View Full Version : Manual Transmission
- Standard LS1 t56 trans with CTS-V clutch?
- SixSpeedinc
- t56 question
- a4 to m6 conversion questions
- cant get into gear???
- Please help!! Spec stage 3 ?
- Cartek clutch VS Textralia oz700
- Transmission Drain Plug Thread Size?
- 2008 Tremec TR6060 (MM6/MZ6)
- Spec Stage 1
- Are stock LT1 flywheels nodular or cast iron?
- LS7 clutch
- Where to find rubber mount?
- Gotta few question...
- Heat tape fell off
- really soft pedal with spec 5....
- Emergency Textralia CLutch ? (Car is apart right now)
- Simple LS7 Clutch Question
- Shifter issue.
- Power Purge
- 6spd swap 4L60E to T56
- Anybody rockin a SixSpeedInc tranny?
- RPS clutch
- Winding Noise when Cluth Depressed
- Master Cylinder easy question, I hope
- spec stage 3 chattering
- Tried search couldnt find anything. Crooked shift knob
- Help please, Master or Slave?
- tranny help me plz bout to take the desert eagle to this POS
- Anyone run a LuK progold setup w/ aluminum flywheel
- 2000 or 2001 Slave?
- 98 WS6 T-56 to gen 1 help
- Car shakes after clutch install
- which sfi bellhousing to buy
- Ls2/M12 Clutch Quesion
- grinding noise from T-56
- slave cyl
- T5 Transmission Removal
- Clutch Choices!!!????
- Is my flywheel ok?
- Anybody have before/after #'s from swapping put the stock clutch?
- Blots to transmission to bellhousing / bellhousing to block
- what parts do i need?
- T56 question on fluid
- Which clutch?
- Slippy slippy clutch
- drivetrain protection? HELP!!
- What do u think about Centerforce Dual Friction
- Replaced Slave and Master cyl Still Losing FLuid
- any info on Mclead RST and RSTX twin disk clutches
- x-grip vs. z-grip
- Mixing Clutch Hydraulics Good Or Bad Idea
- What clutch for lt1?
- Clutchmasters - dowels\balancing etc
- Spec 2 or 3?
- dimensions of C5 transaxle
- Master cylinder u-bolt?!?
- What size are the bolts in the T56 transmisson mount?
- Changing from automatic to manual tranny Good idea?
- Confused..
- Need new clutch for n20
- bird of prey?
- Slip or Dump, which one is it?
- replacement clutch disc
- Textralia twins? Who has them?
- can't bleed system
- question on drill mod
- Sticky First Gear
- Burn't Clutch MMMM
- 2 different Hurst Billet Plus Shifters
- tranny problem
- Drag Racing the M6
- Do my longtubes have to be loosened to remove trans for clutch swap?
- Shifter threads?
- LS1 Clutch power?
- What fluid should I use in my T-56 as per Tremec techincal support
- lt1 t56/ ls series block
- reverse pops out of gear
- Pressure problems in the clutch?
- Is this leak from my slave? *Pics*
- damn clutch issue
- Leaking Slave Cylinder
- Where to buy performance rebuild kit at?
- has the drill mod worked for anyone?
- LS7 set up work on a LS2 based CTS-V????
- Flywheel question
- Need a better trany
- New Clutch Problems
- t56 rebuild question
- clutch pedal assembly
- Is the fly wheel the same on the LS1 compared to the LS7 clutch?
- Fix for those that have the Mcleod Master Cylinder
- Spec Clutch issues...
- Where is the cheapest place to get a slave cylinder?
- What clutch can be slipped out of the hole at the track?
- Hard clutch pedal
- LS2 GTO Clutch
- A4 To M6 6 Swap Parts
- Torque arm mount bolts
- T-56 install ?
- Kevlar Clutch Question?
- T56 parts ??
- Another clutch question
- ls1 pilot bearing help
- t56 lost every gear but 4th last night
- which mustang sticks are you using?
- food for thought
- Sdpc
- Wont go into 1st & 2ed after skip shift elim.
- Ok who is putting down over 700 rwtq on their tex twin?
- T/O Bearing is wearing on the pressure plate fingers? **PICS**
- additives in oils?
- OZ700 X Grip- Opinions???
- Why is it Hard to shift on Hard Acceleration?
- which one? pilot bearing or pilot bushing??
- What kind of shifter is this??? (lost of pics)
- Six Speeds info for friday and saturday
- Pedal on the floor
- Final questions about master/slave before I take it in
- Metal swishing noise?
- Durability of a T-56??
- driveshaft length
- So pissed gotta put money into tranny 3rd gear popping out!!!
- shifter pics
- Textralia Guys, X grip or Z grip which and why??
- Prepping slave and pilot bearing.
- need dimensions PLEASE
- dont know what happened!
- Clutch Problem just cant put my foot on!!!
- people that have owned multiple shifters.
- clutch hyd line needed
- Clutch grabs when I rev
- What makes a car do this?
- Bent Rod In Master Cyl
- Anyone seen any good clutch/hydraulics packages?
- Can i use a Gto master and clutch line with a f-body slave?
- The best tool EVARRRRR!!!1!one!!eleven!!
- Ram clutch?
- Hard to get into reverse
- Need a Master cylinder with atleast a 7/8" bore
- Marathon of part replacement started...
- t-56 clutch size 11',12' witch on ????????
- Anyone running a centerforce DFX?
- clutch help
- please help. master cylinder ?
- ???short throw???
- Slave cylinder differences
- 6 speed conversion thread -In Realtime-
- About slave Cylinder and Throwout Bearing
- How much HP/TQ can the LS6 flywheel handle?
- Shakey shifter when going into gear...
- Leave In Gear? Spec 5
- P/N For a specific o ring?
- LS7 Clutch installed...goodbye sticky pedal
- wow
- what happened to t56rebuilds.com?
- Little vibration with LS7 setup normal?
- LS7 clutch on LS1 Z28 compatible?
- Viper input shaft mod?Cobra input shaft mod?
- T56....How much power capacity?.....
- Anything else to look at?...
- 93-97 T56 vs 98-02 T56's Difference?
- drill mod quick question... (and yes i hve read the stickeys)
- what size thread on hurst shifter?
- High Performance Transmissions (Houston, TX)
- How do you guys keep the clutch fluid clean?
- Noise when letting clutch out in reverse and 1st
- vent tube on T56
- Kinda disapointed
- Question about 5-6 grinding
- Cartek clutches???
- What clutch to get??
- Help! My Hurst Billet is noisy as hell
- Shim Q w/Spec
- Clutch Install help needed asap!!
- Maybe the Craziest T56 Application Yet
- Best place to get Mcleod twin disk?
- Project V6 T56 Conversion is DONE!
- MN 12 700-800 hp build
- Shifter Wines
- Fidanza Twin Disc Clutch
- Worth it to get an aftermarket shifter?
- Exhaust Mount for t56
- RPM Tranny
- Good Parts Dealer?
- Wiring question.
- Will Centerforce Dual Friction clutch hold 480-500flb torque??
- need t-56 for my camaro... 600 hp 600 tq can i keep the six speed?
- Switching from a4 to m6 few questions..
- Squeaky clutch?
- Spec 5 street, search down
- mikronited gears
- Tranny questions
- textrailia oz700 question
- Centerforce 12” Dual Friction clutch
- Jumping out of fourth
- New slave/master question..
- Clutch tool in DFW
- whats popping!!!???
- Which McLeod Disc is better for street?
- help on spec clutch not going into reverse
- Hydralic problems
- output shaft seal
- Damage possible for t-56?
- Anyone use Energy Suspension trany mount?
- Need Ideas clutch won't work
- Shifting troubles... Slave Cylinder? HELP
- eXEDY sTAGE 3 aNY gOOD??
- air ratchet on flywheel bolts?
- LT1 Scatter shield question
- Lightened flywheel
- Clutch Rattle - Dealer wants $1472.
- Need a 1000rwhp T-56
- trans or clutch causing the issue?
- where to buy a new t56?
- Spec Stage 3
- 400-500hp, need new tranny
- McLeod SFI Bellhousing
- Need advice on clutch
- t56 stick
- Which Lous Short Stick will fit the B&M Ripper
- Anyone sell just the clutch disc for Textralia Exo?
- I'm lost, need help with quick disconnect on tranny.
- what is the problem with my T56 ? B&M shifter ?
- T56 Pros I need some help I screwed up
- For those who have done an auto to manual swap come in.
- Clutch alignment tool needed.
- problems mounting viper t56 behind ls1
- First Impressions of Textralia OZ700 Z-Grip
- Synergyn substitute???
- Where to find this Knob?..
- Question on a Tex. clutch HELP!
- Anyone have a completeshift boot???
- Clutch Fluid
- I'm replacing the clutch...should I replace the master too?
- 6 SP ?? How many
- Yea I think its broken
- Shifter Boot Ring
- Stock clutch Q
- What Clutch & Flywheel to get
- do you have a noisy shifter?
- trans mount
- best trans fluid for a '96 lt1 style T-56
- LS1 T56 quick connect fitting
- Trans builders.... have question
- McCloud RST Street Twin
- Clutch Issues(I think)
- bought a new slave,done know if its the right one...help!
- Clutch Went
- clutch grinding on takeoff
