PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. Clutch got soft out of nowhere
  2. Broken input shaft?
  3. What clutch will handle 600rwhp?
  4. spec 3+ experience
  5. Zoom clutches
  6. stripped flywheel bolt removal
  7. growling into gear
  8. Manual Tranny Stick Noise?
  9. t56 vent tube
  10. How many quarts of fluid does the 6 speed hold?
  11. 2nd time slave cylinder nuked! why?
  12. how much movement in the shifter is normal?
  13. ligth flywheels vs heavy
  14. ls7 clutch install, picks inside!
  15. 3rd gear vibration...WTF?
  16. Nv4500????
  17. spec 3, toast! Been in since FEB! Fragged on dragweek
  18. Whirring Sound
  19. clunk sound
  20. People that have a rebuild done by T56rebuilds.com
  21. Shift knob threadlocker
  22. Spec Stage 3+ Prices/Dealers
  23. Questions about my clutch and noises it makes.
  24. cdf clutch shifting problems
  25. what are signs that a clutch is slipping?
  26. Please help diagnose
  27. Ram HD bad or something else?
  28. Newb ? bout Double clutching
  29. Bought New GM 99-02 clutch is it a Z06 or?
  30. RAM HD Died after 10kish what next????
  31. Who has broke a input ahft and why did it break?
  32. Clutch trying to engage in neutral?
  33. shim the slave?what shims?need info
  34. NEED HELP FAST!!? cant get out of 4th!!
  35. Question about Centerforce Dual Friction
  36. hurst shifter
  37. Are these the same clutches?!
  38. clutch questions
  39. Bleeding the clutch system after takeing out trany
  40. got my ls7 clutch to day!
  41. Can I get a T-56 manual/rebuild gude somewhere for free?
  42. Fidanza w/ LS7 or LS6 clutch...
  43. Car pops out of 3rd gear?
  44. Does anyone make a blowproof bellhousing....
  45. Clutch dropped to the floor!! help!
  46. trans or clutch problems?
  47. Weird 2nd gear issues
  48. Fbody T56 in a C5?
  49. gears are gettin hard to get into......
  50. 6th gear problem
  51. Short stick shifter positioning?
  52. Squeak when shifting?
  53. When to shift on stock tac.
  54. 2nd gear went out what is my next step.
  55. Clutch wont bleed?
  56. M6 take off issue
  57. hard getting into any gear
  58. LT1 and LS1 have same clutch disc?
  59. can anyone help quickly! ls1 Crank to m6 flywheel dowel, is it stepped 11 -13 mm?
  60. spec stage 3 or 3+
  61. No pressure on clutch...
  62. converting LS1 T56 to LT1 T56 trans
  63. T56Rebuilds.com Sept/Oct Special
  64. spec 3I still holding up-10.6@129 1.47 60ft.
  65. Ram Powergrip HD warranty info? and more...
  66. How much play do you have in your clutch peddal?
  67. Pilot bearing install
  68. adjustable factory clutch master
  69. shifting problems
  70. Can a Z06 slave cylinder be used in F-bodies
  71. just need to make sure
  72. Did I go overboard?
  73. car shudders at takeoff
  74. help! quick disconnect problem
  75. 6 sp console top plate, 94 interchange with 97+?
  76. When replacing the slave what else?....
  77. m6 trany oil
  78. T56 synchros gong out, or cluch needs a bleeding? Read this
  79. NOOO.. Blew 4th?
  80. Q for Spec 3+ with supplied shim.
  81. need advise on what clutch with my setup... procharged 408
  82. How to perform drill mod?
  83. Shortest short throw shifter???
  84. help.....need ram shim advice
  85. Master cyl replacement Q
  86. Slave quick disconnect missing plastic release?
  87. Q about drill mod?
  88. Flywheel bolts??
  89. Bad idea to use a ram adjustable clutch master cylinder with a cartek clutch?
  90. best place this clutch
  91. Clutch Life Expectancy?(Spec 3)
  92. ls7 clutch, how hard is the install?
  93. B&m and Pro 5.0 question????
  94. what would you guys suggest for a clutch??
  95. Put in my Centerforce DF clutch.
  96. slipping on and off
  97. Knob is stuck
  98. How to use a proshifted tranny?
  99. B&M SHIFTER QUESTION??
  100. clutch went out
  101. Help, Clutch not going into gear at higher RPM's?
  102. Need a NEW T-56 Transmission. Where to get?!?
  103. my drill mod experience
  104. Slave Cylinder replacement
  105. shifter knob install
  106. Just installed Hurst Billet Plus Shifter
  107. So I talked to a machinest today about RAM HD clutches...
  108. 01-02 hydraulics
  109. Finish Line T56??
  110. Bad Clutch????
  111. T56 pilot bearing/bushings crushed!!
  112. Clutch feels diffrent after the track (Is it slipping?)
  113. Mcleod master rebuild problems.
  114. Ram HD unfazed by hard second-gear launch
  115. Just installed Pro 5.0, now have a rattling noise.
  116. Ram Powergrip HD
  117. is there any way...
  118. Center Force vs. LS7 vs. Ram HD
  119. Clutch Spring Problem
  120. whatcha think about these..
  121. Tranny wont go back in...
  122. My Spec 3 crapped out on me
  123. Please Listen To My T56 Sound Clips
  124. Resurface flywheel after 6k?
  125. Tranny shop in Nashville?
  126. Do I need a new master cylinder?
  127. A4 to M6 swap
  128. My T-56 is dying. Long read need to vent!
  129. Ive done everything...could this be the problem.
  130. spec 3 question
  131. Is something wrong with my spec?
  132. removing tranny from 02 z06.. help please
  133. Love the WS6 Store Short Throw!
  134. Can't shift for SHIT after heads/cam install!
  135. Corvette 6spd vs f-body 6spd
  136. Spec twin disc
  137. What stuff needs to go with a new clutch?
  138. Clutch stays on floor.
  139. Those racing with 650-700 rw what clutch are you using?
  140. who knows part numbers? (ls7 clutch)
  141. Tranny problems need help
  142. Need recommendation for 300-450whp clutch
  143. Gauging Interest
  144. Shifter Installation?
  145. T-56 throwout bearing?
  146. Slave Cylinder: Is this normal?
  147. Bad TOB or do I need to shim?? Knocking coming from bellhousing
  148. Ultimate LS7 clutch thread....
  149. Pro-shifted/faceplated users inside
  150. Rebuilt T56 cases
  151. CLutch install on v6 mustang
  152. Problem With Textralia
  153. which clutch will hold a kenne bell?
  154. 93 t56 build up
  155. gto t-56 tailshaft??
  156. shifting point - might be a dumb ques.
  157. Do I need a new master cylinder?
  158. Bellhousing Upgrade?
  159. T56 vs A4
  160. 400 miles enough for break in???
  161. Getting ready to install the 5.0, any tips I need to know about?
  162. Need some Suggestions with New Clutch
  163. synchros going out
  164. Do I need shims between the flywheel and pressure plate??
  165. Whats the best way to install tranny?
  166. Can you bleed the slave/master un-hooked??
  167. How does the slave work??
  168. Need help before tomorrow morning!!!
  169. Clutch Problem
  170. squeaking noise
  171. Switching auto to 6spd
  172. Replacing clutch. Help.
  173. Bad rear main seal. Did it ruin my new Textralia clutch?
  174. Where to pick up a flywheel FAST?
  175. short stick keeps coming loose??
  176. F-body T-56 input shaft question
  177. Drive shafts, M6 vs Auto
  178. Need help with hydraulic problem
  179. Tranny Rebuilt- 3rd gear probs
  180. 99TA, T56 tranny mount
  181. ws6 store short stick
  182. LS1 camaro on Pinks!
  183. T-56 people where to build for 800rwhp/t
  184. LS7 clutch with resurfaced LS1 flywheels?
  185. warranty question
  186. 1500 Truck
  187. any M6 guys..
  188. clutch no workie!
  189. T-56 Differences?
  190. RAM powergrip gone after 7k
  191. Is drill mod neccessary?
  192. Bad Master?
  193. how long to brk in my ram clutch?
  194. possible ls7 clutch issuse
  195. Pilot Bushing Question?
  196. Popping out of gear
  197. trans swap? too much hasle?
  198. Pro 5.0 address?
  199. RAM replacement clutch
  200. trans fluid?
  201. Tranny stuck in 4th after WOT run
  202. Unusual clutch sticking to floor problem - does it always
  203. 5spd Conversion...?
  204. just orderd my ls7
  205. Ram HD Clutch Wont go in Gear
  206. do you have to do the drill mod to the master cylinder line?
  207. is this a decent price for a slave cylinder install??
  208. Tranny gone/ List of problems
  209. T56 Hydraulics replace?
  210. Clutch Question??
  211. Hybrid Clutch idea.......
  212. Need help puttin tranny back in!!!!!
  213. PLEASE HELP, wont go into reverse
  214. Help Need Info
  215. Anyone using the ls2 clutch
  216. SPEC 3 most likely gone
  217. WTT: a4 for m6
  218. Is this too much for a stock clutch?
  219. Anyone using McLeod set-up...
  220. Signs of air in hydraulics? Other problems?
  221. t56 issues
  222. drill mod questions
  223. ls7 clutch ?
  224. Question about clutch masters.....
  225. Wrong Flywheel!!!!
  226. Ls7 Clutch Users Come Inside....
  227. Spec 3+, Spec 4 or Ram HD?
  228. T/O Bearing Replacement
  229. How often should you replace the clutch master Cyl?
  230. Changing Flywheel with Clutch
  231. Which sponsor currently has the best price on a Spec Clutch?
  232. z06 clutch removal question
  233. Ram HD. Need shim??
  234. need help sorting out confusion.
  235. Got Gear End Play Spec??
  236. Mcleod Street Twin issues.....
  237. Odd Clutch Slippage
  238. C4 radio shack skip shift delete?
  239. Clutch pedal sticks to Floor NEED HELP!!!!
  240. FYI: Spec 5 Shim
  241. Is my clutch bad?
  242. clutch master help now!!!!!
  243. Looking to get new shifter for car
  244. Is My Clutch Getting Sloppy?
  245. Problem out of no were.
  246. Did this happen to any other Spec's out there?
  247. Great, now what did I destroy/damage
  248. What is a pro-shifted t-56???
  249. Ls6 Clutch-pedal/engagement
  250. spec 3..very touchy trying to get used to it
