View Full Version : Manual Transmission
- can decide on a clutch
- clutch change with jack stands?
- Clutch sticks to floor WTF!?
- Clutch won't engage
- Hydraulic Issues(semi long, story included)
- Fully Built Z06 T56 Transmission w/G-Force Mainshaft For Sale
- whats it holding? textralia
- HELP - clicking noise when in gear, goes away when I push clutch in
- Quick stupid question..
- books on rebuilding trans
- Slave Cylinder
- pilot bearing part#?
- cooler question
- Clutch and flywheel install, a little pricey?
- Pros and Cons on "drill Mod"
- New Spec 2+ Vibration - Questions
- NEW Spec 3+
- Clutch Master & Slave Cylinder Pressure Ratings
- Q for those w Mcleod MC and LS7 clutch.
- Wounded My Trans Today
- Doug Nash swap?
- To much shifter movement
- dropping a transmission
- Just verify bleeding clutch for me?
- Advanced Acceleration Question: Gearing
- skip shift
- Kinda of a noob question
- t 56 questions
- clutch master leak
- Noob Questions (T56 Noises)
- aluminum flywheel for 1/4 mile car
- noise when reversing
- Shift Boot Part
- Bellhousing won't come off. WTF??????????????
- Need clutch advice
- Buying new synchros? Should I buy this kit?
- New high performance 6 puck Centerforce Clutch
- s/c T/A in need of clutch
- LS7 Clutch Kits in Stock with Flywheels
- LS7 clutch on order...
- Clutch stuck engaged.. hydraulic prob. plz help.
- Need Advise on New Clutch/Flywheel Setup!
- I need help!
- M6 conversion ?
- Driveshaft yoke compatibility question
- want to learn more about manual drivetrain
- Emergency brake
- Tell me what this sounds like!!
- Notchy shifting after quick runs.
- pilot bearing
- Clutch engages different after making 1/4 pass?
- What Stage is this SPEC Clutch??????
- T56 question
- Does Ram Master cylinder come with new braided line!?
- Tremec TKO 600 Shifter
- Stock Clutch
- New clutch installed, do i have to bleed it now?
- hurst chrome billet plus stick fit pro 5.0 base?
- Mcleod>all others
- notchy shifting
- clutch's engagement, disengagement varies
- Will LS2 clutch fit LS1?
- Top Speed
- Funny Clutch Feel - anyone wanna post a clutch sticky?
- How To Shift Diagram
- problem with reverse
- Transmission Fluid
- tranny mount??? where and what to buy?
- Clutch pedal makes bubbly noise, wtf?
- Wierd Noise from t56 under 2k rpm.
- Hydraulic Slave Cylinder & Release Bearing
- Dunno if clutch is going out
- Grind in 2nd
- Can't shift from 6-5 without going 4-5. What happened?
- Transmission Won't Slide All The Way In
- LS6 Clutch in a LS1 Camaro...?
- Sweet I Love Blown Trannys!
- clutch problems...time to replace?
- Transmission Install ?
- m6 slip yoke ?
- smooth shifting
- Pilot Bearing Install?
- I think I need a differnt clutch
- First Night at the Track With The Textralia
- m6 for c5
- Need Help, Slave fittings not the same.
- Clutch install, now slips?
- which LT1 T56 fluid?
- Need Help!!!!
- Clicking noise when pushing in clutch?
- Help Slipping Clutch
- How many bolts for a clutch?
- Flywheel and flexplate bolts the same?
- Noise?!?!?!?!
- 85 Firebird V6 to V8 Conversion w T5 transmission
- tranny removal problem
- no walk bushing
- New SPEC clutch
- Install time on a new clutch?
- bleeder access hole post
- squeaking clutch pedal return spring?
- What is the Blind puller remover part number from Autozone?
- Pics of a 5k mile Textraila clutch.
- How much power can a Stock T56 handle????
- About to purchase LS7 clutch, question about slave etc
- Lt1 Clutch bleed
- question
- Opinions, advice and suggestions needed!! Please help!!
- M6 to Auto back to M6
- Harsh, Sudden Engagement with Spec 3
- C6 Tranny drain/Fill plug!
- Here's how to bleed the clutch without getting under the car.
- shifter bobs up and down
- Need bolt torque specs
- MAJOR props to RPM Transmissions
- Bad throwout bearing
- Centerforce 11" or 12"
- Noise after new clutch and flywheel install?
- Dropped socket in bellhousing while trying to bleed clutch
- Clutch/ flywheel rattling? Experts please chime in.
- spec 3 problems.....anyone else?
- How many people have shimed their slave?
- LS7/LS2 combo behavior?
- I need different 5th and 6th gear ratios
- Newly Installed LS7 clutch..Questions?
- help with oil cap in back of crank
- CTS-V Clutch Question
- have anyone ever used a Oreilly fenco clutch
- Chatter in a newly installed LS6 clutch?
- Clutch is more grabby when car is cold
- My Clutch!!!!!!!!!!!!!!!!!
- Second clutch and scared it going too
- Anyone disappointed with alum flywheel?
- 03 cobra tranny into an ls1?
- Clunk going into 1st
- How much should the stick move when I give it gas?
- Noise after Textralia install
- Who has most miles on Textrilla???
- A4> M6 swap
- Stick Rattle
- Textralia OZ700SB
- Spec 5/Shimed Slave- Big Problems
- clutch is new but seems to slip? do you have to break it in ?
- Clutch Promlems....
- Shifting problems
- Question for textralia owners
- Noise driving me insane
- Clutch Sqeakin and not enganging at times...
- Flywheel
- LS6 Clutch Power Threshold
- P/N for GM master cylinder rebuild kit...
- New clutch is chattering... questions
- Clutch noice...
- Need help removing my T56!
- Tips on break in?
- Thanks to T-56 Rebuilds
- Just Got LS7 clutch!!
- Clutch Sticking, is it the Clutch or Hydraulics?
- Bleeder Screw
- Gap between TO bearing and clutch
- Clutch chattering making knock sensor go off
- Short Stick Shifter
- clutch
- Where to buy clutch slave to tranny shim ?
- clutch stuck to the floor?
- Morning clutch problems.
- Manual transmission fluid help
- Looking into buying a SPEC STAGE 4?
- Help!! M6 Swap Questions
- Quick question
- Will a T56 bolt up to an 8.1L 496?
- I have a new love.....
- Best Ls1 Clutch?
- Help me identify these parts...
- HELP! snapped driveshaft = T56 mainshaft!!@##$
- How long wait time to get Textralia clutches?
- Spec clutch is wearing out...Remove slave shim to get more life?
- 00 t56 to 95 lt1 HELP!!!
- best shofter for c5 z06?
- A4 to MN6
- Transmission life if 1 gear grinds at WOT...
- Length of Throws
- snapped driveshaft = insane tranny leak?!
- need new clutch which one!
- Need t56 tail housing quick!
- lt1 t56 clutch fork
- Clutch or Rebuild?
- T56 Rebuild, who to get parts from
- Spec 5
- bleeding clutch
- Damn clutch is frustrating me to no end....
- clutch help please!
- Mcleod bell housing disaster
- New tranny, need help with speed sensor
- Does anyone have a stock bell housing 4 sale
- Clutch Bleed Problems....
- Re building a T56
- DO i need a new flywheels with a new Clutch?
- WS6 Store Stick....
- flywheel turned, have questions.
- Need some help with a T/O
- T56 rebuilder in Chicago area
- best shifter??!!
- Moment of Inertia
- Getting best Gas mileage?
- Tips for launching on Street tires?
- weird POP + play in the clutch
- Fluid change interval?
- Liberty's T56
- cobra stick on stock shifter?
- the "Truth" about cags? *parnoia inside*
- Tricks to remove the transmission?
- needing new clutch
- Loud A$$ Shifter!
- Hurst products....
- M6 rebuilt in DFW area
- Best clutch for 408ci+200NOS
- Getting New Clutch
- Help!!
- Your thoughts...
- Spec 3+
- Pressure Plate, Master Cylinder?
- Clutch 4 nos
- Could it be the clutch?
- need help
- shifting high horsepower
- Anyone experienced this before
- Clutch bleeding tips..
- Burning Clutch
- will a Spec Stage 3 out of F-Body work in C5?
- Mcleod F-Body Adjustable Masters In Stock Special
- Squeaking....
- Tsb 02-07-31-001
- hard to get into reverse
- PLEASE help me pick a clutch/FW.
- Centerforce vs. Ram vs. LS7
- Will any t56 work
- Possible master fix w.o a lift/jack?
- smallest shift light?
- WS6Store 6.5 inch short stick installed...
- Help! This is kiiling me!
- skip shift whyyyyyy
- ls7 clutch prices?
- GM T56 Troubleshooting Charts
- Help...Need new clutch
- CENTERFORCE dual friction- Trashed in less than 5-6k miles!! (being resolved :) )
- best short stick for the buck?
- Textralia Flywheel problems
- Ram Adjustable Master..what The Hell?
- Motor swap have questions
