PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 [131] 132 133 134 135 136 137
  1. OH NO MY CLUTCH!!!!!!
  2. My clutch smells?? Does that mean...
  3. NEED ANYTHING ELSE FOR A STAGE 3 CLUTCH
  4. Is my T-56 done for?
  5. Long bleed screw for T56
  6. BENT FORKS OR CLUTCH PROBLEM..GETTING STUCK IN GEARS
  7. who to buy spec stage III from
  8. I have a late 2000 car w/ 241 heads. Do I save the 01
  9. Mcleod Adjustable Master
  10. NEED OPINION ON CLUTCH PLEASE
  11. Need a clutch recomendation
  12. where can i get a shim for the slave cylinder
  13. What fluid do you guys use in your T56?
  14. 1LE Mount on 2002
  15. Sequential gearbox
  16. Figured out what was wrong...now what do YOU think...??
  17. Trouble getting into gear...
  18. B & M RIPPER SHIFTER
  19. lookinf for possible a4 t56 trade
  20. Need some help with Ram Clutch
  21. Has anyone had to rebuild their Mcloed adjustable master?
  22. Where can I get a LSS?
  23. Optimal shift points with this given setup
  24. Manual transmission removal?
  25. Drill Mod without removing the Master Cylinder????
  26. What clutch for Superchager (500rwhp)
  27. weird problem going into 6th
  28. Spec Stage III with Stock Master
  29. I need your knowledge (kinda long)
  30. Need Help Quick!
  31. Opinion on Spec Stage III clutch????
  32. Need clutch help!!!!
  33. Please HELP!!! My T56 is frozen>>>
  34. A4 to M6 swap?????
  35. Question about adjusting adj. clutch master cylinder
  36. p/n for 01 master, slave
  37. Still having Clutch problems
  38. What happened to the Pro-Shifted T56 guy?
  39. PLEASE HELP FAST...My friend's clutch is stuck down.
  40. How to remover your pilot bearing...
  41. Anyone running SPEC Stage 5
  42. shifting above 6600rpm?
  43. PRO 5.0 HELP>
  44. HELP! CLUNK SOUND
  45. Just got a LSS couple questions ...
  46. mclead master or 01 master
  47. what clutch for a 346 SR with a lot of juice
  48. t5 and t56 short stick
  49. What is a Reasonable Price to Install a Clutch?
  50. 2000SS Drill mod only or must I change the hydrolic master?
  51. Why is it shifting hard?
  52. Pro 5.0 Service!
  53. Easiest way to install the Pilot Bearing
  54. What's up with my 3rd gear?
  55. BEST CLUTCH!!
  56. WTF is going on with my gf's T56??? Heelp!
  57. please help........anyone with M6 knowledge
  58. What type of jack can i use for clutch install?
  59. This clutch in good shape?
  60. What happened to my friends T56?
  61. Part # for M6 shift boot assembly?
  62. How much power can a stock T-56 hold?
  63. Weight diff between 4L60E and T-56?
  64. Tips for re-installing the tranny?
  65. Is your disc, pressure plate and flywheel SFI approved????
  66. Anyone rebuilt their RAM 402 PP?
  67. Driveshaft, auto A4 same length as a M6?
  68. Will a Ram clutch disc work with a McCloed flwheel/plate?
  69. Replace Clutch Slave Cylinder
  70. URGENT, Need Ram tq specs for pressure plate to ring?
  71. Shift Knob
  72. T56 ?
  73. Spec Stage III Kevlar
  74. Clutch going soon, have a few questions
  75. Reverse Bleeding, Someone please explain step by step..
  76. McLeod Adj Master
  77. Clutch pedal is feeling different. Clutch going out?
  78. B&M Ripper Hits console in reverse
  79. Blew up my clutch, bellhousing and tranny tonight. *PICS*
  80. Clutch bad?
  81. Best drive shaft??
  82. Stronger gears now available for T-56
  83. Corvette Tranny
  84. JSS, LSS, or Qwik Stick
  85. zo6 clutch
  86. Pilot Bearing info needed
  87. Need install instructions for adj. master cyl.
  88. Clutch Pedal return Spring Broke Again
  89. To Short Stick or Not
  90. Rebuild kit for T56???
  91. Can't bleed clutch!
  92. F--ing quick connect fitting!!!
  93. How do you make sure the stops are adjusted correctly
  94. car shakes hard while sitting still with clutch out!
  95. Reverse lock out solinoid
  96. What Causes the Clutch Pedal to Stick to the Floor?
  97. Help - I think my 4th clutch is shot!
  98. How did you re-fill your T56 trannie fluid?
  99. Did drill mod and screwed something up big time!
  100. Factory Warranty Voided ?
  101. clutch pedal feels real bad, need help
  102. Problem With Reverse
  103. Factor Hurst/Lou's short stick question...
  104. best clutch and flywheel?
  105. Second gear issues Help inside ASAP
  106. How hot???
  107. Popping sound when pressing clutch???
  108. where does you clutche start egaging?
  109. Help me seek some truth...
  110. Clutch master cylinder install hangup!?!
  111. Need help! What happened?
  112. when should I change my tranny fluid?
  113. stuck in 4th gear
  114. Best Driveshaft loop with LT's?
  115. home made master?
  116. Clutch install tips please!
  117. What's this sound?
  118. Car Constantly Pops Out Of Reverse!
  119. How Hot is too Hot for an M6
  120. mcleod M/C acting funny.
  121. How long will stock clutch last?
  122. tranny mount
  123. Tell me why my RAM clutch hates me.
  124. Help diagnose clutch
  125. Where to buy 5/6 gear puller?
  126. I really want to run an Alluminum Flywheel but?
  127. HELP me diagnose this simple tranny prob
  128. SPEC Stage 2 review inside
  129. WTF!! manual gurus inside please!!!
  130. Pilot Bearing
  131. Is there any upgrades that you can make to a T56?
  132. what gear ratio?
  133. JSS installed.....wow
  134. jerky clutch?
  135. Fixing the M6.......for good!
  136. Clutch install problems
  137. Tail shaft seal
  138. Part Number for little white cup on M6??
  139. The Gear Box - T56 Parts
  140. Does this mean its time for a new clutch?
  141. Where to get a rebuild book for t56
  142. Opinions on clutches by experience only
  143. Can stock flywheel be used with Spec stage 3 clutch?
  144. Shifter Install Question
  145. lightweight flywheel vs stock??????
  146. Special tool to rebuild t56
  147. Chatter!?
  148. ram 910 clutch is the way to go.
  149. Hurst Short Throw???
  150. Drill mod necessary for 02' master and Centerforce DF?
  151. Cartek clutch help fast, please
  152. ACK!!!...wtf is wrong w/ my car!?!?!
  153. Where can I find the master drill mod and does it work?
  154. transmission gurus
  155. *HELP* Ram Clutch Install
  156. 11.30 e.t. and faster, please come in
  157. Still can not bleed my McLeod Adjustable master cylinder
  158. Do I have to bleed the slave ?
  159. upgrade/rebuild T56?
  160. New SPEC clutch installed w/ McCleod master
  161. Shifter Knobs - Questions
  162. Help bleeding clutch
  163. Slave???
  164. To get a new flywheel or not...
  165. How can I tell if a pressure plate is going out?
  166. Pro 5.0 installed!!
  167. Which Clutch for Stock Pedal Pressure?
  168. DIY T-56 Rebuid Questions, etc inside?
  169. Bleeding (ahhhhhhhh!)
  170. M6 rebuilt - now which fluid???
  171. Anyone converted from A4 to M6?
  172. How long will it take me to install a new Spec stg 3
  173. Drill Mod / Adjustable Master Cylinder
  174. Help, clutch problem
  175. worthless T56......
  176. Where to buy B&M Ripper Shifter???
  177. Where to buy Bulletproof T56?
  178. What aftermarket clutch is best for stock w/ boltons?
  179. Clutch Fluid keeps turing Black
  180. T-56 REBUILD INFO
  181. How do you bleed clutch
  182. Power Braking
  183. Breakin Period on Clutch?
  184. slight grind in 2nd
  185. new tranny and clutch grinding!?!?
  186. How to install aluminum fly wheel and spec stage 3 clutch
  187. Harlen Shift Lights
  188. Paging Joe Kizzire and anyone else that can help!!
  189. will the clutch hold
  190. Wiring diagram ??
  191. T-56 TECHNICAL BULLETIN by FreakZ!
  192. Clutch started smoking!!! PLEASE HELP!!!
  193. Transmission install?!
  194. Stuck In 4th...
  195. FINALLY....clutch is bled
  196. Would I benefit from a transmission cooler?
  197. WHAT ARE THE SIGNS OF A BAD PILOT BEARING
  198. What is electrical connection on pass side of T56?
  199. Where did you go to get your clutch installed?
  200. any body used clutch masters???
  201. Broke clutch pics
  202. My 6th gear only has 2 clicks to engage instead of 3
  203. How much fluid is needed to bench bleed?
  204. Bad Slave???
  205. T56 shifter feels really loose!
  206. Help...clutch won't bleed
  207. broke a Ram clutch on the dyno.....
  208. Guys with 4.10's in here!
  209. Grinding 4th gear, why?
  210. 97 z28
  211. Pro 5.0 w/ LSS question
  212. NEED TQ #'S FOR RAM CLUTCH!!!!!! please help, need tonight!!
  213. how is traction with 4.10's on the streets??
  214. Centerforce clutches
  215. Check this out!
  216. What the F----!!!
  217. Clutch Problems
  218. WHERE TO GET SHIFT LIGHT?
  219. Error DTC P0782 2-3 Shift Malfunction?
  220. real quick question...
  221. Anyone have a write-up on how to bleed the clutch?
  222. SPEC stage 5 review...
  223. What transmission mount?
  224. Coolant leaking on flywheel/clutch?? (long, lots-o-pics)
  225. c5 guys with cartek clutch
  226. Ram 910 problems
  227. Question about clutch pedal return spring
  228. Spec Stage III ????
  229. Did your tranny grind when your clutch slipped
  230. Need help with T-56
  231. clutch pedal has no pressure
  232. what to get ? mcloed street twin or spec stage 5?
  233. what is the best tranny fluid for the t-56?
  234. Another T-56 Bites The Dust!
  235. RAM Clutch excellent customer service
  236. Anybody find a SFI approved Bellhousing yet?
  237. How do I remove my T56 trans in my 97 camaro
  238. How long to receive Harlan light?
  239. Help Redlne Synthetic
  240. Mcloed twin disk is here!!!
  241. Where to get T56 rebuilt?
  242. trans fluid on t-56
  243. bye bye clutch
  244. Tranny wiring problems
  245. does the 120 dollar service manual have info on........
  246. Need help on steel flywheel
  247. silly question, clutch install HELP!!!!
  248. Anyone tried the SPEC stage 5?
  249. cartek clutch questions
  250. where to get trany rebuilt in Dallas area
