View Full Version : Manual Transmission
- Cartek Hydraulics???
- Softer clutch pedal with Mcleod Adj. Master
- Clutch?
- Who has the Fidanza Flywheel?
- Z06 Clutch Question
- Pics of trashed T56
- Clutch Delimma
- Time to pitch the M6
- clutch drill out
- MN6 or MM6?
- Having problems with Ram clutch, Tranny shop says it won't work HURRY!!
- Mcleod Rev-Lok II vs. RAM
- What plates to get, for a star clutch
- Cartek clutch fluid?
- Cartek messed up... help?
- Clutch Question
- Did I damage my shift fork or am I having synchro problems???
- Can't speedshift M6 after fluid swap!
- Spongy Clutch Pedal
- Checking my entire drivetrain front to back. (looking for vibration) pulley or clutch
- LT1-LT4 clutch disc difference???
- a3 vs m6
- Problem with Cartek Clutch not disengaging??
- Clutch install help
- Mcleod & Thunder Racing customer service
- M6 to A4- clutch pos. switch
- How to adjust the Mcleod Master?
- Help M6
- using stock master with Mcleod Twin Disk
- Weight for LS6 clutch assembly
- Destroyed T56 Tranny...
- Z06 Flywheel question
- Rate the RAM Sinetered iron clutch
- M6-4th gear sometimes feels blocked out - OK when release clutch and retry-diagnosis?
- Clutch question w/in please
- CLUTCH QUESTION
- an easy McLeod master?
- Clutch Break In -> Got on it a bit, did I mess up the clutch??
- Cartek or McLeod master cyl.?
- Which clutch?
- clutch problem.. wont go in gear!
- Paging anyone who shortened their PRO 5.0 shifter...
- clutch problems
- What type of fluid goes in a M6?
- new 02 Z06, 2000 miles....clutch stuck to floor on launch!!
- Major Clutch Decision...
- How to change M6 tranny fluid
- t56 rebuild kits
- Throwout bearing, Help please
- Is My Slave Cylinder Causing the Clutch to Slip?
- M6 tranny, besides GM??
- RAM or MCLEOD????
- What are the best clutches to put in a 4L60E
- slipping clutch
- Which clutch is better: Z06 or SLP?
- New Ram clutch is in. Sintered Iron baby!!!!!!!!!
- what are the signs of a slipping/failing clutch?
- Can't find reverse with Cartek clutch
- Clutch went to the floor and then came back up?
- Anyone know where to find used M6 parts?
- Pro 5.0 Question.....
- For those having problems with Mcleod Master Cylinder
- Irritating clutch problem
- Need clutch help
- T56 problems please Help.
- Can new flywheels be purchased?
- Z06 clutch in an SS??
- GM Posi Additive in a T56?
- Cartek Clutch Help..Pedal too high => Resolved
- Do the flywheels have to be balanced?
- Push clutch in while braking or leave it in gear?
- Ram Clutch slipping at torque peak, adjustment?
- T56 repair in Houston?
- M6 ticking sound from shifter 1st and 3rd gears
- Need help on T-56 needs rebuild or need a new one
- What kind of clutch guys?
- Change tranny fluid on M6??
- MCleod Adj. Master Cylinder
- Stock Clutch
- Ripper or Pro 5.0
- Pro 5.0 Problems... Little Help??
- aluminum flywheel ?
- Having problems with your M6 getting stuck in gear?
- LT1 T56 on an LS1?
- Aluminum flywheel guys...help me decide
- M6 cars, does ur tranny shake when shifting.
- Got some 'issues' with new RAM clutch setup. Help please...
- Cartek clutch....does everyone like it?
- Which clutch is best for 550rwhp+ ? Dealer isnt ....
- bought a Pro 5.0, some ??s though
- t56 experts , help me please.......
- McLeod Adjustabe/hyd troubleshooting
- POS M6 popping out of 3rd on DECELL!!
- T56 help needed.
- ZO6 CLUTCH
- Help in choosing a clutch
- Spec clutch gone...01 z06 and 288 slave in..one question?
- M6 Failure? Locked in 4th gear.
- Hydraulic Clutch Line
- M6 shifting issues....
- Will the drill mod help my slipping clutch?
- Life of stock clutch in 2000 T/A
- 12K miles and my clutch is is going, what to do?
- Problems with Ram clutch, step inside pleeeeaaaaseeeee
- clutch return spring broke again.....but there glass by my feet?
- M6er's, need part number for the plastic shifter socket
- Drill mod for Cartek adj master???
- Questions about clutch setup centered around RAM 6130 disk....
- My T56 is broke (12000 miles)...why put another one in if it's gonna keep breaking?
- broken clutch pedal spring
- whine in t-56
- Ok, stupid question re: Ram clutch in my C5
- need ram clutch info
- Clutch alignment????? (CarTek)
- 1/2 way thru clutch install
- Hurst/Pro 5.0/Kirban
- any pointers before installing a CARTEK clutch?
- Ram Clutch?
- Clutch
- Clutch on the Floor!!!!!!!!!!!!!!! Help! (please)
- 400 miles of break-in on the new clutch setup, enough mileage to start ripping gears?
- Clutch Line on 2001 Z28
- LS1 Clutch Experiances!!!! Please help!!
- I thought McLeod Single disk clutches had soft pedals??
- Should I do drill mod with Cartek master?
- Clutch Help....
- ? about Ram billet flywheels.....
- T-56 rear main seal
- What gears for a M6
- Ram Clutch Disk??
- What would be the CAUSE of my T56 going south?
- Which Clutch?? RAM or McLeod??
- centerforce dual friction clutch??
- Clutch Pedal Trouble................ :(
- Adjusting the Mcleod Master Cylinder
- caliper grinding
- D&D "Synchro kit" is not what I expected.
- [pics] My stock clutch's corpse
- Ram's reason we shouldn't be using stock flywheels!
- Can the factory clutch Hold this power ?? >>>
- Cartek Clutch had been broken after 900 mile
- Cartek clutch: What it looks like after 500miles
- HELP!!!! B&M Ripper shifter
- Should it take 2 hands of strength to shift into any gear with a brand new clutch?
- Is my clutch toasted?
- T56 repair manual?
- Turning a aluminum flywheel.....when does it become "under spec"?
- Rebuild kit for the T-56
- What Clutch?!?
- clutch question???
- Problems bleeding McLeod Adj. Master Cylinder...how do I do it???
- Clutch Install?
- T56 question
- Ram clutch just keeps on keepin on!!!!
- clutch question
- Clutch Pedal Issues
- ****Dealership doesn't know how bleed Mcleod adj. master cylinder...HELP!!!!!!*******
- flywheel resurfacing question
- Ram Clutch setup HELP SOON!!
- What is the best clutch??
- Light rust on new flywheel...Problem?
- T-56 Questions
- Ears on LS1 T56 crossmember?
- Best way to break in a new McLeod clutch and aluminum flywheel???
- clutch fluid reservoir
- Ram CLutch is in :)
- what gear is a gu6 in a 2002 camaro m6
- CLUTCH???
- No smoking section.....Help! Is my clutch toasted?
- clutch/hydrolics/tranny problem??
- how do i shorten the clutch throw on a t56?
- Pro 5.0 Noise????
- ’01/'02 M6 cars, what’s the deal with your stock clutch?
- Clutch Chatter
- M6 trany jumping out of reverse
- doing clutch install toaday....question
- M6 guys I need a little help....
- Ram Clutch questions(drilling out pressure plate)
- M-6 hard to shift (clutch or tranny)
- Has anyone changed tranny mounts? (M6)
- First Impression - Ram Cintered clutch
- Aluminum flywheel worth the $
- What's the 'drill out mod' on a M6 tranny?
- clutch disk choice??
- Quality of '01 and '02 clutches
- Cartek Clutch guys ? about engagement points
- M6 tranny question
- rookie clutch ?'s
- How long do I need to break in a new clutch for...or do I need to break it in at all?
- need a place to get a zo6 clutch and hydraulics at good price
- McLeod Street Twin Dual-Disk Clutch as a daily driver question.
- Clutch Hydrolic problems (long sry)
- 2001 stock M/C vs. McLeod adj M/C
- 98 M6 problems
- Does anyone recommend changing the T-56 trans fluid to synthetic right away?
- recall on clutch !
- I'm Bleeding my McLeod clutch need help please.
- Stronger...Built clutch or built 4L60e?
- Stronger...stock 4L60E or stock Clutch?
- SLP Billet Flywheel: good value?
- Clutch Hydraulic oil??? What brand to use?
- Opinions on aluminum flywheels
- Does your T56 leak any oil from the rear seal?
- what does everyones clutch pedal feel like? (aftermarket)
- PRO 5.0 SHIFHER?
- flywheel.
- Grinding fourth on downshift...Help!
- Adj. clutch master
- Question for M6 Guys with 4.10's and lots of HP
- omg- clutch chatter got WORSE!!!!!
- McLeod Slave unit come with T.O. bearing?
- Bleed the Hydraulic Clutch cylinder before installing it?
- 2001 Hydraulic Clutch cylinder..
- HARD LEAVE and M6?
- Safe to launch on ET's @ 1500-2k rpm Stock Rear M6??
- RAM GUYS! Clutch Disc??
- Swapping in T56- Need Checklist
- need # for west tech transmisson t56
- Clutch Engagement ?
- Clutch bench bleeding ?
- Avg install price for clutches
- Is Yank the only place offering conversion kits for M6 to an auto?
- Q on the Z06 clutch assy.
- SLP Clutch Vs. '02 Z06 clutch..
- HELP !!!Clutch sticks to floor.
- Why...Why...Why??!! (Grinding when down shifting to 3rd)
- Possible replacement tranny for T56....
- Cartek Clutch engaugement point changes on its own???
- Pulling the McLeod clutch!
- Drag radials and stock clutch..
- $1100 for parts and labor for stock clutch replace?!
- How to get a M6 a decent '60?
- Starr III isn't all that. What about the CARTEK
- Ram clutch owners come on in!
- Help me decide between Alum./Steel Flywheel!
- Which clutch to get?
- Whats been your experience with the Star III Clutch
- Clutch or Tranny?
- Anyone with Cartek clutch problems please come in!
- Cartek / McLeod "Hybrid" clutch....
- McLeod Adj. Master
- Cartek clutch install... missing something obvious here?
- CHP this Month, new Mcleod Steel Master?
- Missed a 2 to 3 shift...Bad synchro now?!?
- Cartek clutch I order...
- Which clutch to get, SPEC, Macleod, etc?
- Carbon drive shaft + light fly wheel = what RWHP?
- Paging Nineball. Need clutch recommendations.
- Anyone using McLeod Iron Disk?
- What upgrades and modifications are available for our M6 trannys?
