View Full Version : LT1-LT4 Modifications
- manifolds
- Tuning my car?
- What Should I Run!!
- Hollowing cats on 96-97 duel cat cars
- Fluid Change = More Hp
- Mods =horsepower
- Need Some Clutch Advice
- NEED HELP with LTCC!!!
- First race with LT'S {lt1vsls1}
- 98-02 style hood on a 97 TA
- Eaton
- cheaper timing chain and gears
- help dead cylinder!!!
- best ground clearance LT1 headers
- Cooling system questions...
- dry sump?
- catalyst failure bank 1
- Head bolt question
- help
- has anyone ever anodized there fuel rails?
- lt1 with ls1 parts
- Guys running the Milodon stroker notched oil pan (30909)
- Can you fit a Victor JR and Intake Elbow under stock hood?
- 1/4 mile time
- thinking about supercharging my LT1
- any guess on E.t's
- ???? Steering Rack
- Getting rid of everything need help !
- guess who has another lt1
- Were to get an LT4 Intake Manifold?
- need help
- TB bypass?
- Just wanted to say thanks!!!
- BBK 58mm Throttle Stop Screw Adjustment?
- valve adjustments?
- tsp rumbler installed
- LT1 Supercharger Issues - Need suggestions!
- Dual Exhaust
- Can't pull codes on my 94 formula?
- Who has the best prices on forged internals?
- LT1 block
- Another LT1 Rookie
- what would i run
- fuel pump may be going out.
- cam questions
- Map sensor forgot what that is?
- What results should I see {longtubes}?
- fuel pump?
- SES light and fans on high, runs fine?
- Problems Already?!
- M6 guys with stock 10 bolt and DRs, come inside
- fuel pump question
- Dyno wrong?!!!!
- Best stroker kit...?
- Knock
- Anybody got pictures of........
- 10's!!
- My New Setup
- roller rocker install write up???
- Gauging interest in a built T-56
- Borla Stainless Steel Adjustable Catback
- how do i dissasemble my lt1 water pump
- solid motor mounts
- Sluggish start-up
- LT4 HOTCAM spec qeustion!!!
- transmission
- Mod Time Soon!
- Lt1s with Port Pro Heads?
- Gm847
- Going on road trip tomorrow
- what size injectors?
- cam question?
- transmission
- transmission
- Gears
- More pics of my 8 sec LT1 buildup
- Look at this....
- HELP!!!!! 94 formula is being dumb.
- Question??
- 4 bolt main??
- Easy questions real quick
- need help......
- where to tap into for water,oil,trans temp
- Need help finding a set of LT1 backing plates
- Flowmaster Catback Crackly?
- Heads
- true duals???
- 98 Cobra wants to race...
- Has anyone had a 3:90 gear
- my tsp rumbler sounds like a truck
- Able to do true duals on an LT1
- Anyone have these parts laying around???
- LS1 Air Intake
- LT4 heads w/LT1 intake
- Tire/Rim Compatability? Help.
- Datalog of problem I'm having
- catch can
- Help Please
- Ignition Hassles
- Diagnostic Curiosity
- NEED OPINIONS and Preferences ON an LT1 cam selection HELP!!!!!!!!!!!
- LT1 final balance and new 3.750 crank issue
- Optispark question
- LOL who thinks this would actually work?
- need some help
- Opinions
- Does a 58mm trottle body help???
- Looking For 383 Lt1 Shortblock
- cam swap need help
- Adjusting TPS
- Hesitation problem!
- Help!!!!!!
- Stock clutch + 150-shot = ???
- lt1 firing order??
- You lose that much torque from a cutout?
- looking for the piece that goes from the throtle body to the mss air
- Finally working on talking friend into a cam for lt1
- SP w/ stock style TB, possible tunning issues
- all thread rods?
- Pacesetter header problems? Anyone experience this.
- Code 16 (low res opti code)
- Clutch is starting to slip.........
- Pushrods
- Block Boring
- Lt1 heads VS Vortec heads
- Andy(2fast97z)'s demolished lt1 motor(NOT 56k friendly)
- I want to mod my car as much as possible by this friday...
- offset rocker question
- need some troubleshooting help guys!!!!
- Nitrous and advance
- Best gear for 6-speed???
- AFR 180cc or LE3 208cc or AI 190cc
- Difference between the L98 and Lt1?
- will a stroked or bored LT1 w/STS turbo be california legal?
- 02 sensors on Ebay
- Banging when powerbraking or shifting 2nd
- Spring seats?
- Rocker Noise OR Exhaust leak?..
- LT1 head and cam install?
- Fel Pro Header Gaskets?
- speed-o way off
- stripped balancer threads?
- LT1 overheating
- Deepest exhaust
- help with my tranny
- swivel thermostat housing for lt1?
- Ceramic 1le elbows?
- Best header gaskets?
- Reading high knock count
- What do you guys think about this deal?
- any have any gains #'s from cc 503
- Need some help
- Code 21 TPS question
- Posi questions
- Its Cam Time
- 58mm Mono-Blade flows 1300 CFM. ANY GOOD?
- Some interesting info
- EGR plates
- Belt?
- Daily Driver Cam for 100 SHOT
- Just picked me up a '97 Trans AM
- Next??
- New to the F-Body World, Your help is needed...
- Weird Idle Problem
- any 93's out there
- LS1 exhaust on LT1
- are Holly Thorttle body any good
- Parting out camaro
- 4.10s killing my top end on A4!?!??!
- with these new mods what should i should run
- ? about upgrading rear brakes on my 94 T/A
- optispark
- well threw a rod last night
- headers for a 93?
- trans problem
- $5k to spend on new Engine. I need opinons.
- lt1 heads
- help please!!
- new time ok i guess
- Bleeding The coolent System?
- hooker ory
- AS&M TB
- Plug wire help please!!!
- TCI 3000 Stall, Any Good?
- need suggestions on lt1 header set up
- Best mini starter for $200 or under?
- Valve float
- SLP CAI issue
- drag times and stuff
- 396 for sale (340cfm heads, solid roller, single plane) NEW PRICE
- carb. conversion
- what does Gemini twin mean on nitrous
- how to do weight reduction
- what Fuel injectors
- $5 Bet track results. I am happy!
- 383 Up and running
- I think i'm going for some nitrous
- whats everyone gap their plugs at?
- Fastest Stock Internal LT1?
- '97 LT1 Formula Coolant Temp and Thermostats
- WTB- Pro Comp Ultra Lite 2 5/8 Oil Pressure Gauge
- What can i get on my Lt1 Trans am with $500
- LT1 Jeep conversion
- Real weird issue...
- Logging scanner
- Accel Optispark
- LS1 vs LT1 Exhaust
- What are ya guys running with bolt-ons only???
- Port the intake manifold with stock internals?
- Ported TB
- New Throttle Body
- How to turn over engine?
- Just Finished Polishing The Intake. Check It Out...
- Cheapest place for 918 Beehives?
- Deleting AC/AIR/EGR
- Help with driveability problems.
- pacesetter LT's
- What 3" E-Cutout..DMH, QTP, Mccord or other?
- street tire pressure
- my car died HELP!
- Should I remove my cat?
- 110mph speedometer on a Formula?
- Cam kit
- Camshafts???
- switched 12 volt source.
- How much does AC effect power?
- Stupid Question, about stock 1/4 mile times.
- How to do make your car NOT run rich?
- ltcc coil mount suggestions
- Ok. I found the source of the coolant leak.
- Zirgo Fans
- Who Should I talk to about a Custom Grind?
- Noise from engine
- Where to get the ram air box for the lt1
- 500rwhp
- Thought this was funny.........
- Fixed my intermittent fan problem!
- Need some help on gauges
- Smoke from exhaust after rev
- Optispark qustion?
- subfram con.
- optispark?
- Sorry I havent had internet
- LT4 knock module part #
- Mr Gasket Mls Head Gaskets
- Guys with 355ci setups, come in.
- Autometer Hook Up! Help Please!
- decisions
- How will it sound
- Lca
