View Full Version : Manual Transmission
- stock pressure plate bolts
- Monster 3.5 how all aftermarket clutches should be.
- LS7 clutch question
- What are the 4 plugs on the T56?
- Help input shaft locked up
- 01 t56 slave cylinder help
- shift light
- new spec super single v2 clutches? aluminum pressure plates!?
- How much tranny fluid??
- My ls7 clutch slipping?
- Dallas/Ft Worth area reputable T56 rebuilders
- Real Bad Vibration
- New clutch, slave, master, and driveshaft...
- Oil in the clutch...!
- Broke my T56!
- removing the hydraulic line
- Reverse Lockout Solenoid...Where can I get one!
- What's it worth....
- Clutch pedal engagement??
- A4 to M6 (Using M6 engine harness) and M6 to A4
- drive line slack, transmission free play?
- LS9 clutch, why doesnt someone...
- Help me bleed my clutch!
- what is needed to upgrade to a Viper output shaft??
- Brake fluid coming out from front of tranny???
- Having difficulty plugging line back to tranny
- T56 parts
- Clutch Questions....With Pictures!!!
- Need trans work on 07 T56 in south Jersey area?
- Ram clutch and adj.master problem?
- It's going down tonight!
- clutch disc in backwards?
- Auto to manual conversion?
- T-56
- Accidently hit reverse when going into 5th
- Are the MN12 Syncros the same as the M6 Syncros?
- Slave or The Master
- master cylinder question
- Really weird trans/clutch problem???
- 2nd gear engagement problem - do I have to rebuild? Where?
- Squeky sounds when decelerating?
- Monster Stage 3 Review
- What clutch for lt1?
- What clutch for heavy street car with 1000rwhp?
- So i ordered the tick master cylinder!
- slave problem?
- quick connect replacement?
- my ram vds clutch broke,which twin disk for 625rwhp?
- Need some advice/help please
- problem need help quick!!!!!!
- Ls7 clutch/sdpc
- mating LS1 engine to LT1 t56
- Help with air in the lines!!
- Broke bellhousing
- upside down t56
- Output shaft seal
- Exoskel Rebuild
- help please, need new clutch kit-
- Removing master cylinder line from transmission?
- New Clutch... Clutch Vibration
- tr6060 installed in my 98 Camaro!
- cant get tranny to bolt up to qt bellhousing???
- What are you guys using for Tranny Fluid??
- Why are monster and text so similar?
- Do any of you guys or gals wish...
- I'm lost
- Is it hydraulics or the transmission?
- M6 Swap Harness...Worth It?
- Transilla from rs gear
- did the t56 come with a shim from the factory?
- Slave question?
- T56
- pump to fill trans?
- Need help with my clutch. PLEASE!!!
- New clutch
- Help with tranny!
- What flywheel is best?
- WTF? I changed fluids and I can't shift in 3rd gear?
- Are ebay master cylinders any good?
- p0704 code, what could be causing this/has anyones tick mc caused a p0704 code?
- slave o-ring??????
- Hyrdualic Removal Ring Missing! Any Ideas??
- Drill mod vs Tick MC
- There Is a Monster Under My Bed!!!!!
- New slave cylinder
- Tremec T56 Rebuild Kits....?
- slave cylinder?
- Pressure plate and flywheel dowels
- reverse lock-out is messed up
- Transmission locked in gear(s) - teardown started have a few questions
- shifting issues after 9in. install..
- Who sells individual T56 parts?
- Monster website down???
- Shimming the slave cylendar?
- clutch problems and what clutch should i buy?
- A4 to M6
- Pilot bearing question....
- Flywheel bots, are they TTY or reusable?
- sticking in 4th gear...BAD
- ACT Street Clutch Review
- Opinions on Competition Clutch
- Do you guys downshift into 1st faster than 20mph?
- buyin a new tranny???
- Another Monster Level III Track Day
- Reverse trouble with T5
- Frustrated w/Mcleod Master = half pedal 20 mi. after bleeding?
- Textralia Clutch chatter
- free mods
- Changing Transmission Fluid
- Is the trans mount for a4 and m6 the same?
- Do ls1 t56 shifters work on lt1 t56's?
- Tick master question
- I have the worst luck with these t56's now the rebuilt one
- Tick clutch Bleeder??
- new tick mc squeaking after 400 miles
- WTH! CLutch engages in neutral?!
- Mucked up my McLeod Magnum Force Twin
- Removal of Output Shaft Seal...????
- Shifter getting stuck, clutch getting stuck
- Should I be worried?
- TEX 101A (or other NASCAR trans) setup?
- clutch/flywheel question
- LS7 clutch on CTC-v t56
- Clutch Trouble
- Just ordered my monster today!
- T56 -- What size are the bellhousing bolts?
- Monster clutch, bad noises?
- Need Trans help (noises) T56
- how do you guys like SPEC flywheels?
- I need PROF HELP w my t56 dilema....
- Bellhousing for 12” clutch
- LS7 CLutch backorder..
- Need help!!! T-56 output shaft seal leaking still
- M6 Swap questions
- Rubber mount for tranny and one solid mount?
- Lightweight flywheel or regular with my monster clutch?
- just ordered tick adj. master woowee
- Is this clutch shot?
- Guys w/ DD Performance T56, please comment
- 3rd Gear Issue
- Clutch slips one day, but not the next?
- PAGING six speed inc old employee's wife.
- lt1 t56
- Shifter Popping out of Gear
- WTF weird noise from clutch/slave cylinder. VIDEOS
- Anyone found or know the limits of LS7 clutch?
- how to disconnect clutch line from slave
- Some more track runs on the Monster....
- Tranny hard to shift. No Sixth gear!!! HELP
- Need a reverse lockout solenoid
- Pro 5.0 Issue
- Tranny Swap
- Squeeling noise coming from inside bell housing?
- Safe Stock shift Points
- Master Cylinder??
- Went out for a joy ride and come home with P0803 and P0801
- need a clutch
- Anyone know torque specs on Textrilla EXO-SKEL clutch?
- Centerforce Dual Friction
- Another happy Tick M/C customer and a sub-par install How to
- missing my pilot
- Clutch Shim Spec Clutch.. LT1
- New Hydros Still issues experts inside please!
- Stock T56 vs built level V T56
- 3rd gear pops out, and forth sticks??
- more clutch install questions
- Is my textralia used up?
- Clutch Bled - Wont go into any gear???
- Need Opinions Please
- vibration, your thoughts??
- How can I tell if I need to replace the tailshaft bushing?
- Vibration after clutch install
- Clutch on Ebay
- Wierd clutch problem...
- Question about T56 noises
- is this hurst?
- cant change after 5K Rpm
- Need Clutch ASAP
- go a3 or m6
- T56 Dust Shield
- clutch problem?
- New GM master/slave, need to bleed??
- hydro problems or something else HELP!
- Looking for a new clutch... need advice!!
- Can t56 handle power shifting on spray?
- Longer shifters? Pro 5.0
- Pilot Bushing Vs. Bearing
- Starter rubbing flywheel?
- LS1 T56 to classic 350
- Anyone done a t-5 swap to a ls2
- Trans fluid leak?
- Is there a difference between an ls7 Slave and ls1?
- reservoir cap on or off when bleeding?
- Won't line up with poly mounts...
- no reverse!!!or 6th!!
- Pro 5.0
- T-5 issues....i need help
- Best Brand ATF
- Oklahoma Performance shop for clutch install needed
- rebuild need advice please help!
- I need some quick help with pressure plate bolts!
- Ram Slave Cylinder, Better than GM?
- T-56 Help
- Stock T56 Breaking Point
- Monster clutch made me snap an axle
- Poping out of 4th gear WHY?
- clutch went out today need opinions/help
- need help with transmission
- Slipping Issues
- Rebuild kits for t56?
- My 4L60e to T56 Swap!
- 2006 rst 4.8 5 speed 6.0 swap question!
- Besting a 1.8 second 60'...
- Textralia exo-skel install instructions
- Ever heard of a TNT short throw shifter?
- Vendors, I need Fidanza Flywheel insert ASAP
- Monster 1/2 stage clutches, what are they?
- T-5 questions
- T56 slips out of 5th wont go into 6th
- Drivetrain breakage ????
- Throw out bearing noise?
- Clutch for 558rwhp SS
- Manual Trans Fluid thats safe for LS1?
- aftermarket clutches
- What is the problem?
- Changed my clutch today, very surprised
- Can you use a Corvette slave in an F-body?
- 94 Slave/Master Install Info Needed
- ls7
- Transmission problems
- TEXtralia OZ700 with ~25,000 miles!!! REVIEW with pics!!!
- Spec Clutch 2+ vs 3
- What Shim?
- what clutch for ms4 and possibly spray
- Monster Stage 3 Problems
- monster logo
- Pilot bushing bad - should I replace the clutch disc?
- Real Big Pain High RPM shit problem someone HELP
- why does my flywheel not fit onto the crank?!
- New stick, new fluid, getting better!
- Help with clutch/transmission problems
- slave connection
- Harlan shiftlight
- Clutch Issues.
- Clutch: which 1 & why?
- Clunk from Bellhousing
- Car starts w/o depressing clutch pedal...
- Click, click noise when taking off from standstill
- Some T56 problem
- LS1 clutch questions...HELP!
