View Full Version : Manual Transmission
- Anyone who has done an Auto to Manual Swap With Harness
- Help- Tranny is Leaking
- Car Grinding Into Third!!!
- what nuts/bolts to attach stock flywheel/clutch housing?
- Clutch noise
- Stupid question Here ? Flywheel bushing
- Best clutch for A 500RWHP street and strip Vette
- Spec stage 5 install balance Q?
- Installing a used Spec3, have questions?
- can i bleed the master out of the car?
- 2-3rd gear thifts
- my hurst shifter is leaking
- handling the spec stage 3 chatter...
- Guys with Fidanza (or other) aluminum flywheels, how do you like them?
- adapter fitting for GM hydraulic T/O bearing
- new clutch feel
- Throwout Bearing Catalogue
- Pro 5.0 noise question...
- finally got to test out my specIII
- Is this clutch on it's last leg?
- Need some Help...Not real familar with clutches
- What is the RAM equivalent of a SPEC Stage 3?
- changing hydraulics
- Where to buy Spec, Zo6, or Ram?
- Making the Cluthc Master Cylinder Adjustable
- Any reason 2 replace my 30K mile old McLeod master cylinder w/ new one? Have extra
- Longer the clutch is in, the harder it is to shift?
- How much noise??
- Ordered The "non-walk" Bushing For T56
- Spec 3I?
- Flywheel discussion
- What's the drill mod
- New 01 Master and Slave Bleeding help??
- Look What I Finally Bought
- Leaking coolant ruined clutch disk.......?????
- Auto-to-Manual
- How many out there using spec 3 with the stock flywheel?
- quick disconnect will not release hose HELP
- torque for tranny and bellhousing
- Which clutch pad
- whats the difference in all the spec pads?
- Real Bad vibration..NOT DRIVESHAFT
- I need a thowout bearing?
- Clutch Recommendations Please (150 Shot daily driver)
- what parts do i need?
- T56 Tranny swap
- New 60mi. SPEC 3, RAGGED hard. Ok?
- going from spec 3 to a stage 2 disc?
- Re-Balancing the Spec 3 and Stock Fywheel...
- SPEC S3 and flywheel install questions...
- Hard clutch peddle?
- where to get input shaft?
- M6 To A4 Swap Anyone???
- Is this normal?
- Sponsers! Check my shopping list
- removing pilot bearing
- SPEC Stage 2
- My tranny is dead. I need help.
- clutch install how to's anywhere?
- breaking in spec stage 3
- spec stage 3 clutch
- how bad does spec 3 chatter when first installed?
- I think #6 tranny has bit the dust - help
- Installed Hurst Billet shifter.. Now have Rattle noise.
- Anyone running an NRC Motorsports Tranny?
- clutch pedal return spring
- Clutch install
- Removing T56...have quick questions???
- Fastest T56 F-body or Corvette
- rookie tranny problem
- Needing clutch advice for 1200hp...
- Aftermarket T56 parts?
- what do i need to change the clutch EVERY last piece and part
- ram level 1,2, or 3?
- FAST HELP!!!big problem, went in 3rd now huge griding noise and car wont go
- Question on why my tranny failed ...
- Reasons for Clutch fluid going black?
- Have anyone had this problem
- Something's wrong...need help
- Help Transmission is Stuck Sometimes.
- What would cause VERY hard shifting?
- How much RWHP before M6 pukes?
- every gear is like neutral! nothing works
- How to check/change hydraulic clutch fluid?
- Will spec 3 clutch hold my HP & last, IYO
- Break in period of a clutch?
- First impression of Spec stage 3
- Clutch problems, I need advice.
- bleeding the clutch?? how?
- Hurst Factory Handle Thread Pitch
- Which spec to get??
- Whats the deal??
- Clutch pedal is sticking
- Cant hit 4th for the life of me.
- I Need Drill Mod Instructions
- Factory hurst seems loose
- Money to spend need opinion!
- I Need Help On A 2001 Trans Am Noise
- '00 SS...Hurst shifter ok?
- no second gear, what did I break
- Upgrading clutch Q's
- little pedal play
- Old Story...Any Ideas?
- anyone drive the spec stg. 4 on the street.
- doing the drill mod, need both 01 slave AND master hydrolics?
- ? about my spec stage 3
- What are your 60' times on street tires
- Bent master cylinder rod...
- anybody know..
- Spec Stage 4 w/aluminum flywheel aint bad at all
- manual tranny , fine in reverse, no-go forward
- Is this the right trans mount for our cars? *PIC*
- Ticking sound coming from Trans?
- T56 rebuild what parts to use
- Ram 402/910 guys inside plz...
- torque specs
- clutch noise???
- New Billet flywheel, slave, master?
- Please advise URGENT!
- Which flywheel?
- Newbie Questions.
- Those who have installed a RAM 402pp on a stock flywheel...
- Can someone from RAM confirm....
- Clutch wont engage after running it hard....
- Loud pop sound came from clutch pedal this morning
- gasket maker on shifter?
- Please help. Clutch won't disengage.
- Ram adjustable master cylinder
- clutch pedal problem
- where can i find a built manual trans
- Replaced Rear Seal, Still Leaking?
- Anyone replace the banjo fittings on the hydraulic system with AN fittings?
- Flywheel resurface in Chicago subs?
- replaced reverse lockout solenoid, now it doesn't lock!
- Trans Prob. Went to dealer.
- ZO6 upgrade
- Help me rebuild my T-56
- Is this a synchro problem or a clutch problem???
- Attention Mityvac experts!
- Anyone ever break a rear shock on a miss shift?
- Synthetic ATF in 00' Camaro
- NEED SOME INFO...drivetrain/clutch/rearend
- synthetic fluid
- I dont want it busting/clutch/drivetrain???
- is there a way to put a t-56 on a 351W
- Clutch disk break in time?
- Adjustable Master.....
- Who has a good 60ft on motor or spray with a 6 speed
- What happened to my Spec Clutch?
- Anyone shipped a tranny?
- Is it fine to slip the Spec 3 clutch at 5000 rpm? will that hurt the clutch?
- Why Are My Slave Cylinders Failing?
- Clutch Advice
- Help ID another tranny!
- Shuddering problem... Help!
- Pro 5.0 bolt question.
- Clanking during initial shifts??
- Drill Mod On Slave
- replacing clutch
- trans fluid????
- clutches n stuff
- Master cylinder question
- Spec clutch chatter???
- Is this the clutch for me?
- Need help, not sure whats wrong
- What does this problem sound like?
- What is wrong with my clutch ...
- Does stock C5 master need the drill mod??
- Does Spec have a website
- Rear end is????
- My opinion on the Spec stage 3I
- Can clutch slip?
- Shed a little light for me. General transmission problems.
- Dirty hydraulic fliud
- McLeod Master Cylinder .... Can it be rebuilt?
- Speedometer Cable
- Predator shift light
- Help!
- Just bought a Pro 5.0
- Symptoms of springs falling out of spec 3?
- will this work?
- Updating GM Clutch Hydraulics...Question
- Question about spec stg 3.
- Cost of a built T56.
- Changing Fluid, How much do I need?
- 02 ls6 clutch being installed
- Question about C5 t56 and fbody t56
- clutch issues
- Hydraulic Clutch Line
- I have went through 2 mcleod clutchs now going to a specs what stage shoud I get..
- T56 Transmission Question HELP!!!
- Stock clutch still holding up to 11.5 at 119mph run(check the video)
- drag cags
- Anyone did an A4 to M6 swap please help
- Centerforce Dual friction or Spec 3?
- Any Harlan 2 Step Users?
- 4.56 in a M6
- clutch pedal raises up on hard launches
- Crap!!!!
- How much power can the mcleod single disk hold?
- help with spec clutch
- Please help me with choosing clutch!
- Adjustable master cylinder, picture?
- pro 5.0 or b&m ripper?
- Got done breaking in SPEC Stage 3!!!
- can't shift into 2nd 4th or 6th
- Stock clutch replacement, any suggestions?
- Jumps out of 1st
- A damn good question!!!
- tranny problem..help
- Where to send a t56?
- Custom disconnect ring
- Anyone try the Exedy clutches??
- Automatic to manual swap with a twist
- Auto to Manual conversion
- What n' World Please Help
- Clutch problem
- Chatter at low RPM w/ stock setup
- distance of shifter
- Factory Hurst Shifter???
- Drill mod or Spec Stage III?
- Crap, I got air in Master Cyl. please help!
- Shim please :- )
- Royal Purple? Is it really worth it???
- Mcleod masters do they work fine these days??
- parts in the spec kit?
- clutch went out >=(
- spec or ram clutch
- M12 tranny in 2000 Trans Am?
- What tools do you need to replace pilot/throwout bearings?
- East Side Performance hooked me up!!!
- Where to put ATF in on a T56????
- T-56 upgrade/rebuild kits
- Worried about my Spec st 3, any others worthy?
- Custom built t 56
- Clutch chatter, an unexpected solution.
- squeaking clutch pedal
- Spec Stage 3 Clutch is slipping!
- installing clutch, need torque specs
- poping noise when disengauging clutch
- transmission seal part number
- Installing spec 3 need help asap (fast).
- Viper/Mustang T56 behind an LS1?
- Do I need new clutch, slave and Adj. master cyl?
- D and D tranny
- Keep missing third:(
- did anyone else use the SPec supplied shim?
- Clutch Problems
- How often to flush the clutch fluid?
- weight differences between clutches
