PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. quick Stock pressure plate question
  2. transmission shakes
  3. Textralia twin disk assessment
  4. Put in my LS7 clutch today......
  5. Does ls7 handle powershifting/drops?
  6. Transmission Fluid Discrepancy
  7. Bolt sizes
  8. High Mileage Clutch That Will Take a Beating?
  9. Textralia GB clutch question
  10. skip shift ?
  11. Pro 5.0 install, stick cut and bent, with PICS
  12. Pilot bearing?
  13. Clutch problem
  14. NOOB ? about trans
  15. WOT Issues
  16. what breaks first
  17. Anyone using the RAM HDX clutch?
  18. Flywheel Question
  19. LSS and stock shifter
  20. sequential gearbox
  21. pilot bearing removal: HELP!!!
  22. Textralia help?
  23. what trannys can i use w/ a lt1 engine?
  24. It's time for an upgrade!
  25. Quick LS7 clutch question about lining up pressure plate...
  26. Time for a road trip to detroit. Powerbled my pos clutch, no change
  27. ticking sound
  28. No reverse lights.
  29. Has anyone got their Exoskel clutch kit yet
  30. centerforce duel friction
  31. T56 Reverse...sucks
  32. New Clutch & Hydraulic System...Won't Go Into Gear
  33. This ever happen to anyone with an M6
  34. Got a new Textrillia and problems
  35. shimming the spec
  36. Clutch/shifting 01 ws6 "help"
  37. Engine / Trans removal without bleeding????
  38. Where to check part numbers on parts?
  39. reverse
  40. clutch issue Z06
  41. ls7 clutch part# problems
  42. Mcleod master cylinder install help ASAP!
  43. Fill me in here.
  44. Weird Clutch Problem
  45. How to tell if you have Hurst Shifter!
  46. Bleeding clutch in car...
  47. Hard shifting in T56
  48. need new clutch
  49. clutch disc material
  50. Throw Out Bearing Question
  51. Griding problems..
  52. Do I Need A Special Tool??
  53. possible master cylinder problem?? please help
  54. transmission swap question
  55. t56 reluctor ring
  56. I have a pedal problem. its soft please help
  57. wheel hopping problem
  58. car stuck in 4th gear @ 115 mph!
  59. clutch going out
  60. Clutch Chatter when in neutral
  61. Having a little trouble shifting into gear.
  62. pedal starts ok, then goes soft.
  63. installing spec 3+
  64. Noobs changing their trans flud.
  65. Need clutch help!
  66. PN on Reverse Lock Out 'Noid
  67. Tranny must hate the winter! It gets all mad and crunchy!
  68. Replacing the pinion seal
  69. Need clutch for 1XXX TQ?
  70. Spec stg3 owners inside
  71. Replacing the Throw-Out Bearing T56
  72. how good is the t56?
  73. Website Updated with In Car Camera
  74. pro 5.0 rebuild?
  75. short shifters
  76. Bell Housing
  77. At exactly what RWHP does the clutch start to slip?
  78. C5 T56 FS W/ 1 YR Warranty
  79. Squeeling Textralia?
  80. t56 woes
  81. so i finally decided on a new clutch...
  82. '01~'02 Master Cylinder Part #???
  83. Clutch swap, what bolts to replace?
  84. My clutch stuck
  85. doing a project for school about clutches
  86. Mcleoud Single Disk???
  87. Best T56 Fluid
  88. Weird noise. Bearing Failure?
  89. What Caused This...
  90. Shift Boot Question
  91. M6 Trans Removal ?????
  92. Removing a T56 from a 98 Trans Am
  93. tips for a noob driving in traffic
  94. steve-d still selling extensions???
  95. trans mount/clunking problems?
  96. C5 T56 W/ G-Force Mainshaft For Sale
  97. squeek! have a quick question
  98. I need a shim
  99. Tranny Mount ??? Help
  100. Do I need to build up my T-56?!?!
  101. Tex install complete
  102. Mighty Vac Didn't Work....Bubbles and Bubbles...Searched & Nada
  103. Problem with LS7 install?
  104. Mighty Vac question... Did it tonight... But how does it work???
  105. Clutch Bad? (Spec Stage 3 Lightweight)
  106. T56Rebuilds.com Fall Special Extended
  107. t56 trying to engage by itself when in neutral
  108. Clutch Pedal to the Floor
  109. Cartek clutch setup
  110. is there any 6 speed...
  111. Slave Cylinder???
  112. 6th to 5th downshift problem...
  113. McLeod MC- What is this thing?
  114. Do you have to pull the bell housing for just the tranny?
  115. black clutch fluid
  116. Question about spec stage 3 plus chatter
  117. Master Cyl Replaced...Still on Floor...Please Help
  118. cartek
  119. Clutch question????
  120. Slipping clutch after transmission install??
  121. Spec V???
  122. Poll:are you happy with your T56???
  123. Corvette Flywheel
  124. What clutch would you suggest?
  125. exoskel install
  126. T56 Install Question?! Need Help Fast
  127. cags/skip shift install help?
  128. How to contact Textralia????
  129. Went over a Dip on I-95, no power to the ground
  130. clutch break in, disengagement was high now low, is this normal
  131. slight groan into gear
  132. Grease in my clutch fluid resevior!!!!
  133. LS7 Clutch: Love it, LS2 flywheel hate it...
  134. no 2nd, 4th, 6th...
  135. LT1 to LS1 t56 conversion.
  136. Overtorqued Flywheel Bolts--what to do
  137. New Product- Pistol Grip Shifter Handle
  138. c6 clutch questions
  139. Spec 3+ Performed well last night
  140. need help please
  141. LS7 clutch vs. the track: how is yours working out?
  142. Frustration!!!
  143. Clutch Slave Engagement problem
  144. Pressure plate cracks!?!?!
  145. im at the end of my rope
  146. T56 in a 944
  147. Help! How Do I Bleed
  148. ls1/ls2 pilot bearing interchangeable???
  149. 2000 camaro throwout bearing size????
  150. Transmission Vibration Please help !!!!!
  151. high rpm grind!
  152. Used spec 3???
  153. well i blew my clutch out
  154. T56Rebuilds "Real Racecars have 3 Pedals" T-Shirts.. Who all wants one
  155. McLeod Slik Stix Shifter
  156. T56 xperts - Grinding into 3rd and 4th
  157. harder to shift into 3rd?
  158. T5 trans
  159. Mating a LT1 T-56 with an LSX using ...
  160. New clutch comming in.
  161. stock clutch coast?
  162. stock flywheel
  163. Mcleoud or Textrilla?
  164. stock clutch and 125 shot?
  165. Grindin all gears
  166. Drag Racers: Type F ATF in T56?
  167. Spec Stage5
  168. McLeod Adjustable Master Questions.
  169. Which tranny fluid came in the tranny from GM?
  170. Squeaking Noises
  171. Squeaking Noises
  172. Who's got the best LS7 clutch packages?
  173. Transmission bolts
  174. clutch and flywheel?
  175. Which Master Cylinder?
  176. T56 problems
  177. How much HP/Torque can an LT1 T56 hold?
  178. optimal RPM?
  179. Got measurements, how to determine shim size?
  180. Ignorance is bliss
  181. How long should i break in my spec 3+ ??
  182. Ls7/ls2 Clutch Install,now Vibrations!
  183. i need a m6 trans!
  184. SPEC 3 5k rpm launch?
  185. Exedy rebuild questions...
  186. Will This Cure Clutch Pedal Stuck On The Floor?
  187. T56Rebuilds.com Shop Motto......
  188. clutch problems.........
  189. Tranny fluid
  190. t56 problems! help!
  191. centerforce dfx
  192. What are the differences i the LT1 and LS1 clutch
  193. whats wrong with my tranny?
  194. adapting lt1 t56 to ls1
  195. McLeod disengaugment issue. CL SL Bleeding Q,
  196. slave cylinder problems
  197. how many qrts does an M6 hold?
  198. Ls7 clutch?
  199. T56 Conversion Install - Moves with clutch in
  200. Think my Spec III is going out! You tell me.
  201. Tranny help ??? T-56
  202. what short stick do u use?
  203. Borg Warner Super T-10 4 speed manual
  204. A4 to M6 swap
  205. T56Rebuilds In Car Camera
  206. t56 input change
  207. Clunk, then clutch wont disengage, pedal is harder
  208. Wtf!!!???? Noise???
  209. Where to buy LSS?
  210. Clutch/shift problems
  211. damn tranny wont budge
  212. Gas mileage by gear
  213. poor shifting when cold
  214. pressure plate bolts!!
  215. HELP unable to shift
  216. fidanza aluminum flywheel?
  217. A4 to M6?
  218. adjusting
  219. Can I use 75w90 gear oil?
  220. New UMI Short Stick Probs
  221. lt1 t56 to ls1
  222. LS7 Clutch Problem
  223. Hard to shift from 4th to 5th. new Z06 trans
  224. pro 5.0 install question
  225. tranny fluid question
  226. Umi Ss ?
  227. Neutral + Clutch In = Stall
  228. Should I change my slave?
  229. LS6 Clutch?
  230. Bleeding the Slave
  231. Skip shift set to avoid accidental 3rd to 2nd downshift?
  232. What is the dia. on the input shaft for the
  233. Replacing slave cylinder
  234. shifter problem? please advise
  235. How many splines on the T-56 main/tail shaft?
  236. New clutch
  237. Need photos of wiring going to
  238. need new clutch, what 1?
  239. Very tired of changing clutches!!
  240. short stick vs. shifter assembly
  241. SPEC warranty
  242. T56Rebuilds.com NEW H/C Highest HP TODAY w/M6
  243. Clutch Hazed Over
  244. Clutch Problems
  245. Clutch events starting to add up...
  246. what size throwout bearing 99TA LS1
  247. Clutch hydro fluid black as hell???
  248. Shifter = ANNOYING VIBRATION!
  249. Skip shift idea/question
  250. Can you put your shifter in backwards?
