View Full Version : Manual Transmission
- Master Cylinder Swap Issue
- I need magnum parts
- 2001 WS6 Clutch help!
- Used spec stage 3 clutch any good?
- Tick master cylinder adjustment
- who has teh sweet black friday deal on t56?
- Winter Sale 2015: $150 Off ANY Tick Performance T56 or TR-6060 Transmission Rebuild!
- To clutch or not? T56......Any clutches for sale?
- Help me solve my problem the 1st time!
- T-56 hard to shift plz help
- LS7 clutch kit information
- T56 Bellhousing for a camaro LS1
- Nv3500 to 5.3
- T56 problems
- Gears not going in!!
- Textralia Triple disc Slave Cylinder questions
- Interest in a gen 1 sbc to ls1 t56 adapter?
- Cts-v t56 questions
- Fidanza Qwik-Rev Clutch Kit Problem
- Help me identify T56 parts, Viper Second? Carbon blocker rings?
- For Sale: ONE Tick Performance Level 1 Rebuilt T56 Transmission, No Core Required!
- t56 to transfer case.
- failing master cylinder or..?
- Making your own master cylinder
- Lt1 to ls1 t56 swap. Any known shops in Sflorida
- Pro 5.0 vs stock hurst with short stick
- Does your Mcleod flywheel have centering dowels?
- Clutch measurement
- How to wire speed sensor to aftermarket speedometer
- Tick master from zo6 on fbody?
- 5th gen shifter question
- Slipping clutch?
- Lt1 t56 clutch on ls1 t56?
- MG9 high torque tr6060
- Pressure Plate for Collins Adapter (CD009)
- Aftermarket T56 gears
- Which clutch and flywheel? LS2 swap into ls1 car
- T56 leak not sure where from pics!!
- Where to buy chromoly viper slip yoke?
- Trans Mount to T-56 Torque?
- Pneumatic Paddle Shifter for H pattern gearbox
- Monster Clutch Halloween sale!!!
- Help choosing clutch, and a few more T56 questions
- stick shift bouce/wobble over bumps
- has anyone mismatch different brand disk and monster clutch?
- My car keeps eating a4's should convert to m6?
- Bad master or slave or....?
- What the heck am I looking at?! *video*
- t56 with 1/4 aluminum mid plate.
- Having problems bleeding the clutch
- M6 conversion questions
- Buying a t56 donor car
- Need sone opinions lol
- T56 noise, rattle, grind (video)
- Need help locating clutch fork for 97 Camaro
- Trans guys, what's wrong with this?
- LT1 T56 worth $600?
- Most reliable & light stock feeling clutch for 700rwhp?
- mystery noise
- IMPORTANT T-56 Need-to-know!
- clutch/flywheel advice for roll racing?
- t56 or clutch issue
- at wit's end with t56 reverse issue
- Anyone know where to buy the slave disconnect fitting? Or have one around?
- what is a tr6060 worth
- What did I do?!!
- Bang for the buck lightweight clutch setup
- LS1 T56 input shaft dimensions
- 6 speed tranny power limits/when to rebuild?
- SSR t56 main shaft
- T56 clutch adjustment tips
- 97 Trans Am LT1/T56 Grinds in reverse after clutch replacement
- looks like a new bellhousing too!
- 2002 SS Clutch replacement and Mech
- Rsg magnum or liberty magnum?
- Monster Stg 3 cheaper than stage 2???
- Questions regarding T56 parts.
- clutch slipping on dyno?
- BMW DCT Gearbox
- 2000 Camaro T56 M6
- Swapping a 5 speed Tremec in 78 corvette with LS?
- Let's talk about lightweight clutch/Flywheel combo's
- Clutch Leak/Crap in Bell Housing
- going rate for complete t56 setup
- auto to stick
- Major headaches bleeding clutch
- T56 Magnum XL
- Carbed 5.3 with t56 install questions
- Anyone ever tried this clutch?
- Trying to choose...Monster or Mcleod twin disk..
- T56 Magnum. What ratios?
- LS swap 71 nova Hydraulic clutch problem
- Clutch advice
- ok, I know you get this a lot but I need experience T56
- What clutch is everyone using?
- Folks that had/have the "CNC" style McLeod Master
- b&m
- New Hinson Motorsports F-Body Short Throw Shifter - Now Available
- LS3/LS7 clutch disc thickness?
- Broken RXT?
- clutch air gap..
- URGENT! NEED Help Diagnosing t56 Noise
- C5 with transmisison/clutch issues...
- Clutch for SS Sedan 6MT
- Ls newb
- Locked out of 2nd and 3rd until car is turned off?
- Monster stg 1 vs 2 - can't decide which to get
- quicktime bellhousing
- Does YOUR Clutch Setup need a Shim from Tick
- Dissapointed with McLeod RST & Tick Master Combo
- SPEC clutches great customer service!!
- t56 tapered bearings
- Need Help McLeod RXT Clutch disengagement issue - Need Helpful Advise
- Monster and Rpm doing work again!! 8.33@168.5
- BEcause I need a couple specific things.. I'm coming here.
- Advise from you guys would be great on choosing a trans
- T56 hard to shift hard
- proform shifter?
- Best stock type master.
- Cold Clutch Slip??
- Tried much, still cant pull 5th/6th cluster
- Tick master chatter?
- Need help / input asap plz tilton 75-875u install 99 camaro
- Clutch Slipping. Finally got hydraulics worked out, now this...
- Removing Bearing Races T56
- Tick Speed Bleeder Install Question
- Powerglide or Th400
- Hydraulic Bleeding Nightmare, Help...
- T56 fluid
- Clutch for 1000 hp turbo car?
- Converting CTSV T56 to GTO problems
- Losing hydro fluid. Tick master. Is slave leaking?
- Can I adjust my Monster stage 2 clutch??
- New Hinson Motorsports C6 & C7 Short Throw Shifters - Now Available & Ready To Ship
- Differences in Factory Replacement Slave cylinders
- T56 hard to get in gear and also moving forward with clutch in???
- 1st/2nd T56 Grinding Noise
- transmission mount nut
- Tick clutch master install problem
- clutch master cylinder mounting flange
- T56 input shaft bearing issues
- GTO Shifter Block
- Faceplated t56?
- Strange issue with m6
- LT1 to LS1 T56 conversion
- 00 WS6 Clutch pedal flapping around
- Viper t56 to 5.3
- About to install LS7 Clutch with Tick MC
- Corvette T56 Main Shaft Options
- My t56 is screwed
- Clutch just stopped working out of ideas.
- Thoughts on this problem
- Manual transmissions
- Seems I can't get the countershaft extension out.
- Parts in GM powered Monster Miata
- Dual disc clutch+flywheel weight
- ideas for an in-car "do you need a slave shim" measuring tool
- t56 conversion
- Clutch options for LS/nv3500?
- Buying donor for t56 swap?
- T-56 front plate
- A4 needs to GO!
- Mantic clutch disengagement issues
- Shifting issues T56 2000 Camaro SS
- C6 Guys Check Out The NEW HINSON Short Throw Coming Your Way From Hinson Motorsports
- New Hinson Short Throw Shifter Putting In A Little Work On The Track - Video Inside
- M12 T56 Clarification
- 2002 Camaro clutch reservior source?
- Pilot Bearing Welded to crank?
- clutch pedal adjustment rod???
- T56 question
- Acceptable vs Unaccptable Wear on Gear Clutch/Dog Teeth?
- Clutch going bad after just 15,000 miles?
- Abnormal rattling noise when foot off clutch
- 1999 t56 Hydraulic Issue
- LS1 clutch bleeding problems
- Tr3650 question
- Textralia Exo-Skel.....rebuild
- Go to brands for pressure plates?
- Monster clutches has horrible customer service
- Rebuilt T56, New Monster Stage 2 Won't Release Completely
- broken gear and sloppy 5-6 cluster
- Is my 98 T56 worth rebuilding?
- LS6 clutch kit + slave cylinder / thow out bearing install
- 2010 Camaro Hurst Knob & Boot in 4th Gen Z28
- Trans fluid smell only while driving?
- Rebuilding T-56
- >>>>>>>>>NEW C5 Short Throw Shifter Now Available From Hinson Motorsports<<<<<<<<<
- Got a couple t56 questions
- Question about drill mod please help!!
- Slave cylinder questions
- MGW Shifter - High effort and slightly notchy
- What is so wrong with stock 6-speed shifter?
- Mgw problems
- ***ATTENTION LS1 OWNERS*** Be Warned!!!
- SynchroRev Match for F-Bodies?
- CTS-V t56 on its way out, whos a good reputable builder?
- T56 Tailhousing Replacement
- rattle when when clutch pedal is depressed
- A4 to M6 Conversion help needed badly!
- Monster błeeder won't seal help
- Clutch Wont Disengage.. opinions?
- '66 Mustang LS1 T-56 Clutch Insanity
- Rotating Output shaft with Driveshaft = Weird Noise
- Clunk when shifting
- T56 All of a Sudden Will Not Disengage
- Reverse Lockout Questions
- c5 t56 shift rail
- Performance Transmission Mounts for Your 04-06 GTO Are Now Available @ Hinson
- Weird Clutch problem. Please Help!
- Help T56 Magnum
- Adjusting the tick master
- Shimming the slave cylinder Question
- Not sure what i damaged on my T-56, any quality shops in south florida?
- Issues with stage 1 monster clutch.
- clutch torsional damper life vibrations drive shaft rear axle S60
- Mcleod RXT Install - Help before i damage something
- Ran T56 a quart+ low, damage?
- Did I completely screw up my T-56?
- LS 3/Muncie 4sp, Corvette
- Mcleod 260571 series 500 disc for LS1 clutch?
- Unknown springs during tick mc install
- Installing a TR6060 aftermarket shifter on a CTS-V T56 magnum
- New clutch: no reverse when engine running?
- T56 Rebuild or Tranzilla
- ssr main shaft on c5 t56 question..
- anyone use a spec 2+
- rev up car with clutch in and it moves...
- Name that part
- Monster Clutch Install Instructions & Slave????
- Which T56 is Best
- '99 Trans Am clutch vibration, need help
- Ideas for shifter knob (drag racing)
- What short shifter with leverage?
- Slight grind in all gears
- Anyone use a Spec stage 1 ?
- T56 Fluid Pump Installed
- Resistance for T56 reverse lockout solenoid?
- Clutch life monster
- Textralia 0z700 installation help......
- Lost in a new clutch, need help!
- Shifter Stuck in 3rd gear?!?!?!
- t56 speed sensor
- Can I switch fluids?
- tr6060 slave adaptor?
- HINSON Motorsports GTO Transmission Mount Update
- McLeod RXT or Monster LT1-SC
- Need helo monster lt1-sc slipling
- 99 camaro t56 slave?
- bleeding this damn clutch!
