market?
- >>quick question on clutch overheating!!!
- Textralia exoskel twin disk, a lilttle noisey?
- The Myth of the Street/Strip Clutch
- t-56 weight?
- Transmission Fluid
- McLeod slave cylinder with OZ700?
- Hurst Shifter question
- Sponsor that sells Hurst Shifter Emblem for rear of car
- problem with sticking 4th gear
- loud thump when i shift!!!
- banging in the trans tunnel??
- How long should this take?
- T56 Clutch and Flywheel question
- Just finished my 4l60e swap to a 6 speed!
- Sticking clutch pedal write-up
- is there a trick to hook up trans?
- Has anyone broken their LS7 clutch yet?
- Replacing clutch very VERY soon..few ?'s
- help me
- problems with t56 please any advise
- How to remove a 5 speed tranny? A friend in France is in trouble with his 96 V6
- Some T56 problems
- Textralia OZ700...first impressions...
- Help: Clutch hose popping out on T56?
- Aftermarket shifters bad for a Daily Driver ?
- Spec 3+ clutch questions. Should I use stock flywheel?
- Question about tranny
- MN12 in T/A, shifter problem HELP!
- clutch confusion
- hard to shift into 1st and reverse
- Remote Bleeder GP
- A built F-body t56 or a stock Gto t56?
- Parts list (ls7 clutch)
- help....
- clutch confusion
- hard shifting, and i have tried alot!!
- Trans is coming out again. #*^$!
- 3rd Gear Grinds
- Does the gto need thw drill mod???
- Strange situation with my hydro's. Not sure what to think
- is an ls7 clutch ok with stock '06 GTO T-out Bearing???
- Installed UMI tranny brace, now horrible vibration!
- clutch don't work need assistance
- Yet another clutch problem.
- New clutch, FW, Hydro's, rebuilt tranny, still not shifting right.
- rebuilt M6
- tranny question really weird
- bellhousing
- Any new shifting vids?
- Steeda Tri Ax handle. Which shift knob fits? Thread and pitch?
- problems
- can i rebuild my t56?
- Clutch shot?
- B & M Ripper install
- clutch install write up
- what 6 speed??
- Shifting
- Flushing Master Cyl.....check it out.
- How long?
- Update......
- T56 conversion question
- Six Speeds Inc. Closed July 4th
- master cylinder
- Ls7 Clutch Kit
- Tranny or Clutch??
- F'in LIVID @ McLeod Industries
- please help bleeder valve
- Need some input, just added longtubes and ory pipe, drivetrain slack?
- LT1 specific clutch questions...
- Seafoamed my car...added so much power, took out the clutch!
- TEX twin exoskel at nearly 400 miles review.
- stuck
- transmission mount tip
- skip shift
- Reverse issue
- Need help!! 96 T/A flex clutch line needed ASAP!!
- Ram powergrip Hd problem.
- T56 Rebuild Questions
- Cost of used t56
- VSS Trouble Code..Speedo not working
- FS: (1) New Spec Stage 3 Clutch Kit
- Problem with billet 3/4 keys/struts
- slave cylinder Q??
- stupid question
- Worn synchros?
- Correct Way to bleed Clutch???
- Hard to get it in Reverse...
- How should i adjust my ram adjustable master asap
- Where to get transmission rebuilt
- Anyone have experience with CF DFX clutch?
- Trans Or Clutch Problem????
- Question For Six Speed,Inc
- 99 Z28 Clutch Help
- What Blew ???
- Adjustable master cylinder???
- Possible ls7 clutch problem...need help
- wont go in gear
- bellhousing
- question about our trannies
- problem with my t56
- 3rd gear problem! help please
- can i get a viper t56 overhaul kit for my t56?
- Weid cluth problems after McLeod Master Cylinder
- when to upgrade mcleod single disc?
- Clutch Leak
- Weird gear noise after Pro 5.0 install
- Need new gear? To worn?
- 93-02 t56
- F*@cking Bell Housing !!
- won't roll in neutral
- Low mile tranny shift problems
- Clutch Question
- Where can I find the best deal on SPEC Clutches?
- how much to torque???
- t56 short stick
- not a good sound! (video included)
- Royal Purple Syncromax
- T56 sticking in gear
- Where to buy a new stock LS1 flywheel?
- Where to get a remote clutch bleeder
- Billet Steel Flywheel Advantages?
- Changing Hydraulic Fluid
- t56 to sbc
- which is the best adjustable master cylinder
- high horsepower clutch
- Converting from pull type clutch
- Pro 5.0 Installed
- LS7 clutch in an LS1 f-body
- Shifter Gasket
- Need a clutch, narrowed it down to two
- T56 Rear Seal leak after Dyno
- Is this normal? Pics inside
- Racking my Brains!!! Need suggestions please
- Heat Shielding for MC Line
- Need Part number for rubber boot.
- Bad clutch, shifter or what???
- T56 gear ratio change?
- LQ4 + McLeod + T-56
- Pressure Plate problems.
- GTO shifting Problems
- popping out of reverse?
- T-56 6th gear stuck
- People With Clutch Pedal Problems Please Read :)
- Spec Stage 2
- who knows????? pelase
- How much is a used 9" center section worth?
- Bent 3/4 shift fork? (search not working)
- Hey guys have a ??
- T56 Rebuild ? (tailhousing)
- Gear safe cleaning solvent?
- weird noise comming from a few gears
- Clutch Problems - any help?
- Why are Clutches more fragile than Brakes?
- Throttle response issues...lags at inital launch
- 6th gear not engaging ???
- LS7 clutch shifter is shaking
- Cant figure out what the problem is with my t-56
- rebuilding T56 have a couple questions, pics included, 56k I dunno
- T56 Reverse Idle Gear (thrust washers?)
- ram clutch stock flywheel HELP
- What clutch would best suit my future power?
- Just installed a spec stage 3 and i have a ???
- Clutch pedal doesn't return, pressure plate?!?! Search down
- parts list and possibly prices for t56 to 480 conversion.
- Ok tex twin owners some advice please.
- T-56 and Harlan 2 step question
- plastic slave cylinder disconnect tool
- Exoskel Question
- is this bad??? someone read
- 01 slave took a shit
- Clutch reservoir fluid exchange..now pedal is worse...???
- Smaller Bellhousing
- clutch fork
- Cant get into gear
- driving with a spec 3
- Trans in gear, shifter off. Trans will not shift.
- rebuild tools questions t56
- LS7 Clutch Question
- Camaro T56 Pro 5.0 fit C5 T56?
- Rubber shifter boot needed
