View Full Version : Suspension & Brakes
- How good are ZO6 brakes?
- Lowered car today
- Hit curb, huge positive camber
- adj TQ arm and reloc brakets fight each other?
- found out a neato thing today...
- Brake Booster Question
- Question for the road racers/autocrossers
- Anyone know p/n for this line from MC to ABS block?
- Anyone got installed pics of the G2 4-Point Roll Bar
- any one try ssbc brakes
- How often should you realistically bleed your brakes?
- Back Order-Baer Eradispeed Disk Brake Rotors
- Low dust pads that still stop
- Whats the big difference between Brands? Hype?
- Stock suspension, negative camber - Any tricks?
- Destroyed Sway bar bushings?
- BMR bolt on relocation bracket install
- Anybody use Lakewood Traction Action Lift Bars?
- Eibach Sportlines Auto X ?
- Looking for recommendations installing suspension kit
- Adj koni yellows?
- Wolfe Torque Arm and Subframe Connectors....
- Sub Frame Connectors
- will ABS still work with a 28" tire???
- How to on replacing springs?
- anyone know where to find individual rear lowering springs?
- GM part #s for 98-02 1LE front and rear swaybars?
- Where to jack car after K member
- SFC Installers in TN?
- Do I have a 4 channel or 3 channel ABS??
- stock K member and engine mounts
- LCA's or Panhard Installed wrong
- line lock...
- bmr or lg?
- Pics of T/A with cut springs? *DELETED*
- Indicator lights after slicks and skinnies..?
- brakes
- help, shocks for pro kit
- squeaking on take off
- Put a pin hole in the upper ball joint grommet....
- DMS springs
- Front Lower Ball Joint Thread
- Hal owners, do you really need the drag spring?
- Alignment issues Question
- Power Steering Fluid
- What do you think of this complete suspension upgrade?
- Where do I get front strut spring perch?
- Ground Control Coilover Spring Rate
- Shock bolt torque specs?
- Anyone here use KYB AGX?
- Bilstein BTS
- funny noise from behind
- g2 sway bars vs bmr sway bars
- Help me Identify my SS's package...
- Very loud Creaking from Rear over bumps
- Front End Alignment question & Specs > within
- Dont know what brakes to use on 9 inch
- extended 15% off sale, most G2 suspension/chassis parts
- Which shocks to use?
- Can you remove a spacer from the stock rims?
- SLP suspension kit 70001 or Prokit and Bilsteins, Koni's ect
- What do i need
- Need pics of BMR upper a arms installed
- which one, poly/poly or rubber/poly
- want to get rid of wheel hop?
- Clunking noise from underneath...please help!
- need help?
- Any ideas?
- Bolt On Subframe Connectors Questions
- M6 hookin up post
- moroso rear trick springs
- replace vacuum booster with hydro-booster?
- Ride Height Adjuster or Air RIde Shocks
- Which Springs would U use???
- Lightest/strongest/most effective 2 point weld-in SFCs?
- Best Eibach set up to get for my car??
- 60 ft times on a bone stock LS-1 vert
- SFC Install price?
- LG Z06 brake conversion
- Whirring sound with Eradispeeds?
- Weld on SFC's is it a DIY project?
- Pirelli DOT radials?
- Too much Loctite?
- Rear Lowering springs
- Creaking noise, front LCA area
- Will swapping from LT1 to LS1 control arms, work for an LT1?
- Installing front springs
- Building traction Whats the biggest help for the buck.
- Spohn tubular chromoly SFCs, anyone compare to these?
- anyone with G2 parts? how long did the ship take?
- can i swap z06 brakes and rotors on my camaro?
- Need advice on what to get....adj.PHR , Hotchkis, and LCA's
- How would I know if I had air in my brake system?
- Name this tune.
- brake job
- SLP SFC's (weld-on)
- PHB adjusting question
- Torque arm setting and panhard for strip???
- Holden Commodore VT vs. VX
- Comments on BMR Adjustable Panhard
- Need input on LGMotorsports G2 Torque Arm...
- Whats the word on Roto Tech rotors?
- Where can I get some non-squeaky rear brake pads?
- how to install wheel studs
- Prothane front swaybar endlinks question
- 1" drop wanted, Which Springs?
- Best street /strip torque arm?
- Anyone used any upgraded brake lines?
- Can the SLP bilstein struts be rebuilt?
- BMR lca?
- Prospeed motorsport delays?
- SLP Bolt-On SFC Install
- drag shocks on the street?
- hal coil over ok for street?
- Wheel Bearings?
- Shock settings for lauching at the strip?
- relocating the lower PHB bracket 1" lower throw it off???
- 1 side lower than the other?
- how do you get 430 rwhp to stick to the ground
- Putting My Firebird on a Diet
- Gains from Hal Adj?
- Bleeding brakes question.....
- I recommend getting Brembo rotors
- Autozone rotors OK.
- Is my suspension optimal for drag racing?
- Need part number for PHR support bracket
- What switch did you use for your line lock?
- Budget brake system
- anything wrong with running different brakes front and rear
- help with rear wheel hop on take off
- I need help with my suspension setup?
- Where to start with new suspension
- Does the spanner wrench really work??
- 2-pt vs. 3-pt SFC's
- Got G2 order in, have rod end question
- will 3rd gen sportline springs fit a fourth gen?
- Difference between bilstein hd and slp bilstein?
- Koni shocks and what springs? suspension/chassis in general
- Weird Noise When Braking
- Pinon angle?
- Update on KYB AGX shocks.
- recaro seat for pass. side...now i need brackets..
- Need help ASAP! Ordering torque arm today, which one?
- ASR switchology
- Front wheels are way forward after k member/a arm install
- BMR K-member motor mounts
- Pics of camaros w/ sportline springs
- What shocks to go with sportline springs?
- Has anyone fabbed up their own SFCs?
- brake problems????
- I need stock PHB dimensions....
- LT1 vs LS1 Pro Kit?
- Does my Bilstein suspension hurt launches?
- New suspension is done! (need help!)
- Installing a tubular K-member how hard?
- What do ya'll think of the BMR Trak Pak?
- coil-cover shocks
- Disadvantage to removing rear upper-spring insulators?
- removing sway bar on car with lowering springs?
- Global West's Del-A-Lum Bushings
- New forum sponsor! Stainless Steel Brakes Corp.
- Anyone running SLP level I suspension kit?
- Calling all with K-member, A-arm setup...
- Drag front suspension help
- Alignment
- Installed KYB AGX shocks today.
- steering wander/drift
- bolt-in vs. weld in sfc's?
- G2 torque arm
- Where do you buy your stock replacment brake pads?
- Horrible Wheel Hop...Help...
- relocation brackets for a moser 12 bolt
- Bilstein BTS-7501
- Got my BMR stuff on this weekend
- Eibach Guys .....I need some info
- new hals wont exstend
- bmr lca relocation brackets
- little help with suspension mods
- Adjustable Coil-Overs!!!
- No spanner wrench... any other way to adjust HAL height??
- Just installed Hal/QA1's and something just isn't right.
- front brake options????????????????????
- suspension upgrade??
- coil-overs
- BMR xtreme duty torque arm install?
- Madman LS1 motor mounts
- Those with G2 Coil-Over Kit, how are daily driving habits?
- Curious about SS swaybar size...
- REMOVE REAR SWAY BARS FOR THE TRACKS?
- Sportline and G2 Super Spring users inside
- Urgent Question
- After Market Engine Cradle\Kmem. and A arms any negitives?
- New Suspension in
- Spohn vs. BMR Xtreme torque arm
- Just put on the Competition Engineering SFC's, and now noise
- Need a non-stock location torque arm for 200R-4 conversion?
- Creaking noise when turning
- Best Rear Springs for Drag Racing...?
- My eibach prokit isn't low enough from the front end. help!!
- best suspension
- Need Spring/Shock Help
- Need review on what I'm doing, street/strip daily driver sus
- FLP LTs and SLP sub frames???
- Terrible banging from G2 LCAs? *DELETED*
- DMS springs just keep gettin lower
- How often do you lube your aftermarket bushings?
- Lowered car- 1/2" variance between front left/right side?
- ATTN: G2 LCA buyers/installers *DELETED*
- And so it begins....
- How can I tell if my ABS Module is going bad?
- Edelbrock Coilovers?
- Anyone with Baer EradiSpeed OEM 2pc Feedback?
- What gains with aftermarket Panhard Bar?
- Need LG subframe pics
- DMS springs and shocks
- How much should I pay for SFC install
- Aimco Extreme (Autozone) rotors!
- DIFFERENCE BETWEEN 2 BMR LCA?
- loud bang when i hit bumps
- Need some tips on front suspension.... out of ideas..
- CHEAPEST PLACE TO GET LCA?
- BMR swaybars installed and howto documented
- Handling of different Speed Rating...ZR vs. YR ?
- What do you think about Hotchkis springs
- Stock 2001 WS6 Springs
- How to get better aerodynamics for roadtrip?
- Suspension Techniques Springs
- Ideal street/strip suspension setup? not your average...
- At what mileage is it time to replace stock shocks/springs?
- Traction bars
- Thinking about SFC's... any difference?
- best suspension set up for drag racing?
- how long w/out swaybar?
- new spohn tq arm install
- 15% discount on all LGM/ G2 suspension/chassis parts
- Best place to purchase Bilstein HD's?
- Front Passenger Side Noise/HELP
- Need an installer for SFC's in New Orleans
- I hear a "pop" when speeding up/slowing down
- Wheelhop from different tire stiffness?
- My Revalved Bilstiens are finally on!
- BMR or Eibach Pro Kit springs???
- performance street pads?
- Are aftermarket brake systems really worth it?
- BMR Swaybars???
- Aimco or Aimco_Extreme
- Will 93-97 f-body rotors fit on a 98+ f-body?
- One more shock post...
- Baer or WillWood?
- SFCs and stock ground effects
