PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 [124] 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Spec 3i vs. Spec 5
  2. Drill mod and nitrous?
  3. Anybody have experience with a Spec Stg. V?
  4. Average lifespan of a Spec 3?
  5. I think my stock clutch is starting to slip but... I only have 8,500 miles > wtf?
  6. Clutch Question
  7. What did I blow up?
  8. Who makes a good tranny mount for the t56?
  9. t-56 question
  10. Any Drag racers using the Exedy Dual Clutch??
  11. Ok to start car with very low tranny fluid?
  12. Gear Whinning in Tranny T56
  13. shifter change
  14. Please help...clutch pedal issue...
  15. Faster et's with new clutch/flywheel
  16. What RPM to launch at with McLeod Twin Disc
  17. Heeeeeeelppppppp
  18. clutch pedal travel
  19. spec stage 3 question
  20. What would it take
  21. Jesus christ look at my flywheel
  22. Tranny Fluid
  23. if you have done the 6spd conv step in***
  24. Big clunk when shifting into second?
  25. magnet??
  26. RAM clutch recommendation for my Hawk
  27. Thickness of stock flywheel
  28. RAM Fitment Issues
  29. Question about a conversion - tranny specific
  30. Friction plate ques?
  31. Posi Traction
  32. Grinding feeling when I downshift
  33. proper break in for luk clutch
  34. What's the deal with 3rd gear?
  35. 4.10 gears...should I go lower?
  36. T56 Moving under acceleration?
  37. Swap is finally complete.
  38. 6th got stuck
  39. Steel shift forks???
  40. Spec Alignment
  41. Adjsuting stops in Hurst Billet Plus
  42. which clutch?
  43. Pressure problem
  44. spec stage 3
  45. clutch chatter/vibration
  46. Clutch Question
  47. g force triple cone sycros
  48. left car for tint and now loose clutch pedal!
  49. Resurfacing Flywheel,Plz Come In =)
  50. is it neccessary to update a 00 slave to a 01 slave?
  51. Racing a Manual Trans
  52. whats about to break?
  53. good cluch
  54. I'm going nuts with clutch problems
  55. what fuild to put in tranny?
  56. trans install ????
  57. Fed up with Hydraulic clutches. Anyone have any unusual leak experience?
  58. Tranny acting funny gimme some input please
  59. Clutch Questoins Please Help.
  60. Application questions
  61. Clutch braided line
  62. After 1,200mi My Ram 910 Clutch Is Shot,what The Hell?
  63. pilot bearing IS NOT MOVING!!!!
  64. question about trans swap
  65. How much did you pay for your 6speed swap?
  66. How to connect tranny to engine, and ram install?
  67. Resurfacing Stock Flywheel
  68. Will Clutch Bleed Help Pedal Return in Extreme Hot Conditions?
  69. clutch pedal assembly?
  70. Who Has The Best Deal On A Stage 5 Spec Clutch....
  71. McLeod Adj. Master Solves Clutch Problem
  72. Perfect clutch line disconnect tool
  73. New clutch question
  74. Place to get MN12 gears for T56??
  75. Whats The Best Upgrade For T-56?
  76. Will my stock clutch be ok?
  77. How many are running McLeod steel bellhousings?
  78. question about the drill mod
  79. McCleod Adjustable Master Cyl. Instructions needed.
  80. Just bought Spec Stage II, worried..should of bought Stage 3I?
  81. Need help quickly if possible. part # for NEW revised c5 slave cylinder
  82. Fluid change question!!!
  83. Any Luck with Centerforce dual friction?
  84. What do I need?
  85. Luk Clutch kit.
  86. Is my tranny dead!?!?!
  87. HELP!!! I think I killed my transmission
  88. Please Help, Cant find Problem!
  89. After Three transmissions and 2 PRO 5.0's..............
  90. tailshaft housing sealant?
  91. SPEC Stg 3 installed!
  92. Did I mess anything up?
  93. Review of New Mods: Moser 12, Spec II, Pro 5.0, and Lou's short stick
  94. Gas Mileage
  95. Spec 3i kicks assssssssssss
  96. rattling shifter
  97. Clutch issues after cam swap.
  98. Ls1/ls6 Camaro/corvette Mcleod Dual Disc W/billet Flywheel!!!!!!!!!
  99. HELP Clutch pressure question...
  100. Whats wrong with my clutch?
  101. LT1 T56 on a Big Block?
  102. Reverse Gear Grinding
  103. stock clutch -- whats my problem?
  104. Install Help!!!
  105. will a lighter flywheel help/hurt clutch chatter?
  106. throwout bearing can cause huge noise?
  107. Metal poping noise around clutch pedal
  108. Where's the bleeder and why do I have to bleed my clutch hydraulics?
  109. T56 Conversion
  110. Z06 clutch problem solved. A little long
  111. 3rd and 4th gear is grinding and clutch peddle got real light(help)
  112. any one have a writeup on removing a trans
  113. 4L60E to T56
  114. big thanx
  115. Bent shift fork?
  116. What did I do to my car? (Clutch?)
  117. My stock clutch is slipping...
  118. What RPM for Shift Light?
  119. 4L60-e to T-56 swap
  120. Steeda Tri-Ax Shifter
  121. Viper Spec
  122. Help. Clutch? Slave? or Tranny itself?
  123. t56 upgrade?
  124. Preventing Miss shifts
  125. need new shifter...not sure what to get.
  126. mcleod adj master worth it?
  127. Cars In Shop
  128. Hurst billet plus
  129. Installed Ripper Shifter, weird noises
  130. Clutch help ASAP!!!!!
  131. new flywheel or not?
  132. M6 Cant get in to 1st or 2nd HELP
  133. tranny being a bitch help!!!!
  134. How hard to pull tranny?
  135. ls1 t-56 to a standard 350
  136. does the spec 3i need to be balanced?
  137. Lightweight option for Spec clutches?
  138. proper break in for a stg 3 spec?
  139. stock clutch finally gave up
  140. Where to order a Spec III
  141. Where in the Quadcities can I get a M6 rebuilt
  142. SPEC stage 4 getting stiffer?
  143. Toasted specIII, but i'll get a specIII again for sure.
  144. whinning noise in tranny
  145. how hard is it to rebuild the t-56
  146. broken trans????
  147. Did i mess something up?
  148. weird noises???
  149. Truth about the 1LE mount
  150. Did I break the T-56 again?
  151. Anybody got a pick of the access hole to self bleed clutch?
  152. grinding into 4th now!!
  153. Help w/ bleeding the clutch
  154. Moving clutch pedal up
  155. Spec Stage 3i Rocks on Slicks, Just FYI
  156. What does it take to fix this clutch petal problem?
  157. Does unplugging the cags to the tranny just cause a ses light?
  158. Swap almost complete...need one last thing to drive the car
  159. Opinions on drill mod after doing it?
  160. Does the Drill mod help if you don't powershift?
  161. CTS-V Shifter handle??
  162. HELP!!! Bored with A4 need M6
  163. Prothane mount in, noisy
  164. Tranny Problems
  165. advantages of having a McLeod Adjustable Master Cylinder over a GM 2001 Master
  166. 3rd to 4th grinds
  167. the car goin in monday
  168. do i need to adjust my clutch?
  169. Ram VDS 910 possible problem
  170. TO in constant contact w/ PP?
  171. Just curious what tool do you guys use to bleed your clutch?
  172. Pic of my toasted McLeod Twin Disc
  173. Need future clutch opinions.
  174. Changing reverse gear?
  175. Bleeding the clutch
  176. Why does the tranny vibrate if.....?
  177. Anyone that has oe has driven with the Spec stage 5 in here please.
  178. Whole car and tranny THUDS when engaging 1st, help
  179. Pops out of reverse. HELP!!
  180. Anyone Cracked Flywheel?
  181. installing spec stage 3 QUICK QUESTION
  182. Clutch fluid Leaking, cannot figure out where ....
  183. need opinions on z06 clutch please.
  184. What's wrong with my trans/clutch?
  185. 1st post, clutch ?'s and recommendations
  186. Clutch help...
  187. clutch
  188. just installled a ram level 2
  189. clutch goong bad?
  190. T-56 trans question
  191. stage 3i, after install questions.
  192. How much can you chop a Pro 5.0 shifter?
  193. Spec's stage 3I or 4
  194. Identifying 6 speeds
  195. Master cylinder
  196. opinions on kirban
  197. McLoed Twin Disc GOES UP IN SMOKE!!!!
  198. Part Number for torque arm mount on tranny?
  199. 383 Stroker...What's a good streetable clutch?
  200. Help me out here fellas, horrible noise
  201. M20 question....
  202. Another Spec 3 Goes In....
  203. Just finished putting in Pro 5-0 and short stick....
  204. Tranny Problems, need input please
  205. Pro 5.0 Shifter stop bolts??
  206. Full throttle shift problem.
  207. Need help with my Ram clutch
  208. Clutch peddle
  209. Is my trans wasted or what?
  210. Do I tap the pilot bearing in all the way till it bottoms out on the crank?
  211. Opinions on aluminum spec stage 3
  212. 2.73's in a M6??
  213. spitting out 3rd gear
  214. Why do I hear this sound??
  215. please help car boggs on take off
  216. shims and RAM - what do they do?
  217. How can I make my stock M6 take 470+ rwhp and it hold together?
  218. Skip shift light on with skip shift eliminator
  219. just wondering
  220. Why is my clutch still slipping?
  221. Stock Master Cylinder Bore Size?
  222. Having problems with clutch Please help?
  223. clutch swap
  224. flywheel needed?
  225. proform?
  226. mcleod twin disk or ram vds 900 for 650RWHP?
  227. any thoughts on this prob????
  228. Do I need an Adj Master Cylinder?
  229. 2nd gear prob. and BEEFED up Tranny?????!!!!
  230. How Much
  231. Sound of bad throwout bearing?
  232. Need help on pilot bearing
  233. Pro 5.0 install
  234. t56 problem
  235. Is this a problem????
  236. Cheapest Hurst Billet Plus
  237. lous short stick vs QWICK stick
  238. Ram 910 picture..???????
  239. Drill mod & slave spacer???
  240. T56 options.
  241. HELP!! vibration after clutch install
  242. bleeding and shim questions
  243. Pro 5/Lou Short Shifter
  244. fill me in on 6-speeds...
  245. Any companies make aftermarket
  246. Weird sound coming from my friends M6
  247. Opinions on Z06 clutch
  248. Also need some tips to get that darn slave line out.
  249. i need to swap my A4 to M6
  250. Another Vibration Problem
