View Full Version : General Maintenance & Repairs
  1. Car breaks up bad under heavy load/high rpm!
  2. This noise is killing me, pop from rearend.
  3. LS1 performance problem
  4. Cat question
  5. Three-year rattle mystery: Solved!
  6. Gas milege drop hard!
  7. Hon DUH Cat on camaro.
  8. Car running a little warm.....
  9. P0131, whats next?
  10. My car is fluttering till 3k Then it hits, HELP!!
  11. Rod knock
  12. Seldom used LT1 won't turn over
  13. completely stumped on LT1 squeak
  14. allen screw head stripped on valley cover any suggestions...please
  15. side view mirror inside part..
  16. EGR Tube Seal
  17. Air Bubbles in Power Steering or?
  18. What causes a fuel gauge to go bad?
  19. gas coming out of exhaust
  20. Smog test NO levels rise suddenly?
  21. AC only though floor and defroster
  22. Cool air from one side of exhaust?
  23. Headlight motor
  24. Problem With Rear Air 01 Tahoe
  25. P0841 - fans wont come on with A/C
  26. Help Car won't pass smog because of DTC stored in PCM!
  27. PO300 Stumble
  28. Metal in oil, slight knock, and vibration - engine is toast, but what happened?
  29. A few small problems.
  30. Starting Issues
  31. Front side door lower hinge (93-02), LH
  32. Fog lights and switch don't work?
  33. Cly 8 is N/A on a ethos scan tool
  34. compression test?
  35. wont start, clicking, electrical surging, *new symptoms*
  36. Warm Starting Problem
  37. Obd1
  38. 93 z28 wont start after electical surge
  39. Header clearance
  40. My AC makes a rattling noise when turned on.... What is it ?
  41. oil pressure low
  42. dash, airbags and column removal
  43. Radio controls and switches: (some) lights going out?
  44. Car just died, what happened??????
  45. AC Water leaking in car
  46. Vibration :(
  47. Need to know.... reluctor wheel placement?
  48. lq4 engine idle then dies
  49. Urgent help!
  50. School
  51. twelvevolt cigarette lighter, only works if gps plug is positioned perfectly
  52. 2000 5.3L EGR Question
  53. 2002 Camaro LS1 leaking Need suggestions
  54. Alternator Wire Help
  55. help with oil pressure issue
  56. Delay when starting
  57. Please Help
  58. 00 TA ac problem
  59. Battery harness
  60. High Idle After Hot Soak
  61. Radiator replacement
  62. Weird noise behind pedals 1995 Trans Am
  63. Fuel Pressure Help
  64. Car bogs at wot
  65. caprice 2002 ls1 ALTERNATOR overcharging!!!
  66. 12.5-12.9 volt reading?
  67. check guages light on for no apparent reason
  68. Steering Column / Ignition question?
  69. speedo reading low
  70. idler issue + first start whine
  71. Fog light / head light ???
  72. popping above 4k
  73. coolant question
  74. Dipstick tube broke
  75. LS2 Camaro stalling and backfiring at high rpm's
  76. wiring problems???
  77. New O2's not functioning properly?
  78. How do you remove Rearview Mirror
  79. Oil pressure sending unit??
  80. Turn signal stick does not return
  81. Clunky only when driving starting from 1st?
  82. reverse lights gone
  83. Clunking
  84. Could my window motor be just seized?
  85. high idle
  86. whats could be wrong?
  87. Gas pedal replacement
  88. Weird brake lights
  89. Weird blinking check engine light..
  90. omfg!! head gasket IN nj
  91. p/s leak after repair
  92. Bad Post-Cat O2 & Issues
  93. headlight motor grinding after closed
  94. Fuel Pressure - Troubleshooting
  95. Alternator pigtail from u pull it
  96. AC DELCO headlight motor part number help
  97. Rice sounding horn?
  98. Doors Won't Lock or Unlock
  99. Vibration at Low RPM's
  100. Gauge cluster goes out while driving
  101. Noise from dash when I just touch the accelerator pedal
  102. Rattling muffler heat shield
  103. Something just broke.....
  104. Stock Compression PSI
  105. Is this turn signal stalk missing a part?
  106. Help with bolt list
  107. Any step by step guides to new a/c install?
  108. Ideas how to get wiper pump back onto reservoir?
  109. Lights go dim
  110. Short cycling of A/C
  111. Bad Misfire issues, Please help!
  112. 99 Trans am clunk
  113. Belt Squeak on the main belt drive?!
  114. Loud Creaking Noise when Turning Left
  115. weird clunking sound in low rpms..
  116. Non Ls1 question, 91 Chevy Lumina
  117. leaky radiator
  118. fuel level sensor install
  119. A/C liquid/hard line replacement questions
  120. Interesting immediate change stop slam from TRANS 2005 SS Impala
  121. Alternator help
  122. Stray Electrical Harness for What?
  123. Traction control, abs inop, check engine, and brake light help
  124. Need One Plug Wire
  125. made some changes, made some new noises
  126. Help!!!
  127. Anti-Glare mirror
  128. Fuel Pump Going Out?
  129. what would cause o2 sensors to foul out?
  130. temp gauge issue?
  131. pic of ac lines on the passenger side???
  132. squeaky belt?
  133. Can I replace an ignition switch for an auto with one for a manual?
  134. Belt squeak sound after reaching operating temp.....
  135. Oil leak
  136. O2 sensor install
  137. DRL module
  138. '99 Z28 - A/C and Fan Control Panel Light
  139. Has anyone deleted the power steering cooler with success
  140. Car stalling, quitting, not starting,...SOLVED
  141. Drivers Door Sag?
  142. Car died/no start thread
  143. power steering pump
  144. what is this redlight for (not security light)
  145. window stops rooling upthen starts after relay cools down (98 firebird formula)
  146. A question about sound deadening/insulation.
  147. Where can I buy seat brackets/tracks/guides?
  148. spark plugs and wires
  149. Where are you guys buying OPSU's?
  150. 94 TA Headlights Wont Turn On?
  151. Disappearing antifreeze. Need suggestions.
  152. How to access TA fog lights?
  153. Oil leak! Oil pressure switch location?
  154. Where can I buy weat brackets?
  155. Lost manual..how many quarts of oil?
  156. How does coolant sensor come off?
  157. lighting question
  158. Can I recover my front seats myself? What are my factory replacement options??
  159. Coolant Blowing through the Overfill Tube
  160. Weird steam from the engine - 99 Camaro z28 - LS1
  161. Running Codes any advice please, can I fix these thigns myself
  162. HELP - Door handle does nothing
  163. (VID) High Voltage issue. Need help ASAP!
  164. Lt1 isn't running, about to get towed!!!
  165. Car drinks coolant and pees it out
  166. Boiling sound at radiator cap
  167. SERVICE ENGINE SOON light code#P1415
  168. Changing AC Compressor
  169. Backfires
  170. Need help
  171. Firebird Headlights - Why do you hate me?
  172. Arrrgh...can't figure out where this "clunk" is coming from
  173. any GM parts guys out there?
  174. Faster Steering Ratio
  175. name that sound
  176. pcv flow diection and oil consumption
  177. Interior slot part number
  178. LEAN at WOT and stumbles.
  179. help! over heating
  180. car wont lock with remote after battery died
  181. Quick 02 sensor question
  182. Long day gets ridiculous. Coolant issue, temp guage, help please
  183. Low oil sensor weirdness
  184. back up light problem
  185. Need Help with 1994 Silverado
  186. Seat Issue
  187. Need help fast!! Ls6 intake swap
  188. Could a loose ground have caused my battery to burn up?
  189. Car electrical system shutting on and off rapidly
  190. Brand New 383 random missfires and eating plus
  191. Help with hesitation
  192. LS1 Missing Need HELP!!! (video included)
  193. Lets play guess the wire :)
  194. AC Help
  195. Altenator Squeal (video)
  196. Top of intake covered in water?!?!?!
  197. Car randomly won't start
  198. Spuddering problem when accelerating
  199. Roll cage grommets
  200. how to adjust windshield wipers
  201. Front Vents Not Woring
  202. No-Start Annoyances
  203. New AC Compressor Noise
  204. HELP! Car is completely dead.
  205. Cruise control issue not engaging
  206. Car won't start
  207. Weatherstripping?
  208. Oil pressure sending unit electrical connections (on a 98)
  209. Serp belt still squeaks
  210. o2 sensors
  211. Crank but no action....
  212. intermittent window/radio power
  213. Windshield Wiperblade Size?
  214. Plug wire question
  215. Ip dimmer blows .
  216. Steering wheel vibration upon acceleration
  217. Quick! I've got wet o2's...ok to drive??
  218. maintenence on showroom SS stored for 10 years....
  219. 2000 Camaro SS smoking?
  220. door panels on trans am
  221. Window regulator
  222. Hood Struts
  223. Click, no start
  224. Why does my power steering groan?
  225. CPS reluctor
  226. TA DRL problem
  227. Headlight Level/Travel - Help
  228. 5w30 or 10w30?
  229. Which Radiator?
  230. Voltage Drop at WOT?
  231. Head light ???
  232. Dashboard Issues
  233. Clacking noise help!!!!!!!!
  234. can you fix windshield wiper wind deflector on camaros
  235. crankcase ventilation problems
  236. Fuel pump relay
  237. One of my T/A Fog Lights Isn't Working
  238. Loss of battery power / AC/Heater Blower
  239. 1999 Camaro SS fuel filter
  240. What else to replace when swapping transmission?
  241. 98 Firebird won't start
  242. Name that water leak!
  243. rattling after intake installation
  244. 1993-97 trunk latch
  245. Floor Jack Clearance 01 Camaro
  246. Recommended higher-milage maintennance
  247. Will these jackstands work?
  248. broken sensor?
  249. stuck fuel line
  250. HVAC control problem
