View Full Version : Manual Transmission
- Clutch Problems
- Master and Slave upgrade
- Spec 4 Users come in!
- drill mod question
- tranny problems
- who to use to build up a T56 for 640RWHP?
- Pictures of Stock Shifter or Hurst...
- Warranty?
- Trans Problem
- Best clutch kit for stock LS1?
- Spec Stage 2 or 3? Feedback?
- Anyone send their trans to MRE?
- T-56, What is this noise?
- How bad is it to...
- Rebuild in progress....Opinions on parts
- t-56 rebuild
- pilot bearing install?
- How do I convert to 2.97 gears like the Zo6?
- ? about rebuild t56
- No clutch disengagement !!WTF!! HELP!!
- F-body Pro 5.0 in a Z06?
- C5 Corvette noisy throwout bearing?
- Cheapest place to get LS6 Clutch Assembely
- Spec 3X vs Spec 3?
- Pro 5.0 and LOU's Short Throw
- Short Stick sale, 2 options!!
- Serious stickshift racers clutch help 6-speed
- How much does it cost to beef up a T56?
- Spec stage III going in tomorrow, one stupid question...
- How hard would it be to install steel shift forks myself?
- transmission mount
- Clutch Recommendation for 99 TA
- Any ideas on what to expect?
- Slave Cylinder Installation
- T56 making noise
- blown clutch already?
- z06 M6 question
- Clutch slipping already?
- What Kind of Shifter do I have...
- This is getting crazy
- will a camaro/corvette T56 fit on a GTO?
- updated slave? longer hose?
- Im having a clutch NIGHTMARE details inside
- Tranny or Clutch???
- Clutch pedal broke.
- HORRIBLE chattering in gear w/ clutch pedal pressed and revved?
- Difficult to Engage 3rd, sometimes doesn't stay in.
- Where can i get a raptor shift light
- Any1 have a broken t56 that u would like to donate or sell??
- Spec engagement point
- Clutch question
- Changing a synchro for the first time
- Clutch suggestions for 650hp?
- Minimum flywheel depth before you need a new one?
- Ram 910/402 review
- tranny help
- I need clutch help
- Clutch recommendations?
- '01/'02 guys, how many miles on your stock clutch?
- Better Trans Shop..FLP or Speed Inc
- Slave
- McLeod Twin Plate in Aussie V8
- Who says us m6 guys cant launch hard
- ram 910 users inside please
- ??? about down shifting..
- Any difference in a GTO, F-Body or Corvette clutch
- Very Lengthy Mechanic oriented
- M6 down shifting noise question
- McLeod Master Clutch
- bout time to rebuild my trans
- grinding at slow revs and part throttle, perfect when WOT??
- ANOTHER Spec 3 clutch question...
- T56 trouble
- help please!
- Ram VDS Clutch system
- Help Diagnose T56 3rd Gear Problem
- M6 is rebuilt..piece of cake
- Are all M6 V8 transmission mounts the same?
- Installing a new clutch?
- Broke my spec III what now?
- ???? Spec stage three...
- How can I tell if I have updated Hydros?
- poor shift
- undecided on clutch
- Anyone esle have a spec stag4 with the new F disc?
- Should I soak my blocker rings??
- I need an accuator
- M6 help needed inside <~~~~~~
- What's going bad?
- Clutch design questions?
- Grinding when going into 6th.
- What's The Best Fluid For The T56?
- Annoying vibration...Any ideas
- d and d T56
- what spec shim, metal or green?
- t-56 conversion Who much to expect?
- So my dual disk McLeod clutch blew up and took out my input shaft too, pics inside...
- Engine stutters at 5500 RPM but only in 1st
- Ls1 & Lt1 T-56
- Depserately need info/help from you guys. Dealer woes tranny probs!
- i pulled the tranny this morning...
- ram powergrip
- question
- where can I get a M6 input shaft?
- Want out of this 6 speed!
- Tranny problems, I need help
- To shim or not to shim, that is the question.
- What's the difference between the Ram and Mcleod Adjustable master?
- Exedy c5 clutch same as f-body's????
- SPEC Stage 2 or 3??
- Problems bleeding the clutch
- Fastes 6 Spd? Who Is It!
- Clutch break-in question
- clutch release spring, AGAIN!
- won't to 2nd @ high rpm
- No pedal presure, what gives
- For all you guys killing the stage 3 clutches try this one
- what risks are there if...
- Spec Stage 2 Versus Ram HD with 900 series disc
- Clutch Pedal Sticking to the Floor
- Clutch out?
- Clutch Slippage when shifting to 2nd
- Shifter question from a new guy
- Help W/ Harlan Shift Light
- Just got through with A4->M6 in truck.
- Tranny Locked Up
- Car Wont START! nobody can figure it out!
- I highly recommend G-Force Transmissions
- Clutch is sticking in?!
- Best Clutch for me?
- Best Clutch for 700+ rwhp?
- triple cone syncro's in a vette?
- RAM 300 series disk
- Need help with shifting problem
- Which Exedy to get??
- Clutch Return Spring
- Clutch Arrived
- help! clutch pedal sticks/goes to floor in 02 z06....
- Will the fbody clutch fluid line work on a c5?
- Ripper Question
- 8hp from SPEC billet Aluminunm Flywheel?
- Will a lighter than stock flywheel make my idle move????
- Stock Clutch cant handle it???
- Replacing slave??
- Whats W/ Spec Problems!?!?
- Shifter knob
- What clutch is in LS2?
- t56 bellhousing question
- Spec stage 3 clutch & steel billet flywheel buyers look
- clutch chatter ???????
- Rebuilding a performance clutch?
- Spec Problems? Please come in.
- Where can i get a M6 changeover kit?
- I could use some advice on shim useage
- ZO6 Clutch
- transmision cart
- Shifting into 1st, 3rd, 5th, and Reverse...
- Newbie Questions about Trans Problem, maybee slave cyl??
- Anyone have their reverse lockout fail?
- confused
- Don't Mean to start a War
- What clutch???
- My beater truck grinds when I put in reverse.
- I need a clutch!!!!!
- Trans Fluid
- Throwout bearing
- Need a clutch for my car!
- T56 in old Bird
- Can't shift into 3rd at High RPM.
- pilot bearing removal
- Clutch question
- Ripper Shifter Knobs....
- thicker shim???
- Pro 5.0 w/ Lou's Short Stick - My experience
- Cartek clutch
- Flywheel ?
- anyone find a place that sell the GM 5/6 gear puller for T56?
- Clutch will not disenguage
- Ripper Shifter Question
- My clutch/tranny is acting rediculously funky, please help!
- aluminum flywheel
- Tranny Question
- just got clutch replaced... extremely loose?
- I thought T56's were supposed to be strong?
- Emergency Help with swap (Car does Not Run)
- Spec 3i Help!!! Vibration
- t-56 grinding
- Full tranny set-up and a few ?'s
- Gen4 Auto to manual trans coversion...possible???
- clutch help?
- Another dumb drill mod question
- SPEC 3 Highway Gear Slip
- Vehicle Speed Sensor
- Whats up with my clutch?
- Whats the Diff between FLP and Speed Inc
- clutch pedal spring broke off!
- Tranny Locked Up In Neutral?
- Mcleod Setup... gettin soft
- Who sells rebuilt/upgraded used t-56's?
- centerforce
- Newbie on the stick
- Another unhappy Spec customer
- What Clutch is in your car?
- Drive Shaft Loop
- rebuild kit
- Spec warranty?
- Updated Part Number For gm Master Cylinder?
- OK...burnt up my clutch with 200miles on it
- Clutch pedal stuck to floor
- ? about my m6
- What causes the clutch to stick?
- Adjusting the Pro 5.0
- Whats Different with the Center Console in a 1998?
- Need help, Reverse lockout, Cruise Control
- Spec clutch problems!!!! I am tired of dealing with them!!!
- Squeak/rattle +Leak from bellhousing back - Rear Main Seal or Clutch Hydraulic Fluid?
- !Having an issue! slave connection supposed to be like this?
- Clutch install pointers
- tranny grinds partial throttle but not @ WOT?!
- Anyone use a flywheel shim?
- Can you mix tranny fluid?
- 5 speed for a 5.3
- Mcleod or Spec or Ram or Centerforce
- Transmission problem at track last night!!!
- Warranty and the T56
- I'm not sure what the title should say ???????
- whats the point of 500 mile break in?
- Funky clutch pedal pressure...
- Spec Stage 3 question
- Name this smell...
- 98 auto to M6 problem
- Need tranny shop
- Hard To Shift Sometimes
- auto/man
- stuck in 3rd..help me out
- I'm starting to have some weird issues with my SPEC III - please help!
- stock clutch going/chatter?
- stock trans going...going...gone! need info for rebuild
- Street Twin Problems
- Clutch pedal release question.
- Converting to M6
- What shifter for 04 GTO?
- just installed new master cyl. and have a ?
- Drill mod?
- Spec or Centerforce???
- Any one else ever break ....
- Starting an M6
- Which Clutch??
- Shifter movement when accelerating
- will this work
