PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 [134] 135 136 137
  1. pro 5.0 and warranty work??
  2. Torque Specs on a clutch install?
  3. Chipped Clutch Disk
  4. Cheapest place to get RAM and cartek clutch
  5. Mcleod Rev-Loc II :(
  6. please help with clutch hydrolics removal
  7. What have I broke? Clutch or Trany?
  8. New Spec S3 clutch from TR slipping.
  9. M6 oil change ???
  10. Where to buy parts for the T-56
  11. 910 vs 980 RAM clutch
  12. How many think some folks can't drive an M6?
  13. bellhousing and flywheel bolt patterns
  14. clutch for 600 hp?
  15. How much fluid does an M6 hold?
  16. Car bogged down with lightened flywheel
  17. Clutch question
  18. Cartek clutch vs RAM VDS clutch
  19. Flywheel
  20. dual centerforce clutch prob's
  21. clutch?
  22. clutch question
  23. Website for LS6 clutch...please
  24. Clutch went out completely!
  25. ABS inop and TCS off after clutch install.
  26. Rebuild on T-56
  27. Alumnium Flywheel
  28. Is There a High Temperature Clutch Fluid?
  29. How do you Bled the clutch after install?
  30. clutch help
  31. Fed Up with the Mcleod Master Cylinder
  32. whats the best rear end gears with a t-56
  33. clutch guru's help...
  34. Mcleod Clutch
  35. MCLEOD ADJ MASTER REBUILD
  36. McLeod Adjustable Master Cylinder Question!!
  37. Clutch And Flywheel Replacement Questions???
  38. How would my 10 bolt hold up with 4:10 gears and my M6??
  39. anyone have clutch recall #
  40. Clutch Spring Part Number??
  41. Torque Management w/ M6?
  42. New pressure plate for my clutch
  43. anyone with Mcleod
  44. best street clutch!!!!!!!!!
  45. Clutch pedal not consistant!
  46. SPEC Clutch Install
  47. HELP! Pro 5.0 short stick coming loose!
  48. Getting a new clutch (need your help)
  49. lt t56 > ls t56
  50. Help with M6 pedal removal
  51. Strange thing happened.. My shaft from the clutch pedal to the cyl broke! HELP please
  52. Clutch sticks down after racing....the damn shaft broke.. Please read & help
  53. McLeod Adjustable Master Cylinder help asap!!!!!
  54. Why replace the master/slave when using and aftermarket clutch?
  55. Do I need Shims if I resurface my flywheel?
  56. Any feedback yet with the Hays clutch?
  57. Clutch hydraulic issue (McLeod M/C)..kinda long
  58. Clutch going...need help finding cheap Spec S2
  59. high temp clutch fluid.. help
  60. Can an LS6 clutch disc be used with a RAM 402 pressure plate?
  61. Need clutch and master
  62. whats wrong w/ my m6
  63. clutch system question
  64. whats the best clutch for street and strip
  65. T56 problems
  66. 01' and 02' M6 f body owners with trani problems inside
  67. Have to shim a SPEC clutch?
  68. RAM Clutch Guys please tell all......
  69. Why my clutch got stuck
  70. What with the Grinding Noise?
  71. clutch advice
  72. 03 Clutch assembly in our car to eliminate the Hydraulic JUNK!!!
  73. What clutch are you using???
  74. Mcleod clutch problem
  75. On my 4th T56, help
  76. MityVac to bleed Clutch hydraulics.
  77. Need help!!! Clutch problem??
  78. McCleod clutch chatter?
  79. T56 rebuild and RAM clutch upgrade.... so far so good
  80. CAR-SPEC clutch in...all grins and it bites HARD!!!
  81. Clutch Problem?
  82. t56 rebuild
  83. Is the RAM Clutch Worth the $ - Look!!!
  84. Guys who have converted-------->M6 to Automatic
  85. RAM or McLeod clutch???????
  86. pro 5.0 shifter, or B&M ripper?
  87. SLP lightweight billet steel flywheel?
  88. Viper T56 guts for ME????
  89. Clutch recommendation for 400rwhp C5.
  90. Broken Clutch Spring
  91. Can anyone tell me the weight of a stock flywheel on an '02 LS1
  92. hurst vs factory m6?
  93. where is that t56 rebuild maual?
  94. LWbillet flywheel and a good clutch for 02Z06 needed.
  95. HUGE problems after clutch install.........long
  96. holy sh!t ... exploding clutch!!
  97. Is my fairly new 02 Z06 clutch not holding up?
  98. Ram 6130 or 910 disc with stock flywheel?
  99. need the mcleod master with a spec s4?
  100. Ok... I think my clutch is toast ... time for a new one...
  101. Is it normal for clutch fluid to turn black?
  102. T56 and a T56 Z06 gearing?
  103. Help me pick a clutch.
  104. Could my clutch be messing up???
  105. WHAT CLUTCH SHOULD I USE??????
  106. just got off the phone with Cartek....
  107. clutch banging on 1-2 shift?
  108. Pro's/Con's of using an Aluminum Flywheel???
  109. Heat is F'n up my clutch hydraulics
  110. t56 Hydraulic clutch problems
  111. Single clutch parts questions? Please help ASAP!!!
  112. Clutch going bad?
  113. McLeod SDK and MC Questions (LONG)
  114. RAM Clutch
  115. Stock clutch sticking on hard launches WTF?
  116. Star Spec IV clutch questions
  117. Clutch Return Spring Broke - Part Number??
  118. GM voided my warranty over T-56 problem & bills my dealer!
  119. 2001 Clutch Slave - pn 12565145 on www.gmpartsdirect.com $64.80
  120. How Do You Fix a Sticking Clutch?
  121. HOLY MOTHER OF GOD! (Mcleod Rev Lok 2)
  122. RAM Clutch Users! ... inside please!
  123. B +M Ripper, Pro 5.0, Hurst ?
  124. Clutch *CLINK*??
  125. Help - trying to get T56 back in
  126. M6 guru's, is double-clutching required with big(bigger) downshifts?
  127. Cartek disk replacement?
  128. Need help from the clutch pro's....
  129. Who beats the snot out of their RAM 402/6130 clutch combo?
  130. Ram Clutch Notes - Manicure Mod
  131. T56 length
  132. T-56 Problems?.....Look inside.
  133. curious about t-56
  134. Home page for SPEC/Star clutches
  135. T56's are junk, please help.................
  136. HD Roller Clutch Pilot Bearing
  137. typical rate for a clutch install?
  138. Clutch Problems?!?!?
  139. HELP! Neutral grinding/rattle sound from tranny.
  140. Anyone ever heard of having to grind the center pin on a 2002?
  141. Z06 Clutch your impressions please
  142. Thinking about buying Pro 5.0, a few questions.
  143. Clutch making weird sound
  144. I NEED HELP TO SOLVE A HELP!! SHIFTING PROBLEM ON 2000 LS1 T56 SPEED
  145. What is needed for a clutch install? (all parts req)
  146. Clutch killing power output?
  147. Part # for new clutch slave?
  148. Clutch info....???
  149. best way to break in my new clutch????
  150. Truck Shifters??
  151. clutch problem's please help
  152. Need help with clutch PLEASE
  153. What gear comes in a stock 2002 Z/28 M6?
  154. HEEEELP!!! Damn clutch!!
  155. Heard a pop in my clutch pedal and now...
  156. Is my clutch going out? (a little long)
  157. McLeod Rev Lok II is in :-)
  158. Stripped nut on Adjustable master-clutch hell continues for me
  159. who sells built t-56's???
  160. Have a slight vibration after clutch swap...
  161. clutch ?
  162. RAM billet flywheel part number?
  163. Part # for M6 console from GM Parts Direct?
  164. RAM Clutch users.....OR anyone with aftermarket Clutch
  165. T56 need help
  166. What is wrong with my M6?
  167. help me choose a new clutch...
  168. is it true that all the 6spd 02 Trans Ams and Camaros come with a Z06 clutch?
  169. slp clutch and flywheel package
  170. How to Adjust Mcleod Master Cylider?
  171. I bought a slightly used ST w/ Al. Flywheel for $350 but.................
  172. Aluminum flywheels - what you need to know
  173. The best clutch ?
  174. t56 wierd problems
  175. Weight on Alum. Flywheels? Which brand? How much?
  176. T56 Acting Up In Second
  177. clutch is fix
  178. Clutch burning on the dyno, could this cause a loss of power??
  179. *****4th Gear Grinding*******
  180. new clutch idea give me you're opinions..
  181. How to beef up a T56???
  182. Just bought z06 clutch and the disk looks damaged...
  183. Everyone with T-56 Problems
  184. Posi Locck Up Clutch
  185. Need help with Clutch install.
  186. Clutch drill mod question
  187. T56 rebuilers in Dallas??
  188. Cartek Adjustable master
  189. Clutch making weird noise. please help.
  190. Adj. clutch master mod?
  191. Frustration with Z06 clutch
  192. Replacing 2000 M6 5th & 6th with 1993 5th & 6th Can it be done?
  193. Aluminum Flywheels
  194. Something very wrong after new clutch install...
  195. Can you use a more aggressive disc with the stock clutch?
  196. How do you guys bleed the LS1 clutch??????
  197. Clutch Master Cylinder
  198. clutch fluid
  199. How are the LS1 flywheels balanced?
  200. Clutch vibration and flywheels
  201. Clutch Anger Management
  202. Torque specs for McLeod Clutch install
  203. T56 won't go into 4th without really pulling back on the shifter
  204. PRO 5.0 NOISE?
  205. Is my clutch slipping??
  206. Clutch loosing its bite?
  207. Billet steel flywheel?
  208. t56... where to get
  209. No clutch pressure after ZO6 install
  210. Pictures of my Flywheel dammage
  211. I'm about ready to tackle my T56 rebuild, and have a question....
  212. I need specs on stock T56 gears
  213. C5 T56 hard to shift. Low oil level possible culprit?
  214. MAXIMUM HP FOR T56&10BOLT??
  215. looking for a good place to get T56 parts
  216. What clutch is the best?
  217. MAJOR Problems with CARTEK!!!!!!
  218. T-56 Rebuilds...What did you pay
  219. Broke the input shaft on my T56........HELP!!!
  220. Clutch Install and Tranny fluid replacement?
  221. **Please Help, Quick Q.- Warranty Tranny work- Take out Pro 5.0??
  222. need clutch any suggestions??
  223. Need high performance clutch mcloed centerforce or star??
  224. clutch noise, should i be worried?
  225. Clutch setup help
  226. any way to beef up a m6 ? other than rear end?
  227. star clutch help: which way do pads face
  228. play in t56 input shaft- is it normal??
  229. Need some Clutch help BAD!
  230. extra hole in the flywheel orientated with the extra hole in the crank?
  231. new power will stock clutch hold????
  232. Centerforce Clutch
  233. Throw out bearing issues
  234. T56 problems - stuck in gear with two different rebuilt trannies!!
  235. Complete T56 for sale.......
  236. ZO6 clutch???
  237. Maximum speed in each gear with T-56?
  238. how many times can you resurface a flywheel?
  239. which clutch DOES NOT CHATTER???
  240. Clutch and adjustable master problems.
  241. Clutch/Tranny/Brake/Rear Fluid question?
  242. Synthetic clutch fluid question
  243. Paging McLeod Adjustable master owners...
  244. M6 guys, do you always rev-match on a WOT downshift, and is it necessary?
  245. Ripper shifter coming, need directions, suggestions.
  246. Those who had a RAM 6130 "FUSE" to your flywheel! How is the 910 disc working?
  247. T56 Tranny Question?
  248. Cartek clutch + Mcleod master = awesome!!
  249. Fidanza Aluminium flywheels
  250. M6 experts in here,please
