PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137
  1. lightwieght flywheel feedback
  2. sticking pedal, could it be the master?
  3. Clutch Slipping? New to M6! Fairly Long...
  4. slave cyl probs
  5. T56 issues
  6. fixed the sticking pedal
  7. torque specs for slave cylinder
  8. Poll on Clutch Master Cylinders
  9. spec2
  10. Shifter problems, Can't they go bad???
  11. brake light switch pops out!?? m6 conversion
  12. What tranny fluid for a T56?
  13. trans swap
  14. What is a used T-56 worth with hydraulics included?
  15. twin disk owners look here
  16. PLEASE READ if you are planning on installing a Ram Twin Disc
  17. Help Please! Skip Shift Eliminator Problems!
  18. Trouble to sixth.
  19. Flywheel and Clutch bolts
  20. New clutch problems
  21. anyone with a ls7 clutch using a lightweight flywheel ??
  22. DIY flywheel balancing - possible?
  23. help!! what went wrong
  24. clutch?
  25. Some one help me!!!
  26. doing a rebuild myself, what do I need
  27. Update
  28. where can i get a spec3 shim?
  29. trans/clutch problems
  30. Anyone else have issues with ARP flywheel bolts?
  31. stock clutch.
  32. Fake Textralia?
  33. Attn: Trans experts and assemblers
  34. Problem with Trans/Clutch help!!
  35. Is my drive shaft too short? Look at pic.
  36. Just ordered!
  37. Lots of noise through Hurst Billet Plus
  38. stock flywheel thickness
  39. LS7 Clutch kit Question Please help!
  40. Clutch pedal doesn't come back up all the way... here's a new one for you...
  41. Do I have to resurface flywheel/change bolts when changing clutch?
  42. Clutch pedal just falls to the floor
  43. question
  44. Textralia Flywheel Question
  45. Clutch Install...
  46. What is the weight of a McLeod Street Twin?
  47. transmission winding noise at high rpms
  48. Six Speeds Inc. 1 week unbelievable special
  49. How much life is left on this clutch?
  50. New Clutch
  51. The synchros in my T-56 would like to extend a special thanks to Ranger
  52. Weird sounds in First Gear...
  53. LS7 clutch review
  54. Transmission Swap problem.. no indicator lights??
  55. recommended clutch
  56. Hurst shifter, will this work? same/different?
  57. Clutch noise, BOOM no clutch, HELP
  58. Suggestions on Skip Shift Eliminator, which one to buy?
  59. has anyone broken their slave cylinder??? what can cause this
  60. Getting new clutch! Imputs on Cartek
  61. When buying a clutch, Should you buy a Lightweight Flywheel as well?
  62. Should I Install a New Master and Slave
  63. What clutch to get? Street driving?
  64. Initial Impression of Spec 4 clutch
  65. Went to the track, Clutch is slipping, 1.75 60 ft.
  66. Hard to go in gear
  67. Weird things are happening here :|
  68. New Clutch/Master wont disenguage
  69. TQ Arm Relocation Bracket?
  70. Bad Clutch?
  71. DOT 5 fluid for your clutch???
  72. Problem with swapping transmissions wiring... ASAP
  73. 2nd gear syncro?
  74. ?'s about the t56 swap
  75. Mcleod dual clutch..Flywheel won't fit over crank
  76. Trans install problem need help!
  77. Pilot bearing disintegrated while using the proper puller....
  78. Bolt size for slave to tranny???
  79. Spec 3+ vs. Textralia OZ700
  80. another spec horror story?
  81. spec 2/ hydraulic problems
  82. Spec stage 3 noise
  83. Throughout bearing?
  84. Single, Double, Triple plated clutch?
  85. New carquest slave cylinder
  86. m6 pops out of 4th gear on soft shifts????
  87. Textralia Exo Skel Chatter
  88. knocking sound, wtf
  89. will 6 speed trans out of a cts-v fit on fbody
  90. Clutch slipping after swap to LQ9
  91. Issues
  92. leaky t5
  93. help with location of place to make clutch or cylynder bleed
  94. Stock flywheel weight?
  95. clutch for 550+ whp on spray
  96. looking for the disconnect tool for slave cylinder
  97. LS7 clutch and ls2 flywheel
  98. Console Parts
  99. Finished m6 conversion, Tips to downshift
  100. What Clutch for 650rwhp?
  101. Replace Slave Cylindar?
  102. LSX Shootout in Memphis what should we bring to show. Opinions Needed.
  103. no BS feedback on the pro 5.0
  104. Just installed LS7 Clutch
  105. twin disk install
  106. Spec clutch problems
  107. Six Speeds Inc. Might close early today and tomorrow due to weather
  108. Finally, everything is working perfectly !!!
  109. Does an Ls1 crankshaft have a dowel?
  110. Connecting Hydraulics w/ trans. mounted
  111. ARP Flywheel bolt question - torque, oil, and loctite
  112. ls7 fly wheel
  113. Yes ANOTHER shifter poll but only two options...
  114. Clutch hydralics... wtf?
  115. PRo 5.0
  116. clutch slips at random times
  117. Anyone heard of "BULLY" clutches? better than Spec?
  118. t56 problems
  119. Clutch fork wont install!
  120. just installed stage 3
  121. Textralia OZ700 Write Up
  122. Spec 2+ more than one shim?
  123. just wondering
  124. Help! I think I may have injured my tranny!!
  125. Ls7 clutch adjustment
  126. Quick Disconnect??
  127. LS7 clutch won't disengage
  128. Bad slave?
  129. SPEC 3+ after 18 month of street driving
  130. flywheel bolts
  131. LS7 clutch purchase question
  132. t56
  133. Bleeding help ASAP!
  134. changed transmition from auto to manual
  135. Worth the price???(clutch, ebay)
  136. aliminium propeller shaft,/flywheel
  137. Textralia Carbon Kevlar
  138. Rebuilding Transmission
  139. Differences Between T-56's... F-body vs. Cobra vs. Viper
  140. seriously WTF????????????
  141. pilot bearing removal
  142. Clutch disengaging problem
  143. Clutch bleeding tool
  144. 2002 corvette transmission help
  145. Reverse Gear Help
  146. breaking point of stock input/ output shaft?
  147. trans question
  148. anyone have an opinion on the new mcleod rst/ rxt?
  149. Spec vs GM LS7 Clutch
  150. LT1 T-56 clutch installed won't disengage
  151. Tranny is on it's way out, help me order parts for tranny and whatever else
  152. Clutch pedal problems?
  153. Help with new T56 install
  154. Just bought stage 1
  155. HELP...Clutch master cylinder won't bleed
  156. brand new spec stage 3+ having problems please help.
  157. '97 Corvette LS1, will a firebird/camaro transmission bolt up?
  158. Buying a TWIN DISK...which Brand?
  159. Strange wear on my clutch after 3800 miles
  160. Centerforce Clutch problems?
  161. *Search is Jacked* Need bolt size...
  162. LS7 clutch and Aluminum flywheel F-Body owners
  163. what the hell
  164. Kinda worried about a rebuild aspect
  165. What to do?
  166. can I buy this seal for the clutch master cylinder line
  167. Fidanza Ring gear loose
  168. I need the clutch Master Cylinder O-Ring
  169. Problem with bleeding clutch, Unique situation, experts inside.
  170. Viper T-56 Conversion "Write UP"
  171. Carbon Fiber Driveshafts
  172. Disengagement issue? step inside
  173. Pops out of sixth gear.
  174. Rattling going on
  175. just intalled ls6 clutch, break in?
  176. bump stops
  177. What clucth for 558 rwhp!!!
  178. Lightest/strongest/best billet flywheel???
  179. Six speeds inc... my expierence. long...
  180. Few manual Questions doing the swap soon!! check my prices
  181. M6 Tranny Kits?
  182. AAMCO trashed my buddies fidonza flywheel. can it be saved
  183. where can I get shift blockoff plates?
  184. Power shifting, missing 3rd gear & the drill mod
  185. Driving a civic screwed up my stick shift skills
  186. LUK clutch????? is it worth it????
  187. The Reason Your Clutch Fluid Turns Black
  188. Searched, do you need shifter stops or not?
  189. What Clutch for 415 RWHP
  190. Balancing a flywheel and clutch
  191. CTS-V T-56 Shifting Problems
  192. 01 M6 Z-28 doesn't have aluminum driveshaft?
  193. Shifter problems please Help!!
  194. t56 wont bolt up to LQ9
  195. Missed 3rd, reverse lights on and stuck shifter...
  196. Help with custom driveshaft
  197. Mis-shift :(
  198. 1st gear issues
  199. SFI Bell Housing M6
  200. Need Help...Shifting problems...
  201. Thanks 6 Speeds Inc
  202. bleeding hyd. system
  203. Core Returns
  204. Need clutch install please help
  205. F1 flywheel
  206. spec stage 3+
  207. centerforce disc
  208. NEED QUICK..."Where to get clutch balanced in Houston???"
  209. Need T56
  210. acceptable radial play in output shaft..?
  211. Downshifting on decel: Why and how you should do it
  212. witch clutch?
  213. Clutch engagement issues
  214. Lubricant for solid bronze pilot bushing?
  215. Can Anyone Beat This?
  216. Ram street twin clutch
  217. car won't go into reverse?!?
  218. RAM Adjustable Master
  219. What do you think about my T56 gears - need replaced?
  220. Reverse Lockout Solenoid.
  221. Sudden clutch blow-up?
  222. Pedal sticks while idling???
  223. LUK "Pro Gold" series any good??
  224. 454/t56
  225. >>3rd gear problem!!!!!!!!!!!
  226. How long should i break in oz700?
  227. Hard to shift to Reverse!!! HELP!
  228. Who makes GM's clutches?
  229. Which flywheel should I buy???
  230. six speed INC
  231. pedal sticks
  232. Slave Question
  233. Install M6 Shifter In A 96 Ws6
  234. spec ???
  235. Help! Speed Sensor not working MPH wont work!
  236. no speedo, no reverse...wtf????
  237. Clutch Questions
  238. Need help with explanation of additional parts for ls7 clutch
  239. Help Please ! need GM part number for braided steel hydraulic line for my '99 LS1 T56
  240. C6 Z51 and C5Z tranny gear ratios
  241. What should I look for
  242. Where did 20 metal balls come from?
  243. Please help me pick the clutch for me!
  244. Textralia Clutch release problems...
  245. Will a 04 cobra t56 fit in a ls1 f-body
  246. Sudden clutch blow-up?
  247. What is the difference?
  248. Help! Textralia or LS7?
  249. The driver mod....where to find it?
  250. Quick review of Ram Dual Disc
