View Full Version : Manual Transmission
- Adjusting Pro 5.0 Shifter
- 99 bellhousing same as 98?
- Clutch replacement - Rear seal part nbr?
- New clutch and hyd. question
- installing my clutch saturday....finally.
- Clutch question
- is it true?
- flywheel bolts, pp bolts part #s
- Whats the best shifter?
- mityvac???
- Ram PowerGrip HD 2 go in next week!
- Angled Short Stick...Benefits?
- Missing bolts in T-56?
- 200mph overlays ??
- Mcleod master cylinder engagement point???
- No skip shift light and clutch prob
- Blown Tranny???
- Help?????????
- Mcleod master problems ideas?
- Clutch Pedal Sticks
- once you did the drill mod was you clutch easyer to push in and out?????
- Clutch on the way out???
- More Hydraulic Problems
- Pros and Cons: Angled vs. Straight
- chooseing the right clutch for my car?
- Drill Mod Without New Master
- Only my knuckles are bleeding.....
- Ok Need Clutch Help for My Cam Only Car
- Z06 clutch sticking??? WTF!!!!!
- Looking to swap t5 into ls1 fbody-need bellhousing bolt pattern info + more
- How much for a rebuilt transmission?
- Grinding 2-3 ?
- Pro 5.0 hard to shift into reverse
- Please see if I need nething else...?!?
- synco problem?
- 3rd gear powershift.....no one home!
- New clutch in- Hard to get into reverse
- Help! Best way to ship a T56
- Clutch pedal play...
- Jumping out of Third Gear?
- Trans rebuild bearing question
- 4 to 3 downshift wont go at high RPM
- Liberty's gears been slow for anyone else?
- HP limits on the stock T-56
- Update on my newly installed Spec V
- Tranny and clutch <inside>
- Reverse.
- No lift shift mechanism
- Difference Between Stock Hurst and aftermarket?
- Slipping Clutch? Broken Tranny? What the Hell!
- Emergency!! Need Help Asap!
- G-force T56
- flywheel ?
- new here, but doing a t56 swap into 86 iroc... any tips?
- clutch slipping/pedal sticking
- Filling new master and slave vs. bleeding:
- Search not working: Mcleod M/C bolt question:
- Help Trannys Busted?
- Some newb downshifting ????
- Help, new to M6s have ????
- The new aussi clutch, a Q about power.
- Master stuck on Pedal
- Transmission weight?
- Tranny Build
- Ram Clutches Back in Stock!
- Fill T56 with tranny fluid via shifter area?
- Help with shifter???????come on in
- Torque specs on driveshaft bolts?
- Cags Eliminator Connector
- tranny install help!!!!
- What resistor for !cags?
- Am I the only person ....
- No Reverse
- question about flywheel and PP
- Newbie has clutch ?/potential prob.
- *looking for a good clutch for my new setup*
- need in put on which clutch to run with my new setup
- Great clutch pressure, new master and slave, clutch will not release, very strange.
- flywheel dowel pin
- Expert M6 rebuilders - please help me out
- Shifter noises?
- Has anyone else seen this clutch?
- Shifting trouble, need a little info....
- Time to replace the clutch
- Grinding From First To Second When Cold......
- Does my T56 have issues or are these symptoms considered "normal"?
- How heavy is the pedal feel on your Spec V?
- bleeding nightmare
- Can't remove stock shifter handle - cover just rotates
- will a spec 3 clutch disc work in my stock clutch?
- Stock hurst losing recentering capability??
- Opinions from those with experience?
- clutch upgrade
- McCleod Master / Ram Cltuch / resurfaced flywheel... just for your info.
- need opinions.
- Clutch squeaking
- alright....got a question..need answers ASAP please
- grinding from 1st to 2nd at high rpm shift
- what replacement master cylinder used?
- Problems With Tranny, Help!!!!!
- Anyone with a Mcleod Adj Master????
- Lt1 6 speed part needed!
- Mcloeds new clutch lines
- Question about drill mod?? come on in if you have done it!!!
- master cyclynder
- Keep missing 2nd!!
- m6 swap now vibration !
- Need Clutch Help ASAP...
- i need help....
- Help Is Clutch Disc Good?
- I need help!!! Clutch problems!!
- Pressure Problems!
- Swap PCMs?
- Textralia clutch vs. Ram 6130
- Spec stage 3 clutch
- Confusing problem with my M6
- [Q] heat insulation of the master cyl. connect line
- pro 5.0
- Second gear is shot
- [Q] part num for clutch actuator switch
- [Q] adjustible RAM master cyl. Cannot fit
- New Sponsor! Textralia clutches
- Best shift light
- urgh...frusterated
- who has the best t-56 rebuild kit
- POLL: What aftermarket clutch do you have?
- *Sale* TTP Stage 3 Built A-K T-56 Trans.
- hard to get into reverse?
- Which Clutch to go with???????
- M6 guys... what tranny fluid you use??
- Double clutching???
- clutch not engaging after install
- Help! Did I fry my clutch?
- 99 A4 car swap with 98 M6
- McLeod Adj MC, adj pedal height or bleed some more?
- t56 tranny rebuild kits
- grinding occasionally. do i need the drill mod
- Tips with launching
- Ram 910 Leftovers Pics inside :)
- Do I need to bleed???
- Reverse always pops out
- Needed: braided master cylinder line
- M6 Conversion - Console ?
- Best place to buy a spec clutch ?
- Spec????? help
- i have a 2001 ta...do i need a new throw out bearing?
- Clutch Fluid Black !!!
- Need Part#'s T56 parts
- Type of GM Synchromesh fluid.... 2 kinds?!?! Manual and Auto quarts?!?!
- how to change a slave cylender
- Spec stage 3 or Ram level 3 or 4 Powergrip clutch??
- Is this O.K. for breaking in a clutch?
- Vibration in clutch & shifter
- performance clutch
- Slave Cylinder Question
- best short stick
- Help!!!!!!!!!!!!!!!!!!!!!!!!
- experience advice needed
- slp short throw
- Clutch Install Help/Advice...
- get rid of hurst????
- t56 making a nasty sound
- trouble with 4th
- M6 Shift skip mod for $2
- M6 shift skip mod for about $2
- Missing third
- Starting problems and clutch switch
- Clutch pedal still sticking to the floor?????
- Will an LS1 M6 go into a LT1?
- Destroyed pilot bearing in 300-400 miles?
- Tranny Problems
- Mityvac Clutch Bleed How To
- Hydro Problem.....
- Ram clutch?? wtf????
- Has anyone had spec 4 problems?
- What can break on a stock clutch?
- what place makes the most bullet proof t56s?
- Clutch install this weekend....no pressure to pedal..help plz
- Spec III noises
- Anyone used the Ram Salve cylinder?
- McLeod Clutches (Rev-Lok, Kevlar/Organic)
- Clutch Pedal Vibration :(
- Spec Stage 3i vs Centerforce Stage 3
- Rebuilding a clutch
- I need help FAST!!! Torque arm mount bolt size.
- Zero balancing a clutch.
- Flywheel help
- In the middle of rebuild. A couple of questions
- Another noob question.
- Shim clutch or slave?
- Z06 cluch???
- New code problem
- whining sound in 1-4 gear..99 SS 6 spd
- Immediate answer needed, but dumb quesiton
- 01-02 slave & throw out bearing
- centerforce dual fric or spec stage 2
- need some clutch advice
- Is this a better way to bleed hydraulics?
- Need help with a problem. PLEASE.
- skip shift resistor
- Exedy Twin (Save your money)
- Should I toss it????
- Tick/click noise under dash while driving..goes away when clutched
- possible hydros acting up?
- What Gear Oil Should I Use??
- are the throwout bearing and slave one piece on are cars?
- Anyone have Mcleod Throw Out Bearing?
- Need transmission advice?
- Pro 5.0 Stick Loose
- Need a part #
- problem ??!!
- Another Drill Mod complete
- Any advantages to using a synth. clutch fluid?
- Ideal clutch brake-in?
- Changing clutch... drop tranny & bellhousing??
- Help Guys!!
- cluch ??
- Spec stage 4?
- M6 fluid choices...
- Hurst Question
- Short throw handle
- Anyone have RAM Powergrip Level3 clutch?
- Help!
- Turning the flywheel?????
- Can swapping a 96 m6 tranny into a 98 ls1 be done?
- Drill Mod seal?
- What else????
- Spec 5 clutch problem....
- OK wtf
- Spec stg. 2 blasted chatter !!
- Life EXPECTANCY????
- T56 heating up bad, what do i do?
- Tilton Hydraulic Release Bearing
- Mcleod/Ram adj. Masters....
- Do all clutch slaves have the same connection?
- Viper Spec vs. normal T56
- Need Help Asap!!
- What years need slave cylinder upgrade?
- Gimme some luv guys.
- Chirping 4th gear
- M6 running hot?
- Hurst Billet Plus Shifter
- getting a z06 clutch, a few hydraulics questions
- Master cylinder U stud
- Mcleod clutch acting weird
- Just blew up my RAM 910 what clutch is next?
- Shifter
- autoparts store master cylinders
- Updated GM hydraulics from LS1Speed, INC.
