PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 [104] 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Mcleod Clutch (LT1)
  2. howto for slave cylinder install
  3. GM Flywheel weights
  4. Anybody want an MN12 upgrade?
  5. i wanna do a t56 swap from A4
  6. Moral delima with SPEC
  7. Mity Vac clutch bleeding ?
  8. Anyone running a Meleod steel bellhousing
  9. clutch pedal?
  10. tips for removing shifter boot?
  11. balancing clutch assembly
  12. Royal purple ATF Trans fuild for t-56? good or bad
  13. Motive 4.10s installed
  14. 20,000 miles and already shifting problems?
  15. My clutch is really starting to annoy me
  16. Mcleod master cylinder line
  17. having trouble shifting?
  18. BEST CLUTCH FOR 425 HP or less
  19. Link for a clutch change: 2001 Z28??
  20. Step by Step directions on how to change my clutch?
  21. SLP LT1 Clutch
  22. Mcleod Twin vs. TEXtralia
  23. Clutch Dilemma
  24. Any experience with the spec 2+ 3+
  25. Sweet spots in an M6
  26. Output shaft measurement
  27. Transmission Problems
  28. cheapest hydraulics?
  29. spray & clutch choice????
  30. any ideas? invisible shift gate!!
  31. T56 Synchro keys??
  32. where to get LS7 clutch????
  33. Slipping out of third gear
  34. What effect does adjustable master have
  35. Crap or not crap??
  36. 1st, 3rd, and 4th gear problems i need LOTS OF HELP!
  37. Cheapest place to buy a clutch?
  38. Got my Stage 4 Spec today, any idea how long these last?
  39. Upgraded hydraulics for 98 T56 install questions.
  40. T-56 rebuild for cheap
  41. '97 C5...no more 3rd gear :-(
  42. Drill Mod?
  43. hardware ???
  44. Used Clutches
  45. JUST in case you get a rear trans leak!!
  46. Quick disconnect Fitting won't go back in HELP
  47. Weird tranny/clutch noise?
  48. Reverse is making a loud noise!
  49. Ups Is Here
  50. Shifting problems??
  51. taking out tranny
  52. Centerforce 12" DF Clutch installed...
  53. pilot bearing trashed, what was yours like
  54. Vibration/Rattle, Clutch????
  55. which mity vac?
  56. clutch slipping?
  57. Skip Shift
  58. How to rid my car of this vibration...
  59. Looks like LS7 clutch can hold some power
  60. Color of tranny fluid ?
  61. Anyone Shortened B&M Shifter?
  62. LT1 T56 into an LS1 car
  63. HELP! Ready to give up!
  64. Who actually makes the stock 6-speeds
  65. shifting problems with t56
  66. Tranny blanket
  67. Clutch pedal sticking 3rd/4th
  68. Bad vibration...???
  69. T-56 And 1000hp
  70. gears won't go in
  71. rattle from shifter?
  72. Who has Textralia Clutches in stock?
  73. Dead battery after shift light install?
  74. GM TSB 04-07-31-005 M/T - Clutch Pressure Plate Wear Indicator Adjustment
  75. GM TSB 01-07-31-002A M/T - Improved Hydraulic Clutch Bleeding Procedure
  76. Clutch decision..
  77. Best mpg?
  78. explane the TO bearing to me
  79. A T-56 On '68 firebird(anyone)
  80. 5th or 6th gear on highway??
  81. clutch pressures
  82. Bleeding the clutch is killing me!!!!!!!!!!!!!
  83. What parts do i need!?
  84. rusty flywheel!!!!!!
  85. T 56 or TKO 600???
  86. At what point do i need an upgraded clutch?
  87. Reduce The Noise
  88. Rear end gear for T 56?
  89. T 56 gears
  90. T 56 in stock Chevelle console???
  91. Are all T56's in GM vehicles interchangeable?
  92. How many running the Textralia clutch?
  93. Spec Stage 2 or RAM Powergrip HD
  94. clutch master cylinder ?
  95. Steal or aluminum flywheel?
  96. Factory hurst into 06 Goat
  97. changing clutch master cyl, need advice
  98. Where to buy Textralia cutch?
  99. What RPM to shift at, also to set shift light?
  100. new clutch, cant put in gear.
  101. A4 to M6 swap peeps get in here!!!
  102. Identify year of T56? Vent? Torque Arm mounts?
  103. What kind of grease in shifter housing?
  104. Looking for opinions on Ram Powergrip HD
  105. Another T56 2nd gear problem
  106. pro 5.0
  107. Rebalance clutch with alum. flywheel
  108. Clutch Pedal down for the count!?
  109. Rebalance clutch with aluminum flywheel?
  110. replacing your hydraulics
  111. luk clutch?
  112. Shift light install?
  113. Changing to aluminum flywheel
  114. What is a T-56 good too?
  115. Possible Clutch Problems?
  116. Damn clutch still sticking
  117. best stall to match cam
  118. New Clutch...which one?
  119. Help!! Got my 01 Z06 and it's sticking in gear!!!
  120. transmission whining
  121. 6inch or 6.5inch short stick?
  122. Master cylinder required?
  123. newer slave cylinder?
  124. Is the stock WS6 shifter a hurst
  125. shift question
  126. Confused
  127. hard to shift. HELP
  128. Removal of T56 synchro keys?
  129. Clutch Replacement Mixed parts: Can I do this???
  130. Stock T-56
  131. pilot bearing's direction (pics)
  132. T56 all syncros going at once????
  133. need bolt size
  134. question about difference between M6 and T56...
  135. Speed Inc's short shifter?????
  136. For those who have completed a T-56 swap
  137. new clutch........
  138. clutch engages on the very top of the movement
  139. What is the proper way to bleed a new slave cylinder?
  140. Not sure what is the problem. Need help
  141. Slave that comes with Textralia is it pre bled?
  142. Pro 5.0 with UMI SS or LSS?
  143. Take a look at this clutch
  144. clutch rattle?
  145. $500 a good qoute?
  146. adjust side tension on 56 shifter?
  147. I think 2nd gear is fnucked, seriously please help
  148. Why won't it come out!
  149. slave cilinder package install
  150. Spec stage 5 streetable???
  151. is riding the clutch bad for the clutch or not?
  152. Another Spec exploded...
  153. clunks while engaging and disengaging clutch..ideas??`
  154. t56 rebuild question
  155. Clutch grinding WTF?
  156. clutch stuck to floor! WTF!!!
  157. New Web Page for T56 Information
  158. Help Removing Stock Hurst Shifter Knob
  159. t56 questions
  160. T-56\5.3l
  161. Cruise Control Prob After A4 to M6 Swap
  162. new clutch...has some quarks?
  163. My clutch is making a klunking noise.
  164. Spec 2+ clutch
  165. Top bolt on the bell housing
  166. T56 Hydraulic clutch booster rod movement??
  167. pro 5.0 where do you buy this shifter for the ls1 camaro ?
  168. SLP/Hurst short throw shifter...what's yours feel like?
  169. about to change clutch what else needed
  170. flywheel fitment question
  171. clutch problem...need help?!?
  172. adjustable master
  173. Input shaft rubbing inside of slave cylinder
  174. cluthc slave, quick disconnect
  175. What's wrong with my clutch this time?
  176. LS7 + LS2 Flywheel reviews
  177. Ls6 Clutch Question
  178. I've searched...few questions (clutch master/slave cylinders)...
  179. Need suggestions for new clutch and flywheel
  180. Mcleod?
  181. what kind of clutch?
  182. help clutch assembly bolts?
  183. Question About Pilot Bearing? Solid Or Roller?
  184. Centerforce with high rpm shifting?
  185. centerforce dfx
  186. Manual Transmission Fluid
  187. C6 shift knob on my 98 Z *pics*
  188. witch tpye of trans fluid (not whatbrand but what type)
  189. LS7 Vs Powergrip
  190. trouble with reverse
  191. Time for a new clutch!
  192. LS6 clutch good enough?
  193. Metal to metal rubing
  194. replacing the release bearing
  195. Anyone use Penzoil Synchromesh in T56 ??
  196. Textralia ordered need install guide
  197. 3rd Gear Grinding Problem
  198. RPS Clutch !
  199. What can it be?
  200. Clutch prob
  201. LS6 Clutch?
  202. My clutch install with parts/sponsor reviews.
  203. Replacing slave cylinder on lt1 TA ?
  204. Hurst problems...
  205. could it be the hydrolics ?
  206. 5th, 6th Grinding...
  207. What size are the Flywheel dowel pins?
  208. T56 Cant get into gear at first then grinding....
  209. Got the shiftlight in... to put the tach back in or not?
  210. Textralia Hydraulic line(SS braided)
  211. Master/slave at NAPA Auto Parts...
  212. how fast does yourclutch wear out?
  213. Squealing in the clucthc area
  214. Skip shift elminator
  215. Z06 clucth in fbody
  216. How Do You Bleed The Clutch With All Stock Parts?
  217. Master cylinder install on a C5
  218. who rebuilds trany in Pheonix area
  219. Which one of these hydr. brake bleeders works best?
  220. T56 Full Line of Parts Now Available(IN STOCK)
  221. tranny problem
  222. Knobs Knobs Knobs
  223. Auto to Manual conversion
  224. Transmission going out?
  225. High mileage, installing cam what do i need?
  226. LS7 clutch install in a C5 PLEASE HELP!!!!!!!!!
  227. Clutch Bleeding, what not to do
  228. what kind of clutch do I need
  229. just had my tranny rebuilt
  230. ls2 and t-56?
  231. Whats a good clutch ?
  232. 550rwhp clutch
  233. Clutch Pedal Question
  234. With new SPEC S3: need new master or just slave?
  235. Manual or automatic???
  236. Where can i buy a SPEC stage 5?
  237. I need a drag clutch please help
  238. Problem with Clutch/Tranny
  239. Bleeding Clutch
  240. M6 Boot/clip Question
  241. T56Rebuilds.com New Years Special
  242. Textralia Clutch Starting to Drag... Solutions?
  243. No Skip Shift since I put in the 4.10's; cool, but why?
  244. Can cold affect the clutch?
  245. About to do clutch swap need torque specs
  246. thinkin of a new clutch???
  247. Fidanza flywheel: cost to resurface
  248. Clutch Switch?
  249. 2 Probems Please Help!
  250. installed my new short stick...nice
