View Full Version : Manual Transmission
- Help with a Pro Shifter 5.0
- Who has a Monster stage 2 clutch?
- How much $$ for a 3rd gear transmission syncro?
- Rockland standard gear!
- Manual Transmission Whine
- LS1 vs. LT1 T56 Tailshaft Housing
- 3rd and 4th synchros? Advice please
- GTO Stock Shifter Location vs Aftermarket
- Whats my next weak link? I want to find out before my clutch makes me...
- Manual center console different?
- Shifting Problem: Help!
- T56 help!
- T56 INTERNAL GEARS HELP/ wisdom
- Gear Engagement Issue
- Cab;e T56?
- m6 tranny on 00 ss camaro
- Car won't start after my clutch install
- Major clutch issue, I am stumped!
- Gto m12
- pedal pressure problems
- clutch pedal
- Monster # clutch life
- CTS-V or to not CTS-V
- luk clutch?
- New master and slave cylinder
- Car idiot needs help (M6)
- LS T56 throwout bearing
- I think my T56 just needs a bleed
- clutch was smoked!!
- Is the mainshaft upgrade to 650 ft lbs even worth the effort?
- High Horsepower and stock clutch
- Clutch master cylinder pressure
- SNL Performance and Tick... stood behind their products, again!
- transmisson M6 whining?? why?
- Spec clutch!!!
- Anybody need to notch their center console...
- what do i need to do to my tranny for a 500rwhp car
- New Monster clutch coming out?
- T56 Temperature Gauge
- needing a new trans mount?
- are my syncros bad?
- reuse pressure plate?
- Recomendations for a Street Clutch
- Popular clutch in question. Is it bad or a matter of over reacting????
- Block 5th and 6th gear?
- Still no pedal pressure?
- How long do carbon on carbon rps clutches last
- Noises
- What are VSS wire colors?
- Casper's skip shift eliminator problem
- Sprayed my Monster stg 3 today Vid inside
- Reliable clutch
- problem with friends new clutch install..
- monster tourque install specs.asap
- clutch help
- really bad noises, sorry its so long
- Pressure plate bolts
- six speed swapped out for TH400...
- Trouble mounting a T56 to a ASA LS1
- Creeping question
- Torque arm to transmission bolts, what size?
- Top bolt(s) on bellhousing removed easily
- 1994 Camaro V-6 5 speed to LQ4 M6 Tranny cross question
- Looking for clutch to hold 800'ish
- lt1 t56 onto my '01 5.3
- replace clutch
- Tick's or McLeod's master cylinder
- Clutch or Syncro's
- c6 z06 tranny in c5?
- New T56
- T-56 Rebuild S.O.S
- Mcleod bellhousing/T56 Heads Up !
- Does Anybody Have A Jam Nut?
- need advice on what clutch to go with. daily driver dig racer.
- Aluminum pressure plate
- Spec 3+ or RAM HD?
- Pondering 6 speed swap...
- T56 compatibility question
- Manual AWD for LS engines?
- Clutch pedal dead half way..still works though.
- What else should I do when changing clutch to help shifting?
- t56 pedals same for LT1 and LS1 or not?
- flywheel difference between 4.8/5.3/5.7
- 4th gear going out?
- Confirm my thoughts Input shaft toast
- T56 Main case question.
- quick question guys, havin trouble with ds
- LS7 clutch issues
- excellent LS swap to tremec, muncie article -Sticky?
- Clutchmasters FX400?
- rear main seal question
- Monster Clutch, Who has the Best Deal?
- Need a T-56 Bellhousing?
- Rebuilding tranny question on syncros
- How to remove clutch line from slave?
- CLutch question
- Gear trouble
- Found good, no stress no bullshit way to remove pilot bearing.
- cts t56 behinde ls2 in first gen bird?
- Few questions to the guys running Monster Stg. 3
- Clutch Replacment
- McLeod Adjustable Master Cylinder, 1998-2002 LS1 F-body
- Need a clutch that will hold 1000ft lbs!!!
- Pro 5.0 Power Tower installed tonight
- pedal so low hard to shif in gear
- Just esploded my new Monster Stage 2
- Stripped bolts that go into slave cylinder...
- RPS Street Twin Lite Carbon Clutch [pics]
- Where to get textrilla clutch disc???
- Anyone used mcleod adapter flywheel?
- what sponsor has the best prices on Slave Cylinders
- Reliability of stock clutch on NOS
- In the market for a ls7 clutch any specials?
- resurface flywheel?
- slave cylinder question
- new clutch recommendation??
- shifter install: found something odd under shifter
- T56 Shifter Swap
- is t56 weak
- Not coming out of gear
- opinions on L92 swap into A-body tremec or T56?
- What should do to ge this thing shifting better?
- rebuild the trany and clutch
- Hardly goes into ANY gear
- Clutch Install
- MGW Shifter Experience
- Eye Candy...faceplated T56
- Notchy shifts in 2nd & 3rd gear when car is cold what fluid sould i use
- raptor shift light
- Disable Clutch
- Quick Clutch Question
- Non-adjustable short throw shifters?
- Clutch Slave Cylinder hydrolic connection
- T56-m6
- Ram powergrip HD will it hold?
- Had TDP Stage 3 Installed Yesterday. Need Help!
- 6 speed tranny interchangeable?
- replacing clutch
- clutch wont disengage
- Intermittent Clutch Disengagement Issues
- shiping time from monster
- Transmission swap
- Problem: Having issue installing tranny
- Info and experience spec twin, WILL IT HOLD?
- Which Flywheel?
- Viperspec T56 Question
- Loss of clutch pedal
- t56 custom rebuild
- 98 s10 t5
- how to tell 6 spd b&m ripper shifter
- Im ready to purchase an ls7 clutch with flywheel. whos got the best deal?
- how long to pedal feels right? and one other question
- T56
- Clutch problem
- used flywheel
- New Clutch Suggestions
- ???~m6 to th400 why or why not~???
- Slave line wont go back in..........
- spec pressure plate Question
- Quick Time bellhousing install directions?
- Need some help, should be a simple fix....
- new clutch? RAM HD?
- Monster stage 3.5 clutch SLIPPING!
- problem after trans rebuild and clutch install
- can a ls1 t56 be made to fit onto a lt1?
- Quick Troublshoot please...
- Trans Mount
- Transmission
- When will the monster dual disk clutches be available?
- Possible to do the Drill Mod without removing Master Cylinder?
- help (pics inside)
- Using Mityvac
- chalk another one up to monster
- Going in gear without stepping on clutch pedal
- t56 skip shift and reverse lockout
- Clutch buyin help
- T56 whirring noise in 5th and 6th
- Clutch problems
- Clutch Problem?
- Race Pedals?
- Removing Master Cylinder
- Plastic clip on master/slave line
- What do i need for a rebuild?
- SSR Fbody T56 hybrid project (1000hp on stock parts?)
- help with clutch disk and preasure plate
- Clutch Hydraulic Fluid Recommendation?
- Hurst shifter on a SS
- Car is falling out of third gear
- will my tranny break if.........
- 10% off all RPM Transmissions and Differentials
- adjustable master cylinder
- throw out bearing??? slave and ls7 clutch install
- Which clutch for my application?
- ... tranny help plz
- 300m ops
- Got my KY clutch kit in.
- tranny mount...
- clutch noise in a WS6
- Guide pin head broken
- LT1 T56 questions
- Lt1 t56
- is this a good deal?
- removing pedals
- converting from A4 to M6
- skip shift???
- Help!! on transmission and clutch installation LT1 T56
- Changing fluid in a higher mileage T56 with gear grind
- Trans rebuild gear question/help
- should i go with the ls7 clutch?
- Hard to get in reverse
- can i custom make remote bleeder valve at local parts store?
- Identify these T56 sensors for me, please!
- A4 to M6
- Shifter and bleeder questions
- Shifter is shaking??? PLEASE HELP
- Tranny Rebuild
- Ram 7.25 Twin Disc Clutch
- 93-02 Hurst Competition Plus
- Ripper shifter stop screws do I need them?
- 6 speed
- MUSTS of a T56 rebuild?
- Swaping T56 LT tailshaft on to t56 LS unit
- All T56's Created Equal?
- 4th gear spit out...
- tick clutch package deal
- master cylinder location
- 1999 Corvette reverse went out.
- Hurts shifters on all SS??
- clutch disk hitting p.p. bolts?????? help!!
- LT1 slave cylinder?
- master cylinders
- need some help on shimming or making an adj master
- Correct dowel pins?
- A new way to bleed our clutch fluid....
- Keisler T56 Front shift relocation kit
- Stock gear question
- Newb bump stop question
- Ordered my Monster Stage 3 today!!!
- Different Gear ratios
- Which LS1 Flywheel bolts/mcleod RST twin
- slight grind
- Odd sound. Help?
- driveshaft question
- Transmission grind after clutch install
- Dowel through flywheel into crank?
- Best daily driver short throw.
- Tranny help!!! bad input shaft bearing?
- T56 on the bench
- Reverse Lockout
- what fluid goes into a manual transmission
