View Full Version : Manual Transmission
- spec 2 or spec 3, how do I tell the difference?
- T56 swap into LS1 Sierra
- spec stage 2 or 3 ?
- Just bought a SPEC Stage 3 and have a ?
- spec2 or spec3 how can I tell?
- explain the drill mod please
- New Tremec TKO
- Tranny Yoke???
- Any difference in MC?
- '98 Vette clutch in '99 T/A?
- Do I need the 01' slave cylinder????
- Tranny mount going out???
- Low hydraulic fluid?
- How do I loosen up free play?
- Flywheel Balanced?
- clutch problem
- Clutch Pedal making a popping sound !!
- Why would it pop out of gear?
- Pro 5.0 + Lou's Short Stick Users Come on in!
- Is my tranny or my Spec 3 broken?
- Limits of stock TQ arm?
- Anyone running an aluminum flywheel?
- Anyone who has installed own clutch?
- First Impressions of My Spec Stage 3i
- Took my t56 apart need help
- '02 F-Body T56 Different from pre-02?
- Need HELP fast!!! PLEASE
- Crap, clutch pedal still rock hard.
- Spec 3 Installed
- Need a pic of pedal assembly
- Why do the drill mod?
- Braided stainless steel master cylinder line(HELP)
- Where ro buy rebuld parts for t-56
- Viper output shaft
- quick help car wont start when clutch is in
- Clutch or syncro's
- Wish me luck
- Pulled My Trans and Centerforce last nite, interesting findings inside
- Question on Lou's short sticks
- About my McLeod clutch & McLeod MC......
- how to beef up T-56?
- Flywheel retention tool
- Shifting Problems...
- Transmission Break-in period
- Line Lock Q.
- Need Help
- Break in for a SPec stage 3
- Is this a clutch or hydraulic issue?
- spec went out
- The sound of performance
- where can I get the front cover for lt1 t56?
- Please post Drill mod
- ESP stage 4 T56 users inside
- In some DEEP trouble
- new clutch on the way, SPEC S4i
- Transmission Blanket - (Scatter Shield)
- 1st gear rpoblems
- Any C5 clutch/tranmission experts in here?
- gear/syncro wear----how to tell?
- Z06 or SPEC 3 clutch??
- grindin 2nd
- spec. stg. 2 or 3?
- Tranny blanket!
- please help car wont go in Reverse
- Question about pro 50 shifter
- 01 Slave cylinder identification
- Getting Legal for LS1Tech Racing Series...Tranny Questions...
- LT1 vs LS1 tranny, end the speculation
- shifter stuck BETWEEN 3rd and 5th???
- Help ID this transmission!!
- differnce between c5 and T/A t56
- clutch slippage
- Something odd happened
- Need a clutch, which one.
- problems
- PLEASE HELP!!! Car wont go in to 1st,3rd,5th
- Spec Stage 3 ceramic vs carbon?
- Tranny Porblem!!
- adjustable master ?'s
- Multiple questions in regards to changing trans fluid in an M6
- how to bleed master cylinder after clutch install??
- Throwout bearing & engine valve rattle
- gettin new clutch and need help!
- Synthetic fluid?????
- How to Tell Bad Slave?? flywheel Q as well..
- Clutch questions for my 90K mile '01... I have no clue about this clutch stuff
- Anyone to rebuild T56 around ATL
- Spec 3 = Bad MF'er
- Pics - Liberty Pro-shifted T56 Parts
- How much clutch dust is normal?
- Spec 3 Kits include what?
- T56 slave cylinder bolts?
- heres my problem, how can i fix it
- Bolts for bellhousing to block?
- T56 transmission popping out of 3rd gear; high pitch noise in 6th
- Line Lock
- T56 will not take 5th, and grinds 6th....whats wrong!?
- Quick Newb Question
- Inside Pics of T-56
- Hydraulic issues now.
- spec stage 3
- What bellhousing is this??
- T56 with wilwood master cylinder
- Clutch engagement and release problems
- Just Installed B&M Ripper...
- 93 M28/M29 SWAP to a M6 94-97?? Possible?
- Broke slave cyl line, How to install new slave cylinder?
- Can you replace the master/slave without dropping the tranny?
- re-use clutch?
- 9 & 10 sec M6 guys,what clutch, flywheel, hydraulics are you running?
- stock flywheel price?
- need diagnosis, occasional buzz/zing noise upshifting to 2nd or 3rd
- Spec III Clutch install!
- Part #'s & Prices for 02 Master/Slave?
- Want to do an auto too T56 swap
- Probs with the SPEC 3????
- Clutch balance?
- What do I need?
- weird smell
- How much does a stock LS1 T-56 weigh?
- Finished Spec Stage 3 install! A little pissed.
- Stock Hurst Vs. Aftermarket Shifters
- T56 whoas
- T56 whoas
- 1993 LT1 T56 swap into auto car
- Cheapest place to buy 01-02 slave cylinder???
- T56 rebuild price?
- i need help guys
- Car losing power on take off
- Losing Hydro pressure
- Another question bout spec stage 3
- Installing SPEC 3 in the morning!
- Question for those runnin the spec stage 3
- Drill mod/done to connector that hooks to master cylinder right
- Quick disconnect fitting on Slave cylinder
- 01-02 slave discontinued??
- Confusion on bleeding clutch.
- Need some help...*please*
- SWAPPING 1994 LT1 M6 into 1999 LS1 M6 Z28
- McLeod?
- Which flywheel for Clutchmasters clutch?
- My first T-56 rebuild is done.
- B&M Ripper Peeps Come IN.....
- What must be done to an LS1 T-56 to work in an LT1?
- Grinding noise.. not clutch
- Another Mcleod Test question (Bugsquawsher..anyone)
- Launching a 2000 Z-28 M-6?
- Nitro Dave's Performance fixed Clutch problem
- does a throwout bearing make noise
- What causes my M6 to whine?
- 6 speed swap?
- What does a throwout bearing look like?
- replacing slave, & part number for 01' slave
- LS1 and T5?
- Which McLeod CenterForce Clutch?
- what is needed to swap a '96 t56 into a ls1?
- Strange M6 problem. Need help
- clutch pedal sticking on cold mornings
- can i resurface my flywheel or do i have to buy a new one?
- Slave is blown...now what?
- Rattling Pro 5.0 w/MBA Knob and Lou's Short Stick.
- Anyone have the SLP short shifter?
- Problems with my T56
- how much is a 99 wrecked LS1 worth
- Output shaft on T56 Getting Sloppy Need Help
- questions before i attempt this
- M6 Tranny Crossmember part #
- Transmission Install Quick Question
- Clutch pedal stuck to floor - need help
- Master or slave problems
- Help....
- Questions about Spec Stage 3 Clutch
- Mcleod Clutch
- Need T-56 Transmission ASAP
- I'm converting to T56 on a 94Z
- Nut size on Mcleod MC for adjusting
- Spec 3 Warranty Question?
- getting mity vac can i bleed this while its on the car
- Spec Stg 3 and stock flywheel,OK????
- Spec 2 Vs Spec 3
- How much did your A4 to M6 conversion cost?
- Replacing the Tremec T56 with the Borg-Warner unit.
- Binding in transmission or rear end?
- Anyone using the Spec Stage 3i yet?
- Questions about spec stage III
- I have to swap my RAM clutch disks!
- help! clutch doesnt completely disengage
- question about poly trans mount?
- T56 from LT1 to an LS1
- question about new master
- 3rd synchro bad ?
- Could it be the shifter linkage?
- ls6 clutch on 99 Camaro SS ?
- Tranny Rebuild Help
- How well do the ten bolts hold w/ new clutch
- Question about what GM Service Manager told me.
- Shifter resistance
- What is the size for stock gear?
- Reverse Lock-out ??
- Need opinions on clutch for 00 ss camaro
- Slave Cylinders ???
- t56 rebuild - good place?
- strange shifting...asap...help
- Third gear slipping
- Um.. I cant spin 2nd ????
- Do the 01/02's have the Z06 clutch or not?
- Carbon Fiber Synchros
- McLoed is shipping bellhousings
- Interesting noise
- The "I" option on Spec clutches.
- Master cylinder part number
- How do I bleed the clutch.
- Leaking Fluid Please help.
- Rear End Whine
- Pro 5.0 shifter
- Pedal engagement question with New Spec 3
- Well I pulled the Slave and that's not it.
- newer slave???
- Holy F'n $hit Little help here...
- Internal or External slave cylinders?
- Car wont go into gear when the engine is on.
- Real clutch problem
- Will Z06 gears work in a Fbody T-56?
- Do you need to change out the Slave C shim with a Spec 3?
- Billet Flywheel
- Spec III LIfe Span??
- Problem with 2nd gear
- Dumb ??? But Need Help!!!
- people with spec stageIII COME IN!!!!!!!
- BIG PROBS with reverse
- Need Help!!!
- ANyone in Northeast Ohio Work on T56?!
- Flywheel Resurfacing in Houston
- WheelHoppin
- Can a T56 handle this?
- Won't go into 6th!!
- Anyone barking 4th gear??
- Is there a way to test slave without pulling transmission?
- Clutch Time
- Plastic ring for steel line to slave disconnect...
- Whine in M6 after getting on it
- Does anybody have a pic of a T-56
- Might be a clutch issue..
- Clutch wont disengage, please help
- Mcleod dual disc pressure plate bolt torque
- Help on picking clutch setup for my car?
- clutch
- Who can rebuild my T-56
- First impression of Mcleod twin disk
- clutch pedal vibrates
