PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. clutch grinding on takeoff
  2. Best Budget Clutch?
  3. Seal transmission case
  4. Clutch Sticking To Floor
  5. Customers in TN, AL, MS, KY Are you okay after the storms?
  6. Installed McLeod RXT twin... new vibration
  7. LT1 Bleeder valve location?
  8. Tranny Question???
  9. Clutch Smell?
  10. Brand new clutch problem
  11. i think my clutch is goin out,
  12. clutch problems?
  13. new clutch problem
  14. Ram Powergrip(Non-Hd)
  15. Problem Shifting at WOT
  16. Who is running an ls7 clutch with a 500whp car?
  17. Silver Base b&m Shifter
  18. centerforce steel flywheel what the most i can turn down
  19. main/output shaft question
  20. messed up clutch
  21. help with clutch problems
  22. HELP! Cannot understand clutch problem
  23. reverse is messed up?
  24. why is a rebuilt t56 for a gto more money
  25. track times with an m12
  26. lost a couple of bolts...need some help
  27. Clutch Overheat?
  28. A4 to M6 and M6 to A4
  29. tranny noise...
  30. Tips for hillbilly tranny removal...
  31. T56 swap help
  32. lots of grinding
  33. May be clutch time...
  34. Does anyone know anything about button clutch material?
  35. Synthic in the driveline...
  36. transmission Question????
  37. pilot bearing pics
  38. Is a T56 compatable with my truck?
  39. 4l60E to T-56 Conversion?????
  40. use cereal box for gasket?
  41. Quicktime bellhousing.
  42. replacing clutch reservoir hose with fuel line?
  43. C6 Shift Knob
  44. spec 3 just installed
  45. tex clutch
  46. Clutch pedal noise?
  47. where can I.......
  48. How Do I Beef Up The T-56?
  49. just rebuilt mcleod MC. Pedal problem
  50. Where do you shift your bolt-on cars?
  51. What have we here?..
  52. Major vibration thru the shifter @ high speeds
  53. SFI Bellhousing
  54. How to keep the shifter stick from loosening?
  55. junkyard score of the century
  56. what shifter should i use?
  57. Pilot bearing/bushing
  58. centerforce clutch and LS2 flywheel
  59. Rookie question about custom shifter postions
  60. Good job Spec
  61. Is it really woth 1200 dollars??
  62. need speedo help
  63. is my flywheel messed up?
  64. 2nd Gear slightly "bumps" when I shift
  65. How can I increase shifting speed?
  66. where to get 01-02 hydraulics from
  67. Wtf???
  68. Leaking trans fluid, but only when on an incline...
  69. February's Six Speeds Inc. Trivia Game
  70. How do I know if I need a Slave Master Cylinder??
  71. F/s Spec Ii Aluminium Flywheel
  72. Spec 3+ Problem Please Help !!
  73. Shim Removal?
  74. LS1 F body vs vette flywheel/clutch
  75. Is bogging bad?
  76. manal swap
  77. What Now?...Help?!
  78. 6-speed shifter pattern
  79. Which one
  80. Centerforce Dual Friction Problem, HELP!!
  81. t56 with a sbc?
  82. Self Adjusting PP?..
  83. Spec 3+ part number?
  84. can i build up the T56?
  85. Problems!
  86. Z06 tranny question
  87. TRANS or DRIVETRAIN NOISE
  88. need to know exactly what hydros to upgrade
  89. WTF: My Tranny grinds!!!!
  90. Oz700 Z-grip and Synchromesh Review pt 2
  91. Another stupid trans Q
  92. Shim on flywheel spec 3 +
  93. bleeding from slave cylinder?
  94. GTO Clutch vs F-Body Clutch. Whats the diff??
  95. Textralia or LS7?
  96. Clutch master cylinder
  97. Clutch Bleeding Pricing?
  98. Stock Shifter??..
  99. T56 vs. M12
  100. Clutch switch help
  101. replacing clutch
  102. LS7 clutch, need it in hand by Wednesday...
  103. Video 8.93@153
  104. Question about ARP bolts on clutch/flywheel
  105. Did I screw up my Spec Stage 2 clutch?
  106. Replacing clutch in my c5!
  107. Shifting into 2nd
  108. Six Speeds Inc. has New WORLD RECORD 1st M6 T56 in the 8's 8.935@153!!!!!
  109. Wet Clutch Question?
  110. At what point did GM stop selling the old Slave and MC?
  111. Your thoughts
  112. downshifting on the highway question
  113. Textralia clutch
  114. Textralia EXO-SKEL Dual Disk
  115. Sticking gears
  116. Is my stock shifter a Hurst?
  117. A weird sound
  118. Anyone got a good way to get a tight shiftknob off?
  119. drill mod ???
  120. what a jackass
  121. Please Help. Track Problems
  122. throwout bearing upgrade?
  123. another stupid pilot bearing question...
  124. Viper T-56 in my '04 Silverado
  125. Short Stick gone wrong?
  126. Are camaro and vette transmissions the same?
  127. Trany Mount for LT1 and LS1 the same?
  128. Changed Hydraulic Fluid.
  129. Tranny Grinding
  130. Need Help 5-6 Driven Gear Removal
  131. M6 fluid change questions
  132. Clutch/Shifter Swap at 21k miles....
  133. Guys that have made the a4 to m6 swap
  134. Grinding in 1st?
  135. part numbers ?
  136. What else do I need? :O
  137. T56 swap
  138. ls2 to t56 transmission conversion
  139. Aftermarket T56 on an LSx?
  140. Just ordered my new tranny from Sixspeeds Inc
  141. ls7 clutch on a ls1
  142. I Need A T-56
  143. Time for new clutch?
  144. TO bearing/ Slave failure pics
  145. how to keep a tranny
  146. tell me what shifter i have
  147. 1993 fbodies had a different 6speed trans...
  148. WTF did I do wrong????
  149. I think I need to get a rebuild....
  150. 2004 z06 clutch issues
  151. M6 LT-1 to LS1 conversion
  152. fs or trade need lt1 t56
  153. T-56 from GTO???
  154. LS7 Clutch Swap
  155. spec 3 help
  156. What clutch for N20?
  157. t-56 with ls7 clutch problems
  158. C.A.T. Power Engine Parts
  159. ls2 flywheel
  160. Slave clyinder bolts
  161. how do you guys get into first gear?
  162. Wiring question for T-56 plugs????Please HELP
  163. Shifter cup differences GTO/F-Body
  164. Problems Shifting Gears
  165. 2 Step
  166. 2005 GTO Clutch ?s
  167. M6 Grinding?
  168. flywheel resurfacing Q
  169. Will the stock clutch hold????
  170. newbee t56 question
  171. what clutch for cam only car?
  172. engine to bellhousing plate?
  173. Knob on WS6Store short stick
  174. Clutch engagement issues...
  175. Part #'s for LS7 clutch & flywheel, best place to buy?
  176. What all needs to be changed when installing new clutch?
  177. noobie t56 question
  178. Prothane tranny mount mod
  179. Can I put this in a 96 T/A
  180. Silverado T56 swap, anyone out there?
  181. help i need a part number
  182. What twin dsk clutch setup?
  183. Why does clutch feel different at WOT?
  184. CAGS block off plug
  185. which clutch to buy? suggestions...
  186. reverse selonoid/ tran PICs
  187. clutch break in
  188. LG shift knob.
  189. new zr1 clutch compatibility???
  190. Tranny questions
  191. LSX motor and LT1 trans
  192. T56 Rebuild Question
  193. Serious clutch issues, need help
  194. how far have you pushed your stock T-56?
  195. question about torq arm
  196. *Guys in the Georgia area looking for a rebuild on their T-56!*
  197. any 408 guys with m6's running the stock 10 bolt on the street?
  198. 04 Z06 clutch problem..
  199. How much more fun would you say a M6 is over an A4
  200. "How to" for Drill mod??
  201. Vacuum bleeding the Clutch hydraulics, question
  202. Auto to manual trans swap?
  203. McLeod RST/RSX twin discs
  204. Slave cylinder?? Help!!
  205. Who Has A Centerforce Dual Friction Clutch?? (12")
  206. Noobie to manual transmissions
  207. is this a clutch problem?
  208. Ls7 Clutch Video
  209. spec stage 1 install/break in
  210. No revers...
  211. difference in hursts?
  212. auto or manual
  213. LS7 Clutch Install
  214. At what point is viper input shaft needed?
  215. clutch to handle 450rwhp + occassional N2O
  216. Hard reverse after head/cam.Why??
  217. Short and Sweet.
  218. Ls7 clutch, will it hold for me?
  219. Converting a LT1 T56 Tranny to Mate To A LS1.
  220. Removing transmission,..
  221. where can i get a stock flywheel????
  222. hard to put in reverse, shifter problem?
  223. Clutch Experts Help!!!!!
  224. LS7 Clutch Question
  225. ? about LS2 Flywheel
  226. Help me figure out what is wrong with my car v clutch hydrolics problem PICS!
  227. Problem Installing Tranny
  228. LS7 clutch/LS2 flywheel combo?
  229. gto m6 vs f body m6
  230. textralia question
  231. stiff reverse or speedo
  232. shifting problems at WOT!
  233. I am not sure if I should do it??????
  234. LS Block with a Tremec 600??? Where to start??
  235. LS7 Clutch Swap Problems
  236. Textralia Oz700 Z-grip Review
  237. Ram HDX
  238. compatability of new zr1 clutch in fbody?
  239. Leak in rear of T56...?
  240. which clutch?
  241. Question On Spec 3 + Clutch Please Help
  242. still having clutch problems
  243. need some help guys
  244. Need help with LT1 T56 info
  245. Worn Clutch or MS or SC..?? Help please!!
  246. Street Twin
  247. problems with new mcleod MC!!
  248. LS2 slave cylinder question
  249. M6 bolt-on cars. Post your times please.
  250. Sloppy Hurst Shifter ?
