View Full Version : Manual Transmission
- First M6. Advice Needed On Shifting Issue
- on the crossroads
- New to the 2011 6 speed
- T56 to old school 2 pb rms engine
- Balancing flywheel and clutch
- Clutch goes to the floor....was fine just a few days ago
- Shifting problems
- T56 Hall Effect VSS
- lm7 manual transmission options help please
- Out with the stock clutch, in with a LT1-S Monster! (dyno results inside)
- Frustrated clutch problems!!!
- T56 mag vs. 4/5 spd Dogbox
- T56 cooler questions and quest
- T56 goes bad into gears when hot
- Tick speed bleeder won't fit new slave
- Two pilot bearings destroyed. Causes?
- 1000rwhp clutch advice
- shifting issue
- RPM speed t56 Short throw shifter
- Shop can't get parts for T56?
- Major MGW shifter install problem
- Which standard transmission to put in my ls1?
- Car won't start when i depress clutch pedal
- What Fluid Do Put In You T-56?
- Clutch suggestions
- Steel or aluminum flywheel
- Hinson Tick Master Cylinder?
- 2nd gear back order
- 3rd and 4th grind after fluid change
- Monster Clutch is the shit!!!! period, hands down the best clutch
- howling after going into 2nd at 90mph
- Richmond 4+1 too much hassel/cost?
- Trying to diagnose my T56
- clutch master cylinder
- sticky clutch pedal
- 01 T56 possible master cylinder issue With video.
- TR6060 1/2 blocker ring question
- Getting rid of the tri-flange?
- random issues...sticking in gear, grinding
- exedy clutch kit
- Best Trans mount?
- Rebuilt T56 Break in?
- Slipping clutch, but clutch looks fine
- clutch upgrade for a ls1
- LS9 clutch in 2007 C6 with Tilton slave..slave/PP gap issues
- LT1 T56 issue
- LS1 Camaro T56 input shaft
- clutch goes out when trans gets hot
- A4-M6 Conversion coming soon.....
- Is this a good rebuilt kit? Tremec Level 2
- Weird shifting inconsistencies
- monster clutch testimonies.
- T-56 Will Not Shift Into Even Gears
- T56 Magnum, 12" clutch, and Quicktime bellhousing?
- 6th gear install query
- T56 pilot bearing disaster
- T56 rebuild recommendations.......
- Sudden, random loss of clutch pressure
- 93 LT1 vs 94-97 LT1 T56 difference?
- Really odd issue when bleeding Tick master
- CobraBob's Shifter Gaskets!!
- Monster Clutch Co. Aluminum Flywheel
- spec aluminum flywheel
- Clutch and/or Mount issues?
- Miles on your clutch
- Best video for T56 removal + dissasembly?
- Anybody Do An American Powertrain Conversion
- shifting issue after new clutch
- Need a viper t56 main shaft
- speed sensor help please!
- Too much shim?
- T56 Bleeding Technique
- T56 upgrades
- Working on my car and it was wet at the back of the tranny
- GM P/N T56 output shaft seal?
- Installing new monster clutch
- MGW Flat Stick shifter question.
- Strange noise, sounds like a grind in or out of gear randomly... WTF?
- Just bought a T56 Magnum...where to get tob guide tube?
- Will wiring LNC-2000 this way turn rpm limit on at beginning or end of pedal
- Spec St2 clutch smoked at 30k?
- Quick question a4 to m6 swap
- AJE LS to Foxbody Swap K Member Users
- what shift light does everyone run?
- best nitrous clutch after the McLeod rxt
- Clutch identification
- only 1-4 gears work 5,6 and reverse dont engage
- Think its time for a new clutch...
- Questions for guys using 2 step as a "no lift shift"
- pressure plate problems
- Magnum t56 and slip yoke question/ concern
- LT1/T56 clutch change
- CTS T56 in a C10
- LSA & TR-6060: clutch & bell ?'s
- Stripped T56 trans bracket to body
- tick performance master cylinder vs stock??? Do I really need the tick one?
- T56 into a Foxbody
- Clutch slave shim advise
- Finding parts for a T56 rebuild, why so tough?
- Need some help with my clutch problem
- 2000 z28 clutch issues... need help!
- Bad master, or hurt trans..what do you think?
- 6speed shift points
- t56 mainshaft
- Tick master installed clutch sticking
- T56 sticking in gear during hi revs. Help!
- grinding gears
- grinding gears
- LT1 T56 Clutch Problems
- Tick master cylinder is this for C5 or GTO
- Clutch issues....
- TRADE! My gmTKO600 for a GOOD T56
- t56 vibration with clutch depressed
- Pressure plate
- clutch questions 00 camaro
- Clutch master stiffness
- Burning up Stage 1 montster clutch in stock LS1 SS first night at the track :(
- Shifter Knobs
- Diamond Clutch
- Quicktime 8020 and GM LSA clutch
- front/shifter vibes on accel and moves to the back on decel
- New PP and flywheel bolts?
- Mcleod RST
- Lt1 T-56 to Ls1
- Tick clutch master adjustment
- Sachs NFW1050 Flywheel bolts
- What would be a good asking price for my broken T56 and related parts?
- 2001 camaro wont shift at high rpms or stuck in gear
- Where to have t56 rebuilt in SW missouri/nw arkansas
- hurst classic look angled short stick??
- 98 trans am trans issues
- Monster Flywheel 28lb after 5k miles
- t56 magnum/monster 11 inch review
- my faceplated T56 build
- Looking for advice on repairing (t56 c5z)
- Help! Trouble going into gear and shifting
- Swap any other transmission instead of T56?
- I NEED a t5 bellhousing
- Blown T56 or Blown Clutch?? in my LPE 02 SS
- LS7 pilot bearing to small
- trouble going into gears
- strange clunking when shifting.
- t56 fluid change intervals
- Ls7 clutch on ls1. Questions about fidanza part number and other components
- Adjusting clutch
- c5 t56 reverse lock out not working
- 2000 Camaro SS M6
- M6 grinding/roaring when shifting.
- Which AMSOIL for the T56?
- Help me identify these shifters! (pics)
- tag deciphering
- Mcleod RXT engagement question.
- Question about clutch engagement
- t56 alignment trouble
- How do I adjust the McLeod/Wilwood clutch master cyl??
- shifter ?
- 5th gear vibration in shifter
- Any guess on what I broke?
- dont know what noise this is?
- Won't go into gear
- Dropping the tranny.
- broke trans t56 need your opinions
- ls1 clutch set up in an ls2
- Spec ST-trim Super Twin experience
- Tick Performance Relocation Bleeder Valve
- SixSpeedsInc T56 possible issue....
- Nv3500
- Would you use this clutch disk? (Shipping damage)
- Mcleod 33lb clutch assembly review
- Tr6060 help
- Flywheel MPG
- t56 fitment question
- Faceplating
- Cannot get hydraulic line back into T56
- Clutch not disengaging?
- Slip yoke leaking???
- GTO 6.0 t56 vs. Fbody t56 (Clutch/Flywheel Question)
- Pressure plate torque specs
- which 31 spline yoke for t56 magnum
- pilot bearing problems
- 5.3 + TR6060 = what kind of clutch?
- bolt-on cam/gear no2... top of 3rd it pulles its self out of gear... scary!
- Lost 5th gear? wtf
- Mobil 1 or synchromesh
- ctsv tick rebuild help
- ARP Pressure plate bolt torque specs
- new engine- new clutch problems..help!!!
- Transmission Bolt lengths
- More Clutch Recommendations
- GTO T56 and F body master cylinder
- Need help
- 3200 stall, hd-2, 30k Trans cooler, billet servos. Cam ls1/100shot😳
- Speed bleeder line
- Clutch recomendations
- Help on quote for T56 Rebuild
- blue99fbody sets M6 reacord again!
- Short throw shifter install
- Issues with Quarter Master twin install
- input shaft end play
- where to find billet slip yoke?
- New shift knob fitment issues
- pedal popped nothing at all now?- OK slave EXPLODED bleeding an empty system?
- Question on Clutch Pedal
- spec 3+ vs monster 2
- Tko 500 behind a ls1
- no clutch please help!!!!!
- t6060 or t56?
- Clutch disengagement sanity check
- Reverse Shim problem
- What short throw shifter to get?
- Problem with braided clutch line after drill mod
- extremely sticky clutch - easy way to bleed clutch?
- Perfect pedal going in the garage, nothing coming out...
- LS7 Clutch
- need help!!
- F-body to GTO shifter swap help
- Sticking Clutch Pedal
- high speed vibration and pedal issues
- Company to build my trans
- Lou's short stick or the hurst short stick and knob
- T56 issues
- Should I be worried?
- CTS V Tail housing
- camaro ss noisy transmission
- Looking to get a rebuild kit from Tick for a t56 couple of questions?
- Air? Shim? Syncros?
- Auto to t56
- Reasonable cost for swap RPM's TR6060 in automatic ls3 vette
- pressure plate bolts??
- T-56 assembly
- SSR mainshafts out of stock everywhere?
- T56 won't go in 2nd at low rpm
- 8020 quicktime bell housing question
- Clutch Master Cylinder Rod
- t56 spedo question
- Question about Sachs 1050 flywheel?
- Cannot line up Tick mc for the life of me
- Anyone using the D&D viper mainshaft?
- How screwed am I?
- t56 on its way out?
- Can someone shed light on this tremec PN TNET-1077
- T-56 1-6 Gear ratios?
- LS Bellhousing Question
- T56 1st gear shift fork pad trouble.. HELP!!
- Yet another 1-2 shift problem....
- Line from master will not click into slave
- keep missing 4th when romping on it
- T56...how much power?!
- Whirling sound
- 1st time clutch install, so far so good...
